cracotte@cracotte-bureau ~ $ ubuntu-drivers debug
=== log messages from detection ===
DEBUG:root:Driver package virtualbox-guest-x11-hwe is incompatible with current X.org server ABI xorg-video-abi-20
DEBUG:root:_get_db_name: output
ID_PCI_CLASS_FROM_DATABASE=Display controller
ID_PCI_SUBCLASS_FROM_DATABASE=VGA compatible controller
ID_PCI_INTERFACE_FROM_DATABASE=VGA controller
ID_VENDOR_FROM_DATABASE=NVIDIA Corporation
DEBUG:root:_get_db_name(/sys/devices/pci0000:00/0000:00:03.1/0000:0a:00.0, pci:v000010DEd00001C03sv00001458sd00003777bc03sc00i00): vendor "NVIDIA Corporation", model "None"
ID_PCI_CLASS_FROM_DATABASE=Network controller
ID_PCI_SUBCLASS_FROM_DATABASE=Network controller
ID_VENDOR_FROM_DATABASE=Broadcom Corporation
ID_MODEL_FROM_DATABASE=BCM4360 802.11ac Wireless Network Adapter
DEBUG:root:_get_db_name(/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.2/0000:04:07.0/0000:09:00.0, pci:v000014E4d000043A0sv00001043sd000085DFbc02sc80i00): vendor "Broadcom Corporation", model "BCM4360 802.11ac Wireless Network Adapter"
DEBUG:root:Loading custom detection plugin /usr/share/ubuntu-drivers-common/detect/arm-gles.py
DEBUG:root:plugin /usr/share/ubuntu-drivers-common/detect/arm-gles.py return value: None
DEBUG:root:Loading custom detection plugin /usr/share/ubuntu-drivers-common/detect/open-vm-dkms.py
DEBUG:root:plugin /usr/share/ubuntu-drivers-common/detect/open-vm-dkms.py return value: None
DEBUG:root:Loading custom detection plugin /usr/share/ubuntu-drivers-common/detect/sl-modem.py
DEBUG:root:plugin /usr/share/ubuntu-drivers-common/detect/sl-modem.py return value: None
DEBUG:root:Loading custom detection plugin /usr/share/ubuntu-drivers-common/detect/cpu-microcode.py
DEBUG:root:plugin /usr/share/ubuntu-drivers-common/detect/cpu-microcode.py return value: ['amd64-microcode']
=== modaliases in the system ===
pci:v000010DEd000010F1sv00001458sd00003777bc04sc03i00
input:b0003v04FCp05D8e0100-e0,1,4,11,14,k71,72,73,74,75,77,79,7A,7B,7C,7D,7E,7F,80,81,82,83,84,85,86,87,88,89,8A,8C,8E,96,98,9E,9F,A1,A3,A4,A5,A6,AD,B0,B1,B2,B3,B4,B7,B8,B9,BA,BB,BC,BD,BE,BF,C0,C1,C2,F0,ram4,l0,1,2,3,4,sfw
pci:v00001022d00001455sv00001022sd00001455bc13sc00i00
platform:regulatory
pci:v00001022d00001467sv00000000sd00000000bc06sc00i00
usb:v062Ap4101d0108dc00dsc00dp00ic03isc01ip02in01
acpi:PNP0303:PNP030B:
hid:b0003g0000v000004FCp000005D8
acpi:LNXCPU:
acpi:PNP0C0F:
acpi:PNP0500:
platform:microcode
input:b0000v0000p0000e0000-e0,5,kramlsfw4,
pci:v00001022d00001464sv00000000sd00000000bc06sc00i00
acpi:PNP0200:
pci:v00001022d0000145Asv00001022sd0000145Abc13sc00i00
pci:v000010ECd00008168sv00001458sd0000E000bc02sc00i00
acpi:AMDI0040:
pci:v00001022d00001456sv00001022sd00001456bc10sc80i00
pci:v00001022d00001463sv00000000sd00000000bc06sc00i00
acpi:PNP0C02:
platform:pcspkr
hdaudio:v10DE0084r00100100a01
input:b0000v0000p0000e0000-e0,5,kramlsfw6,8,
acpi:AMDI0030:AMDI0030:
pci:v00001022d00001461sv00000000sd00000000bc06sc00i00
pci:v00001022d00001450sv00001022sd00001450bc06sc00i00
input:b0003v062Ap4101e0110-e0,1,2,3,4,k71,72,73,74,77,80,82,83,85,86,87,88,89,8A,8B,8C,8E,8F,90,96,98,9B,9C,9E,9F,A1,A3,A4,A5,A6,A7,A8,A9,AB,AC,AD,AE,B0,B1,B2,B5,B6,CE,CF,D0,D1,D2,D4,D8,D9,DB,DF,E0,E1,E4,E7,E8,E9,EA,EB,F0,F1,F4,100,110,111,112,113,114,161,162,166,16A,16E,172,174,176,178,179,17A,17B,17C,17D,17F,180,182,183,185,188,189,18C,18D,18E,18F,190,191,192,193,195,197,198,199,19A,19C,1A0,1A1,1A2,1A3,1A4,1A5,1A6,1A7,1A8,1A9,1AA,1AB,1AC,1AD,1AE,1AF,1B0,1B1,1B7,1BA,240,241,242,243,244,245,246,250,251,260,261,262,263,264,265,r0,1,6,7,8,a20,28,29,2A,2B,2C,m4,lsfw
acpi:PNP0C01:
acpi:PNP0B00:
pci:v00001022d00001465sv00000000sd00000000bc06sc00i00
pci:v00001022d00007901sv00001458sd0000B002bc01sc06i01
pci:v00001022d00001452sv00000000sd00000000bc06sc00i00
input:b0000v0000p0000e0000-e0,5,kramlsfwD,
hid:b0003g0001v0000062Ap00004101
acpi:PNP0C08:
acpi:AMDIF030:AMDIF030:
wmi:05901221-D566-11D1-B2F0-00A0C9062910
pci:v00001022d00001466sv00000000sd00000000bc06sc00i00
acpi:PNP0800:
input:b0019v0000p0001e0000-e0,1,k74,ramlsfw
acpi:IFX0102:PNP0C31:
usb:v1D6Bp0003d0410dc09dsc00dp03ic09isc00ip00in00
platform:Fixed MDIO bus
acpi:PNP0000:
acpi:PNP0C14:
input:b0003v04FCp05D8e0100-e0,1,2,3,4,k71,72,73,74,77,80,82,83,85,86,87,88,89,8A,8B,8C,8E,8F,90,96,98,9B,9C,9E,9F,A1,A3,A4,A5,A6,A7,A8,A9,AB,AC,AD,AE,B0,B1,B2,B5,B6,CE,CF,D0,D1,D2,D4,D8,D9,DB,DF,E0,E1,E4,E7,E8,E9,EA,EB,F0,F1,F4,100,110,111,112,113,114,161,162,166,16A,16E,172,174,176,178,179,17A,17B,17C,17D,17F,180,182,183,185,188,189,18C,18D,18E,18F,190,191,192,193,195,197,198,199,19A,19C,1A0,1A1,1A2,1A3,1A4,1A5,1A6,1A7,1A8,1A9,1AA,1AB,1AC,1AD,1AE,1AF,1B0,1B1,1B7,1BA,240,241,242,243,244,245,246,250,251,260,261,262,263,264,265,r0,1,6,7,8,a20,m4,lsfw
pci:v00001022d0000790Esv00001458sd00005001bc06sc01i00
wmi:ABBC0F6A-8EA1-11D1-00A0-C90629100000
acpi:PNP0103:
usb:v04FCp05D8d0110dc00dsc00dp00ic03isc01ip01in00
pci:v00001022d00001457sv00001458sd0000A182bc04sc03i00
acpi:PNP0F03:PNP0F13:
pci:v00001022d00001462sv00000000sd00000000bc06sc00i00
input:b0003v062Ap4101e0110-e0,1,4,11,14,k71,72,73,74,75,77,79,7A,7B,7C,7D,7E,7F,80,81,82,83,84,85,86,87,88,89,8A,8C,8E,96,98,9E,9F,A1,A3,A4,A5,A6,AD,B0,B1,B2,B3,B4,B7,B8,B9,BA,BB,BC,BD,BE,BF,C0,C1,C2,F0,ram4,l0,1,2,sfw
acpi:AMDI0020:
acpi:PNP0A08:PNP0A03:
acpi:AMDI0010:
dmi:bvnAmericanMegatrendsInc.:bvrF4:bd04/07/2017:svnGigabyteTechnologyCo.,Ltd.:pnAB350-Gaming:pvrDefaultstring:rvnGigabyteTechnologyCo.,Ltd.:rnAB350-Gaming-CF:rvrx.x:cvnDefaultstring:ct3:cvrDefaultstring:
acpi:PNP0C0C:
usb:v04FCp05D8d0110dc00dsc00dp00ic03isc01ip02in01
hdaudio:v10EC0887r00100302a01
usb:v0BC2pA013d0100dc00dsc00dp00ic08isc06ip50in00
input:b0000v0000p0000e0000-e0,5,kramlsfw2,
acpi:PNP0501:
acpi:PNP0100:
pci:v00001022d00001451sv00001022sd00001451bc08sc06i00
usb:v03F0pC211d0100dc00dsc00dp00icFFiscCCip00in00
pci:v00001022d000043B7sv00001B21sd00001062bc01sc06i01
pci:v00001022d0000790Bsv00001458sd00005001bc0Csc05i00
acpi:LNXSYBUS:
usb:v062Ap4101d0108dc00dsc00dp00ic03isc01ip01in00
usb:v03F0pC211d0100dc00dsc00dp00icFFisc04ip01in02
pci:v00001022d00001460sv00000000sd00000000bc06sc00i00
cpu:type:x86,ven0002fam0017mod0001:feature:,0000,0001,0002,0003,0004,0005,0006,0007,0008,0009,000B,000C,000D,000E,000F,0010,0011,0013,0017,0018,0019,001A,001C,0020,0021,0022,0023,0024,0025,0026,0027,0028,0029,002B,002C,002D,002E,002F,0030,0031,0034,0036,0037,0038,0039,003A,003B,003D,0064,0068,006E,0070,0071,0074,0075,0078,007A,007C,0080,0081,0083,0089,008C,008D,0093,0094,0096,0097,0099,009A,009B,009C,009D,009E,00C0,00C1,00C2,00C3,00C4,00C5,00C6,00C7,00C8,00C9,00CC,00CD,00D1,00D6,00D7,00D8,00DA,00DC,00DD,00E8,010F,0120,0123,0125,0127,0128,0132,0133,0134,0137,013D,0140,0141,0142,0143,01A0,01A1,01A2,01C2,01E0,01E1,01E2,01E3,01E4,01E5,01E6,01E7,01EA,01EB,01EC,01ED,01EF,01F0,0220,0221,0223,0224
acpi:LNXSYSTM:
usb:v1D6Bp0002d0410dc09dsc00dp01ic09isc00ip00in00
usb:v03F0pC211d0100dc00dsc00dp00ic07isc01ip02in01
=== matching driver packages ===
firmware-b43legacy-installer: installed: <none> available: 1:019-2 [distro] non-free modalias: pci:v000014E4d000043A0sv00001043sd000085DFbc02sc80i00 path: /sys/devices/pci0000:00/0000:00:01.3/0000:03:00.2/0000:04:07.0/0000:09:00.0 vendor: Broadcom Corporation model: BCM4360 802.11ac Wireless Network Adapter
amd64-microcode: installed: 2.20160316.1 available: 2.20160316.1 (auto-install) [distro] non-free
nvidia-384: installed: 384.90-0ubuntu0.16.04.2 available: 384.90-0ubuntu0.16.04.2 (auto-install) [distro] non-free modalias: pci:v000010DEd00001C03sv00001458sd00003777bc03sc00i00 path: /sys/devices/pci0000:00/0000:00:03.1/0000:0a:00.0 vendor: NVIDIA Corporation
bcmwl-kernel-source: installed: 6.30.223.271+bdcom-0ubuntu1~1.2 available: 6.30.223.271+bdcom-0ubuntu1~1.2 (auto-install) [distro] non-free modalias: pci:v000014E4d000043A0sv00001043sd000085DFbc02sc80i00 path: /sys/devices/pci0000:00/0000:00:01.3/0000:03:00.2/0000:04:07.0/0000:09:00.0 vendor: Broadcom Corporation model: BCM4360 802.11ac Wireless Network Adapter
firmware-b43-installer: installed: <none> available: 1:019-2 [distro] non-free modalias: pci:v000014E4d000043A0sv00001043sd000085DFbc02sc80i00 path: /sys/devices/pci0000:00/0000:00:01.3/0000:03:00.2/0000:04:07.0/0000:09:00.0 vendor: Broadcom Corporation model: BCM4360 802.11ac Wireless Network Adapter
