Mint Cinnamon 18.2 : HDMI ne fonctionne pas.
arieugon
Message par arieugon »
Bonjour à tous.
J'ai plusieurs systèmes sur mon portable (voir ma signature), et sur les autres systèmes je peux afficher mon écran de PC sur celui de ma télévision via un câble HDMI.
Mais sur Mint 18.2 ça ne fonctionne pas.
Je vous donne le résultat de la sortie de la commande lspci -v
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
	Subsystem: ASUSTeK Computer Inc. 2nd Generation Core Processor Family DRAM Controller
	Flags: bus master, fast devsel, latency 0
	Capabilities: [e0] Vendor Specific Information: Len=0c <?>
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09) (prog-if 00 [VGA controller])
	Subsystem: ASUSTeK Computer Inc. 2nd Generation Core Processor Family Integrated Graphics Controller
	Flags: bus master, fast devsel, latency 0, IRQ 28
	Memory at ddc00000 (64-bit, non-prefetchable) [size=4M]
	Memory at c0000000 (64-bit, prefetchable) [size=256M]
	I/O ports at e000 [size=64]
	[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
	Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [d0] Power Management version 2
	Capabilities: [a4] PCI Advanced Features
	Kernel driver in use: i915
	Kernel modules: i915
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
	Subsystem: ASUSTeK Computer Inc. 6 Series/C200 Series Chipset Family MEI Controller
	Flags: bus master, fast devsel, latency 0, IRQ 29
	Memory at dfe0b000 (64-bit, non-prefetchable) [size=16]
	Capabilities: [50] Power Management version 3
	Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05) (prog-if 20 [EHCI])
	Subsystem: ASUSTeK Computer Inc. 6 Series/C200 Series Chipset Family USB Enhanced Host Controller
	Flags: bus master, medium devsel, latency 0, IRQ 16
	Memory at dfe08000 (32-bit, non-prefetchable) [size=1K]
	Capabilities: [50] Power Management version 2
	Capabilities: [58] Debug port: BAR=1 offset=00a0
	Capabilities: [98] PCI Advanced Features
	Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
	Subsystem: ASUSTeK Computer Inc. 6 Series/C200 Series Chipset Family High Definition Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 30
	Memory at dfe00000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [100] Virtual Channel
	Capabilities: [130] Root Complex Link
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 24
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 0000d000-0000dfff
	Memory behind bridge: df400000-dfdfffff
	Prefetchable memory behind bridge: 00000000d1600000-00000000d1ffffff
	Capabilities: [40] Express Root Port (Slot+), MSI 00
	Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [90] Subsystem: ASUSTeK Computer Inc. 6 Series/C200 Series Chipset Family PCI Express Root Port 1
	Capabilities: [a0] Power Management version 2
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b5) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 25
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 0000c000-0000cfff
	Memory behind bridge: dea00000-df3fffff
	Prefetchable memory behind bridge: 00000000d0b00000-00000000d14fffff
	Capabilities: [90] Subsystem: ASUSTeK Computer Inc. 6 Series/C200 Series Chipset Family PCI Express Root Port 2
00:1c.5 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 6 (rev b5) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 26
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: 0000b000-0000bfff
	Memory behind bridge: de000000-de9fffff
	Prefetchable memory behind bridge: 00000000d0000000-00000000d09fffff
	Capabilities: [90] Subsystem: ASUSTeK Computer Inc. 6 Series/C200 Series Chipset Family PCI Express Root Port 6
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05) (prog-if 20 [EHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 23
	Memory at dfe07000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation HM65 Express Chipset Family LPC Controller (rev 05)
	Subsystem: ASUSTeK Computer Inc. HM65 Express Chipset Family LPC Controller
	Kernel driver in use: lpc_ich
	Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 05) (prog-if 01 [AHCI 1.0])
	Subsystem: ASUSTeK Computer Inc. 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller
	Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 27
	I/O ports at e0b0 [size=8]
	I/O ports at e0a0 [size=4]
	I/O ports at e090 [size=8]
	I/O ports at e080 [size=4]
	I/O ports at e060 [size=32]
	Memory at dfe06000 (32-bit, non-prefetchable) [size=2K]
	Capabilities: [70] Power Management version 3
	Capabilities: [a8] SATA HBA v1.0
	Capabilities: [b0] PCI Advanced Features
	Kernel driver in use: ahci
	Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
	Subsystem: ASUSTeK Computer Inc. 6 Series/C200 Series Chipset Family SMBus Controller
	Flags: medium devsel, IRQ 3
	Memory at dfe05000 (64-bit, non-prefetchable) [size=256]
	I/O ports at e040 [size=32]
	Kernel modules: i2c_i801
02:00.0 Network controller: Ralink corp. RT5390 Wireless 802.11n 1T/1R PCIe
	Subsystem: AzureWave RT5390 Wireless 802.11n 1T/1R PCIe
	Flags: bus master, fast devsel, latency 0, IRQ 17
	Memory at dea00000 (32-bit, non-prefetchable) [size=64K]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 00
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [140] Device Serial Number 00-00-ff-bb-95-68-2f-74
	Kernel driver in use: rt2800pci
	Kernel modules: rt2800pci
03:00.0 Ethernet controller: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet (rev c0)
	Subsystem: ASUSTeK Computer Inc. AR8151 v2.0 Gigabit Ethernet
	Flags: bus master, fast devsel, latency 0, IRQ 31
	Memory at de000000 (64-bit, non-prefetchable) [size=256K]
	I/O ports at b000 [size=128]
	Capabilities: [48] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [58] Express Endpoint, MSI 00
	Capabilities: [6c] Vital Product Data
	Capabilities: [180] Device Serial Number ff-14-44-fe-54-04-a6-ff
	Kernel driver in use: atl1c
	Kernel modules: atl1c
Dans les paramètres système je vois bien l'écran de télévision quand le câble HDMI est branché, donc le système semble le voir.
Pourtant ma télé m'affiche "Aucun signal !". Je suis sur la bonne entrée HDMI (HDMI2) sur ma télévision.
Si quelqu'un a une idée ? Peut-être cela vient-il de Cinnamon lui même ?
Merci de vos réponses.
Portable ASUS K73E ( RAM : 4 Go, HD : 1 To, 64 bits ).
Systèmes installées : Debian 7 / 8 / 9 , Ubuntu 17.4 , Devuan 1.0 , Mint 18.3 Cinnamon 64 bits, Mint 19 Cinnamon 64 bits.
Re: Mint Cinnamon 18.2 : HDMI ne fonctionne pas.
tu as installer le microcode intel ?
sudo apt install intel-microcode
redémarre et test !!
