Résolu le 17-11-18 Message du journal ACPI, kernel ect...
Ajean
Message par Ajean »
Le journal m'affiche ces erreurs :
12:11:54 kernel: CPU3: Package temperature above threshold, cpu clock throttled (total events = 5)
12:11:54 kernel: CPU5: Package temperature above threshold, cpu clock throttled (total events = 5)
12:11:54 kernel: CPU6: Package temperature above threshold, cpu clock throttled (total events = 5)
12:11:54 kernel: CPU1: Package temperature above threshold, cpu clock throttled (total events = 5)
12:11:54 kernel: CPU2: Package temperature above threshold, cpu clock throttled (total events = 5)
12:11:54 kernel: CPU7: Package temperature above threshold, cpu clock throttled (total events = 5)
12:11:54 kernel: CPU4: Package temperature above threshold, cpu clock throttled (total events = 5)
12:11:54 kernel: CPU0: Package temperature above threshold, cpu clock throttled (total events = 5)
12:11:54 kernel: CPU4: Core temperature above threshold, cpu clock throttled (total events = 5)
12:01:33 kernel: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1)
12:01:33 kernel: CPU2: Package temperature above threshold, cpu clock throttled (total events = 1)
12:01:33 kernel: CPU6: Package temperature above threshold, cpu clock throttled (total events = 1)
12:01:33 kernel: CPU4: Package temperature above threshold, cpu clock throttled (total events = 1)
12:01:33 kernel: CPU7: Package temperature above threshold, cpu clock throttled (total events = 1)
12:01:33 kernel: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1)
12:01:33 kernel: CPU5: Package temperature above threshold, cpu clock throttled (total events = 1)
12:01:33 kernel: CPU3: Package temperature above threshold, cpu clock throttled (total events = 1)
12:01:33 kernel: CPU4: Core temperature above threshold, cpu clock throttled (total events = 1)
12:01:33 kernel: CPU0: Core temperature above threshold, cpu clock throttled (total events = 1)
12:01:30 pulseaudio: [pulseaudio] pid.c: Daemon already running.
12:01:14 lightdm: PAM adding faulty module: pam_kwallet5.so
12:01:11 wpa_supplicant: dbus: Failed to construct signal
12:01:10 systemd-udevd: Invalid rule /etc/udev/rules.d/50-brother-libsane-type1-inst.rules:14: unknown key 'SYSFS{idVendor}'
12:01:09 kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.PEG0.PEGP.DD02._BCL, AE_NOT_FOUND (20170831/psparse-550)
Le système tourne plus ou moins bien a part les ventilateurs qui tournent assez fort et trop souvent a mon goût, j'ai un dual boot avec fenêtre 10 et dessus les mêmes ventilo tourne moins...
Pour ce qui est des messages lié a acpi j'ai :
journalctl |grep acpi
jean@jean-P34V2:~$ journalctl |grep acpi
juil. 09 19:08:57 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 09 19:08:57 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 09 19:08:57 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 09 19:08:57 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 09 19:08:57 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 09 19:08:58 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 09 19:08:58 jean-P34V2 acpid[600]: starting up with netlink and the input layer
juil. 09 19:08:58 jean-P34V2 acpid[600]: 8 rules loaded
juil. 09 19:08:58 jean-P34V2 acpid[600]: waiting for events: event logging is off
juil. 09 19:08:58 jean-P34V2 sensors[684]: acpitz-virtual-0
juil. 09 19:09:45 jean-P34V2 ureadahead[410]: ureadahead:acpi: Chemin relatif ignoré
juil. 09 17:56:26 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 09 17:56:26 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 09 17:56:26 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 09 17:56:26 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 09 17:56:26 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 09 17:56:27 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 09 17:56:27 jean-P34V2 acpid[631]: starting up with netlink and the input layer
juil. 09 17:56:27 jean-P34V2 acpid[631]: 8 rules loaded
juil. 09 17:56:27 jean-P34V2 acpid[631]: waiting for events: event logging is off
juil. 09 17:56:27 jean-P34V2 sensors[726]: acpitz-virtual-0
juil. 09 17:56:30 jean-P34V2 acpid[631]: client connected from 966[0:0]
juil. 09 17:56:30 jean-P34V2 acpid[631]: 1 client rule loaded
juil. 09 19:29:31 jean-P34V2 acpid[631]: client 966[0:0] has disconnected
juil. 09 19:29:31 jean-P34V2 acpid[631]: client connected from 10620[0:0]
juil. 09 19:29:31 jean-P34V2 acpid[631]: 1 client rule loaded
juil. 09 19:29:34 jean-P34V2 acpid[631]: client 10620[0:0] has disconnected
juil. 09 19:29:34 jean-P34V2 acpid[631]: client connected from 10630[0:0]
juil. 09 19:29:34 jean-P34V2 acpid[631]: 1 client rule loaded
juil. 09 20:09:52 jean-P34V2 acpid[631]: client 10630[0:0] has disconnected
juil. 09 20:09:52 jean-P34V2 acpid[631]: client connected from 966[0:0]
juil. 09 20:09:52 jean-P34V2 acpid[631]: 1 client rule loaded
juil. 09 20:41:25 jean-P34V2 acpid[631]: client 966[0:0] has disconnected
juil. 09 20:41:25 jean-P34V2 acpid[631]: client connected from 12483[0:0]
juil. 09 20:41:25 jean-P34V2 acpid[631]: 1 client rule loaded
juil. 09 20:41:28 jean-P34V2 acpid[631]: client 12483[0:0] has disconnected
juil. 09 20:41:28 jean-P34V2 acpid[631]: client connected from 12490[0:0]
juil. 09 20:41:28 jean-P34V2 acpid[631]: 1 client rule loaded
juil. 09 21:02:50 jean-P34V2 acpid[631]: client 12490[0:0] has disconnected
juil. 09 21:02:50 jean-P34V2 acpid[631]: client connected from 966[0:0]
juil. 09 21:02:50 jean-P34V2 acpid[631]: 1 client rule loaded
juil. 09 21:24:06 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 09 21:24:06 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 09 21:24:06 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 09 21:24:06 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 09 21:24:06 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 09 21:24:06 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 09 21:24:07 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 09 21:24:07 jean-P34V2 sensors[749]: acpitz-virtual-0
juil. 09 21:24:07 jean-P34V2 acpid[653]: starting up with netlink and the input layer
juil. 09 21:24:07 jean-P34V2 acpid[653]: 8 rules loaded
juil. 09 21:24:07 jean-P34V2 acpid[653]: waiting for events: event logging is off
juil. 09 21:24:09 jean-P34V2 acpid[653]: client connected from 986[0:0]
juil. 09 21:24:09 jean-P34V2 acpid[653]: 1 client rule loaded
juil. 09 21:24:54 jean-P34V2 ureadahead[382]: ureadahead:acpi_cpufreq: Chemin relatif ignoré
juil. 09 21:24:54 jean-P34V2 ureadahead[382]: ureadahead:xen_acpi_processor: Chemin relatif ignoré
juil. 09 21:24:54 jean-P34V2 ureadahead[382]: ureadahead:acpi: Chemin relatif ignoré
juil. 09 21:24:54 jean-P34V2 ureadahead[382]: ureadahead:acpi-fan: Chemin relatif ignoré
juil. 09 21:43:05 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 09 21:52:14 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 09 21:52:16 jean-P34V2 acpid[653]: client 986[0:0] has disconnected
juil. 09 21:52:16 jean-P34V2 acpid[653]: client connected from 3905[0:0]
juil. 09 21:52:16 jean-P34V2 acpid[653]: 1 client rule loaded
juil. 09 21:52:17 jean-P34V2 acpid[653]: client 3905[0:0] has disconnected
juil. 09 21:52:17 jean-P34V2 acpid[653]: client connected from 3914[0:0]
juil. 09 21:52:17 jean-P34V2 acpid[653]: 1 client rule loaded
juil. 09 21:52:24 jean-P34V2 acpid[653]: client 3914[0:0] has disconnected
juil. 09 21:52:24 jean-P34V2 acpid[653]: client connected from 986[0:0]
juil. 09 21:52:24 jean-P34V2 acpid[653]: 1 client rule loaded
juil. 09 22:37:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 06:48:09 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 10 06:48:09 jean-P34V2 acpid[653]: client 986[0:0] has disconnected
juil. 10 06:48:09 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 06:48:09 jean-P34V2 acpid[653]: client connected from 986[0:0]
juil. 10 06:48:09 jean-P34V2 acpid[653]: 1 client rule loaded
juil. 10 06:48:12 jean-P34V2 acpid[653]: client 986[0:0] has disconnected
juil. 10 06:48:12 jean-P34V2 acpid[653]: client connected from 11098[0:0]
juil. 10 06:48:12 jean-P34V2 acpid[653]: 1 client rule loaded
juil. 10 06:48:13 jean-P34V2 acpid[653]: client 11098[0:0] has disconnected
juil. 10 06:48:13 jean-P34V2 acpid[653]: client connected from 11176[0:0]
juil. 10 06:48:13 jean-P34V2 acpid[653]: 1 client rule loaded
juil. 10 06:49:35 jean-P34V2 acpid[653]: client 11176[0:0] has disconnected
juil. 10 06:49:35 jean-P34V2 acpid[653]: client connected from 986[0:0]
juil. 10 06:49:35 jean-P34V2 acpid[653]: 1 client rule loaded
juil. 10 06:51:03 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 10 06:51:03 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 10 06:51:03 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 10 06:51:03 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 10 06:51:03 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 10 06:51:03 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 06:51:03 jean-P34V2 sensors[640]: acpitz-virtual-0
juil. 10 06:51:03 jean-P34V2 acpid[587]: starting up with netlink and the input layer
juil. 10 06:51:03 jean-P34V2 acpid[587]: 8 rules loaded
juil. 10 06:51:03 jean-P34V2 acpid[587]: waiting for events: event logging is off
juil. 10 06:51:05 jean-P34V2 acpid[587]: client connected from 865[0:0]
juil. 10 06:51:05 jean-P34V2 acpid[587]: 1 client rule loaded
juil. 10 07:16:09 jean-P34V2 acpid[587]: client 865[0:0] has disconnected
juil. 10 07:16:09 jean-P34V2 acpid[587]: client connected from 6843[0:0]
juil. 10 07:16:09 jean-P34V2 acpid[587]: 1 client rule loaded
juil. 10 07:16:09 jean-P34V2 acpid[587]: client 6843[0:0] has disconnected
juil. 10 07:16:09 jean-P34V2 acpid[587]: client connected from 6852[0:0]
juil. 10 07:22:41 jean-P34V2 acpid[587]: client 6852[0:0] has disconnected
juil. 10 07:22:41 jean-P34V2 acpid[587]: client connected from 865[0:0]
juil. 10 07:22:41 jean-P34V2 acpid[587]: 1 client rule loaded
juil. 10 07:24:30 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 10 07:24:30 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 10 07:24:30 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 10 07:24:30 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 10 07:24:30 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 10 07:24:30 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 07:24:31 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 07:24:31 jean-P34V2 sensors[685]: acpitz-virtual-0
juil. 10 07:24:31 jean-P34V2 acpid[592]: starting up with netlink and the input layer
juil. 10 07:24:31 jean-P34V2 acpid[592]: 8 rules loaded
juil. 10 07:24:31 jean-P34V2 acpid[592]: waiting for events: event logging is off
juil. 10 07:24:33 jean-P34V2 acpid[592]: client connected from 931[0:0]
juil. 10 07:24:33 jean-P34V2 acpid[592]: 1 client rule loaded
juil. 10 07:25:17 jean-P34V2 ureadahead[399]: ureadahead:acpi: Chemin relatif ignoré
juil. 10 07:25:59 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 10 07:25:59 jean-P34V2 acpid[592]: client 931[0:0] has disconnected
juil. 10 07:25:59 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 07:25:59 jean-P34V2 acpid[592]: input device has been disconnected, fd 8
juil. 10 07:26:00 jean-P34V2 acpid[592]: client connected from 931[0:0]
juil. 10 07:26:00 jean-P34V2 acpid[592]: 1 client rule loaded
juil. 10 07:26:03 jean-P34V2 acpid[592]: client 931[0:0] has disconnected
juil. 10 07:26:03 jean-P34V2 acpid[592]: client connected from 2417[0:0]
juil. 10 07:26:03 jean-P34V2 acpid[592]: 1 client rule loaded
juil. 10 07:26:04 jean-P34V2 acpid[592]: client 2417[0:0] has disconnected
juil. 10 07:26:04 jean-P34V2 acpid[592]: client connected from 2431[0:0]
juil. 10 07:26:04 jean-P34V2 acpid[592]: 1 client rule loaded
juil. 10 07:58:08 jean-P34V2 acpid[592]: client 2431[0:0] has disconnected
juil. 10 07:58:08 jean-P34V2 acpid[592]: client connected from 931[0:0]
juil. 10 07:58:08 jean-P34V2 acpid[592]: 1 client rule loaded
juil. 10 07:58:52 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 10 07:58:52 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 10 07:58:52 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 10 07:58:52 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 10 07:58:52 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 10 07:58:52 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 07:58:53 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 07:58:53 jean-P34V2 sensors[657]: acpitz-virtual-0
juil. 10 07:58:53 jean-P34V2 acpid[588]: starting up with netlink and the input layer
juil. 10 07:58:53 jean-P34V2 acpid[588]: 8 rules loaded
juil. 10 07:58:53 jean-P34V2 acpid[588]: waiting for events: event logging is off
juil. 10 07:59:31 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 10 07:59:31 jean-P34V2 acpid[588]: input device has been disconnected, fd 8
juil. 10 07:59:31 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 18:50:08 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 10 19:19:10 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 10 19:19:10 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 10 19:19:10 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 10 19:19:10 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 10 19:19:10 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 10 19:19:10 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 19:19:11 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 10 19:19:11 jean-P34V2 sensors[744]: acpitz-virtual-0
juil. 10 19:19:11 jean-P34V2 acpid[718]: starting up with netlink and the input layer
juil. 10 19:19:11 jean-P34V2 acpid[718]: 8 rules loaded
juil. 10 19:19:11 jean-P34V2 acpid[718]: waiting for events: event logging is off
juil. 10 19:19:13 jean-P34V2 acpid[718]: client connected from 1007[0:0]
juil. 10 19:19:13 jean-P34V2 acpid[718]: 1 client rule loaded
juil. 10 19:52:35 jean-P34V2 acpid[718]: client 1007[0:0] has disconnected
juil. 10 19:52:35 jean-P34V2 acpid[718]: client connected from 4862[0:0]
juil. 10 19:52:35 jean-P34V2 acpid[718]: 1 client rule loaded
juil. 10 19:52:35 jean-P34V2 acpid[718]: client 4862[0:0] has disconnected
juil. 10 19:52:35 jean-P34V2 acpid[718]: client connected from 4871[0:0]
juil. 11 08:18:47 jean-P34V2 acpid[718]: client 4871[0:0] has disconnected
juil. 11 08:18:47 jean-P34V2 acpid[718]: client connected from 1007[0:0]
juil. 11 08:18:47 jean-P34V2 acpid[718]: 1 client rule loaded
juil. 11 08:45:56 jean-P34V2 acpid[718]: client 1007[0:0] has disconnected
juil. 11 08:45:56 jean-P34V2 acpid[718]: client connected from 13601[0:0]
juil. 11 08:45:56 jean-P34V2 acpid[718]: 1 client rule loaded
juil. 11 08:45:58 jean-P34V2 acpid[718]: client 13601[0:0] has disconnected
juil. 11 08:45:59 jean-P34V2 acpid[718]: client connected from 13608[0:0]
juil. 11 08:45:59 jean-P34V2 acpid[718]: 1 client rule loaded
juil. 11 08:46:07 jean-P34V2 acpid[718]: client 13608[0:0] has disconnected
juil. 11 08:46:07 jean-P34V2 acpid[718]: client connected from 1007[0:0]
juil. 11 08:46:07 jean-P34V2 acpid[718]: 1 client rule loaded
juil. 11 08:53:21 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 11 17:35:45 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 11 17:35:46 jean-P34V2 acpid[718]: client 1007[0:0] has disconnected
juil. 11 17:35:46 jean-P34V2 acpid[718]: client connected from 25357[0:0]
juil. 11 17:35:46 jean-P34V2 acpid[718]: 1 client rule loaded
juil. 11 17:35:47 jean-P34V2 acpid[718]: client 25357[0:0] has disconnected
juil. 11 17:35:47 jean-P34V2 acpid[718]: client connected from 25363[0:0]
juil. 11 17:35:47 jean-P34V2 acpid[718]: 1 client rule loaded
juil. 11 17:36:26 jean-P34V2 acpid[718]: client 25363[0:0] has disconnected
juil. 11 17:36:26 jean-P34V2 acpid[718]: client connected from 1007[0:0]
juil. 11 17:36:26 jean-P34V2 acpid[718]: 1 client rule loaded
juil. 11 17:40:59 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 11 17:40:59 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 11 17:40:59 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 11 17:40:59 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 11 17:40:59 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 11 17:41:00 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 11 17:41:00 jean-P34V2 sensors[727]: acpitz-virtual-0
juil. 11 17:41:01 jean-P34V2 acpid[705]: starting up with netlink and the input layer
juil. 11 17:41:01 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 11 17:41:01 jean-P34V2 acpid[705]: 8 rules loaded
juil. 11 17:41:01 jean-P34V2 acpid[705]: waiting for events: event logging is off
juil. 12 08:42:29 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 12 20:38:29 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 12 20:38:29 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 12 21:49:21 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 13 07:33:28 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 13 08:25:40 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 13 19:58:54 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 13 19:58:54 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 14 08:32:33 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 14 08:32:33 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 14 12:08:18 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 14 12:08:18 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 14 12:08:18 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 14 12:08:18 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 14 12:08:18 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 14 12:08:18 jean-P34V2 kernel: acpi LNXSYBUS:01: hash matches
juil. 14 12:08:19 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 14 12:08:19 jean-P34V2 sensors[753]: acpitz-virtual-0
juil. 14 12:08:19 jean-P34V2 acpid[721]: starting up with netlink and the input layer
juil. 14 12:08:19 jean-P34V2 acpid[721]: 8 rules loaded
juil. 14 12:08:19 jean-P34V2 acpid[721]: waiting for events: event logging is off
juil. 14 12:09:06 jean-P34V2 ureadahead[387]: ureadahead:acpi-fan: Chemin relatif ignoré
juil. 14 12:09:06 jean-P34V2 ureadahead[387]: ureadahead:acpi: Chemin relatif ignoré
juil. 15 02:49:13 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 15 02:49:13 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 15 02:49:13 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 15 02:49:13 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 15 02:49:13 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 15 02:49:14 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 15 02:49:14 jean-P34V2 sensors[709]: acpitz-virtual-0
juil. 15 02:49:14 jean-P34V2 acpid[596]: starting up with netlink and the input layer
juil. 15 02:49:14 jean-P34V2 acpid[596]: 8 rules loaded
juil. 15 02:49:14 jean-P34V2 acpid[596]: waiting for events: event logging is off
juil. 15 03:17:37 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 15 13:14:26 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 15 13:14:26 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 15 13:26:28 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 16 07:13:33 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 16 17:01:12 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 16 17:01:12 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 16 17:01:12 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 16 17:01:12 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 16 17:01:12 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 16 17:01:13 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 16 17:01:13 jean-P34V2 sensors[735]: acpitz-virtual-0
juil. 16 17:01:13 jean-P34V2 acpid[683]: starting up with netlink and the input layer
juil. 16 17:01:13 jean-P34V2 acpid[683]: 8 rules loaded
juil. 16 17:01:13 jean-P34V2 acpid[683]: waiting for events: event logging is off
juil. 16 18:00:39 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 16 18:10:01 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 16 18:10:01 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 16 18:10:01 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 16 18:10:01 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 16 18:10:01 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 16 18:10:01 jean-P34V2 kernel: acpi device:45: hash matches
juil. 16 18:10:02 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 16 18:10:02 jean-P34V2 sensors[658]: acpitz-virtual-0
juil. 16 18:10:02 jean-P34V2 acpid[645]: starting up with netlink and the input layer
juil. 16 18:10:02 jean-P34V2 acpid[645]: 8 rules loaded
juil. 16 18:10:02 jean-P34V2 acpid[645]: waiting for events: event logging is off
juil. 16 18:27:44 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 16 18:27:44 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 16 18:27:44 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 16 18:27:44 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 16 18:27:44 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 16 18:27:45 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 16 18:27:45 jean-P34V2 sensors[707]: acpitz-virtual-0
juil. 16 18:27:45 jean-P34V2 acpid[618]: starting up with netlink and the input layer
juil. 16 18:27:45 jean-P34V2 acpid[618]: 8 rules loaded
juil. 16 18:27:45 jean-P34V2 acpid[618]: waiting for events: event logging is off
juil. 16 22:26:56 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 17 09:16:42 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 17 22:51:22 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 17 22:51:35 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 18 06:32:42 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 18 06:32:42 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 18 07:07:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 18 18:46:07 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 18 19:10:45 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 18 19:10:45 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 18 19:10:45 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 18 19:10:45 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 18 19:10:45 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 18 19:10:45 jean-P34V2 kernel: acpi device:47: hash matches
juil. 18 19:10:45 jean-P34V2 kernel: acpi device:1a: hash matches
juil. 18 19:10:46 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 18 19:10:46 jean-P34V2 sensors[726]: acpitz-virtual-0
juil. 18 19:10:46 jean-P34V2 acpid[724]: starting up with netlink and the input layer
juil. 18 19:10:46 jean-P34V2 acpid[724]: 8 rules loaded
juil. 18 19:10:46 jean-P34V2 acpid[724]: waiting for events: event logging is off
juil. 18 19:12:09 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 18 19:12:09 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 18 19:12:09 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 18 19:12:09 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 18 19:12:09 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 18 19:12:09 jean-P34V2 kernel: acpi device:47: hash matches
juil. 18 19:12:09 jean-P34V2 kernel: acpi device:1a: hash matches
juil. 18 19:13:16 jean-P34V2 sensors[2966]: acpitz-virtual-0
juil. 18 19:13:16 jean-P34V2 acpid[2945]: starting up with netlink and the input layer
juil. 18 19:13:16 jean-P34V2 acpid[2945]: 8 rules loaded
juil. 18 19:13:16 jean-P34V2 acpid[2945]: waiting for events: event logging is off
juil. 19 06:08:42 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 19 06:08:42 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 19 06:08:42 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 19 06:08:42 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 19 06:08:42 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 19 06:08:43 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 19 06:08:43 jean-P34V2 sensors[665]: acpitz-virtual-0
juil. 19 06:08:43 jean-P34V2 acpid[634]: starting up with netlink and the input layer
juil. 19 06:08:43 jean-P34V2 acpid[634]: 8 rules loaded
juil. 19 06:08:43 jean-P34V2 acpid[634]: waiting for events: event logging is off
juil. 19 15:29:19 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 19 15:29:19 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 19 16:37:23 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 19 16:37:23 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 19 16:37:23 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 19 16:37:23 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 19 16:37:23 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 19 16:37:23 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 19 16:37:24 jean-P34V2 sensors[721]: acpitz-virtual-0
juil. 19 16:37:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 19 16:37:24 jean-P34V2 acpid[666]: starting up with netlink and the input layer
juil. 19 16:37:24 jean-P34V2 acpid[666]: 8 rules loaded
juil. 19 16:37:24 jean-P34V2 acpid[666]: waiting for events: event logging is off
juil. 19 17:09:08 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 19 17:09:08 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 19 17:09:08 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 19 17:09:08 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 19 17:09:08 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 19 17:09:08 jean-P34V2 kernel: acpi device:43: hash matches
juil. 19 17:09:09 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 19 17:09:09 jean-P34V2 sensors[716]: acpitz-virtual-0
juil. 19 17:09:09 jean-P34V2 acpid[631]: starting up with netlink and the input layer
juil. 19 17:09:09 jean-P34V2 acpid[631]: 8 rules loaded
juil. 19 17:09:09 jean-P34V2 acpid[631]: waiting for events: event logging is off
juil. 19 17:10:02 jean-P34V2 ureadahead[388]: ureadahead:acpi: Chemin relatif ignoré
juil. 19 17:10:02 jean-P34V2 ureadahead[388]: ureadahead:acpi-fan: Chemin relatif ignoré
juil. 19 20:34:19 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 20 16:08:56 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 20 16:08:56 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 20 16:55:34 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 20 17:03:11 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 21 00:30:38 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 21 06:24:08 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 21 06:24:08 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 21 07:08:58 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 21 14:45:54 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 21 14:45:54 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 21 14:47:25 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 21 14:47:25 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 21 14:47:25 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 21 14:47:25 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 21 14:47:25 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 21 14:47:25 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 21 14:47:26 jean-P34V2 acpid[603]: starting up with netlink and the input layer
juil. 21 14:47:26 jean-P34V2 acpid[603]: 8 rules loaded
juil. 21 14:47:26 jean-P34V2 acpid[603]: waiting for events: event logging is off
juil. 21 14:47:26 jean-P34V2 sensors[745]: acpitz-virtual-0
juil. 21 18:27:07 jean-P34V2 acpid[603]: input device has been disconnected, fd 14
juil. 21 23:44:16 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 22 08:08:06 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 22 08:08:06 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 22 08:26:28 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 23 05:57:16 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 23 05:57:16 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 23 06:33:16 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 23 16:43:36 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 23 16:43:36 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 23 17:15:37 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 23 17:22:11 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 23 17:22:11 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 23 17:39:47 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 23 19:46:53 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 23 19:46:53 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 23 20:06:19 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 23 21:37:40 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 23 21:37:40 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 23 22:34:16 jean-P34V2 acpid[603]: input device has been disconnected, fd 11
juil. 24 06:28:41 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 24 06:28:41 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 24 17:23:24 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 24 17:23:24 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 24 17:23:24 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 24 17:23:24 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 24 17:23:24 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 24 17:23:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 24 17:23:26 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 24 17:23:26 jean-P34V2 sensors[913]: acpitz-virtual-0
juil. 24 17:23:26 jean-P34V2 acpid[880]: starting up with netlink and the input layer
juil. 24 17:23:26 jean-P34V2 acpid[880]: 8 rules loaded
juil. 24 17:23:26 jean-P34V2 acpid[880]: waiting for events: event logging is off
juil. 24 17:24:19 jean-P34V2 ureadahead[385]: ureadahead:acpi: Chemin relatif ignoré
juil. 24 18:47:52 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 24 19:28:20 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 24 19:28:20 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 24 20:23:20 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 07:23:09 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 25 07:23:09 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 08:21:03 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 12:47:15 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 25 12:47:15 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 12:50:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 13:05:55 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 25 13:05:55 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 14:02:08 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 25 14:02:08 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 25 14:02:08 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 25 14:02:08 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 25 14:02:08 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 25 14:02:09 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 14:02:10 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 14:02:11 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 14:02:11 jean-P34V2 sensors[965]: acpitz-virtual-0
juil. 25 14:02:11 jean-P34V2 acpid[946]: starting up with netlink and the input layer
juil. 25 14:02:11 jean-P34V2 acpid[946]: 8 rules loaded
juil. 25 14:02:11 jean-P34V2 acpid[946]: waiting for events: event logging is off
juil. 25 14:09:41 jean-P34V2 acpid[946]: input device has been disconnected, fd 18
juil. 25 17:21:26 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 25 17:21:26 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 25 17:21:26 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 25 17:21:26 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 25 17:21:26 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 25 17:21:26 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 17:21:28 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 17:21:28 jean-P34V2 sensors[954]: acpitz-virtual-0
juil. 25 17:21:28 jean-P34V2 acpid[892]: starting up with netlink and the input layer
juil. 25 17:21:28 jean-P34V2 acpid[892]: 8 rules loaded
juil. 25 17:21:28 jean-P34V2 acpid[892]: waiting for events: event logging is off
juil. 25 15:35:54 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 25 15:35:54 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 25 15:35:54 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 25 15:35:54 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 25 15:35:54 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 25 15:35:55 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 15:35:55 jean-P34V2 acpid[577]: starting up with netlink and the input layer
juil. 25 15:35:55 jean-P34V2 acpid[577]: 8 rules loaded
juil. 25 15:35:55 jean-P34V2 acpid[577]: waiting for events: event logging is off
juil. 25 15:35:55 jean-P34V2 sensors[671]: acpitz-virtual-0
juil. 25 15:36:49 jean-P34V2 ureadahead[398]: ureadahead:acpi: Chemin relatif ignoré
juil. 25 15:41:21 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 25 15:41:21 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 25 15:41:21 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 25 15:41:21 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 25 15:41:21 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 25 15:41:22 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 15:41:22 jean-P34V2 acpid[564]: starting up with netlink and the input layer
juil. 25 15:41:22 jean-P34V2 acpid[564]: 8 rules loaded
juil. 25 15:41:22 jean-P34V2 acpid[564]: waiting for events: event logging is off
juil. 25 15:41:22 jean-P34V2 sensors[711]: acpitz-virtual-0
juil. 25 16:00:26 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 25 16:00:26 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 25 16:00:26 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 25 16:00:26 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 25 16:00:26 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 25 16:00:27 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 25 16:00:27 jean-P34V2 sensors[704]: acpitz-virtual-0
juil. 25 16:00:27 jean-P34V2 acpid[635]: starting up with netlink and the input layer
juil. 25 16:00:27 jean-P34V2 acpid[635]: 8 rules loaded
juil. 25 16:00:27 jean-P34V2 acpid[635]: waiting for events: event logging is off
juil. 25 16:00:55 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:00:59 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:01:06 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:01:23 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:01:27 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:01:51 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:01:55 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:02:19 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:02:23 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:02:47 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:02:51 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:03:15 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:03:19 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:03:43 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:03:47 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:04:11 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:04:15 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:04:39 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:04:43 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:05:07 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:05:11 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:05:35 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:05:39 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:06:03 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:06:07 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:06:31 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:06:35 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:06:59 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:07:03 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:07:27 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:07:31 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:07:55 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:07:59 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:08:23 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:08:27 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:08:51 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:08:55 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:09:19 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:09:23 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:09:47 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:09:51 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:10:15 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:10:19 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:10:43 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:10:47 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:11:11 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:11:15 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:11:39 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:11:43 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:12:07 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:12:11 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:12:35 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:12:39 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:13:03 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:13:07 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:13:31 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:13:35 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:13:59 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:14:03 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:14:27 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:14:31 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:14:55 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:14:59 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:15:23 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:15:27 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:15:51 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:15:55 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 16:16:19 jean-P34V2 kernel:  snd_rawmidi acpi_als kfifo_buf industrialio snd_seq snd_seq_device snd_timer wmi snd soundcore mac_hid sch_fq_codel parport_pc ppdev lp parport ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq dm_mirror dm_region_hash dm_log hid_logitech_hidpp hid_logitech_dj usbhid hid i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci r8169 drm psmouse libahci mii video
juil. 25 17:23:55 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 26 17:24:29 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 27 08:46:00 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 27 08:46:00 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 27 08:46:00 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 27 08:46:00 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 27 08:46:00 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 27 08:46:00 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 27 08:46:00 jean-P34V2 sensors[801]: acpitz-virtual-0
juil. 27 08:46:00 jean-P34V2 acpid[765]: starting up with netlink and the input layer
juil. 27 08:46:00 jean-P34V2 acpid[765]: 8 rules loaded
juil. 27 08:46:00 jean-P34V2 acpid[765]: waiting for events: event logging is off
juil. 27 07:20:46 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 27 16:47:19 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 27 16:47:19 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 27 18:22:07 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 27 18:25:24 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 27 18:25:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 27 18:35:19 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 27 18:35:19 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 27 18:35:19 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 27 18:35:19 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 27 18:35:19 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 27 18:35:20 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 27 18:35:20 jean-P34V2 acpid[604]: starting up with netlink and the input layer
juil. 27 18:35:20 jean-P34V2 acpid[604]: 8 rules loaded
juil. 27 18:35:20 jean-P34V2 acpid[604]: waiting for events: event logging is off
juil. 27 18:35:20 jean-P34V2 sensors[683]: acpitz-virtual-0
juil. 27 18:36:14 jean-P34V2 ureadahead[393]: ureadahead:acpi: Chemin relatif ignoré
juil. 27 18:36:14 jean-P34V2 ureadahead[393]: ureadahead:acpi-fan: Chemin relatif ignoré
juil. 28 13:56:03 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 28 13:56:03 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 28 13:56:03 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 28 13:56:03 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 28 13:56:03 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 28 13:56:03 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 28 13:56:04 jean-P34V2 sensors[641]: acpitz-virtual-0
juil. 28 13:56:04 jean-P34V2 acpid[574]: starting up with netlink and the input layer
juil. 28 13:56:04 jean-P34V2 acpid[574]: 8 rules loaded
juil. 28 13:56:04 jean-P34V2 acpid[574]: waiting for events: event logging is off
juil. 28 14:01:16 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 28 14:01:16 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 28 14:01:16 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 28 14:01:16 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 28 14:01:16 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 28 14:01:16 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 28 14:01:17 jean-P34V2 sensors[686]: acpitz-virtual-0
juil. 28 14:01:17 jean-P34V2 acpid[587]: starting up with netlink and the input layer
juil. 28 14:01:17 jean-P34V2 acpid[587]: 8 rules loaded
juil. 28 14:01:17 jean-P34V2 acpid[587]: waiting for events: event logging is off
juil. 28 14:08:35 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 28 14:08:35 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 28 14:08:35 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 28 14:08:35 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 28 14:08:35 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 28 14:08:35 jean-P34V2 kernel: acpi device:03: hash matches
juil. 28 14:08:35 jean-P34V2 kernel: acpi PNP0C02:00: hash matches
juil. 28 14:08:35 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 28 14:08:36 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 28 14:08:36 jean-P34V2 sensors[657]: acpitz-virtual-0
juil. 28 14:08:36 jean-P34V2 acpid[615]: starting up with netlink and the input layer
juil. 28 14:08:36 jean-P34V2 acpid[615]: 8 rules loaded
juil. 28 14:08:36 jean-P34V2 acpid[615]: waiting for events: event logging is off
juil. 28 14:43:34 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 28 15:56:30 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 28 15:56:30 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 28 16:19:36 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 29 09:48:30 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 29 09:48:30 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 29 13:08:32 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 29 13:08:32 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 29 13:08:32 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 29 13:08:32 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 29 13:08:32 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 29 13:08:32 jean-P34V2 kernel: acpi device:01: hash matches
juil. 29 13:08:32 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 29 13:08:34 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 29 13:08:34 jean-P34V2 sensors[944]: acpitz-virtual-0
juil. 29 13:08:34 jean-P34V2 acpid[933]: starting up with netlink and the input layer
juil. 29 13:08:34 jean-P34V2 acpid[933]: 8 rules loaded
juil. 29 13:08:34 jean-P34V2 acpid[933]: waiting for events: event logging is off
juil. 29 17:51:21 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 29 17:51:21 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 29 17:51:21 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 29 17:51:21 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 29 17:51:21 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 29 17:51:22 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 29 17:51:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 29 17:51:24 jean-P34V2 sensors[918]: acpitz-virtual-0
juil. 29 17:51:24 jean-P34V2 acpid[906]: starting up with netlink and the input layer
juil. 29 17:51:24 jean-P34V2 acpid[906]: 8 rules loaded
juil. 29 17:51:24 jean-P34V2 acpid[906]: waiting for events: event logging is off
juil. 30 22:45:17 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 30 22:45:17 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 30 22:45:17 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 30 22:45:17 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 30 22:45:17 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 30 22:45:18 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 30 22:45:19 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 30 22:45:20 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 30 22:45:20 jean-P34V2 sensors[943]: acpitz-virtual-0
juil. 30 22:45:20 jean-P34V2 acpid[905]: starting up with netlink and the input layer
juil. 30 22:45:20 jean-P34V2 acpid[905]: 8 rules loaded
juil. 30 22:45:20 jean-P34V2 acpid[905]: waiting for events: event logging is off
juil. 30 23:38:00 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
juil. 30 23:38:00 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
juil. 30 23:38:00 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
juil. 30 23:38:00 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
juil. 30 23:38:00 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
juil. 30 23:38:00 jean-P34V2 kernel: acpi LNXCPU:06: hash matches
juil. 30 23:38:01 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 30 23:38:02 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 30 23:38:03 jean-P34V2 sensors[939]: acpitz-virtual-0
juil. 30 23:38:03 jean-P34V2 acpid[875]: starting up with netlink and the input layer
juil. 30 23:38:03 jean-P34V2 acpid[875]: 8 rules loaded
juil. 30 23:38:03 jean-P34V2 acpid[875]: waiting for events: event logging is off
juil. 31 08:09:16 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 31 08:09:16 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 31 20:25:33 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
juil. 31 20:25:33 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
juil. 31 20:25:33 jean-P34V2 acpid[875]: input device has been disconnected, fd 15
juil. 31 21:00:06 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 01 17:58:01 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 01 17:58:01 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 01 18:33:22 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 01 20:34:44 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 01 20:34:44 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 01 20:51:23 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 02 07:53:43 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 02 07:53:43 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 02 08:48:26 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 02 08:51:11 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 02 08:51:11 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 04 16:07:47 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 04 16:07:47 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 04 16:37:14 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 05 07:56:45 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 05 07:56:45 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 06 00:32:30 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 06 17:07:02 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 06 19:17:43 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 06 19:18:01 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 06 19:18:01 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 06 21:42:36 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 06 21:42:36 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 06 21:42:36 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 06 21:42:36 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 06 21:42:36 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 06 21:42:36 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 06 21:42:38 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 06 21:42:38 jean-P34V2 sensors[936]: acpitz-virtual-0
août 06 21:42:39 jean-P34V2 acpid[893]: starting up with netlink and the input layer
août 06 21:42:39 jean-P34V2 acpid[893]: 8 rules loaded
août 06 21:42:39 jean-P34V2 acpid[893]: waiting for events: event logging is off
août 07 18:30:12 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 07 18:30:12 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 07 18:30:12 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 07 18:30:12 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 07 18:30:12 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 07 18:30:12 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 07 18:30:14 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 07 18:30:15 jean-P34V2 sensors[938]: acpitz-virtual-0
août 07 18:30:15 jean-P34V2 acpid[893]: starting up with netlink and the input layer
août 07 18:30:15 jean-P34V2 acpid[893]: 8 rules loaded
août 07 18:30:15 jean-P34V2 acpid[893]: waiting for events: event logging is off
août 07 18:31:08 jean-P34V2 ureadahead[392]: ureadahead:acpi_cpufreq: Chemin relatif ignoré
août 07 18:31:08 jean-P34V2 ureadahead[392]: ureadahead:xen_acpi_processor: Chemin relatif ignoré
août 07 18:31:08 jean-P34V2 ureadahead[392]: ureadahead:acpi: Chemin relatif ignoré
août 07 18:31:08 jean-P34V2 ureadahead[392]: ureadahead:acpi-fan: Chemin relatif ignoré
août 07 21:47:23 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 08 16:04:28 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 08 16:04:28 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 08 22:31:00 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 08 22:31:00 jean-P34V2 acpid[893]: input device has been disconnected, fd 15
août 08 22:31:00 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 09 06:41:09 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 09 06:54:24 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 09 06:54:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 09 15:33:38 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 09 15:33:38 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 09 21:44:25 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 09 21:44:25 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 09 21:44:25 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 09 21:44:25 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 09 21:44:25 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 09 21:44:25 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 09 21:44:27 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 09 21:44:27 jean-P34V2 sensors[945]: acpitz-virtual-0
août 09 21:44:28 jean-P34V2 acpid[881]: starting up with netlink and the input layer
août 09 21:44:28 jean-P34V2 acpid[881]: 8 rules loaded
août 09 21:44:28 jean-P34V2 acpid[881]: waiting for events: event logging is off
août 09 19:51:06 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 09 19:51:06 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 09 19:51:06 jean-P34V2 acpid[881]: input device has been disconnected, fd 15
août 10 08:34:16 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 10 08:34:16 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 10 09:10:47 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 10 11:30:27 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 10 11:30:27 jean-P34V2 acpid[881]: input device has been disconnected, fd 18
août 10 18:10:07 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 10 18:10:07 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 10 18:10:07 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 10 18:10:07 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 10 18:10:07 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 10 18:10:07 jean-P34V2 kernel: acpi device:45: hash matches
août 10 18:10:07 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 10 18:10:09 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 10 18:10:09 jean-P34V2 sensors[938]: acpitz-virtual-0
août 10 18:10:10 jean-P34V2 acpid[921]: starting up with netlink and the input layer
août 10 18:10:10 jean-P34V2 acpid[921]: 8 rules loaded
août 10 18:10:10 jean-P34V2 acpid[921]: waiting for events: event logging is off
août 11 18:25:42 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 11 18:25:42 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 11 18:25:42 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 11 18:25:42 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 11 18:25:42 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 11 18:25:43 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 11 18:25:45 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 11 18:25:45 jean-P34V2 sensors[926]: acpitz-virtual-0
août 11 18:25:45 jean-P34V2 acpid[848]: starting up with netlink and the input layer
août 11 18:25:45 jean-P34V2 acpid[848]: 8 rules loaded
août 11 18:25:45 jean-P34V2 acpid[848]: waiting for events: event logging is off
août 12 20:08:25 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 12 20:08:25 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 12 20:08:25 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 12 20:08:25 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 12 20:08:25 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 12 20:08:25 jean-P34V2 kernel: acpi device:10: hash matches
août 12 20:08:26 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 12 20:08:28 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 12 20:08:28 jean-P34V2 acpid[873]: starting up with netlink and the input layer
août 12 20:08:28 jean-P34V2 acpid[873]: 8 rules loaded
août 12 20:08:28 jean-P34V2 acpid[873]: waiting for events: event logging is off
août 12 20:08:28 jean-P34V2 sensors[945]: acpitz-virtual-0
août 12 23:25:00 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 13 07:55:35 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 13 09:30:40 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 13 09:30:40 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 13 09:30:40 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 13 09:30:40 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 13 09:30:40 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 13 09:30:41 jean-P34V2 kernel: acpi LNXPOWER:05: hash matches
août 13 09:30:41 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 13 09:30:43 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 13 09:30:43 jean-P34V2 sensors[932]: acpitz-virtual-0
août 13 09:30:43 jean-P34V2 acpid[860]: starting up with netlink and the input layer
août 13 09:30:43 jean-P34V2 acpid[860]: 8 rules loaded
août 13 09:30:43 jean-P34V2 acpid[860]: waiting for events: event logging is off
août 13 18:42:12 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 13 18:42:12 jean-P34V2 acpid[860]: input device has been disconnected, fd 15
août 13 19:09:17 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 13 19:09:17 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 13 20:59:30 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 14 05:37:09 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 14 05:37:09 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 14 08:53:40 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 14 18:37:35 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 14 18:37:35 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 14 19:14:55 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 14 20:21:05 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 14 20:21:05 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 16 09:32:20 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 16 09:32:20 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 16 09:32:20 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 16 09:32:20 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 16 09:32:20 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 16 09:32:20 jean-P34V2 kernel: acpi LNXPOWER:05: hash matches
août 16 09:32:21 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 16 09:32:22 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 16 09:32:23 jean-P34V2 sensors[960]: acpitz-virtual-0
août 16 09:32:23 jean-P34V2 acpid[876]: starting up with netlink and the input layer
août 16 09:32:23 jean-P34V2 acpid[876]: 8 rules loaded
août 16 09:32:23 jean-P34V2 acpid[876]: waiting for events: event logging is off
août 16 10:04:20 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 17 07:36:50 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 17 07:36:50 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 17 20:24:15 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 17 20:24:15 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 17 20:24:15 jean-P34V2 acpid[876]: input device has been disconnected, fd 15
août 17 21:13:26 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 17 21:49:05 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 17 21:49:05 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 17 21:58:42 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 17 21:58:42 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 17 21:58:42 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 17 21:58:42 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 17 21:58:42 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 17 21:58:43 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 17 21:58:45 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 17 21:58:45 jean-P34V2 sensors[954]: acpitz-virtual-0
août 17 21:58:45 jean-P34V2 acpid[895]: starting up with netlink and the input layer
août 17 21:58:45 jean-P34V2 acpid[895]: 8 rules loaded
août 17 21:58:45 jean-P34V2 acpid[895]: waiting for events: event logging is off
août 17 21:59:38 jean-P34V2 ureadahead[399]: ureadahead:acpi: Chemin relatif ignoré
août 17 22:39:39 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 18 07:19:31 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 18 08:53:03 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 18 09:06:31 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 18 09:06:31 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 18 09:16:12 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 18 09:31:56 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 18 10:20:20 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 19 10:06:30 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 19 10:06:30 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 19 10:48:22 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 19 10:48:22 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 19 10:48:22 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 19 10:48:22 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 19 10:48:22 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 19 10:48:23 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 19 10:48:25 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 19 10:48:25 jean-P34V2 sensors[933]: acpitz-virtual-0
août 19 10:48:25 jean-P34V2 acpid[888]: starting up with netlink and the input layer
août 19 10:48:25 jean-P34V2 acpid[888]: 8 rules loaded
août 19 10:48:25 jean-P34V2 acpid[888]: waiting for events: event logging is off
août 19 11:49:42 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 19 11:49:42 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 19 11:49:42 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 19 11:49:42 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 19 11:49:42 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 19 11:49:42 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 19 11:49:44 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 19 11:49:44 jean-P34V2 sensors[929]: acpitz-virtual-0
août 19 11:49:44 jean-P34V2 acpid[874]: starting up with netlink and the input layer
août 19 11:49:44 jean-P34V2 acpid[874]: 8 rules loaded
août 19 11:49:44 jean-P34V2 acpid[874]: waiting for events: event logging is off
août 19 17:12:10 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 19 17:12:11 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 19 17:12:11 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 19 17:12:11 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 19 17:12:11 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 19 17:12:11 jean-P34V2 kernel: acpi-fan PNP0C0B:00: hash matches
août 19 17:12:11 jean-P34V2 kernel: acpi PNP0C0B:00: hash matches
août 19 17:12:11 jean-P34V2 kernel: acpi device:4f: hash matches
août 19 17:12:11 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 19 17:12:13 jean-P34V2 sensors[933]: acpitz-virtual-0
août 19 17:12:13 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 19 17:12:13 jean-P34V2 acpid[908]: starting up with netlink and the input layer
août 19 17:12:13 jean-P34V2 acpid[908]: 8 rules loaded
août 19 17:12:13 jean-P34V2 acpid[908]: waiting for events: event logging is off
août 20 06:10:58 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 20 06:10:58 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 20 06:10:58 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 20 06:10:58 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 20 06:10:58 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 20 06:10:58 jean-P34V2 kernel: acpi device:28: hash matches
août 20 06:10:58 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 20 06:13:12 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 20 06:13:12 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 20 06:13:12 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 20 06:13:12 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 20 06:13:12 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 20 06:13:12 jean-P34V2 kernel: acpi device:63: hash matches
août 20 06:13:12 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 21 22:44:30 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 21 22:44:30 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 21 22:44:30 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 21 22:44:30 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 21 22:44:30 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 21 22:44:31 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 21 22:47:11 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 21 22:47:11 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 21 22:47:11 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 21 22:47:11 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 21 22:47:11 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 21 22:47:12 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 21 22:50:06 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 21 22:50:06 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 21 22:50:06 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 21 22:50:06 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 21 22:50:06 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 21 22:50:06 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 09:01:38 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 09:01:38 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 09:01:38 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 09:01:38 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 09:01:38 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 09:01:39 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 09:02:13 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 09:02:13 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 09:02:13 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 09:02:13 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 09:02:13 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 09:09:52 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 09:09:52 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 09:09:52 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 09:09:52 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 09:09:52 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 09:09:52 jean-P34V2 kernel: acpi device:31: hash matches
août 22 09:09:53 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 09:11:07 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 09:11:07 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 09:11:07 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 09:11:07 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 09:11:07 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 09:11:07 jean-P34V2 kernel: acpi device:31: hash matches
août 22 09:11:08 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 09:31:13 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 09:31:13 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 09:31:13 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 09:31:13 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 09:31:13 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 09:31:13 jean-P34V2 kernel: acpi LNXPOWER:05: hash matches
août 22 09:31:14 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 12:07:18 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 12:07:18 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 12:07:18 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 12:07:18 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 12:07:18 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 12:07:18 jean-P34V2 kernel: acpi LNXSYBUS:01: hash matches
août 22 12:07:19 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 12:21:22 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 12:21:22 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 12:21:22 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 12:21:22 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 12:21:22 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 12:21:22 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 12:35:57 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 12:35:57 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 12:35:57 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 12:35:57 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 12:35:57 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 12:35:58 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 12:55:41 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 12:55:41 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 12:55:41 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 12:55:41 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 12:55:41 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 12:55:41 jean-P34V2 kernel: acpi ABCD0000:00: hash matches
août 22 12:55:42 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 12:58:13 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 12:58:13 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 12:58:13 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 12:58:13 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 12:58:13 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 12:58:13 jean-P34V2 kernel: acpi PNP0C14:00: hash matches
août 22 12:58:14 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 13:00:46 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 13:00:46 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 13:00:46 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 13:00:46 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 13:00:46 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 13:00:47 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 13:00:48 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 13:00:48 jean-P34V2 sensors[889]: acpitz-virtual-0
août 22 13:00:48 jean-P34V2 acpid[843]: starting up with netlink and the input layer
août 22 13:00:48 jean-P34V2 acpid[843]: 8 rules loaded
août 22 13:00:48 jean-P34V2 acpid[843]: waiting for events: event logging is off
août 22 13:12:23 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 13:12:23 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 13:12:23 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 13:12:23 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 13:12:23 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 13:12:23 jean-P34V2 kernel: acpi PNP0200:00: hash matches
août 22 13:12:23 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 13:12:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 13:12:25 jean-P34V2 sensors[908]: acpitz-virtual-0
août 22 13:12:25 jean-P34V2 acpid[905]: starting up with netlink and the input layer
août 22 13:12:25 jean-P34V2 acpid[905]: 8 rules loaded
août 22 13:12:25 jean-P34V2 acpid[905]: waiting for events: event logging is off
août 22 13:24:29 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 13:24:29 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 13:24:29 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 13:24:29 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 13:24:29 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 13:24:29 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 13:24:30 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 13:24:30 jean-P34V2 sensors[884]: acpitz-virtual-0
août 22 13:24:31 jean-P34V2 acpid[824]: starting up with netlink and the input layer
août 22 13:24:31 jean-P34V2 acpid[824]: 8 rules loaded
août 22 13:24:31 jean-P34V2 acpid[824]: waiting for events: event logging is off
août 22 13:26:12 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 13:26:12 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 13:26:12 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 13:26:12 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 13:26:12 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 13:26:12 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 13:26:13 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 13:26:14 jean-P34V2 sensors[920]: acpitz-virtual-0
août 22 13:26:14 jean-P34V2 acpid[872]: starting up with netlink and the input layer
août 22 13:26:14 jean-P34V2 acpid[872]: 8 rules loaded
août 22 13:26:14 jean-P34V2 acpid[872]: waiting for events: event logging is off
août 22 16:59:48 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 22 16:59:48 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 22 16:59:48 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 22 16:59:48 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 22 16:59:48 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 22 16:59:49 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 16:59:50 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 16:59:50 jean-P34V2 sensors[920]: acpitz-virtual-0
août 22 16:59:50 jean-P34V2 acpid[915]: starting up with netlink and the input layer
août 22 16:59:50 jean-P34V2 acpid[915]: 8 rules loaded
août 22 16:59:50 jean-P34V2 acpid[915]: waiting for events: event logging is off
août 22 19:56:39 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 22 20:29:16 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 22 20:29:16 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 23 14:35:08 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 23 14:53:26 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 23 14:53:26 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 23 14:53:26 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 23 14:53:26 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 23 14:53:26 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 23 14:53:27 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 23 14:53:28 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 23 14:53:28 jean-P34V2 sensors[898]: acpitz-virtual-0
août 23 14:53:28 jean-P34V2 acpid[855]: starting up with netlink and the input layer
août 23 14:53:28 jean-P34V2 acpid[855]: 8 rules loaded
août 23 14:53:28 jean-P34V2 acpid[855]: waiting for events: event logging is off
août 25 17:39:36 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 25 17:39:36 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 25 17:39:36 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 25 17:39:36 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 25 17:39:36 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 25 17:39:36 jean-P34V2 kernel: acpi INT33A1:00: hash matches
août 25 17:39:36 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 25 17:39:37 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 25 17:39:37 jean-P34V2 sensors[888]: acpitz-virtual-0
août 25 17:39:38 jean-P34V2 acpid[852]: starting up with netlink and the input layer
août 25 17:39:38 jean-P34V2 acpid[852]: 8 rules loaded
août 25 17:39:38 jean-P34V2 acpid[852]: waiting for events: event logging is off
août 25 17:40:31 jean-P34V2 ureadahead[392]: ureadahead:acpi: Chemin relatif ignoré
août 25 18:17:47 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 25 18:39:29 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 25 18:39:29 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 25 18:53:19 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 08:29:56 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 26 08:29:56 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 26 08:29:56 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 26 08:29:56 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 26 08:29:56 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 26 08:29:57 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 08:29:58 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 08:29:58 jean-P34V2 sensors[896]: acpitz-virtual-0
août 26 08:29:58 jean-P34V2 acpid[831]: starting up with netlink and the input layer
août 26 08:29:58 jean-P34V2 acpid[831]: 8 rules loaded
août 26 08:29:58 jean-P34V2 acpid[831]: waiting for events: event logging is off
août 26 09:59:01 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 10:09:56 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 26 10:09:56 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 10:09:56 jean-P34V2 acpid[831]: input device has been disconnected, fd 18
août 26 12:07:37 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 26 12:07:37 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 26 12:07:37 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 26 12:07:37 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 26 12:07:37 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 26 12:07:38 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 12:07:39 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 12:07:39 jean-P34V2 sensors[938]: acpitz-virtual-0
août 26 12:07:39 jean-P34V2 acpid[878]: starting up with netlink and the input layer
août 26 12:07:39 jean-P34V2 acpid[878]: 8 rules loaded
août 26 12:07:39 jean-P34V2 acpid[878]: waiting for events: event logging is off
août 26 12:08:31 jean-P34V2 ureadahead[395]: ureadahead:acpi: Chemin relatif ignoré
août 26 15:28:51 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 26 15:28:51 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 26 15:28:51 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 26 15:28:51 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 26 15:28:51 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 26 15:28:51 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 15:28:52 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 15:28:52 jean-P34V2 sensors[972]: acpitz-virtual-0
août 26 15:28:53 jean-P34V2 acpid[913]: starting up with netlink and the input layer
août 26 15:28:53 jean-P34V2 acpid[913]: 8 rules loaded
août 26 15:28:53 jean-P34V2 acpid[913]: waiting for events: event logging is off
août 26 15:33:18 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 26 15:33:18 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 26 15:33:18 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 26 15:33:18 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 26 15:33:18 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 26 15:33:18 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 15:33:19 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 15:33:19 jean-P34V2 sensors[986]: acpitz-virtual-0
août 26 15:33:19 jean-P34V2 acpid[900]: starting up with netlink and the input layer
août 26 15:33:19 jean-P34V2 acpid[900]: 8 rules loaded
août 26 15:33:19 jean-P34V2 acpid[900]: waiting for events: event logging is off
août 26 15:42:08 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 26 15:42:08 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 26 15:42:08 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 26 15:42:08 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 26 15:42:08 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 26 15:42:08 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 15:42:10 jean-P34V2 sensors[969]: acpitz-virtual-0
août 26 15:42:10 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 15:42:10 jean-P34V2 acpid[906]: starting up with netlink and the input layer
août 26 15:42:10 jean-P34V2 acpid[906]: 8 rules loaded
août 26 15:42:10 jean-P34V2 acpid[906]: waiting for events: event logging is off
août 26 15:43:47 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 26 15:43:47 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 26 15:43:47 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 26 15:43:47 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 26 15:43:47 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 26 15:43:47 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 15:43:48 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 15:43:48 jean-P34V2 sensors[986]: acpitz-virtual-0
août 26 15:43:49 jean-P34V2 acpid[945]: starting up with netlink and the input layer
août 26 15:43:49 jean-P34V2 acpid[945]: 8 rules loaded
août 26 15:43:49 jean-P34V2 acpid[945]: waiting for events: event logging is off
août 26 15:53:43 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 26 15:53:43 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 26 15:53:43 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 26 15:53:43 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 26 15:53:43 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 26 15:53:43 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 26 15:53:43 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 26 15:53:43 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 15:53:44 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 15:53:45 jean-P34V2 sensors[960]: acpitz-virtual-0
août 26 15:53:45 jean-P34V2 acpid[925]: starting up with netlink and the input layer
août 26 15:53:45 jean-P34V2 acpid[925]: 8 rules loaded
août 26 15:53:45 jean-P34V2 acpid[925]: waiting for events: event logging is off
août 26 17:37:47 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 20:32:23 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 26 20:32:23 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 26 21:19:08 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 17:13:34 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 27 17:13:34 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 17:23:46 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 17:23:46 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 27 17:23:46 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 17:23:46 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 27 17:23:46 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 27 17:23:46 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 27 17:23:46 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 27 17:23:46 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 17:23:47 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 17:23:47 jean-P34V2 sensors[955]: acpitz-virtual-0
août 27 17:23:48 jean-P34V2 acpid[875]: starting up with netlink and the input layer
août 27 17:23:48 jean-P34V2 acpid[875]: 8 rules loaded
août 27 17:23:48 jean-P34V2 acpid[875]: waiting for events: event logging is off
août 27 17:25:16 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 17:25:16 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 27 17:25:16 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 17:25:16 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 27 17:25:16 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 27 17:25:16 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 27 17:25:16 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 27 17:25:16 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 17:25:17 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 17:25:17 jean-P34V2 sensors[962]: acpitz-virtual-0
août 27 17:25:18 jean-P34V2 acpid[896]: starting up with netlink and the input layer
août 27 17:25:18 jean-P34V2 acpid[896]: 8 rules loaded
août 27 17:25:18 jean-P34V2 acpid[896]: waiting for events: event logging is off
août 27 17:31:57 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 17:31:57 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 27 17:31:57 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 17:31:57 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 27 17:31:57 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 27 17:31:57 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 27 17:31:57 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 27 17:31:57 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 17:31:58 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 17:31:58 jean-P34V2 sensors[977]: acpitz-virtual-0
août 27 17:31:58 jean-P34V2 acpid[878]: starting up with netlink and the input layer
août 27 17:31:58 jean-P34V2 acpid[878]: 8 rules loaded
août 27 17:31:58 jean-P34V2 acpid[878]: waiting for events: event logging is off
août 27 17:54:44 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 17:54:44 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 27 17:54:44 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 17:54:44 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 27 17:54:44 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 27 17:54:44 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 27 17:54:44 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 27 17:54:45 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 17:54:46 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 17:54:46 jean-P34V2 sensors[984]: acpitz-virtual-0
août 27 17:54:46 jean-P34V2 acpid[938]: starting up with netlink and the input layer
août 27 17:54:46 jean-P34V2 acpid[938]: 8 rules loaded
août 27 17:54:46 jean-P34V2 acpid[938]: waiting for events: event logging is off
août 27 18:02:19 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 18:02:19 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 27 18:02:19 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 18:02:19 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 27 18:02:19 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 27 18:02:19 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 27 18:02:19 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 27 18:02:20 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 18:02:21 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 18:02:21 jean-P34V2 sensors[972]: acpitz-virtual-0
août 27 18:02:21 jean-P34V2 acpid[919]: starting up with netlink and the input layer
août 27 18:02:21 jean-P34V2 acpid[919]: 8 rules loaded
août 27 18:02:21 jean-P34V2 acpid[919]: waiting for events: event logging is off
août 27 18:05:51 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 18:05:51 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 27 18:05:51 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 18:05:52 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 27 18:05:52 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 27 18:05:52 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 27 18:05:52 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 27 18:05:52 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 18:05:53 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 18:05:53 jean-P34V2 sensors[950]: acpitz-virtual-0
août 27 18:05:53 jean-P34V2 acpid[902]: starting up with netlink and the input layer
août 27 18:05:53 jean-P34V2 acpid[902]: 8 rules loaded
août 27 18:05:53 jean-P34V2 acpid[902]: waiting for events: event logging is off
août 27 18:07:15 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 18:07:15 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 27 18:07:15 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 18:07:15 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 27 18:07:15 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 27 18:07:15 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 27 18:07:15 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 27 18:07:15 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 18:07:16 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 18:07:16 jean-P34V2 sensors[963]: acpitz-virtual-0
août 27 18:07:17 jean-P34V2 acpid[953]: starting up with netlink and the input layer
août 27 18:07:17 jean-P34V2 acpid[953]: 8 rules loaded
août 27 18:07:17 jean-P34V2 acpid[953]: waiting for events: event logging is off
août 27 19:53:29 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 19:53:29 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 27 19:53:29 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 27 19:53:29 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 27 19:53:29 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 27 19:53:29 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 27 19:53:29 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 27 19:53:29 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 19:53:30 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 27 19:53:30 jean-P34V2 sensors[984]: acpitz-virtual-0
août 27 19:53:30 jean-P34V2 acpid[923]: starting up with netlink and the input layer
août 27 19:53:30 jean-P34V2 acpid[923]: 8 rules loaded
août 27 19:53:30 jean-P34V2 acpid[923]: waiting for events: event logging is off
août 28 17:36:38 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 28 17:36:38 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 28 17:36:38 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 28 17:36:38 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 28 17:36:38 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 28 17:36:38 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 28 17:36:38 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 28 17:36:38 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 28 17:36:39 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 28 17:36:40 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 28 17:36:40 jean-P34V2 sensors[958]: acpitz-virtual-0
août 28 17:36:40 jean-P34V2 acpid[923]: starting up with netlink and the input layer
août 28 17:36:40 jean-P34V2 acpid[923]: 8 rules loaded
août 28 17:36:40 jean-P34V2 acpid[923]: waiting for events: event logging is off
août 28 17:55:36 jean-P34V2 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 28 17:55:36 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 28 17:55:36 jean-P34V2 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-33-generic root=UUID=7a6c57e3-83c6-4ebe-a6dc-83d0f4f31c61 ro nouveau.blacklist=1 quiet splash acpi=force nouveau.runpm=0 vt.handoff=1
août 28 17:55:36 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 28 17:55:36 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 28 17:55:36 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 28 17:55:36 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 28 17:55:36 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 28 17:55:37 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 28 17:55:37 jean-P34V2 sensors[958]: acpitz-virtual-0
août 28 17:55:37 jean-P34V2 acpid[932]: starting up with netlink and the input layer
août 28 17:55:37 jean-P34V2 acpid[932]: 8 rules loaded
août 28 17:55:37 jean-P34V2 acpid[932]: waiting for events: event logging is off
août 28 18:36:39 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 28 18:36:40 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 28 18:36:40 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 28 18:36:40 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 28 18:36:40 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 28 18:36:40 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 28 18:36:41 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 28 18:36:41 jean-P34V2 acpid[900]: starting up with netlink and the input layer
août 28 18:36:41 jean-P34V2 acpid[900]: 8 rules loaded
août 28 18:36:41 jean-P34V2 acpid[900]: waiting for events: event logging is off
août 28 18:36:41 jean-P34V2 sensors[980]: acpitz-virtual-0
août 28 19:34:17 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 28 19:34:17 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 28 19:34:17 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 28 19:34:17 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 28 19:34:17 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 28 19:34:17 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 28 19:34:18 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 28 19:34:18 jean-P34V2 sensors[970]: acpitz-virtual-0
août 28 19:34:19 jean-P34V2 acpid[951]: starting up with netlink and the input layer
août 28 19:34:19 jean-P34V2 acpid[951]: 8 rules loaded
août 28 19:34:19 jean-P34V2 acpid[951]: waiting for events: event logging is off
août 28 20:30:22 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 06:07:41 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 29 06:07:41 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 06:28:55 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 29 06:28:55 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 29 06:28:55 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 29 06:28:55 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 29 06:28:55 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 29 06:28:55 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 06:28:56 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 06:28:56 jean-P34V2 sensors[957]: acpitz-virtual-0
août 29 06:28:56 jean-P34V2 acpid[899]: starting up with netlink and the input layer
août 29 06:28:56 jean-P34V2 acpid[899]: 8 rules loaded
août 29 06:28:56 jean-P34V2 acpid[899]: waiting for events: event logging is off
août 29 06:36:33 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 29 06:36:33 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 29 06:36:33 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 29 06:36:33 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 29 06:36:33 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 29 06:36:33 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 06:36:34 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 06:36:34 jean-P34V2 sensors[955]: acpitz-virtual-0
août 29 06:36:35 jean-P34V2 acpid[899]: starting up with netlink and the input layer
août 29 06:36:35 jean-P34V2 acpid[899]: 8 rules loaded
août 29 06:36:35 jean-P34V2 acpid[899]: waiting for events: event logging is off
août 29 06:46:37 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 17:11:34 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 29 17:11:34 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 17:32:52 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 29 17:32:52 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 29 17:32:52 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 29 17:32:52 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 29 17:32:52 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 29 17:32:52 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 17:32:53 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 17:32:53 jean-P34V2 sensors[960]: acpitz-virtual-0
août 29 17:32:53 jean-P34V2 acpid[902]: starting up with netlink and the input layer
août 29 17:32:53 jean-P34V2 acpid[902]: 8 rules loaded
août 29 17:32:53 jean-P34V2 acpid[902]: waiting for events: event logging is off
août 29 17:55:22 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 29 17:55:22 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 29 17:55:22 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 29 17:55:22 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 29 17:55:22 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 29 17:55:22 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 17:55:23 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 17:55:23 jean-P34V2 sensors[958]: acpitz-virtual-0
août 29 17:55:23 jean-P34V2 acpid[883]: starting up with netlink and the input layer
août 29 17:55:23 jean-P34V2 acpid[883]: 8 rules loaded
août 29 17:55:23 jean-P34V2 acpid[883]: waiting for events: event logging is off
août 29 18:05:27 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 29 18:05:27 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 29 18:05:27 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 29 18:05:27 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 29 18:05:27 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 29 18:05:27 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 18:05:28 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 18:05:28 jean-P34V2 sensors[994]: acpitz-virtual-0
août 29 18:05:29 jean-P34V2 acpid[949]: starting up with netlink and the input layer
août 29 18:05:29 jean-P34V2 acpid[949]: 8 rules loaded
août 29 18:05:29 jean-P34V2 acpid[949]: waiting for events: event logging is off
août 29 18:15:24 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 29 18:15:24 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 29 18:15:24 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 29 18:15:24 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 29 18:15:24 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 29 18:15:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 18:15:25 jean-P34V2 sensors[990]: acpitz-virtual-0
août 29 18:15:26 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 18:15:26 jean-P34V2 acpid[972]: starting up with netlink and the input layer
août 29 18:15:26 jean-P34V2 acpid[972]: 8 rules loaded
août 29 18:15:26 jean-P34V2 acpid[972]: waiting for events: event logging is off
août 29 18:15:27 jean-P34V2 acpid[972]: client connected from 1098[0:0]
août 29 18:15:27 jean-P34V2 acpid[972]: 1 client rule loaded
août 29 18:18:44 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 29 18:18:44 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 29 18:18:44 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 29 18:18:44 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 29 18:18:44 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 29 18:18:44 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 18:18:46 jean-P34V2 sensors[989]: acpitz-virtual-0
août 29 18:18:46 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 18:18:46 jean-P34V2 acpid[948]: starting up with netlink and the input layer
août 29 18:18:46 jean-P34V2 acpid[948]: 8 rules loaded
août 29 18:18:46 jean-P34V2 acpid[948]: waiting for events: event logging is off
août 29 18:18:47 jean-P34V2 acpid[948]: client connected from 1098[0:0]
août 29 18:18:47 jean-P34V2 acpid[948]: 1 client rule loaded
août 29 20:10:48 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 21:44:22 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 29 21:44:22 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 29 21:44:22 jean-P34V2 acpid[948]: client 1098[0:0] has disconnected
août 29 21:44:22 jean-P34V2 acpid[948]: client connected from 1098[0:0]
août 29 21:44:22 jean-P34V2 acpid[948]: 1 client rule loaded
août 29 22:19:24 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 07:39:48 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 30 07:39:48 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 07:39:48 jean-P34V2 acpid[948]: client 1098[0:0] has disconnected
août 30 07:39:48 jean-P34V2 acpid[948]: client connected from 1098[0:0]
août 30 07:39:48 jean-P34V2 acpid[948]: 1 client rule loaded
août 30 08:56:32 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 15:43:07 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 30 15:43:07 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 15:43:07 jean-P34V2 acpid[948]: client 1098[0:0] has disconnected
août 30 15:43:07 jean-P34V2 acpid[948]: client connected from 1098[0:0]
août 30 15:43:07 jean-P34V2 acpid[948]: 1 client rule loaded
août 30 16:33:20 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 18:08:15 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 30 18:08:15 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 18:08:15 jean-P34V2 acpid[948]: client 1098[0:0] has disconnected
août 30 18:08:15 jean-P34V2 acpid[948]: client connected from 1098[0:0]
août 30 18:08:15 jean-P34V2 acpid[948]: 1 client rule loaded
août 30 19:09:56 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 30 19:09:56 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 30 19:09:56 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 30 19:09:56 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 30 19:09:56 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 30 19:09:56 jean-P34V2 kernel: acpi device:48: hash matches
août 30 19:09:56 jean-P34V2 kernel: acpi device:1b: hash matches
août 30 19:09:57 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 19:09:58 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 19:09:58 jean-P34V2 sensors[992]: acpitz-virtual-0
août 30 19:09:58 jean-P34V2 acpid[969]: starting up with netlink and the input layer
août 30 19:09:58 jean-P34V2 acpid[969]: 8 rules loaded
août 30 19:09:58 jean-P34V2 acpid[969]: waiting for events: event logging is off
août 30 19:09:59 jean-P34V2 acpid[969]: client connected from 1103[0:0]
août 30 19:09:59 jean-P34V2 acpid[969]: 1 client rule loaded
août 30 19:26:04 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 19:50:29 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 30 19:50:29 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 19:50:29 jean-P34V2 acpid[969]: client 1103[0:0] has disconnected
août 30 19:50:29 jean-P34V2 acpid[969]: client connected from 1103[0:0]
août 30 19:50:29 jean-P34V2 acpid[969]: 1 client rule loaded
août 30 19:53:52 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
août 30 19:53:52 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
août 30 19:53:52 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
août 30 19:53:52 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
août 30 19:53:52 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
août 30 19:53:52 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 19:53:53 jean-P34V2 sensors[982]: acpitz-virtual-0
août 30 19:53:54 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 19:53:54 jean-P34V2 acpid[968]: starting up with netlink and the input layer
août 30 19:53:54 jean-P34V2 acpid[968]: 8 rules loaded
août 30 19:53:54 jean-P34V2 acpid[968]: waiting for events: event logging is off
août 30 19:53:55 jean-P34V2 acpid[968]: client connected from 1140[0:0]
août 30 19:53:55 jean-P34V2 acpid[968]: 1 client rule loaded
août 30 19:54:46 jean-P34V2 ureadahead[393]: ureadahead:acpi: Chemin relatif ignoré
août 30 19:56:48 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 22:43:04 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 30 22:43:04 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 30 22:43:04 jean-P34V2 acpid[968]: client 1140[0:0] has disconnected
août 30 22:43:04 jean-P34V2 acpid[968]: client connected from 1140[0:0]
août 30 22:43:04 jean-P34V2 acpid[968]: 1 client rule loaded
août 30 23:12:58 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 31 06:16:54 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 31 06:16:54 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 31 06:16:54 jean-P34V2 acpid[968]: client 1140[0:0] has disconnected
août 31 06:16:54 jean-P34V2 acpid[968]: client connected from 1140[0:0]
août 31 06:16:54 jean-P34V2 acpid[968]: 1 client rule loaded
août 31 06:59:30 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 31 17:11:51 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
août 31 17:11:51 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
août 31 17:11:51 jean-P34V2 acpid[968]: client 1140[0:0] has disconnected
août 31 17:11:52 jean-P34V2 acpid[968]: client connected from 1140[0:0]
août 31 17:11:52 jean-P34V2 acpid[968]: 1 client rule loaded
août 31 18:16:17 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 01 16:49:41 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
sept. 01 16:49:41 jean-P34V2 acpid[968]: client 1140[0:0] has disconnected
sept. 01 16:49:41 jean-P34V2 acpid[968]: client connected from 1140[0:0]
sept. 01 16:49:41 jean-P34V2 acpid[968]: 1 client rule loaded
sept. 02 08:19:25 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
sept. 02 08:19:25 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 08:19:25 jean-P34V2 acpid[968]: client 1140[0:0] has disconnected
sept. 02 08:19:25 jean-P34V2 acpid[968]: input device has been disconnected, fd 15
sept. 02 08:19:25 jean-P34V2 acpid[968]: input layer read error: Resource temporarily unavailable (11)
sept. 02 08:19:25 jean-P34V2 acpid[968]: client connected from 1140[0:0]
sept. 02 08:19:25 jean-P34V2 acpid[968]: 1 client rule loaded
sept. 02 09:31:33 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
sept. 02 09:31:33 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
sept. 02 09:31:33 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
sept. 02 09:31:33 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
sept. 02 09:31:33 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
sept. 02 09:31:33 jean-P34V2 kernel: acpi LNXPOWER:04: hash matches
sept. 02 09:31:34 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 09:31:35 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 09:31:35 jean-P34V2 sensors[999]: acpitz-virtual-0
sept. 02 09:31:35 jean-P34V2 acpid[959]: starting up with netlink and the input layer
sept. 02 09:31:35 jean-P34V2 acpid[959]: 8 rules loaded
sept. 02 09:31:35 jean-P34V2 acpid[959]: waiting for events: event logging is off
sept. 02 09:31:36 jean-P34V2 acpid[959]: client connected from 1154[0:0]
sept. 02 09:31:36 jean-P34V2 acpid[959]: 1 client rule loaded
sept. 02 09:32:09 jean-P34V2 acpid[959]: client 1154[0:0] has disconnected
sept. 02 09:34:31 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
sept. 02 09:34:31 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
sept. 02 09:34:31 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
sept. 02 09:34:31 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
sept. 02 09:34:31 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
sept. 02 09:34:31 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 09:34:32 jean-P34V2 sensors[987]: acpitz-virtual-0
sept. 02 09:34:33 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 09:34:33 jean-P34V2 acpid[925]: starting up with netlink and the input layer
sept. 02 09:34:33 jean-P34V2 acpid[925]: 8 rules loaded
sept. 02 09:34:33 jean-P34V2 acpid[925]: waiting for events: event logging is off
sept. 02 09:34:34 jean-P34V2 acpid[925]: client connected from 1143[0:0]
sept. 02 09:34:34 jean-P34V2 acpid[925]: 1 client rule loaded
sept. 02 09:54:57 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
sept. 02 09:54:57 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
sept. 02 09:54:57 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
sept. 02 09:54:57 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
sept. 02 09:54:57 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
sept. 02 09:54:58 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 09:54:59 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 09:54:59 jean-P34V2 sensors[998]: acpitz-virtual-0
sept. 02 09:54:59 jean-P34V2 acpid[958]: starting up with netlink and the input layer
sept. 02 09:54:59 jean-P34V2 acpid[958]: 8 rules loaded
sept. 02 09:54:59 jean-P34V2 acpid[958]: waiting for events: event logging is off
sept. 02 09:55:00 jean-P34V2 acpid[958]: client connected from 1153[0:0]
sept. 02 09:55:00 jean-P34V2 acpid[958]: 1 client rule loaded
sept. 02 10:05:04 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
sept. 02 10:05:04 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
sept. 02 10:05:04 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
sept. 02 10:05:04 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
sept. 02 10:05:04 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
sept. 02 10:05:05 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 10:05:06 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 10:05:06 jean-P34V2 sensors[994]: acpitz-virtual-0
sept. 02 10:05:06 jean-P34V2 acpid[937]: starting up with netlink and the input layer
sept. 02 10:05:06 jean-P34V2 acpid[937]: 8 rules loaded
sept. 02 10:05:06 jean-P34V2 acpid[937]: waiting for events: event logging is off
sept. 02 10:05:08 jean-P34V2 acpid[937]: client connected from 1151[0:0]
sept. 02 10:05:08 jean-P34V2 acpid[937]: 1 client rule loaded
sept. 02 10:56:44 jean-P34V2 acpid[937]: client 1151[0:0] has disconnected
sept. 02 11:18:23 jean-P34V2 kernel: acpi LNXPOWER:01: Turning OFF
sept. 02 11:18:23 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 11:18:24 jean-P34V2 acpid[937]: client connected from 1151[0:0]
sept. 02 11:18:24 jean-P34V2 acpid[937]: 1 client rule loaded
sept. 02 12:01:09 jean-P34V2 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
sept. 02 12:01:09 jean-P34V2 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
sept. 02 12:01:09 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
sept. 02 12:01:09 jean-P34V2 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
sept. 02 12:01:09 jean-P34V2 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
sept. 02 12:01:10 jean-P34V2 kernel: acpi device:41: Cannot transition to power state D3hot for parent in (unknown)
sept. 02 12:01:10 jean-P34V2 sensors[987]: acpitz-virtual-0
sept. 02 12:01:10 jean-P34V2 acpid[982]: starting up with netlink and the input layer
sept. 02 12:01:10 jean-P34V2 acpid[982]: 8 rules loaded
sept. 02 12:01:10 jean-P34V2 acpid[982]: waiting for events: event logging is off
sept. 02 12:01:11 jean-P34V2 acpid[982]: client connected from 1160[0:0]
sept. 02 12:01:11 jean-P34V2 acpid[982]: 1 client rule loaded
jean@jean-P34V2:~$
Que puis je faire afin d'enlever tout ces messages d'erreur ,et aussi évité que les ventilos ne moulines pas trop.
Je precise aussi qu'a la base c'est une mint19 xfce que j'ai désinstallé avec cinnamon installé a la place.
MACHINE : portable gigabyte P34G v2
CPU : Intel(R) Core(TM) i7-4710HQ CPU @ 2.50GHz
CHIPSET : Mobile Intel HM87 Express
MEMOIRE : DDR3L SDRAM 8+4go
GPU : NVIDIA GeForce GTX 860M / Intel HD Graphics 4600 - 4 Go GDDR5 SDRAM
STOCKAGE : 500Go SSD + 1 To HDD
DUAL BOOT (LEGACY) : linux Mint / windows 10
VERSION : linux mint 19 noyau 4.15.0-33-generic cinamon 3.8.8
Re: Message du journal ACPI, kernel ect...
D'après les messages «Package temperature above threshold, cpu clock throttled», la température de tes CPUs dépassent le seuil autorisé et la vitesse de l'horloge des CPUS est donc bridée.
Donc, ce n'est pas du tout normal pour une utilisation "basique" (sans lancer des logiciels gourmands).
Vérifie la température et les seuils de tes CPU en lançant la commande :
sensors
Ajean
Message par Ajean »
voici ce que me retourne sensors
jean@jean-P34V2:~$ sensors
pch_haswell-virtual-0
Adapter: Virtual device
temp1:        +63.5°C
acpitz-virtual-0
temp1:        +27.8°C  (crit = +100.0°C)
temp2:        +29.8°C  (crit = +100.0°C)
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:  +66.0°C  (high = +84.0°C, crit = +100.0°C)
Core 0:        +66.0°C  (high = +84.0°C, crit = +100.0°C)
Core 1:        +64.0°C  (high = +84.0°C, crit = +100.0°C)
Core 2:        +60.0°C  (high = +84.0°C, crit = +100.0°C)
Core 3:        +61.0°C  (high = +84.0°C, crit = +100.0°C)
J'ai bien entendu le message du journal:
CPU: Package temperature above threshold, cpu clock throttled ...
Je tiens a precisé que j'ai thermald d'installé et j'ai aussi forcé le cpu a tourné sur le mode powersave grâce a ce tuto :
http://www.webupd8.org/2014/04/prevent- ... ating.html
Ajean
Message par Ajean »
apres avoir tourné le sujet en long en large et en diagonale...j'ai changer la pâte thermique et sa à résolu mon problème de température.
Bref , les choses simples sont les meilleures solutions. Sinon c'est etonnant que windows ne m'ai jamais signalé de problème de température...
Du coup dans m'on démontage de coque pour remplacé la pâte je me suis rendu compte que m'a batterie avait gonflé :-o , lion polymère..sa risque d'explosé ou prendre feu! donc démontage et parcours du combattant pour trouvé un fournisseur.
bonjour,
la coche du résolu et le "résolu" doivent être mis sur le premier message ;)
mais comme les 15 jours sont passés, je vais le faire pour toi ;)
Ajean
Re: [résolu] Message du journal ACPI, kernel ect...
Message par Ajean »
Merci !
