J'ai installé Mint 19.1 32 bits sur un MacBook 4,1 équipé d'un disque dur SSD.
L'installation et fonctionnement ok, mais il est lent au démarrage et également lent lors du changement de session.
voici le retour de systemd-analyze :
Startup finished in 1min 5.159s (kernel) + 34.264s (userspace) = 1min 39.424s
graphical.target reached after 34.251s in userspace
31.536s lightdm.service
31.532s plymouth-quit-wait.service
967ms dev-sda2.device
928ms udisks2.service
670ms accounts-daemon.service
663ms networkd-dispatcher.service
623ms ModemManager.service
541ms ubuntu-system-adjustments.service
508ms NetworkManager.service
504ms hddtemp.service
486ms apport.service
462ms lm-sensors.service
461ms grub-common.service
437ms networking.service
432ms speech-dispatcher.service
428ms alsa-restore.service
416ms kerneloops.service
378ms gpu-manager.service
371ms avahi-daemon.service
341ms systemd-logind.service
318ms upower.service
312ms pppd-dns.service
283ms apparmor.service
273ms systemd-journald.service
255ms thermald.service
255ms rsyslog.service
249ms keyboard-setup.service
240ms wpa_supplicant.service
198ms systemd-udev-trigger.service
168ms systemd-journal-flush.service
154ms lvm2-monitor.service
135ms systemd-resolved.service
107ms polkit.service
104ms systemd-modules-load.service
92ms systemd-udevd.service
89ms user@1000.service
83ms systemd-fsck@dev-disk-by\x2duuid-a3a92a0a\x2dbed6\x2d4662\x2db850\x2d7c22e72cc9c1.service
75ms ntp.service
66ms systemd-tmpfiles-setup-dev.service
62ms bluetooth.service
62ms systemd-tmpfiles-setup.service
54ms dns-clean.service
44ms systemd-random-seed.service
43ms systemd-sysctl.service
41ms ufw.service
39ms systemd-remount-fs.service
38ms kmod-static-nodes.service
38ms sys-kernel-debug.mount
37ms dev-mqueue.mount
34ms setvtrgb.service
33ms systemd-rfkill.service
32ms blk-availability.service
29ms dev-hugepages.mount
26ms dev-disk-by\x2duuid-3ae535cb\x2d72ae\x2d447f\x2dacc0\x2d8a08c6b279d2.swap
26ms systemd-user-sessions.service
24ms openvpn.service
23ms plymouth-start.service
20ms systemd-update-utmp.service
20ms home.mount
18ms sys-fs-fuse-connections.mount
16ms sys-kernel-config.mount
14ms ureadahead-stop.service
14ms plymouth-read-write.service
12ms console-setup.service
11ms systemd-update-utmp-runlevel.service
9ms rtkit-daemon.service
6ms systemd-backlight@backlight:intel_backlight.service
Comment peut-on améliorer ça ?
merci d'avance pour vos réponses.
