étant habitué sur une debian 8 a faire les mises à jour en console, je regarde la liste des mises à jour par la commande:
sudo apt list --upgradable
alain@debian:~$ sudo apt list --upgradable
En train de lister... Fait
libopenjp2-7/oldstable 2.1.0-2+deb8u3+b1 amd64 [upgradable from: 2.1.0-2+deb8u3]
libsmbclient/oldstable 2:4.2.14+dfsg-0+deb8u9 amd64 [upgradable from: 2:4.2.14+dfsg-0+deb8u8]
libwbclient0/oldstable 2:4.2.14+dfsg-0+deb8u9 amd64 [upgradable from: 2:4.2.14+dfsg-0+deb8u8]
phonon-backend-vlc/oldstable 0.8.0-2 amd64 [upgradable from: 0.6.0-1]
python-samba/oldstable 2:4.2.14+dfsg-0+deb8u9 amd64 [upgradable from: 2:4.2.14+dfsg-0+deb8u8]
samba-common/oldstable 2:4.2.14+dfsg-0+deb8u9 all [upgradable from: 2:4.2.14+dfsg-0+deb8u8]
samba-common-bin/oldstable 2:4.2.14+dfsg-0+deb8u9 amd64 [upgradable from: 2:4.2.14+dfsg-0+deb8u8]
samba-dsdb-modules/oldstable 2:4.2.14+dfsg-0+deb8u9 amd64 [upgradable from: 2:4.2.14+dfsg-0+deb8u8]
samba-libs/oldstable 2:4.2.14+dfsg-0+deb8u9 amd64 [upgradable from: 2:4.2.14+dfsg-0+deb8u8]
samba-vfs-modules/oldstable 2:4.2.14+dfsg-0+deb8u9 amd64 [upgradable from: 2:4.2.14+dfsg-0+deb8u8]
vivaldi-snapshot/stable 1.13.1008.30-1 amd64 [upgradable from: 1.13.1008.21-1]
alain@debian:~$
alain@lmde2 ~ $ sudo apt list --upgradable
[sudo] password for alain:
apt
Usage: apt command [options]
apt help command [options]
Commands:
add-repository - Add entries to apt sources.list
autoclean - Erase old downloaded archive files
autoremove - Remove automatically all unused packages
build - Build binary or source packages from sources
build-dep - Configure build-dependencies for source packages
changelog - View a package's changelog
check - Verify that there are no broken dependencies
clean - Erase downloaded archive files
contains - List packages containing a file
content - List files contained in a package
deb - Install a .deb package
depends - Show raw dependency information for a package
dist-upgrade - Perform an upgrade, possibly installing and removing packages
download - Download the .deb file for a package
dselect-upgrade - Follow dselect selections
held - List all held packages
help - Show help for a command
hold - Hold a package
install - Install/upgrade packages
policy - Show policy settings
purge - Remove packages and their configuration files
recommends - List missing recommended packages for a particular package
rdepends - Show reverse dependency information for a package
reinstall - Download and (possibly) reinstall a currently installed package
remove - Remove packages
search - Search for a package by name and/or expression
show - Display detailed information about a package
source - Download source archives
sources - Edit /etc/apt/sources.list with nano
unhold - Unhold a package
update - Download lists of new/upgradable packages
upgrade - Perform a safe upgrade
version - Show the installed version of a package
This apt has Super Cow Powers
alain@lmde2 ~ $
Je l'ai essayée sur LM17.3 ça fait pareil.list
La commande list est utilisée pour afficher une liste de paquets. Il gère les motifs du shell pour chercher les noms de paquets, ainsi que les options suivantes : --installed, --upgradable,
--all-versions.
Sur LMDE2 et debian 8.9, c'est la même version d'apt, la : 1.0.9.8.4 ????
Sauriez vous pourquoi cette commande ne fonctionne pas sur LMDE2 et sur LM17.3 ?
Quelqu'un connaîtrait il la commande a faire pour avoir la liste des paquets a mettre à jours?
Jusqu'a aujourd’hui je ne m'en étais pas inquiété car je regardais la liste dans mintupdate.
PS: C'est pas important, car je continu comme à mon habitude a regarder la liste des mises à jour dans mintupdate, mais bon, j'aimerai bien savoir...
