videos youtube impossible
gillesch
Re: videos youtube impossible
Message par gillesch »
Bonjour alain,
Le microcode intel est bien installé. les résultats des commandes:
gilles@ASUSGILLES ~ $ inxi -G
Graphics:  Card: Intel Device 22b0
           Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.06hz
           GLX Renderer: Mesa DRI Intel HD Graphics (Cherrytrail)
           GLX Version: 3.0 Mesa 17.2.8
gilles@ASUSGILLES ~ $ glxinfo | grep -i render
direct rendering: Yes
    GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
Extended renderer info (GLX_MESA_query_renderer):
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics (Cherrytrail)
    GL_ARB_compute_shader, GL_ARB_conditional_render_inverted,
    GL_MESA_texture_signed_rgba, GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_light_max_exponent,
    GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
gilles@ASUSGILLES ~ $ glxgears
Running synchronized to the vertical refresh.  The framerate should be
approximately the same as the monitor refresh rate.
316 frames in 5.0 seconds = 63.030 FPS
301 frames in 5.0 seconds = 60.055 FPS
301 frames in 5.0 seconds = 60.051 FPS
301 frames in 5.0 seconds = 60.064 FPS
301 frames in 5.0 seconds = 60.061 FPS
301 frames in 5.0 seconds = 60.045 FPS
301 frames in 5.0 seconds = 60.046 FPS
301 frames in 5.0 seconds = 60.067 FPS
301 frames in 5.0 seconds = 60.044 FPS
301 frames in 5.0 seconds = 60.062 FPS
301 frames in 5.0 seconds = 60.060 FPS
301 frames in 5.0 seconds = 60.059 FPS
301 frames in 5.0 seconds = 60.070 FPS
299 frames in 5.0 seconds = 59.668 FPS
301 frames in 5.0 seconds = 60.058 FPS
301 frames in 5.0 seconds = 60.052 FPS
301 frames in 5.0 seconds = 60.043 FPS
301 frames in 5.0 seconds = 60.100 FPS
301 frames in 5.0 seconds = 60.025 FPS
301 frames in 5.0 seconds = 60.071 FPS
301 frames in 5.0 seconds = 60.073 FPS
301 frames in 5.0 seconds = 60.018 FPS
301 frames in 5.0 seconds = 60.084 FPS
XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
      after 25520 requests (25520 known processed) with 0 events remaining.
Pour la dernière commande: je ne vois rien de particulier et pas d'ecran qui se fige si c'était la question.
charge du processeur: en général 20%, mini 15, maxi 25. les 4 coeurs en même temps.
Bonjour victoria.
Je comprend très bien ce que tu veux dire et j'aurais certainement du installer autre chose sur cet ordi.
Maintenant, que libreoffice ne soit pas très fluide, je ne l'ai jamais ouvert et ça n'a aucune importance pour moi.
Je réexplique:
c'est un ordi secondaire, je l'utilise lorsque je ne suis pas chez moi. c'est à dire : ouverture de pages internet, écoute de spotify (pour avoir la version PC et non téléphone) à l'aide d'une petite carte son pro M-AUDIO et d'un casque BEYERDYNAMICS DT770PRO et visionnage de videos youtube ou replay tv avec le même équipement audio.et c'est tout.
Modifié en dernier par débitant le dim. 17 juin 2018 09:46, modifié 1 fois.
Raison : ajout des balises "code" pour faciliter la lecture du sujet
Laptop ASUS x206ha-fd0018ts. Linux Mint 18.3 Cinnamon 64 bit .Cinnamon 3.6.7
Noyau 4.13.0-43 generic . Atom X5-Z8300 cpu@ 1,44 ghz x4 .memoire 1,8 go.
DD 28 go. Carte graphique Intel corporation device 22b0. Sans dual boot
Salut gillesch ;)
Pourrais tu reprendre ton message et mettre entre balises code le résultat du terminal, ça rend le message plus lisible et plus clair ;)
victoria
Message par victoria »
Maintenant on a la réponse à notre question.
Si glxgears n'a pas figé ni ralentit ton pc, malgré que cette commande fasse volontairement travailler la partie graphique du cpu, ça veut bien dire que ton pc ne supporte pas la charge de cinnamon + le navigateur web + la lecture de vidéos sur YouTube ou tout autre site du genre qui demande de la puissance.
Si glxgears te prends déjà 20% de charge cpu comment veux tu que youtube soit fluide ?!!?
J'en reviens à ce que je disais au début et ce que Alain pense aussi, change d'environnement de bureau.
Si ce n'est qu'un pc d'appoint pourquoi prendre un environnement lourd..
De prendre xfce tu auras que des avantages, avec une meilleure autonomie de batterie parce que le pc forcera moins.
Après c'est toi qui voit.
Mais au final ton problème n'en est pas un, c'est juste un mauvais choix de ta part.. que j'essaie de t'expliquer depuis 4 pages....
victoria a écrit :J'en reviens à ce que je disais au début et ce que Alain pense aussi, change d'environnement de bureau.
zebulon a écrit :Je vois dans ta signature que tu as 1.8 go (2) de ram, ça fait peut être peu pour cinnamon :?
Essaye de voir tes ressources au moment du "bug" tu as une partition swap ?
:l et moi je compte pour du beurre :roll: :mrgreen: :lol:
Souvent le cpu est à fond chez moi, mais ca ne dur pas longtemps, je pense que ca fait pareil chez notre ami "en utilisation normal".
Après c'est sur qu'en regardant des vidéos sur le net, le cpu doit pédaler fort :D
j'ai ajouté les balises "code" merci de les utiliser à l'avenir ;)
débitant a écrit :j'ai ajouté les balises "code" merci de les utiliser à l'avenir ;)
T'es sympa deb, je comptais verrouiller le sujet le temps de le faire, voir même fermer le forum, suivant l'humeur du moment :mrgreen:
mpedro
Message par mpedro »
Est ce que YouTube à un rapport avec cinnamon?
J affirme que 2G de RAM avec cinnamon c'est fluide puisque c'est ce que j'ai avec un HP (voir signature) et avec un mini N150 Samsung porté a 2G (parce que 1G c etait penible avec start office installe d origine et pour allumer Windows) ça passe très bien avec LM 13 jusqu'à LM 15 qui se trouve sur un dd. Sur N150 j avais achete une barette de 2G justement pour la fluidité avec cinnamon en multitaches et plusieurs bureau ouverts. Le problème peut être matériel ou logiciel le swap ou autres mais ce n'est pas directement cinnamon qui est en cause pour le visionnage. Essaye youtube dans un terminal on peut le faire.
Modifié en dernier par mpedro le dim. 17 juin 2018 10:57, modifié 2 fois.
mpedro a écrit :J affirme que 2G de RAM avec cinnamon c'est fluide puisque c'est ce que j'ai avec un HP
Et certains te diront qu'un escargot vas très vite ;)
Tu le dis toi même, les applis mettent un certain temps avant de s'ouvrir ;)
On dira que c'est utilisable. Même si youtube n'a pas de rapport avec cinnamon, prend un bon gros log de traitement vidéos ou images qui n'a pas non plus de rapport et tu verras que ca plante très bien ;)
mpedro
Inutile de rester sur ce sujet alors. Ciao...
Reprendre VLC puisque ça fonctionne sur ton PC
Si avec Windows light ça fonctionnait ça vient logiquement de cinnamon lol
victoria
Oui enfin quand Cinnamon monopolise déjà 700 Mo de ram, juste pour lui sur un démarrage à froid, Chromium en prend autant avec peu d'onglets ouverts, alors avec Youtube qui tourne, oui ça ralenti le pc, je ne vois pas trop ce qu'il y a d'anormal..
Il y a 3/4 de la ram de prise pour une utilisation "basique", alors qu'un pc standard avec 8 Go de ram, jamais tu l'a remplis de moitié, et jamais le pc ralentit...
Et en plus le cpu qui est faiblard, c'est le cocktail parfait pour avoir un pc au ralenti.
Maintenant prends un openbox qui te mange 120 Mo de ram au démarrage, lance Firefox, et va sur Youtube, et tu verra si ce n'est pas plus fluide subitement.
Ca ne sera pas un avion de chasse, et ça ne le sera jamais au vu des caractéristiques du pc, mais avec un autre D.E ça tournera déjà mieux..
Alors pourquoi le demandeur ne teste pas Mint Xfce en live ?!!
Au moins il sera si oui ou non son pc va mieux avec ??
Et ça mettra tout le monde d'accord comme ça, même si on est plus nombreux à penser que Cinnamon n'a rien a faire sur un pc bas de gamme.
Il a qu'à essayé aussi Gnome avec toute la panoplie de logiciels qui tournent en tache de fonds (évolution notamment) et on verra là aussi si le pc ne va pas être au ralenti :l :l
@mpedro
D'ailleurs simple question du dimanche matin.
Comment tu expliques qu'un pc de 15 ans tourne très bien et de façon fluide avec un D.E Lxde, alors que Mate le mettait en difficulté rien que pour aller sur des sites internet (pas de vidéos, ni de flash, ni de htlm5) ???? (expérience avec mon ordinosaure)
A quoi bon les développeurs se cassent la tête à faire des D.E légers si au final selon toi ils ne servent à rien ???
Et qu'un mammouth comme Cinnamon ou Gnome (vu qu'ils sont cousins) peuvent tourner sur des vieux pc ou pc faiblards ??
Et pourquoi un pc est littérallement transformé quand tu passes d'un D.E à un autre ???
Fruit du hasard ??
Effet placebo ??
Hallucination divine ??
mpedro
gillesch a écrit :Bonjour,
impossible de lire des videos sur youtube ou du replay sur les sites des chaines de télé.
VLC fonctionne sans probleme. J ai essayé des extensions firefox mais sans succès.
Le système à pourtant fonctionné juste après l installation de Mint puis plus rien.
Quelqu un aurait il une idée? Je ne sais absolument pas si cela vient du materiel,de MINT, de FIREFOX....
Avant ça marchait et depuis que cinnamon s est réveillé ça marche plus impossible :(
Cinnamon ne est pas le bon compromis ok mais le sujet est plus précis que ça.
un autre DE en live ce sera encore plus lourd pour le proc et la ram mais ça peut voir si ça fonctionne ou pas les accès à youtube
Modifié en dernier par mpedro le dim. 17 juin 2018 11:54, modifié 4 fois.
