Résolu le 10-03-22 activer bluetooth
Abel17
activer bluetooth
Message par Abel17 »
Je viens d'installer une mint 20.3 sur un Dell Vostro 5391.
J'ai pas le Bluetooth...
Voici ce que donne les diverses commandes :
lsusb
Bus 002 Device 003: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 002 Device 002: ID 05e3:0626 Genesys Logic, Inc. USB3.1 Hub
Bus 001 Device 005: ID 0bda:565a Realtek Semiconductor Corp. Integrated_Webcam_HD
Bus 001 Device 004: ID 27c6:538d Shenzhen Goodix Technology Co.,Ltd. FingerPrint
Bus 001 Device 009: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 001 Device 008: ID 04e8:6860 Samsung Electronics Co., Ltd Galaxy series, misc. (MTP mode)
Bus 001 Device 003: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 006: ID 8087:0aaa Intel Corp.
Bus 001 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
rfkill list
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
hciconfig -a
hci0:	Type: Primary  Bus: USB
	BD Address: 24:41:8C:BE:F4:E1  ACL MTU: 1021:4  SCO MTU: 96:6
	DOWN
	RX bytes:1119 acl:0 sco:0 events:115 errors:0
	TX bytes:7646 acl:0 sco:0 commands:115 errors:0
	Features: 0xbf 0xfe 0x0f 0xfe 0xdb 0xff 0x7b 0x87
	Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
	Link policy: RSWITCH SNIFF
	Link mode: SLAVE ACCEPT
inxi -Fxz
System:
  Kernel: 5.4.0-104-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: MATE 1.26.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Machine:
  Type: Laptop System: Dell product: Vostro 5391 v: N/A serial: <filter>
  Mobo: Dell model: 074H1M v: A00 serial: <filter> UEFI: Dell v: 1.16.0
  date: 12/08/2021
Battery:
  ID-1: BAT0 charge: 30.8 Wh condition: 30.8/45.0 Wh (68%)
  model: BYD DELL DGV2499 status: Full
  Device-1: hidpp_battery_0
  model: Logitech M720 Triathlon Multi-Device Mouse
  charge: 10% (should be ignored) status: Discharging
  Device-2: hidpp_battery_1
  model: Logitech K850 Performance Wireless Keyboard
  charge: 100% (should be ignored) status: Discharging
CPU:
  Topology: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
  arch: Kaby Lake rev: C L2 cache: 6144 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  bogomips: 33599
  Speed: 800 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 798 2: 800
  3: 800 4: 798 5: 800 6: 800 7: 800 8: 799
Graphics:
  Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0
  Device-2: NVIDIA GP108M [GeForce MX250] vendor: Dell driver: nouveau
  v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.13 driver: modesetting
  unloaded: fbdev,vesa resolution: 1920x1080~60Hz, 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.6
  direct render: Yes
Audio:
  Device-1: Intel vendor: Dell driver: sof-audio-pci bus ID: 00:1f.3
  Sound Server: ALSA v: k5.4.0-104-generic
Network:
  Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 4000
  bus ID: 00:14.3
  IF: wlp0s20f3 state: down mac: <filter>
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
  bus ID: 2-4.2:3
  IF: enx00e04c6802d5 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 476.77 GiB used: 49.49 GiB (10.4%)
  ID-1: /dev/mmcblk0 model: SC256 size: 238.30 GiB
  ID-2: /dev/nvme0n1 vendor: SK Hynix model: BC511 NVMe 256GB
Partition:
  ID-1: / size: 218.97 GiB used: 12.19 GiB (5.6%) fs: ext4
  dev: /dev/nvme0n1p6
  ID-2: /home size: 238.18 GiB used: 37.20 GiB (15.6%) fs: xfs
  dev: /dev/mmcblk0p1
  ID-3: swap-1 size: 14.90 GiB used: 54.2 MiB (0.4%) fs: swap
  dev: /dev/nvme0n1p5
Sensors:
  System Temperatures: cpu: 35.0 C mobo: N/A gpu: nouveau temp: 40 C
  Fan Speeds (RPM): cpu: 3073
Info:
  Processes: 296 Uptime: 6h 30m Memory: 7.44 GiB used: 3.60 GiB (48.4%)
  Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
  inxi: 3.0.38
J'ai installé Blueman, mais il ne détecte rien.
Les paquets suivants sont aussi installés :Bluetooth, Gnome-bluetooth, Gir.2-gnomebluetools-1.0, Indicator-bluetooth et Bluez
Si quelqu'un a une idée, je suis preneur...
Re: activer bluetooth
que donne
sudo dmesg | grep 'error|fail|firmw'
thx
Et tu as bien ce pquet d'installer : backport-iwlwifi-dkms ?
apt policy backport-iwlwifi-dkms
Si non, installe le
sudo apt install backport-iwlwifi-dkms
Et reboote
Abel17
cyrille a écrit :
mer. 9 mars 2022 18:17
que donne
thx
Aucun retour...
Abel
backport-iwlwifi-dkms est installé ?
Abel17
cyrille a écrit :
mer. 9 mars 2022 18:23
Si non, installe le
Et reboote
Bien installé
backport-iwlwifi-dkms est déjà la version la plus récente (8324-0ubuntu3~20.04.4).
rebooté et lancé le gestionnaire Bluetooth et ça fonctionne... mais pourquoi ce paquet ne s'installe t-il pas dès l'installation...
En tout cas un grand merci à vous tous.
Abel
parce qu'en fonction de la puce wifi / bletooth, on n'en a pas pas forcement besoin ;)
Par contre pense à passer en résolu si OK
