Abandon le 3-07-20 Activation carte wifi sur un DELL Latitude E6410
redelap
Message par redelap »
Installation d'une LMDE4 sur un Dell sur lequel traînait un vieux windows..
Le Wifi fonctionnait sous windows
Une fois installé, pas de wifi.. Connexion câblée
je cherche...
lspci
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02)
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
00:19.0 Ethernet controller: Intel Corporation 82577LM Gigabit Network Connection (rev 05)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05)
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 05)
00:1c.3 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 4 (rev 05)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation QM57 Chipset LPC Interface Controller (rev 05)
00:1f.2 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05)
00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 05)
02:00.0 SD Host controller: Ricoh Co Ltd MMC/SD Host Controller (rev 03)
02:00.4 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 PCIe IEEE 1394 Controller (rev 03)
3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
3f:02.1 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 (rev 02)
3f:02.2 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
3f:02.3 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
Je ne vois pas de trace d'une carte Wifi
bon@lmde4:~$ lspci -nnk | grep -i network -A 3
00:19.0 Ethernet controller [0200]: Intel Corporation 82577LM Gigabit Network Connection [8086:10ea] (rev 05)
	Subsystem: Dell Latitude E6410 [1028:040a]
	Kernel driver in use: e1000e
	Kernel modules: e1000e
La "Intel Corporation 82577LM" serait-elle la carte wifi recherchée ??
Après l'install et les mises à jour, le noyau semble avoir changé
et je sais , sur une autre machine avoir perdu le wifi après mise à jour du noyau....
bon@lmde4:~$ cat /proc/version
Linux version 4.19.0-9-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.118-2+deb10u1 (2020-06-07)
J'ai lancé
bon@lmde4:~$ sudo apt-get update && sudo apt-get install wireless-tools wpasupplicant
et obtenu à la fin...
wireless-tools est déjà la version la plus récente (30~pre9-13).
wpasupplicant est déjà la version la plus récente (2:2.7+git20190128+0c1e29f-6+deb10u2).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 2 non mis à jour.
Les "2 non mis à jour" concernait Firefox
bon@lmde4:~$ iwconfig
lo        no wireless extensions.
eno1      no wireless extensions.
bon@lmde4:~$  inxi -n
Network:   Device-1: Intel 82577LM Gigabit Network driver: e1000e
           IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 5c:26:0a:31:0e:e3
Et là, je ne comprends plus rien... Carte ? Pas carte ?
Merci de vos lumières
Modifié en dernier par redelap le ven. 3 juil. 2020 09:10, modifié 1 fois.
PC Windows10
Re: Activation carte wifi sur un DELL Latitude E6410
Bonjour redelap.
Non pas de carte wifi :? ...La Intel 82577LM est carte Ethernet (filaire).
Tente (sans y croire) un:
lsusb
redelap
bon@lmde4:~$ lsusb
Bus 002 Device 005: ID 0a5c:5800 Broadcom Corp. BCM5880 Secure Applications Processor
Bus 002 Device 003: ID 046d:c06a Logitech, Inc. USB Optical Mouse
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 05ca:1814 Ricoh Co., Ltd HD Webcam
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Etonnant quand même car avant l'install de LMDE4, il fonctionnait en Wifi (très lent) sous Windows
et dans "connexion réseau", la box apparaît, avec son nom, son code et tout...
PC Windows10
redelap
J'ai tenté et obtenu ça...
bon@lmde4:~$ sudo apt-get install firmware-linux-nonfree firmware-atheros firmware-brcm80211 firmware-ipw2x00 firmware-iwlwifi firmware-libertas firmware-ralink firmware-realtek
[sudo] Mot de passe de bon :
firmware-atheros est déjà la version la plus récente (20190114-2).
firmware-brcm80211 est déjà la version la plus récente (20190114-2).
firmware-ipw2x00 est déjà la version la plus récente (20190114-2).
firmware-iwlwifi est déjà la version la plus récente (20190114-2).
firmware-libertas est déjà la version la plus récente (20190114-2).
firmware-linux-nonfree est déjà la version la plus récente (20190114-2).
firmware-ralink est déjà la version la plus récente (20190114-2).
firmware-realtek est déjà la version la plus récente (20190114-2).
PC Windows10
Bin..Écoutes...Tu auras beau essayer tous les pilotes possibles, si ta carte n'est pas vue, ça ne changera rien.
T'aurais pas un bouton de mise en service du wifi, par hazard ?
redelap
Si.. j'y ai pensé... il est bien en position "marche" (sur le coté)
Mais NADA
PC Windows10
redelap a écrit :
ven. 3 juil. 2020 06:47
Normal si tu es connecté en ethernet.
redelap
Cable débranché, et reboot... la box apparaît dans "connexion réseau"
le bouton latéral (coulissant av-ar) n'active pas du tout les petits voyants wifi coté clavier (à coté du voyant bluetooth qui lui s'allume à la mise en route)
Je pencherais pour un pb de faux contact au niveau de ce bouton... l'odinateur étant ancien...
et le bluetooth fonctionne parfaitement
Modifié en dernier par redelap le ven. 3 juil. 2020 09:01, modifié 1 fois.
PC Windows10
Y a des chances, oui...
Sujet fermé & déplacé dans la rubrique «Compatibilité Matériel» (pour le réouvrir → MP à un membre de l'équipe).
