Réinstallation le 26-04-20 Disparition du son
d2d3
Re: Disparition du son
Message par d2d3 »
Merci Cyrille (on a toujours besoin d'un ch'ti...)
bon ce soir nouvelle conférence sur zoom et pas de soucis de son, je pense donc que c'est zoom qui met la grouille dans l'audio car après la conférence de nouveau plus de son.
en tout cas voici le résultat de la commande (attention c'est long)
[    0.000000] Linux version 4.9.0-12-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP Debian 4.9.210-1 (2020-01-20)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-12-amd64 root=UUID=974f57ac-b76b-4f8e-9b66-8da04b588a4d ro quiet splash
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f3ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f400-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000b8d2efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000b8d2f000-0x00000000b9b2ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000b9b30000-0x00000000b9b8bfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000b9b8c000-0x00000000baf8bfff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000baf8c000-0x00000000bf58efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf58f000-0x00000000bfa8efff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bfa8f000-0x00000000bfb8efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000bfb8f000-0x00000000bfbfefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000bfbff000-0x00000000bfbfffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bfc00000-0x00000000dfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ffc00000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000011effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: TOSHIBA SATELLITE C50D-A-133/PT10AN, BIOS 1.20 08/30/2013
[    0.000000] Kernel/User page tables isolation: disabled
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x11f000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-FFFFF write-through
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0000000000 mask FF80000000 write-back
[    0.000000]   1 base 0080000000 mask FFC0000000 write-back
[    0.000000]   2 base 00BFB77000 mask FFFFFFF000 uncachable
[    0.000000]   3 base 00FFC00000 mask FFFFC00000 write-protect
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] TOM2: 000000011f000000 aka 4592M
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: last_pfn = 0xbfc00 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fe200-0x000fe20f] mapped at [ffff9f0ac00fe200]
[    0.000000] Base memory trampoline at [ffff9f0ac0099000] 99000 size 24576
[    0.000000] Using GB pages for direct mapping
[    0.000000] BRK [0x5cb35000, 0x5cb35fff] PGTABLE
[    0.000000] BRK [0x5cb36000, 0x5cb36fff] PGTABLE
[    0.000000] BRK [0x5cb37000, 0x5cb37fff] PGTABLE
[    0.000000] BRK [0x5cb38000, 0x5cb38fff] PGTABLE
[    0.000000] BRK [0x5cb39000, 0x5cb39fff] PGTABLE
[    0.000000] BRK [0x5cb3a000, 0x5cb3afff] PGTABLE
[    0.000000] BRK [0x5cb3b000, 0x5cb3bfff] PGTABLE
[    0.000000] BRK [0x5cb3c000, 0x5cb3cfff] PGTABLE
[    0.000000] BRK [0x5cb3d000, 0x5cb3dfff] PGTABLE
[    0.000000] BRK [0x5cb3e000, 0x5cb3efff] PGTABLE
[    0.000000] BRK [0x5cb3f000, 0x5cb3ffff] PGTABLE
[    0.000000] RAMDISK: [mem 0x33bcd000-0x35dddfff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000FE020 000024 (v02 TOSASU)
[    0.000000] ACPI: XSDT 0x00000000BFBFE120 0000BC (v01 TOSASU TOSASU00 00000100      01000013)
[    0.000000] ACPI: FACP 0x00000000BFBFA000 00010C (v05 TOSASU TOSASU00 00000100 ACPI 00040000)
[    0.000000] ACPI: DSDT 0x00000000BFBDE000 017A66 (v01 TOSASU TOSASU00 F0000000 ACPI 00040000)
[    0.000000] ACPI: FACS 0x00000000BFB3D000 000040
[    0.000000] ACPI: ECDT 0x00000000BFBFD000 0000C1 (v01 TOSASU TOSASU00 00000001 ACPI 00040000)
[    0.000000] ACPI: MSDM 0x00000000BFBFC000 000055 (v03 TOSASU TOSASU00 06222004 ACPI 00040000)
[    0.000000] ACPI: UEFI 0x00000000BFBFB000 000236 (v01 TOSASU TOSASU00 00000001 ACPI 00040000)
[    0.000000] ACPI: HPET 0x00000000BFBF9000 000038 (v01 TOSASU TOSASU00 00000001 ACPI 00040000)
[    0.000000] ACPI: APIC 0x00000000BFBF8000 000090 (v03 TOSASU TOSASU00 00000001 ACPI 00040000)
[    0.000000] ACPI: MCFG 0x00000000BFBF7000 00003C (v01 TOSASU TOSASU00 00000001 ACPI 00040000)
[    0.000000] ACPI: ASF! 0x00000000BFBF6000 0000A5 (v32 TOSASU TOSASU00 00000001 ACPI 00040000)
[    0.000000] ACPI: BOOT 0x00000000BFBDD000 000028 (v01 TOSASU TOSASU00 00000001 ACPI 00040000)
[    0.000000] ACPI: SLIC 0x00000000BFBDC000 000176 (v01 TOSASU TOSASU00 00000001 ACPI 00040000)
[    0.000000] ACPI: WDRT 0x00000000BFBDB000 000047 (v01 TOSASU TOSASU00 00000000 ACPI 00040000)
[    0.000000] ACPI: WDAT 0x00000000BFBDA000 0001AC (v01 TOSASU TOSASU00 00000001 ACPI 00040000)
[    0.000000] ACPI: FPDT 0x00000000BFBD8000 000044 (v01 TOSASU TOSASU00 00000001 ACPI 00040000)
[    0.000000] ACPI: SSDT 0x00000000BFBD6000 00043C (v01 INSYDE IS CRB   00000001 ACPI 00040000)
[    0.000000] ACPI: SSDT 0x00000000BFBD1000 0046B7 (v02 INSYDE IS CRB   00000002 ACPI 00040000)
[    0.000000] ACPI: SSDT 0x00000000BFBCF000 00165A (v01 INSYDE IS CRB   00000001 ACPI 00040000)
[    0.000000] ACPI: SSDT 0x00000000BFBCE000 000662 (v01 INSYDE IS CRB   00000001 ACPI 00040000)
[    0.000000] ACPI: SSDT 0x00000000BFBCD000 000D4E (v01 INSYDE IS CRB   00000001 ACPI 00040000)
[    0.000000] ACPI: SSDT 0x00000000BFBCB000 0010C2 (v01 INSYDE IS CRB   00000001 ACPI 00040000)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000011effffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x11effb000-0x11effffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000011effffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000b8d2efff]
[    0.000000]   node   0: [mem 0x00000000b9b30000-0x00000000b9b8bfff]
[    0.000000]   node   0: [mem 0x00000000baf8c000-0x00000000bf58efff]
[    0.000000]   node   0: [mem 0x00000000bfbff000-0x00000000bfbfffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000011effffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000011effffff]
[    0.000000] On node 0 totalpages: 901933
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 12047 pages used for memmap
[    0.000000]   DMA32 zone: 770959 pages, LIFO batch:31
[    0.000000]   Normal zone: 1984 pages used for memmap
[    0.000000]   Normal zone: 126976 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 4, version 33, address 0xfec00000, GSI 0-23
[    0.000000] IOAPIC[1]: apic_id 5, version 33, address 0xfec01000, GSI 24-55
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x10228210 base: 0xfed00000
[    0.000000] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xb8d2f000-0xb9b2ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xb9b8c000-0xbaf8bfff]
[    0.000000] PM: Registered nosave memory: [mem 0xbf58f000-0xbfa8efff]
[    0.000000] PM: Registered nosave memory: [mem 0xbfa8f000-0xbfb8efff]
[    0.000000] PM: Registered nosave memory: [mem 0xbfb8f000-0xbfbfefff]
[    0.000000] PM: Registered nosave memory: [mem 0xbfc00000-0xdfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfec0ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec11000-0xfed7ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed80000-0xfed80fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed81000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xffbfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xffc00000-0xffffffff]
[    0.000000] e820: [mem 0xe0000000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] percpu: Embedded 35 pages/cpu s105304 r8192 d29864 u524288
[    0.000000] pcpu-alloc: s105304 r8192 d29864 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 887817
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-12-amd64 root=UUID=974f57ac-b76b-4f8e-9b66-8da04b588a4d ro quiet splash
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 3433204K/3607732K available (6287K kernel code, 1162K rwdata, 2876K rodata, 1424K init, 660K bss, 174528K reserved, 0K cma-reserved)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:33024 nr_irqs:1000 16
[    0.000000] spurious 8259A interrupt: IRQ7.
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 998.221 MHz processor
[    0.000113] Calibrating delay loop (skipped), value calculated using timer frequency.. 1996.44 BogoMIPS (lpj=3992884)
[    0.000121] pid_max: default: 32768 minimum: 301
[    0.000170] ACPI: Core revision 20160831
[    0.069389] ACPI: 7 ACPI AML tables successfully acquired and loaded
[    0.069565] Security Framework initialized
[    0.069570] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.069587] AppArmor: AppArmor disabled by boot time parameter
[    0.070404] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.073355] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.074863] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.074889] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.075722] mce: CPU supports 6 MCE banks
[    0.075756] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 4
[    0.075759] Last level dTLB entries: 4KB 512, 2MB 256, 4MB 128, 1GB 0
[    0.075763] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.075768] Spectre V2 : Mitigation: Full AMD retpoline
[    0.075769] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.075775] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.097157] Freeing SMP alternatives memory: 24K
[    0.105041] ftrace: allocating 25348 entries in 100 pages
[    0.146813] smpboot: Max logical packages: 2
[    0.147459] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.295175] smpboot: CPU0: AMD E1-2100 APU with Radeon(TM) HD Graphics (family: 0x16, model: 0x0, stepping: 0x1)
[    0.295186] Performance Events: AMD PMU driver.
[    0.295196] ... version:                0
[    0.295198] ... bit width:              48
[    0.295200] ... generic registers:      4
[    0.295202] ... value mask:             0000ffffffffffff
[    0.295204] ... max period:             00007fffffffffff
[    0.295205] ... fixed-purpose events:   0
[    0.295207] ... event mask:             000000000000000f
[    0.296997] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.297538] x86: Booting SMP configuration:
[    0.297542] .... node  #0, CPUs:      #1
[    0.300005] x86: Booted up 1 node, 2 CPUs
[    0.300012] smpboot: Total of 2 processors activated (3992.88 BogoMIPS)
[    0.301302] devtmpfs: initialized
[    0.301544] x86/mm: Memory block size: 128MB
[    0.313941] PM: Registering ACPI NVS region [mem 0xbfa8f000-0xbfb8efff] (1048576 bytes)
[    0.314198] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.314226] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.314349] pinctrl core: initialized pinctrl subsystem
[    0.314753] NET: Registered protocol family 16
[    0.324052] cpuidle: using governor ladder
[    0.336059] cpuidle: using governor menu
[    0.336192] Simple Boot Flag at 0x44 set to 0x1
[    0.336234] ACPI: bus type PCI registered
[    0.336238] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.336524] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.336530] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.336551] PCI: Using configuration type 1 for base access
[    0.337150] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.337152] mtrr: probably your BIOS does not setup all CPUs.
[    0.337153] mtrr: corrected configuration.
[    0.352638] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[    0.352643] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.353587] ACPI: Added _OSI(Module Device)
[    0.353590] ACPI: Added _OSI(Processor Device)
[    0.353592] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.353595] ACPI: Added _OSI(Processor Aggregator Device)
[    0.353625] ACPI : EC: EC started
[    0.353626] ACPI : EC: interrupt blocked
[    0.356606] ACPI: \: Used as first EC
[    0.356611] ACPI: \: GPE=0x1e, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.356615] ACPI: \: Used as boot ECDT EC to handle transactions
[    0.356982] ACPI: Executed 1 blocks of module-level executable AML code
[    0.375636] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    1.005355] ACPI : EC: EC stopped
[    1.005359] ACPI : EC: EC started
[    1.005361] ACPI : EC: interrupt blocked
[    1.005829] ACPI: \_SB_.PCI0.LPC0.EC__: Used as first EC
[    1.005835] ACPI: \_SB_.PCI0.LPC0.EC__: GPE=0x1e, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    1.005840] ACPI: \_SB_.PCI0.LPC0.EC__: Used as boot DSDT EC to handle transactions
[    1.005842] ACPI: Interpreter enabled
[    1.005914] ACPI: (supports S0 S3 S4 S5)
[    1.005917] ACPI: Using IOAPIC for interrupt routing
[    1.006599] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    1.008517] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[    1.010569] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[    1.031849] ACPI: Power Resource [P0L0] (off)
[    1.032019] ACPI: Power Resource [P0L1] (off)
[    1.032185] ACPI: Power Resource [P0L2] (off)
[    1.032353] ACPI: Power Resource [P0L3] (off)
[    1.035820] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    1.035837] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    1.036417] acpi PNP0A08:00: _OSC: platform does not support [PCIeCapability]
[    1.036697] acpi PNP0A08:00: _OSC: not requesting control; platform does not support [PCIeCapability]
[    1.036704] acpi PNP0A08:00: _OSC: OS requested [PCIeHotplug PME AER PCIeCapability]
[    1.036709] acpi PNP0A08:00: _OSC: platform willing to grant [PCIeHotplug PME AER]
[    1.036714] acpi PNP0A08:00: _OSC failed (AE_SUPPORT); disabling ASPM
[    1.036767] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[    1.037091] acpi PNP0A08:00: ignoring host bridge window [mem 0x000cc000-0x000cffff window] (conflicts with Video ROM [mem 0x000c0000-0x000ce9ff])
[    1.037722] PCI host bridge to bus 0000:00
[    1.037729] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    1.037734] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    1.037739] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    1.037744] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    1.037748] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    1.037753] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    1.037757] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    1.037761] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    1.037766] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    1.037770] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    1.037774] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    1.037779] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    1.037783] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[    1.037787] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[    1.037792] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xf7ffffff window]
[    1.037796] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed3ffff window]
[    1.037801] pci_bus 0000:00: root bus resource [mem 0xfed45000-0xffffffff window]
[    1.037806] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.037826] pci 0000:00:00.0: [1022:1536] type 00 class 0x060000
[    1.038131] pci 0000:00:01.0: [1002:9834] type 00 class 0x030000
[    1.038157] pci 0000:00:01.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[    1.038174] pci 0000:00:01.0: reg 0x18: [mem 0xf0000000-0xf07fffff 64bit pref]
[    1.038186] pci 0000:00:01.0: reg 0x20: [io  0x3000-0x30ff]
[    1.038198] pci 0000:00:01.0: reg 0x24: [mem 0xf0a00000-0xf0a3ffff]
[    1.038210] pci 0000:00:01.0: reg 0x30: [mem 0xfffe0000-0xffffffff pref]
[    1.038277] pci 0000:00:01.0: supports D1 D2
[    1.038282] pci 0000:00:01.0: PME# supported from D1 D2 D3hot
[    1.038564] pci 0000:00:01.1: [1002:9840] type 00 class 0x040300
[    1.038587] pci 0000:00:01.1: reg 0x10: [mem 0xf0a40000-0xf0a43fff 64bit]
[    1.038687] pci 0000:00:01.1: supports D1 D2
[    1.038917] pci 0000:00:02.0: [1022:1538] type 00 class 0x060000
[    1.039202] pci 0000:00:02.3: [1022:1439] type 01 class 0x060400
[    1.039329] pci 0000:00:02.3: PME# supported from D0 D3hot D3cold
[    1.039489] pci 0000:00:02.3: System wakeup disabled by ACPI
[    1.039618] pci 0000:00:02.4: [1022:1439] type 01 class 0x060400
[    1.039728] pci 0000:00:02.4: PME# supported from D0 D3hot D3cold
[    1.039945] pci 0000:00:02.4: System wakeup disabled by ACPI
[    1.040100] pci 0000:00:10.0: [1022:7814] type 00 class 0x0c0330
[    1.040130] pci 0000:00:10.0: reg 0x10: [mem 0xf0a48000-0xf0a49fff 64bit]
[    1.040260] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
[    1.040417] pci 0000:00:10.0: System wakeup disabled by ACPI
[    1.040553] pci 0000:00:11.0: [1022:7801] type 00 class 0x010601
[    1.040578] pci 0000:00:11.0: reg 0x10: [io  0x3118-0x311f]
[    1.040590] pci 0000:00:11.0: reg 0x14: [io  0x3124-0x3127]
[    1.040603] pci 0000:00:11.0: reg 0x18: [io  0x3110-0x3117]
[    1.040616] pci 0000:00:11.0: reg 0x1c: [io  0x3120-0x3123]
[    1.040628] pci 0000:00:11.0: reg 0x20: [io  0x3100-0x310f]
[    1.040642] pci 0000:00:11.0: reg 0x24: [mem 0xf0a4e000-0xf0a4e3ff]
[    1.040715] pci 0000:00:11.0: PME# supported from D3hot
[    1.041142] pci 0000:00:12.0: [1022:7807] type 00 class 0x0c0310
[    1.041162] pci 0000:00:12.0: reg 0x10: [mem 0xf0a4d000-0xf0a4dfff]
[    1.041382] pci 0000:00:12.0: System wakeup disabled by ACPI
[    1.041514] pci 0000:00:12.2: [1022:7808] type 00 class 0x0c0320
[    1.044257] pci 0000:00:12.2: reg 0x10: [mem 0xf0a4c000-0xf0a4c0ff]
[    1.060456] pci 0000:00:12.2: supports D1 D2
[    1.060461] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot D3cold
[    1.060611] pci 0000:00:12.2: System wakeup disabled by ACPI
[    1.060740] pci 0000:00:13.0: [1022:7807] type 00 class 0x0c0310
[    1.060759] pci 0000:00:13.0: reg 0x10: [mem 0xf0a4b000-0xf0a4bfff]
[    1.060975] pci 0000:00:13.0: System wakeup disabled by ACPI
[    1.061100] pci 0000:00:13.2: [1022:7808] type 00 class 0x0c0320
[    1.063815] pci 0000:00:13.2: reg 0x10: [mem 0xf0a4a000-0xf0a4a0ff]
[    1.080022] pci 0000:00:13.2: supports D1 D2
[    1.080027] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot D3cold
[    1.080176] pci 0000:00:13.2: System wakeup disabled by ACPI
[    1.080307] pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
[    1.080633] pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
[    1.080661] pci 0000:00:14.2: reg 0x10: [mem 0xf0a44000-0xf0a47fff 64bit]
[    1.080757] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[    1.081013] pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
[    1.081341] pci 0000:00:18.0: [1022:1530] type 00 class 0x060000
[    1.081602] pci 0000:00:18.1: [1022:1531] type 00 class 0x060000
[    1.081854] pci 0000:00:18.2: [1022:1532] type 00 class 0x060000
[    1.082109] pci 0000:00:18.3: [1022:1533] type 00 class 0x060000
[    1.082371] pci 0000:00:18.4: [1022:1534] type 00 class 0x060000
[    1.082629] pci 0000:00:18.5: [1022:1535] type 00 class 0x060000
[    1.083051] pci 0000:01:00.0: [168c:0036] type 00 class 0x028000
[    1.083084] pci 0000:01:00.0: reg 0x10: [mem 0xf0900000-0xf097ffff 64bit]
[    1.083146] pci 0000:01:00.0: reg 0x30: [mem 0xffff0000-0xffffffff pref]
[    1.083257] pci 0000:01:00.0: supports D1 D2
[    1.083261] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.095410] pci 0000:00:02.3: PCI bridge to [bus 01]
[    1.095428] pci 0000:00:02.3:   bridge window [mem 0xf0900000-0xf09fffff]
[    1.095718] pci 0000:02:00.0: [1969:10a0] type 00 class 0x020000
[    1.095757] pci 0000:02:00.0: reg 0x10: [mem 0xf0800000-0xf083ffff 64bit]
[    1.095773] pci 0000:02:00.0: reg 0x18: [io  0x2000-0x207f]
[    1.095994] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.107448] pci 0000:00:02.4: PCI bridge to [bus 02]
[    1.107461] pci 0000:00:02.4:   bridge window [io  0x2000-0x2fff]
[    1.107470] pci 0000:00:02.4:   bridge window [mem 0xf0800000-0xf08fffff]
[    1.110796] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    1.111054] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    1.111338] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    1.111601] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    1.111832] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    1.112000] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    1.112167] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    1.112338] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    1.113687] ACPI: Enabled 1 GPEs in block 00 to 1F
[    1.114345] ACPI : EC: interrupt unblocked
[    1.114354] ACPI : EC: event unblocked
[    1.114398] ACPI: \_SB_.PCI0.LPC0.EC__: GPE=0x1e, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    1.114404] ACPI: \_SB_.PCI0.LPC0.EC__: Used as boot DSDT EC to handle transactions and events
[    1.114986] vgaarb: setting as boot device: PCI:0000:00:01.0
[    1.114990] vgaarb: device added: PCI:0000:00:01.0,decodes=io+mem,owns=io+mem,locks=none
[    1.115003] vgaarb: loaded
[    1.115006] vgaarb: bridge control possible 0000:00:01.0
[    1.115302] PCI: Using ACPI for IRQ routing
[    1.117437] PCI: pci_cache_line_size set to 64 bytes
[    1.117641] e820: reserve RAM buffer [mem 0x0009f400-0x0009ffff]
[    1.117646] e820: reserve RAM buffer [mem 0xb8d2f000-0xbbffffff]
[    1.117649] e820: reserve RAM buffer [mem 0xb9b8c000-0xbbffffff]
[    1.117652] e820: reserve RAM buffer [mem 0xbf58f000-0xbfffffff]
[    1.117656] e820: reserve RAM buffer [mem 0xbfc00000-0xbfffffff]
[    1.117659] e820: reserve RAM buffer [mem 0x11f000000-0x11fffffff]
[    1.118192] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    1.118203] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    1.120292] clocksource: Switched to clocksource hpet
[    1.144436] VFS: Disk quotas dquot_6.6.0
[    1.144508] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.144784] pnp: PnP ACPI init
[    1.145353] system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
[    1.145359] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
[    1.145372] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.145907] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    1.146023] pnp 00:02: Plug and Play ACPI device, IDs TOS1103 PNPc030 PNP0303 (active)
[    1.146120] pnp 00:03: Plug and Play ACPI device, IDs TTP0210 PNP0f13 (active)
[    1.146288] system 00:04: [io  0x025c-0x025d] has been reserved
[    1.146294] system 00:04: [io  0x0400-0x04cf] has been reserved
[    1.146300] system 00:04: [io  0x04d0-0x04d1] has been reserved
[    1.146305] system 00:04: [io  0x04d6] has been reserved
[    1.146310] system 00:04: [io  0x0680-0x06ff] has been reserved
[    1.146315] system 00:04: [io  0x077a] has been reserved
[    1.146320] system 00:04: [io  0x0c00-0x0c01] has been reserved
[    1.146325] system 00:04: [io  0x0c14] has been reserved
[    1.146330] system 00:04: [io  0x0c50-0x0c52] has been reserved
[    1.146335] system 00:04: [io  0x0c6c] has been reserved
[    1.146340] system 00:04: [io  0x0c6f] has been reserved
[    1.146345] system 00:04: [io  0x0cd0-0x0cdb] has been reserved
[    1.146350] system 00:04: [io  0x0840-0x0847] has been reserved
[    1.146359] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.146633] system 00:05: [mem 0x000e0000-0x000fffff] could not be reserved
[    1.146640] system 00:05: [mem 0xffc00000-0xffffffff] has been reserved
[    1.146648] system 00:05: Plug and Play ACPI device, IDs PNP0c01 (active)
[    1.148693] pnp: PnP ACPI: found 6 devices
[    1.160607] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    1.160630] pci 0000:00:01.0: can't claim BAR 6 [mem 0xfffe0000-0xffffffff pref]: address conflict with reserved [mem 0xffc00000-0xffffffff]
[    1.160637] pci 0000:01:00.0: can't claim BAR 6 [mem 0xffff0000-0xffffffff pref]: no compatible bridge window
[    1.160703] pci 0000:00:01.0: BAR 6: assigned [mem 0xf0a60000-0xf0a7ffff pref]
[    1.160715] pci 0000:01:00.0: BAR 6: assigned [mem 0xf0980000-0xf098ffff pref]
[    1.160720] pci 0000:00:02.3: PCI bridge to [bus 01]
[    1.160730] pci 0000:00:02.3:   bridge window [mem 0xf0900000-0xf09fffff]
[    1.160743] pci 0000:00:02.4: PCI bridge to [bus 02]
[    1.160748] pci 0000:00:02.4:   bridge window [io  0x2000-0x2fff]
[    1.160756] pci 0000:00:02.4:   bridge window [mem 0xf0800000-0xf08fffff]
[    1.160773] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    1.160778] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    1.160783] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    1.160787] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    1.160792] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    1.160796] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    1.160801] pci_bus 0000:00: resource 10 [mem 0x000d0000-0x000d3fff window]
[    1.160805] pci_bus 0000:00: resource 11 [mem 0x000d4000-0x000d7fff window]
[    1.160810] pci_bus 0000:00: resource 12 [mem 0x000d8000-0x000dbfff window]
[    1.160814] pci_bus 0000:00: resource 13 [mem 0x000dc000-0x000dffff window]
[    1.160818] pci_bus 0000:00: resource 14 [mem 0x000e0000-0x000e3fff window]
[    1.160823] pci_bus 0000:00: resource 15 [mem 0x000e4000-0x000e7fff window]
[    1.160827] pci_bus 0000:00: resource 16 [mem 0x000e8000-0x000ebfff window]
[    1.160831] pci_bus 0000:00: resource 17 [mem 0x000ec000-0x000effff window]
[    1.160836] pci_bus 0000:00: resource 18 [mem 0xe0000000-0xf7ffffff window]
[    1.160840] pci_bus 0000:00: resource 19 [mem 0xfc000000-0xfed3ffff window]
[    1.160844] pci_bus 0000:00: resource 20 [mem 0xfed45000-0xffffffff window]
[    1.160849] pci_bus 0000:01: resource 1 [mem 0xf0900000-0xf09fffff]
[    1.160854] pci_bus 0000:02: resource 0 [io  0x2000-0x2fff]
[    1.160858] pci_bus 0000:02: resource 1 [mem 0xf0800000-0xf08fffff]
[    1.161290] NET: Registered protocol family 2
[    1.161846] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.162104] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.162315] TCP: Hash tables configured (established 32768 bind 32768)
[    1.162412] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.162465] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.162687] NET: Registered protocol family 1
[    1.162738] pci 0000:00:01.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    1.364857] pci 0000:02:00.0: set MSI_INTX_DISABLE_BUG flag
[    1.364906] PCI: CLS 64 bytes, default 64
[    1.365074] Unpacking initramfs...
[    3.150146] Freeing initrd memory: 34884K
[    3.150256] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    3.150261] software IO TLB: mapped [mem 0xbb58f000-0xbf58f000] (64MB)
[    3.150356] perf: AMD NB counters detected
[    3.150363] perf: AMD LLC counters detected
[    3.150468] LVT offset 0 assigned for vector 0x400
[    3.150523] perf: AMD IBS detected (0x000000ff)
[    3.151609] audit: initializing netlink subsys (disabled)
[    3.151661] audit: type=2000 audit(1587749159.140:1): initialized
[    3.153096] workingset: timestamp_bits=40 max_order=20 bucket_order=0
[    3.153170] zbud: loaded
[    3.155603] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    3.155705] io scheduler noop registered
[    3.155707] io scheduler deadline registered
[    3.155769] io scheduler cfq registered (default)
[    3.156702] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    3.156720] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    3.157282] GHES: HEST is not enabled!
[    3.157495] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    3.158988] Linux agpgart interface v0.103
[    3.159679] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    3.159681] AMD IOMMUv2 functionality not available on this system
[    3.160256] i8042: PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    3.163941] i8042: Detected active multiplexing controller, rev 1.1
[    3.165311] serio: i8042 KBD port at 0x60,0x64 irq 1
[    3.165327] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[    3.165439] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[    3.165539] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[    3.165638] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[    3.166139] mousedev: PS/2 mouse device common for all mice
[    3.166252] rtc_cmos 00:01: RTC can wake from S4
[    3.166513] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    3.166550] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[    3.166661] ledtrig-cpu: registered to indicate activity on CPUs
[    3.167514] x86/pm: family 0x16 cpu detected, MSR saving is needed during suspending.
[    3.167792] NET: Registered protocol family 10
[    3.168502] mip6: Mobile IPv6
[    3.168507] NET: Registered protocol family 17
[    3.168513] mpls_gso: MPLS GSO support
[    3.169013] microcode: CPU0: patch_level=0x0700010b
[    3.169033] microcode: CPU1: patch_level=0x0700010b
[    3.169151] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    3.169612] registered taskstats version 1
[    3.169654] zswap: loaded using pool lzo/zbud
[    3.169899] ima: No TPM chip found, activating TPM-bypass!
[    3.169905] ima: Allocated hash algorithm: sha256
[    3.170878] rtc_cmos 00:01: setting system clock to 2020-04-24 17:26:00 UTC (1587749160)
[    3.171081] PM: Hibernation image not present or could not be loaded.
[    4.168067] tsc: Refined TSC clocksource calibration: 998.127 MHz
[    4.168075] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1cc65b93289, max_idle_ns: 881590487074 ns
[    4.389656] Freeing unused kernel memory: 1424K
[    4.389661] Write protecting the kernel read-only data: 12288k
[    4.394882] Freeing unused kernel memory: 1888K
[    4.394886] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    4.404715] Freeing unused kernel memory: 1220K
[    4.411022] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[    4.411028] atkbd serio0: Use 'setkeycodes 7c <keycode>' to make it known.
[    4.423768] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    4.613266] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[    4.613272] atkbd serio0: Use 'setkeycodes 7c <keycode>' to make it known.
[    4.705413] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    4.705729] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    4.705768] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    4.810198] ACPI: Video Device [VGA] (multi-head: yes  rom: no  post: no)
[    4.810412] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[    4.811138] acpi device:00: registered as cooling_device2
[    4.811338] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
[    4.814290] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[    4.814303] ACPI: Power Button [PWRB]
[    4.817283] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[    4.817289] atkbd serio0: Use 'setkeycodes 7c <keycode>' to make it known.
[    4.824362] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input6
[    4.826012] pci_bus 0000:01: Allocating resources
[    4.826038] pcieport 0000:00:02.3: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
[    4.826047] pcieport 0000:00:02.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[    4.826060] pci_bus 0000:02: Allocating resources
[    4.826119] pcieport 0000:00:02.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[    4.826135] pcieport 0000:00:02.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    4.826141] pcieport 0000:00:02.3: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    4.826147] pcieport 0000:00:02.4: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    4.826152] pcieport 0000:00:02.4: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    4.826158] pcieport 0000:00:02.3: res[13]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    4.826163] pcieport 0000:00:02.3: res[13]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    4.826207] pcieport 0000:00:02.3: BAR 15: assigned [mem 0xf0b00000-0xf0cfffff 64bit pref]
[    4.826241] pcieport 0000:00:02.4: BAR 15: assigned [mem 0xf0d00000-0xf0efffff 64bit pref]
[    4.826253] pcieport 0000:00:02.3: BAR 13: assigned [io  0x1000-0x1fff]
[    4.836245] ACPI: Lid Switch [LID]
[    4.836465] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input7
[    4.836475] ACPI: Power Button [PWRF]
[    4.838212] pci_bus 0000:01: Allocating resources
[    4.838241] pci_bus 0000:02: Allocating resources
[    4.858227] thermal LNXTHERM:00: registered as thermal_zone0
[    4.858232] ACPI: Thermal Zone [THZ0] (50 C)
[    4.859926] wmi: Mapper loaded
[    4.871702] ACPI: bus type USB registered
[    4.871796] usbcore: registered new interface driver usbfs
[    4.871836] usbcore: registered new interface driver hub
[    4.871897] [drm] Initialized
[    4.877418] usbcore: registered new device driver usb
[    4.879231] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.880680] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.881333] ehci-pci: EHCI PCI platform driver
[    4.897953] ehci-pci 0000:00:12.2: EHCI Host Controller
[    4.897975] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
[    4.897989] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    4.898002] ehci-pci 0000:00:12.2: debug port 1
[    4.898097] ehci-pci 0000:00:12.2: irq 17, io mem 0xf0a4c000
[    4.900210] SCSI subsystem initialized
[    4.912002] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[    4.912231] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.912236] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.912241] usb usb1: Product: EHCI Host Controller
[    4.912245] usb usb1: Manufacturer: Linux 4.9.0-12-amd64 ehci_hcd
[    4.912249] usb usb1: SerialNumber: 0000:00:12.2
[    4.912688] hub 1-0:1.0: USB hub found
[    4.912718] hub 1-0:1.0: 4 ports detected
[    4.913757] ehci-pci 0000:00:13.2: EHCI Host Controller
[    4.913776] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 2
[    4.913790] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    4.913803] ehci-pci 0000:00:13.2: debug port 1
[    4.913865] ehci-pci 0000:00:13.2: irq 17, io mem 0xf0a4a000
[    4.914199] alx 0000:02:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [54:be:f7:8c:ce:78]
[    4.918649] libata version 3.00 loaded.
[    4.928502] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[    4.928716] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.928721] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.928725] usb usb2: Product: EHCI Host Controller
[    4.928729] usb usb2: Manufacturer: Linux 4.9.0-12-amd64 ehci_hcd
[    4.928733] usb usb2: SerialNumber: 0000:00:13.2
[    4.929232] hub 2-0:1.0: USB hub found
[    4.929261] hub 2-0:1.0: 4 ports detected
[    4.930832] ohci-pci: OHCI PCI platform driver
[    4.931238] ohci-pci 0000:00:12.0: OHCI PCI host controller
[    4.931258] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 3
[    4.931341] ohci-pci 0000:00:12.0: irq 18, io mem 0xf0a4d000
[    4.940664] AVX version of gcm_enc/dec engaged.
[    4.940667] AES CTR mode by8 optimization enabled
[    4.958465] [drm] radeon kernel modesetting enabled.
[    4.992836] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    4.992843] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.992848] usb usb3: Product: OHCI PCI host controller
[    4.992852] usb usb3: Manufacturer: Linux 4.9.0-12-amd64 ohci_hcd
[    4.992856] usb usb3: SerialNumber: 0000:00:12.0
[    4.993298] hub 3-0:1.0: USB hub found
[    4.993327] hub 3-0:1.0: 4 ports detected
[    4.995139] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\_SB.PCI0.SMBS.SMB0) (20160831/utaddress-247)
[    4.995156] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    4.995525] xhci_hcd 0000:00:10.0: xHCI Host Controller
[    4.995545] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 4
[    4.995781] xhci_hcd 0000:00:10.0: hcc params 0x014040c3 hci version 0x100 quirks 0x00000410
[    4.996225] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    4.996231] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.996235] usb usb4: Product: xHCI Host Controller
[    4.996239] usb usb4: Manufacturer: Linux 4.9.0-12-amd64 xhci-hcd
[    4.996243] usb usb4: SerialNumber: 0000:00:10.0
[    4.996723] hub 4-0:1.0: USB hub found
[    4.996757] hub 4-0:1.0: 2 ports detected
[    4.997138] xhci_hcd 0000:00:10.0: xHCI Host Controller
[    4.997150] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 5
[    4.999998] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.000103] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[    5.000111] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.000115] usb usb5: Product: xHCI Host Controller
[    5.000123] usb usb5: Manufacturer: Linux 4.9.0-12-amd64 xhci-hcd
[    5.000131] usb usb5: SerialNumber: 0000:00:10.0
[    5.000721] hub 5-0:1.0: USB hub found
[    5.000749] hub 5-0:1.0: 2 ports detected
[    5.001191] ahci 0000:00:11.0: version 3.0
[    5.001709] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    5.001718] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp fbs pio slum part
[    5.006916] scsi host0: ahci
[    5.007299] scsi host1: ahci
[    5.007483] ata1: SATA max UDMA/133 abar m1024@0xf0a4e000 port 0xf0a4e100 irq 30
[    5.007489] ata2: SATA max UDMA/133 abar m1024@0xf0a4e000 port 0xf0a4e180 irq 30
[    5.021212] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[    5.021219] atkbd serio0: Use 'setkeycodes 7c <keycode>' to make it known.
[    5.033070] alx 0000:02:00.0 enp2s0: renamed from eth0
[    5.046769] CRAT table not found
[    5.046773] Finished initializing topology ret=0
[    5.047834] kfd kfd: Initialized module
[    5.049216] [drm] initializing kernel modesetting (KABINI 0x1002:0x9834 0x1179:0xFA33 0x00).
[    5.049252] [drm] register mmio base: 0xF0A00000
[    5.049254] [drm] register mmio size: 262144
[    5.049266] [drm] doorbell mmio base: 0xF0000000
[    5.049268] [drm] doorbell mmio size: 8388608
[    5.050943] ATOM BIOS: AMD
[    5.051009] [drm] Changing default dispclk from 300Mhz to 600Mhz
[    5.051046] radeon 0000:00:01.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
[    5.051051] radeon 0000:00:01.0: GTT: 2048M 0x0000000020000000 - 0x000000009FFFFFFF
[    5.051066] [drm] Detected VRAM RAM=512M, BAR=256M
[    5.051068] [drm] RAM width 128bits DDR
[    5.051251] [TTM] Zone  kernel: Available graphics memory: 1736322 kiB
[    5.051254] [TTM] Initializing pool allocator
[    5.051268] [TTM] Initializing DMA pool allocator
[    5.051328] [drm] radeon: 512M of VRAM memory ready
[    5.051331] [drm] radeon: 2048M of GTT memory ready.
[    5.051372] [drm] Loading kabini Microcode
[    5.051450] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/kabini_pfp.bin
[    5.051511] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/kabini_me.bin
[    5.051568] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/kabini_ce.bin
[    5.051637] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/kabini_mec.bin
[    5.051695] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/kabini_rlc.bin
[    5.051748] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/kabini_sdma.bin
[    5.051757] [drm] Internal thermal controller without fan control
[    5.052874] [drm] radeon: dpm initialized
[    5.053132] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/bonaire_uvd.bin
[    5.053144] [drm] Found UVD firmware Version: 1.64 Family ID: 9
[    5.053364] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/BONAIRE_vce.bin
[    5.057168] [drm] Found VCE firmware/feedback version 40.2.2 / 15!
[    5.057206] [drm] GART: num cpu pages 524288, num gpu pages 524288
[    5.091902] [drm] PCIE GART of 2048M enabled (table at 0x000000000030E000).
[    5.092249] radeon 0000:00:01.0: WB enabled
[    5.092279] radeon 0000:00:01.0: fence driver on ring 0 use gpu addr 0x0000000020000c00 and cpu addr 0xffff9f0bd1e38c00
[    5.092284] radeon 0000:00:01.0: fence driver on ring 1 use gpu addr 0x0000000020000c04 and cpu addr 0xffff9f0bd1e38c04
[    5.092289] radeon 0000:00:01.0: fence driver on ring 2 use gpu addr 0x0000000020000c08 and cpu addr 0xffff9f0bd1e38c08
[    5.092294] radeon 0000:00:01.0: fence driver on ring 3 use gpu addr 0x0000000020000c0c and cpu addr 0xffff9f0bd1e38c0c
[    5.092299] radeon 0000:00:01.0: fence driver on ring 4 use gpu addr 0x0000000020000c10 and cpu addr 0xffff9f0bd1e38c10
[    5.093183] radeon 0000:00:01.0: fence driver on ring 5 use gpu addr 0x0000000000078d30 and cpu addr 0xffffb07141038d30
[    5.093529] radeon 0000:00:01.0: fence driver on ring 6 use gpu addr 0x0000000020000c18 and cpu addr 0xffff9f0bd1e38c18
[    5.093533] radeon 0000:00:01.0: fence driver on ring 7 use gpu addr 0x0000000020000c1c and cpu addr 0xffff9f0bd1e38c1c
[    5.093537] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    5.093539] [drm] Driver supports precise vblank timestamp query.
[    5.093636] radeon 0000:00:01.0: radeon: using MSI.
[    5.093685] [drm] radeon: irq initialized.
[    5.099440] [drm] ring test on 0 succeeded in 3 usecs
[    5.099557] [drm] ring test on 1 succeeded in 3 usecs
[    5.099586] [drm] ring test on 2 succeeded in 3 usecs
[    5.099875] [drm] ring test on 3 succeeded in 5 usecs
[    5.099885] [drm] ring test on 4 succeeded in 4 usecs
[    5.145746] [drm] ring test on 5 succeeded in 2 usecs
[    5.165628] [drm] UVD initialized successfully.
[    5.275040] [drm] ring test on 6 succeeded in 18 usecs
[    5.275054] [drm] ring test on 7 succeeded in 3 usecs
[    5.275056] [drm] VCE initialized successfully.
[    5.275060] clocksource: Switched to clocksource tsc
[    5.278578] [drm] ib test on ring 0 succeeded in 0 usecs
[    5.289514] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[    5.289520] atkbd serio0: Use 'setkeycodes 7c <keycode>' to make it known.
[    5.331981] usb 1-4: new high-speed USB device number 2 using ehci-pci
[    5.332028] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    5.482905] usb 2-1: New USB device found, idVendor=058f, idProduct=6366
[    5.482912] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.482916] usb 2-1: Product: Flash Card Reader/Writer
[    5.482920] usb 2-1: Manufacturer: Generic
[    5.482924] usb 2-1: SerialNumber: 058F63666485
[    5.489495] usb-storage 2-1:1.0: USB Mass Storage device detected
[    5.490290] scsi host2: usb-storage 2-1:1.0
[    5.490554] usbcore: registered new interface driver usb-storage
[    5.491848] usbcore: registered new interface driver uas
[    5.493262] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[    5.493268] atkbd serio0: Use 'setkeycodes 7c <keycode>' to make it known.
[    5.506268] usb 1-4: New USB device found, idVendor=04f2, idProduct=b3b1
[    5.506275] usb 1-4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    5.506280] usb 1-4: Product: TOSHIBA Web Camera - HD
[    5.506284] usb 1-4: Manufacturer: Chicony Electronics Co.,Ltd.
[    5.506287] usb 1-4: SerialNumber: 0x0001
[    5.540056] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    5.540091] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    5.542040] ata2.00: ATAPI: TSSTcorp CDDVDW SU-208DB, TF01, max UDMA/100
[    5.544923] ata2.00: configured for UDMA/100
[    5.566356] ata1.00: ATA-8: TOSHIBA MQ01ABF050, AM003M, max UDMA/100
[    5.566363] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    5.568271] ata1.00: configured for UDMA/100
[    5.568871] scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MQ01ABF0 3M   PQ: 0 ANSI: 5
[    5.601333] scsi 1:0:0:0: CD-ROM            TSSTcorp CDDVDW SU-208DB  TF01 PQ: 0 ANSI: 5
[    5.619861] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    5.620068] sd 0:0:0:0: [sda] Write Protect is off
[    5.620075] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    5.620150] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.636095] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    5.636102] cdrom: Uniform CD-ROM driver Revision: 3.20
[    5.636680] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    5.697381]  sda: sda1 sda3
[    5.698529] sd 0:0:0:0: [sda] Attached SCSI disk
[    5.799995] [drm] ib test on ring 1 succeeded in 0 usecs
[    6.094948] random: fast init done
[    6.312105] [drm] ib test on ring 2 succeeded in 0 usecs
[    6.312207] [drm] ib test on ring 3 succeeded in 0 usecs
[    6.312287] [drm] ib test on ring 4 succeeded in 0 usecs
[    6.506024] scsi 2:0:0:0: Direct-Access     Multiple Card  Reader     1.00 PQ: 0 ANSI: 4
[    6.510590] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[    6.631977] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio4/input/input12
[    6.856043] [drm] ib test on ring 5 succeeded
[    6.876923] [drm] ib test on ring 6 succeeded
[    6.877685] [drm] ib test on ring 7 succeeded
[    6.951914] [drm] radeon atom DIG backlight initialized
[    6.951922] [drm] Radeon Display Connectors
[    6.951927] [drm] Connector 0:
[    6.951929] [drm]   LVDS-1
[    6.951931] [drm]   HPD1
[    6.951935] [drm]   DDC: 0x6530 0x6530 0x6534 0x6534 0x6538 0x6538 0x653c 0x653c
[    6.951937] [drm]   Encoders:
[    6.951938] [drm]     LCD1: INTERNAL_UNIPHY
[    6.951940] [drm] Connector 1:
[    6.951942] [drm]   HDMI-A-1
[    6.951943] [drm]   HPD2
[    6.951947] [drm]   DDC: 0x6540 0x6540 0x6544 0x6544 0x6548 0x6548 0x654c 0x654c
[    6.951948] [drm]   Encoders:
[    6.951950] [drm]     DFP1: INTERNAL_UNIPHY
[    6.951951] [drm] Connector 2:
[    6.951953] [drm]   VGA-1
[    6.951957] [drm]   DDC: 0x65c0 0x65c0 0x65c4 0x65c4 0x65c8 0x65c8 0x65cc 0x65cc
[    6.951958] [drm]   Encoders:
[    6.951960] [drm]     CRT1: INTERNAL_KLDSCP_DAC1
[    7.961982] [drm] fb mappable at 0xE0722000
[    7.961986] [drm] vram apper at 0xE0000000
[    7.961989] [drm] size 4325376
[    7.961991] [drm] fb depth is 24
[    7.961992] [drm]    pitch is 5632
[    7.962260] fbcon: radeondrmfb (fb0) is primary device
[    8.070258] Console: switching to colour frame buffer device 170x48
[    8.080580] radeon 0000:00:01.0: fb0: radeondrmfb frame buffer device
[    8.104826] [drm] Initialized radeon 2.49.0 20080528 for 0000:00:01.0 on minor 0
[    8.105121] ohci-pci 0000:00:13.0: OHCI PCI host controller
[    8.105140] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 6
[    8.105211] ohci-pci 0000:00:13.0: irq 18, io mem 0xf0a4b000
[    8.167988] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    8.167994] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.167998] usb usb6: Product: OHCI PCI host controller
[    8.168002] usb usb6: Manufacturer: Linux 4.9.0-12-amd64 ohci_hcd
[    8.168006] usb usb6: SerialNumber: 0000:00:13.0
[    8.168514] hub 6-0:1.0: USB hub found
[    8.168541] hub 6-0:1.0: 4 ports detected
[    8.183263] device-mapper: uevent: version 1.0.3
[    8.183494] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    8.479775] raid6: sse2x1   gen()   438 MB/s
[    8.547634] raid6: sse2x1   xor()  1080 MB/s
[    8.615619] raid6: sse2x2   gen()  1647 MB/s
[    8.683621] raid6: sse2x2   xor()  1359 MB/s
[    8.751624] raid6: sse2x4   gen()  2179 MB/s
[    8.819596] raid6: sse2x4   xor()  1523 MB/s
[    8.819601] raid6: using algorithm sse2x4 gen() 2179 MB/s
[    8.819602] raid6: .... xor() 1523 MB/s, rmw enabled
[    8.819605] raid6: using ssse3x2 recovery algorithm
[    8.820444] xor: automatically using best checksumming function   avx
[    8.838510] Btrfs loaded, crc32c=crc32c-intel
[    9.381186] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   10.078336] random: crng init done
[   10.078342] random: 7 urandom warning(s) missed due to ratelimiting
[   10.921090] ip_tables: (C) 2000-2006 Netfilter Core Team
[   11.060637] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[   11.061271] systemd[1]: Detected architecture x86-64.
[   11.080995] systemd[1]: Set hostname to <tresorier>.
[   13.184423] systemd[1]: Listening on Journal Audit Socket.
[   13.184693] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   13.185227] systemd[1]: Created slice User and Session Slice.
[   13.185326] systemd[1]: Listening on fsck to fsckd communication Socket.
[   13.185454] systemd[1]: Listening on Journal Socket (/dev/log).
[   13.185632] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   13.185770] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   13.805014] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   14.024121] systemd-journald[237]: Received request to flush runtime journal from PID 1
[   14.157907] lp: driver loaded but no devices found
[   14.294186] ppdev: user-space parallel port driver
[   14.483589] Key type encrypted registered
[   15.403745] acpi_cpufreq: overriding BIOS provided _PSD data
[   15.560269] ACPI: AC Adapter [AC0] (on-line)
[   15.589394] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   15.667875] ACPI: Battery Slot [BAT0] (battery absent)
[   15.807756] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   15.807875] sr 1:0:0:0: Attached scsi generic sg1 type 5
[   15.808001] sd 2:0:0:0: Attached scsi generic sg2 type 0
[   15.813536] toshiba_bluetooth: Toshiba ACPI Bluetooth device driver
[   16.033828] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
[   16.241871] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input13
[   16.260412] toshiba_acpi: Toshiba Laptop ACPI Extras version 0.24
[   16.307505] toshiba_acpi: WMI event detected, hotkeys will not be monitored
[   16.424130] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver v0.05
[   16.424320] sp5100_tco: PCI Vendor ID: 0x1022, Device ID: 0x780b, Revision ID: 0x3a
[   16.424386] sp5100_tco: Using 0xfed80b00 for watchdog MMIO address
[   16.424398] sp5100_tco: Last reboot was not triggered by watchdog.
[   16.424808] sp5100_tco: initialized (0xffffb07140726b00). heartbeat=60 sec (nowayout=0)
[   16.440071] snd_hda_codec_idt hdaudioC1D0: autoconfig for 92HD95: line_outs=1 (0xd/0x0/0x0/0x0/0x0) type:speaker
[   16.440085] snd_hda_codec_idt hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   16.440091] snd_hda_codec_idt hdaudioC1D0:    hp_outs=1 (0xa/0x0/0x0/0x0/0x0)
[   16.440095] snd_hda_codec_idt hdaudioC1D0:    mono: mono_out=0x0
[   16.440099] snd_hda_codec_idt hdaudioC1D0:    inputs:
[   16.440104] snd_hda_codec_idt hdaudioC1D0:      Internal Mic=0xe
[   16.440109] snd_hda_codec_idt hdaudioC1D0:      Mic=0xb
[   16.479174] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/sound/card1/input14
[   16.480067] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input15
[   16.480275] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:14.2/sound/card1/input16
[   16.599002] usb 3-3: new full-speed USB device number 2 using ohci-pci
[   16.870522] ath: phy0: WB335 2-ANT card detected
[   16.870527] ath: phy0: Set BT/WLAN RX diversity capability
[   16.870986] toshiba_acpi: Supported laptop features: touchpad special-function-keys panel-power-on usb3 cooling-method
[   16.879805] ath: phy0: Enable LNA combining
[   16.883648] ath: phy0: ASPM enabled: 0x42
[   16.883654] ath: EEPROM regdomain: 0x65
[   16.883656] ath: EEPROM indicates we should expect a direct regpair map
[   16.883660] ath: Country alpha2 being used: 00
[   16.883661] ath: Regpair used: 0x65
[   16.897368] input: PC Speaker as /devices/platform/pcspkr/input/input17
[   16.922039] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   16.922797] ieee80211 phy0: Atheros AR9565 Rev:0 mem=0xffffb07142080000, irq=36
[   17.439709] kvm: Nested Virtualization enabled
[   17.439716] kvm: Nested Paging enabled
[   17.495893] EDAC MC: Ver: 3.0.0
[   17.689925] fuse init (API version 7.26)
[   17.736009] MCE: In-kernel MCE decoding enabled.
[   17.737632] EDAC amd64: DRAM ECC disabled.
[   17.737643] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
                Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
                (Note that use of the override may cause unknown side effects.)
[   17.772476] EDAC amd64: DRAM ECC disabled.
[   17.772487] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[   19.345269] ath9k 0000:01:00.0 wlp1s0: renamed from wlan0
[   22.831044] media: Linux media interface: v0.10
[   22.860053] Linux video capture interface: v2.00
[   22.921418] uvcvideo: Found UVC 1.00 device TOSHIBA Web Camera - HD (04f2:b3b1)
[   22.923390] uvcvideo 1-4:1.0: Entity type for entity Extension 4 was not initialized!
[   22.923403] uvcvideo 1-4:1.0: Entity type for entity Processing 2 was not initialized!
[   22.923410] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[   22.923729] input: TOSHIBA Web Camera - HD as /devices/pci0000:00/0000:00:12.2/usb1/1-4/1-4:1.0/input/input18
[   22.924008] usbcore: registered new interface driver uvcvideo
[   22.924011] USB Video Class driver (1.1.1)
[   24.099574] input: BRLTTY 5.4 Linux Screen Driver Keyboard as /devices/virtual/input/input19
[   32.106044] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[   32.107421] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[   32.108215] alx 0000:02:00.0 enp2s0: NIC Up: 100 Mbps Full
[   32.108438] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[   32.132118] IPv6: ADDRCONF(NETDEV_UP): wlp1s0: link is not ready
[ 1317.443744] usb 3-1: new low-speed USB device number 3 using ohci-pci
[ 1317.625856] usb 3-1: New USB device found, idVendor=04b3, idProduct=3107
[ 1317.625865] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1318.078894] hidraw: raw HID events driver (C) Jiri Kosina
[ 1318.098082] usbcore: registered new interface driver usbhid
[ 1318.098086] usbhid: USB HID core driver
[ 1318.135184] input: HID 04b3:3107 as /devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.0/0003:04B3:3107.0001/input/input20
[ 1318.196545] hid-generic 0003:04B3:3107.0001: input,hidraw0: USB HID v11.10 Mouse [HID 04b3:3107] on usb-0000:00:12.0-1/input0
[ 4798.846745] perf: interrupt took too long (2507 > 2500), lowering kernel.perf_event_max_sample_rate to 79750
[ 5450.985387] perf: interrupt took too long (3139 > 3133), lowering kernel.perf_event_max_sample_rate to 63500
[ 7255.725773] perf: interrupt took too long (3937 > 3923), lowering kernel.perf_event_max_sample_rate to 50750
HP G72, Intel P6100 @ 2 GHz x 2, ram 1.8 Go, LMDE 5 Cinnamon 64bit
Toshiba Satellite, AMD E1-2100 APU with Radeon™ HD Graphics × 2; 800-1000 MHz, noyau : 4.19.0-8-amd64, LMDE 4 Debbie,Cinnamon 4.4.8, ram 3.3 Go
OK donc résolu je suppose
Mais fais attention à Zoom...
viewtopic.php?f=23&t=15325&p=172134&hilit=zoom#p172134
C
d2d3
Message par d2d3 »
non non, Cyrille,
le son ne fonctionne qu'uniquement lorsque j'utilise zoom, en dehors de zoom i.e. tout le temps plus de son du tout.
Je ne peux même plus écouter ma radio préférée en jouant aux échecs....snif
je tente une déinstallation de zoom et te dis ce qu'il en est
A+
d2d3
Message par d2d3 »
zoom déinstallé (en mode terminal) rien n'à faire toujours pas de son
Desinstaller / purger pulse audio et le reinstaller ?
d2d3
Message par d2d3 »
merci Cyrille, je tente la manip
une curiosité : sur mon HP zoom+flatpak et j'ai du son, sur le toshiba zoom sans flatpak apparent mais listé avec dpkg .... mais pas de son (sauf pour zoom)
sur le toshiba d'ailleurs, j'ai du faire la dernière mise à jour à la main car il y avait un soucis avec les paquets ou les dépôts...
d2d3
Re: Disparition du son
Message par d2d3 »
voilà ce que je disais, j'ai pas du choisir les bons dépôts et impossible d'installer pulseaudio avec apt-get, ni après un apt-get update.....:
tresorier@tresorier:~$ sudo apt-get install pulseaudio
Les paquets suivants ont été installés automatiquement et ne sont plus nécessaires :
  ibus libxcb-xtest0
Veuillez utiliser « sudo apt autoremove » pour les supprimer.
The following additional packages will be installed:
  pulseaudio-utils
Paquets suggérés :
  pavumeter paman paprefs
  pulseaudio pulseaudio-utils
0 mis à jour, 2 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 1 165 ko dans les archives.
Après cette opération, 6 282 ko d'espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer ? [O/n] o
Err:1 https://deb.debian.org/debian stretch/main amd64 pulseaudio-utils amd64 10.0-1+deb9u1
  Could not resolve host: deb.debian.org
Err:2 https://deb.debian.org/debian stretch/main amd64 pulseaudio amd64 10.0-1+deb9u1
E: Impossible de récupérer https://deb.debian.org/debian/pool/main/p/pulseaudio/pulseaudio-utils_10.0-1+deb9u1_amd64.deb  Could not resolve host: deb.debian.org
E: Impossible de récupérer https://deb.debian.org/debian/pool/main/p/pulseaudio/pulseaudio_10.0-1+deb9u1_amd64.deb  Could not resolve host: deb.debian.org
E: Impossible de récupérer certaines archives, peut-être devrez-vous lancer apt-get update ou essayer avec --fix-missing ?
tresorier@tresorier:~$ sudo apt-get update
Err:1 http://mirrors.ircam.fr/pub/linuxmint cindy InRelease
  Ne parvient pas à résoudre « mirrors.ircam.fr »
Err:2 https://deb.debian.org/debian stretch InRelease
Err:3 https://deb.debian.org/debian stretch-updates InRelease
Err:4 http://security.debian.org stretch/updates InRelease
  Ne parvient pas à résoudre « security.debian.org »
Err:5 http://www.deb-multimedia.org stretch InRelease
  Ne parvient pas à résoudre « www.deb-multimedia.org »
Err:6 https://repo.skype.com/deb stable InRelease
  Could not resolve host: repo.skype.com
W: Impossible de récupérer http://mirrors.ircam.fr/pub/linuxmint/dists/cindy/InRelease  Ne parvient pas à résoudre « mirrors.ircam.fr »
W: Impossible de récupérer https://deb.debian.org/debian/dists/stretch/InRelease  Could not resolve host: deb.debian.org
W: Impossible de récupérer https://deb.debian.org/debian/dists/stretch-updates/InRelease  Could not resolve host: deb.debian.org
W: Impossible de récupérer http://security.debian.org/dists/stretch/updates/InRelease  Ne parvient pas à résoudre « security.debian.org »
W: Impossible de récupérer http://www.deb-multimedia.org/dists/stretch/InRelease  Ne parvient pas à résoudre « www.deb-multimedia.org »
W: Impossible de récupérer https://repo.skype.com/deb/dists/stable/InRelease  Could not resolve host: repo.skype.com
W: Le téléchargement de quelques fichiers d'index a échoué, ils ont été ignorés, ou les anciens ont été utilisés à la place.
d2d3
Message par d2d3 »
bon grosse bêtise,
j'ai changé le dépôt, du coup le toshiba redémarre mais ne trouve plus cinnamon!
oulala et il trouve quoi du coup le toshiba ?
je te dirai :
passe en tty : CTRL ALT F3
renseigne ton login et mot de passe et ensuite :
sudo apt update
sudo apt install --reinstall -f mint-meta-cinnamon
quand il a fini
sudo apt reboot
d2d3
Message par d2d3 »
désolé mais je n'ai pas vu ton post, du coup j'ai tout réinstallé, updaté, etc...(sauf bien sur zoom....), remis le dépot utilisé pour le portable HP (qui lui a du son normal pour un hp :lol: )
c'est toujours le meme pb....
le système ne trouve pas les hauts-parleurs :
les pulseaudio sont bien là :
dpkg --list :
ii  pulseaudio     10.0-1+deb9u amd64        PulseAudio sound server
ii  pulseaudio-mod 10.0-1+deb9u amd64        Bluetooth module for PulseAudio s
ii  pulseaudio-uti 10.0-1+deb9u amd64        Command line tools for the PulseA
Modifié en dernier par Invité le sam. 25 avr. 2020 18:20, modifié 1 fois.
Raison : image mise sur FFLMpics
Lors de la désinstallation, tu as bien fait un purge plutot qu'un remove pour virer les fichiers de conf précédents ?
