Résolu le 15-02-21 Canon pixma 4551 simple scan
Marois
Message par Marois »
simple scan et xsane ne touve pas le scannner en USB et en WiFI de mon canon pixma tr 4551 j'ai bien télécharger décompresser et installé via le terminal les pilotes du site canon pour linux.
Après quelques nombreuses heures passé à chercher une solution sur le net et de nombreux essais rien!! il semblerait que je ne suis pas le seul à avoir de problème de détection du scan avec linux mint 19.3. Malgré la lecture des conseils donner au autres, mes 2 applications Scan sont tours aveugles
voici un extrait du terminal
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
francoisberteloot@francois:~$ sane-find-scanner tool
  # sane-find-scanner will now attempt to detect your scanner. If the
  # result is different from what you expected, first make sure your
  # scanner is powered up and properly connected to your computer.
  # No SCSI scanners found. If you expected something different, make sure that
  # you have loaded a kernel SCSI driver for your SCSI adapter.
  # No USB scanners found. If you expected something different, make sure that
  # you have loaded a kernel driver for your USB host controller and have setup
  # the USB system correctly. See man sane-usb for details.
  # Not checking for parallel port scanners.
  # Most Scanners connected to the parallel port or other proprietary ports
  # can't be detected by this program.
  # You may want to run this program as root to find all devices. Once you
  # found the scanner devices, be sure to adjust access permissions as
  # necessary.
could not open USB device 0x8087/0x0024 at 002:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 002:001: Access denied (insufficient permissions)
could not open USB device 0x0c45/0xc35a at 001:005: Access denied (insufficient permissions)
could not open USB device 0x0cf3/0x3004 at 001:006: Access denied (insufficient permissions)
could not open USB device 0x0bda/0x0129 at 001:003: Access denied (insufficient permissions)
could not open USB device 0x8087/0x0024 at 001:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0003 at 004:001: Access denied (insufficient permissions)
found USB scanner (vendor=0x04a9 [Canon], product=0x1854 [TR4500 series]) at libusb:003:010
could not open USB device 0x07ab/0xfc17 at 003:006: Access denied (insufficient permissions)
could not open USB device 0x13fe/0x4200 at 003:009: Access denied (insufficient permissions)
could not open USB device 0x046d/0xc077 at 003:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 003:001: Access denied (insufficient permissions)
  # Your USB scanner was (probably) detected. It may or may not be supported by
  # SANE. Try scanimage -L and read the backend's manpage.
  # necessary.
francoisberteloot@francois:~$ tcp 192.168.1.26
La commande « tcp » n'a pas été trouvée, mais il y en a 29 similaires.
francoisberteloot@francois:~$ xed admin:/etc/sane.d/canon TR4500series.conf
(xed:17308): Gtk-WARNING **: 14:14:12.401: Could not load a pixbuf from icon theme.
This may indicate that pixbuf loaders or the mime database could not be found.
** (xed:17308): WARNING **: 14:14:12.564: L’emplacement indiqué n’est pas monté
** (xed:17308): CRITICAL **: 14:14:31.416: xed_conversion_error_info_bar_get_encoding: assertion 'menu' failed
** (xed:17308): WARNING **: 14:15:28.724: Set document metadata failed: Erreur lors de la définition des métadonnées du fichier : Aucun fichier ou dossier de ce type
Modifié en dernier par débitant le sam. 5 déc. 2020 20:51, modifié 1 fois.
Raison : ajout des balises "code"
Marois
francoisMacbook Kernel: 5.4.0-58-generic x86_64 bits: 64
Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
Mac-2E6FAB96566FE58C v: MacBookAir5,2
Dual Core model: Intel Core i7-3667U bits: 64 type: MT MCP
Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
Local Storage: total: 465.92 GiB used: 308.57 GiB (66.2%)
Re: Canon pixma 4551 simple scan
message approuvé mais merci de le ré éditer pour mettre des balises code, là c'est impossible à lire....
Marois
je suis tout nouveau sur ce forum pouvez vous m'expliquer "reediter" est ce le faite d'avoir copier collé qui rend ilisible dans ce cas comment faire!!
merci
Marois
on appuie sur le petit crayon
Et pour les balises de code
Pour ton soucis as tu lu la doc d'ubuntu sur le scanner de ta marque ?
Marois
j'ai lu tellement de chose que je ne sais plus, mais je vais revoir ça
Marois
Marois
Cyrille,
j'ai été sur UBUNTU,j'ai vérifié le paquet indiqué pour le scan, li est bien intallé sur ma machine.
Marois
Marois
[url]file:///home/francoisberteloot/Documents/extrait%20termilnal%20canon.html[/url]
Aucun scanner n'a été identifié. Si vous vous attendiez à quelque chose de différent,
vérifiez que le scanner est branché, allumé et détecté par le
outil sane-find-scanner (le cas échéant). Veuillez lire la documentation
fourni avec ce logiciel (README, FAQ, pages de manuel).
francoisberteloot @ francois: ~ $ outil sane-find-scannerAucun scanner n'a été identifié. Si vous vous attendiez à quelque chose de différent,
# sane-find-scanner va maintenant tenter de détecter votre scanner. Si la
# résultat est différent de ce que vous attendiez, assurez-vous d'abord que votre
# le scanner est sous tension et correctement connecté à votre ordinateur.
# Aucun scanneur SCSI trouvé. Si vous vous attendiez à quelque chose de différent, assurez-vous que
# vous avez chargé un pilote SCSI du noyau pour votre adaptateur SCSI.
# Aucun scanneur USB trouvé. Si vous vous attendiez à quelque chose de différent, assurez-vous que
# vous avez chargé un pilote de noyau pour votre contrôleur hôte USB et avez configuré
# le système USB correctement. Voir man sane-usb pour plus de détails.
# Ne pas vérifier les scanners de ports parallèles.
# La plupart des scanners connectés au port parallèle ou à d'autres ports propriétaires
# ne peut pas être détecté par ce programme.
# Vous pouvez exécuter ce programme en tant que root pour trouver tous les périphériques. Une fois que vous
# trouvé les périphériques du scanner, assurez-vous d'ajuster les autorisations d'accès comme
# nécessaire.
francoisberteloot @ francois: ~ $ sane-find-scanner
Impossible d'ouvrir le périphérique USB 0x8087 / 0x0024 à 002: 002: accès refusé (autorisations insuffisantes)
n'a pas pu ouvrir le périphérique USB 0x1d6b / 0x0002 à 002: 001: accès refusé (autorisations insuffisantes)
impossible d'ouvrir le périphérique USB 0x0c45 / 0xc35a à 001: 005: accès refusé (autorisations insuffisantes)
Impossible d'ouvrir le périphérique USB 0x0cf3 / 0x3004 à 001: 006: accès refusé (autorisations insuffisantes)
Impossible d'ouvrir le périphérique USB 0x0bda / 0x0129 à 001: 003: accès refusé (autorisations insuffisantes)
Impossible d'ouvrir le périphérique USB 0x8087 / 0x0024 à 001: 002: accès refusé (autorisations insuffisantes)
Impossible d'ouvrir le périphérique USB 0x1d6b / 0x0002 à 001: 001: accès refusé (autorisations insuffisantes)
Impossible d'ouvrir le périphérique USB 0x1d6b / 0x0003 à 004: 001: accès refusé (autorisations insuffisantes)
scanner USB trouvé (fournisseur = 0x04a9 [Canon], produit = 0x1854 [série TR4500]) à libusb: 003: 010
impossible d'ouvrir le périphérique USB 0x07ab / 0xfc17 à 003: 006: accès refusé (autorisations insuffisantes)
impossible d'ouvrir le périphérique USB 0x13fe / 0x4200 à 003: 009: accès refusé (autorisations insuffisantes)
impossible d'ouvrir le périphérique USB 0x046d / 0xc077 à 003: 002: accès refusé (autorisations insuffisantes)
Impossible d'ouvrir le périphérique USB 0x1d6b / 0x0002 à 003: 001: accès refusé (autorisations insuffisantes)
# Votre scanner USB a (probablement) été détecté. Il peut ou non être pris en charge par
# SANE. Essayez scanimage -L et lisez la page de manuel du backend.
# nécessaire.
francoisberteloot @ francois: ~ $ tcp 192.168.1.26
La commande «tcp» n'a pas été trouvée, mais il y en a 29 similaires
francoisberteloot @ francois: ~ $ xed admin: /etc/sane.d/canon TR4500series.conf
(xed: 17308): Gtk-WARNING **: 14: 14: 12.401: Impossible de charger un pixbuf à partir du thème d'icônes.
Cela peut indiquer que les chargeurs pixbuf ou la base de données mime sont introuvables.
** (xed: 17308): WARNING **: 14: 14: 12.564: L'emplacement indiqué n'est pas monté
** (xed: 17308): CRITICAL **: 14: 14: 31.416: xed_conversion_error_info_bar_get_encoding: l'assertion 'menu' a échoué
** (xed: 17308): ATTENTION **: 14: 15: 28.724: Échec de la définition des métadonnées du document: Erreur lors de la définition des métadonnées du fichier: Aucun fichier ou dossier de ce type
# nécessaire.
# nécessaire.
La commande «tcp» n'a pas été trouvée, mais il y en a 29 similaires.
Modifié en dernier par débitant le sam. 5 déc. 2020 20:48, modifié 1 fois.
Raison : reprise des balises
Marois
bonjour,
j'ai édité le message pour "démêler le sac de noeuds" :l ;)
pour l'utilisation des balises, voir : tuto barre d'outils des messages
ne pas oublier la signature technique comme tu t y es engagé lors de ton inscrition, voir : Aide pour une signature technique
Marois
Un grand merci
je vais lire et apprendre tout ça
Bonne soirée
Marois
Marois
capdeframint
Message par capdeframint »
Ce que tu écris est malheureusement incohérent: tu dis que tu as téléchargé le pilote pour le scanner chez Canon et que pourtant SimpleScan ne fonctionne pas! Et bien c'est normal car le pilote de Canon, c'est avec le logiciel ScangearMP qu'il fonctionne et c'est celui que tu as installé :l Si SimpleScan fonctionne, c'est grâce aux pilotes intégrés dans Linuxmint mais pas avec ceux de Canon
Vérifie si tu as bien un exécutable nommé "scangearmp" ou "scangearmp2" dans /USR/BIN/ et , si c'est le cas tu fais un double clic dessus pour le lancer et tu vois si le scan fonctionne. Si oui, et ça devrait être le cas, tu n'as plus qu'à te faire un beau lanceur sur le bureau pour avoir facilement accès au logiciel de scan fourni par Canon.
