Tue Nov 12 07:13:33 2019
Command line: TestDisk
TestDisk 7.1, Data Recovery Utility, July 2019
Christophe GRENIER <grenier@cgsecurity.org>
https://www.cgsecurity.org
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin 2009.0
ext2fs lib: 1.43.1, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=239379415040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=220625636864
filewin32_getfilesize(\\.\G:) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\G:) SetFilePointer err Fonction incorrecte.
Warning: can't get size for \\.\G:
Hard disk list
Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - LDLC F7+240GB, S/N:08302219D0019, FW:S0626A0
Disk /dev/sdb - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - ST31500341AS, S/N:9VS56FA7, FW:CC4G
Partition table type (auto): Intel
Disk /dev/sdb - 1500 GB / 1397 GiB - ST31500341AS
Partition table type: Intel
Analyse Disk /dev/sdb - 1500 GB / 1397 GiB - CHS 182401 255 63
Geometry from i386 MBR: head=255 sector=63
NTFS at 0/32/33
BAD_RS LBA=649057125 5918957
check_part_i386 5 type 72: no test
BAD_RS LBA=1159977793 1083631
check_part_i386 6 type 74: no test
BAD_RS LBA=599581554 1838434
Current partition structure:
1 P HPFS - NTFS 0 32 33 26822 254 63 430909447
2 E extended LBA 26824 0 57 182401 68 3 2499348736
No partition is bootable
A logical partition must contain only one partition
5 L Sys=72 40401 239 4 146345 239 53 1701990410
Bad relative sector.
6 L Sys=74 72205 70 59 106066 35 22 543974724
7 L NetWare 3.11+ 37322 57 34 37322 57 33 0
search_part()
NTFS at 0/32/33
filesystem size 430909447
sectors_per_cluster 8
mft_lcn 3
mftmirr_lcn 100991
clusters_per_mft_record -10
clusters_per_index_record 1
NTFS, blocksize=4096, 220 GB / 205 GiB
NTFS at 26824/0/57
filesystem size 2294544447
mft_lcn 77046841
mftmirr_lcn 1530080
HPFS - NTFS 26824 0 57 169652 201 20 2294544447
NTFS, blocksize=4096, 1174 GB / 1094 GiB
recover_EXT2: s_block_group_nr=0/781, s_mnt_count=232/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocksize=4096
recover_EXT2: s_blocks_count 25600512
recover_EXT2: part_size 204804096
Filesystem created: Sat Feb 2 16:04:20 2019
Last mount time: Sun Nov 10 15:41:52 2019
Linux 169652 204 25 182401 68 3 204804096
ext4 blocksize=4096 Large_file Sparse_SB, 104 GB / 97 GiB
file_pread(5,2,buffer,2930278400(182401/100/36)) lseek err Invalid argument
file_pread(5,1,buffer,2930278400(182401/100/36)) lseek err Invalid argument
file_pread(5,2,buffer,2930278460(182401/101/33)) lseek err Invalid argument
file_pread(5,1,buffer,2930278460(182401/101/33)) lseek err Invalid argument
file_pread(5,2,buffer,2930278463(182401/101/36)) lseek err Invalid argument
file_pread(5,2,buffer,2930278523(182401/102/33)) lseek err Invalid argument
file_pread(5,1,buffer,2930278523(182401/102/33)) lseek err Invalid argument
file_pread(5,8,buffer,2930277248(182401/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,2930277248(182401/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,2930277376(182401/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,2930277504(182401/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,2930277632(182401/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,2930277760(182401/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,2930277888(182401/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,2930278016(182401/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,2930278144(182401/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,2930278272(182401/98/34)) lseek err Invalid argument
file_pread(5,8,buffer,2930278400(182401/100/36)) lseek err Invalid argument
file_pread(5,8,buffer,2930278408(182401/100/44)) lseek err Invalid argument
file_pread(5,3,buffer,2930278416(182401/100/52)) lseek err Invalid argument
file_pread(5,3,buffer,2930278463(182401/101/36)) lseek err Invalid argument
file_pread(5,8,buffer,2930278479(182401/101/52)) lseek err Invalid argument
file_pread(5,11,buffer,2930278526(182401/102/36)) lseek err Invalid argument
file_pread(5,2,buffer,2930280448(182401/133/5)) lseek err Invalid argument
Results
* HPFS - NTFS 0 32 33 26823 32 25 430911488
P HPFS - NTFS 26824 0 57 169652 201 20 2294544447
P Linux 169652 204 25 182401 68 3 204804096
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Failed to load $MFT: Input/output error.
Failed to startup volume: Input/output error.
Not an exFAT boot sector.
Can't open filesystem. Filesystem seems damaged.
interface_write()
1 * HPFS - NTFS 0 32 33 26823 32 25 430911488
2 P HPFS - NTFS 26824 0 57 169652 201 20 2294544447
3 P Linux 169652 204 25 182401 68 3 204804096
search_part()
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
NTFS at 100/181/17
filesystem size 1615872
mft_lcn 3
mftmirr_lcn 100991
HPFS - NTFS 0 32 33 100 181 17 1615872
NTFS found using backup sector, blocksize=4096, 827 MB / 789 MiB
NTFS at 100/181/18
filesystem size 429293575
mft_lcn 4
mftmirr_lcn 26830848
HPFS - NTFS 100 181 18 26822 254 63 429293575
NTFS, blocksize=4096, 219 GB / 204 GiB
file_pread(5,16,buffer,9341007(581/114/61)) ReadFile Erreur de données (contrôle de redondance cyclique).
file_pread(5,16,buffer,9341054(581/115/45)) ReadFile Erreur de données (contrôle de redondance cyclique).
file_pread(5,1,buffer,9341057(581/115/48)) ReadFile Erreur de données (contrôle de redondance cyclique).
NTFS at 26822/254/63
mft_lcn 3
mftmirr_lcn 100991
NTFS found using backup sector, blocksize=4096, 220 GB / 205 GiB
NTFS at 26824/0/57
mft_lcn 77046841
mftmirr_lcn 1530080
block_group_nr 1
recover_EXT2: "e2fsck -b 32768 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=1/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 104 GB / 97 GiB
Linux Swap 169670 35 30 169931 56 29 4194288
SWAP2 version 1, pagesize=4096, 2147 MB / 2047 MiB
block_group_nr 3
recover_EXT2: "e2fsck -b 98304 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=3/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
recover_EXT2: "e2fsck -b 819200 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=25/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 175935 95 33 188683 214 11 204804096
ext4 blocksize=4096 Large_file Sparse_SB Recover, 104 GB / 97 GiB
This partition ends after the disk limits. (start=2826401792, size=204804096, end=3031205887, disk end=2930277168)
recover_EXT2: s_block_group_nr=0/781, s_mnt_count=221/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Last mount time: Thu Nov 7 20:59:09 2019
Linux 175954 159 14 188703 22 55 204804096
This partition ends after the disk limits. (start=2826711040, size=204804096, end=3031515135, disk end=2930277168)
Linux 175958 179 30 188707 43 8 204804096
This partition ends after the disk limits. (start=2826776576, size=204804096, end=3031580671, disk end=2930277168)
recover_EXT2: s_block_group_nr=0/781, s_mnt_count=220/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Last mount time: Mon Nov 4 23:15:40 2019
Linux 175983 208 34 188732 72 12 204804096
This partition ends after the disk limits. (start=2827180032, size=204804096, end=3031984127, disk end=2930277168)
block_group_nr 625
recover_EXT2: "e2fsck -b 20480000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=625/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 729
recover_EXT2: "e2fsck -b 23887872 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=729/781, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
file_pread(5,2,buffer,2930278399(182401/100/35)) lseek err Invalid argument
file_pread(5,1,buffer,2930278399(182401/100/35)) lseek err Invalid argument
Check the harddisk size: HD jumper settings, BIOS detection...
The harddisk (1500 GB / 1397 GiB) seems too small! (< 1552 GB / 1445 GiB)
The following partitions can't be recovered:
Results
HPFS - NTFS 100 181 18 26823 32 25 429295616
* HPFS - NTFS 26824 0 57 169652 201 20 2294544447
Linux Swap 169670 35 30 169931 56 45 4194304
SWAP2 version 1, pagesize=4096, 2147 MB / 2048 MiB
interface_write()
1 * HPFS - NTFS 26824 0 57 169652 201 20 2294544447
simulate write!
write_mbr_i386: starting...
write_all_log_i386: starting...
No extended partition
Interface Advanced
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
Sectors are identical.
A valid NTFS Boot sector must be present in order to access
any data; even if the partition is not bootable.
rebuild_NTFS_BS
mft at 24
ntfs_find_mft: mft_lcn 3
ntfs_find_mft: mftmirr_lcn 100991
ntfs_find_mft: sectors_per_cluster 8
ntfs_find_mft: mft_record_size 1024 bytes
ntfs_find_mft: index_block_size 4096
Extrapolated boot sector and current boot sector are identical.
mft_lcn 3
mftmirr_lcn 100991
Directory /
5 dr-xr-xr-x 0 0 0 10-Nov-2019 15:21 .
5 dr-xr-xr-x 0 0 0 10-Nov-2019 15:21 ..
41 dr-xr-xr-x 0 0 0 10-Nov-2019 15:39 $RECYCLE.BIN
40 dr-xr-xr-x 0 0 0 10-Nov-2019 15:37 Local Disk F_111020191537
36 dr-xr-xr-x 0 0 0 10-Nov-2019 15:36 System Volume Information
mft_lcn 3
mftmirr_lcn 100991
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
NTFS at 0/32/33
search_part()
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
NTFS at 26824/0/57
mft_lcn 77046841
mftmirr_lcn 1530080
Results
interface_write()
simulate write!
Interface Advanced
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
rebuild_NTFS_BS
mft at 24
mft_lcn 3
mftmirr_lcn 100991
Directory /
mft_lcn 3
mftmirr_lcn 100991
Directory /
mft_lcn 3
mftmirr_lcn 100991
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
rebuild_NTFS_BS
mft at 24
mft_lcn 3
mftmirr_lcn 100991
Directory /
mft_lcn 3
mftmirr_lcn 100991
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
Interface Advanced
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
repair_MFT
NTFS at 0/32/33
MFT and MFT mirror match perfectly.
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
rebuild_NTFS_BS
mft at 24
mft_lcn 3
mftmirr_lcn 100991
Directory /
mft_lcn 3
mftmirr_lcn 100991
Directory /
Directory /System Volume Information
36 dr-xr-xr-x 0 0 0 10-Nov-2019 15:36 .
17 dr-xr-xr-x 0 0 0 10-Nov-2019 15:24 Chkdsk
39 -r--r--r-- 0 0 76 10-Nov-2019 15:36 IndexerVolumeGuid
38 -r--r--r-- 0 0 12 10-Nov-2019 15:36 WPSettings.dat
37 -r--r--r-- 0 0 20480 10-Nov-2019 15:36 tracking.log
Directory /
Directory /
mft_lcn 3
mftmirr_lcn 100991
Directory /
Directory /
Directory /
mft_lcn 3
mftmirr_lcn 100991
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
repair_MFT
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
rebuild_NTFS_BS
mft at 24
mft_lcn 3
mftmirr_lcn 100991
Directory /
mft_lcn 3
mftmirr_lcn 100991
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
repair_MFT
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
rebuild_NTFS_BS
mft at 24
mft_lcn 3
mftmirr_lcn 100991
Directory /
mft_lcn 3
mftmirr_lcn 100991
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 3
mftmirr_lcn 100991
Boot sector
Status: OK
Backup boot sector
Status: OK
Interface Advanced
NTFS at 0/32/33
TestDisk exited normally.
