SSH TIME OUT
Questions concernant les lignes de commandes
GISALE
SSH TIME OUT
Message par GISALE »
J'ai installé sur mon PC Linux(A) openssh-server, puis depuis un autre PC (B) Windows ou Linux (C) ou même un Android (D) en utilisant Putty, j'essaye de m'y connecter mais la réponse est toujours la même Connection Failed Time out.
J'ai checrhé sur internet des solutions et je les ai essayé mais ça ne fonctionne toujours pas!
Sur ma box de SFR j'ai bien ouvert dans le NAT les ports correspondant ici le 2222
Voici le fichier sshd_conf
  GNU nano 2.9.3                 /etc/ssh/sshd_config
#       $OpenBSD: sshd_config,v 1.101 2017/03/14 07:19:07 djm Exp $
# This is the sshd server system-wide configuration file.  See
# sshd_config(5) for more information.
# This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
# The strategy used for options in the default sshd_config shipped with
# OpenSSH is to specify options with their default value where
# possible, but leave them commented.  Uncommented options override the
# default value.
Port 2222
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_ecdsa_key
#HostKey /etc/ssh/ssh_host_ed25519_key
# Ciphers and keying
#RekeyLimit default none
# Logging
#SyslogFacility AUTH
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
#PermitRootLogin prohibit-password
#StrictModes yes
#MaxAuthTries 6
#MaxSessions 10
#PubkeyAuthentication yes
# Expect .ssh/authorized_keys2 to be disregarded by default in future.
#AuthorizedKeysFile     .ssh/authorized_keys .ssh/authorized_keys2
#AuthorizedPrincipalsFile none
#AuthorizedKeysCommand none
#AuthorizedKeysCommandUser nobody
# For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#HostbasedAuthentication no
# Change to yes if you don't trust ~/.ssh/known_hosts for
# HostbasedAuthentication
#IgnoreUserKnownHosts no
# Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
# To disable tunneled clear text passwords, change to no here!
#PasswordAuthentication yes
#PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
#GSSAPIStrictAcceptorCheck yes
#GSSAPIKeyExchange no
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication.  Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM yes
#AllowAgentForwarding yes
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding yes
#X11DisplayOffset 10
#X11UseLocalhost yes
#PermitTTY yes
PrintMotd no
#PrintLastLog yes
TCPKeepAlive no
#UseLogin no
#PermitUserEnvironment no
#Compression delayed
ClientAliveInterval 60
ClientAliveCountMax 240
#UseDNS no
#PidFile /var/run/sshd.pid
#MaxStartups 10:30:100
#PermitTunnel no
#ChrootDirectory none
#VersionAddendum none
# no default banner path
#Banner none
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
# override default of no subsystems
Subsystem       sftp    /usr/lib/openssh/sftp-server
# Example of overriding settings on a per-user basis
#Match User anoncvs
#       X11Forwarding no
#       AllowTcpForwarding no
#       PermitTTY no
#       ForceCommand cvs server
Puis j'ai enregistré ce fichier par Ctrl O et quitter par Ctrl X
Puis j'ai redémarré ssh
root@gilles-DS10G:/home/gilles# service ssh restart
J'ai réessayé depuis les différents PC et rien y fait j'ai essayé de redémarré le service via plusieurs commandes et toujours rien !
voici les commandes essayées :
root@gilles-DS10G:/home/gilles# /etc/init.d/sshd restart
root@gilles-DS10G:/home/gilles# systemctl restart sshd.service
l'adresse IP de la machine est 192.168.1.200
Donc je mets dans Putty 192.168.1.200 et comme port 2222
Mais aucune connexion possible car Timeout
Merci pour votre aide.
Lenovo IdeaPad Z500
LM 20.3 Una Mate
Processeur : Intel Core i7 3520M 2.9Ghz
RAM : 6Go
GISALE
Re: SSH TIME OUT
Ok j'ai résolu mon erreur
En fait mon pare-feu était activé mais je n'avais pas ouvert le port 2222 dans le dossier personnel.
Maintenant qu'il est ouvert cela fonctionne!
Mais est-ce bien la bonne démarche d'ouvrir le port 2222 dans le dossier personnel du pare-feu, y a t--il une autre façon de faire?
Lenovo IdeaPad Z500
LM 20.3 Una Mate
RAM : 6Go
