dernière option que je connaisse.éditer le fichier connon_dr.
sudo xed /etc/sane.d/canon_dr.conf
# lide 200
usb 0x04a9 0x1905
dernière option que je connaisse.Code : Tout sélectionner
# lide 200
usb 0x04a9 0x1905
lsusb
sudo sane-find-scanner
scanimage -L
Bus 002 Device 005: ID 046d:09a4 Logitech, Inc. QuickCam E 3500
Bus 002 Device 004: ID 04a9:1905 Canon, Inc. CanoScan LiDE 200
Bus 002 Device 003: ID 04e8:3321 Samsung Electronics Co., Ltd
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 04d9:1400 Holtek Semiconductor, Inc. PS/2 keyboard + mouse controller
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
# No USB scanners found. If you expected something different, make sure that
# you have loaded a kernel driver for your USB host controller and have setup
# the USB system correctly. See man sane-usb for details.
# SANE has been built without libusb support. This may be a reason
# for not detecting USB scanners. Read README for more details.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
device `genesys:libusb:002:004' is a Canon LiDE 200 flatbed scanner
sudo apt-get install sane-utils
sudo sane-find-scanner -q
sudo add-apt-repository ppa:michael-gruz/canon-trunk
sudo apt-get update
sudo apt-get install cnijfilter-common
sudo apt-get install scangearmp-common
