Me voila, comme indiqué dans le titre, sans Grub depuis la réinstallation de Windows 7.
J'ai bien évidemment tenter plusieurs Boot-repair sans résultat. Je n'ai pas changé de version BIOS depuis la dernière install'.
La seule chose étrange et incomprise est que la partition /grub se trouve au même endroit que /home. Ce qui me donne dans Gparted: /dev/sda4......../boot, /home.
Voici la Boot-info généré après ma dernière tentative de Boot-repair
Boot Info Script 8f991e4 + Boot-Repair extra info [Boot-Info 25oct2017]
=> Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
for (,msdos4)/grub. It also embeds following components:
modules
fshelp ext2 part_msdos biosdisk
File system: ntfs
Boot sector type: Windows 7/2008: NTFS
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /grldr /bootmgr /Boot/BCD
/Windows/System32/winload.exe /grldr
File system: Extended Partition
Boot sector type: Unknown
Boot sector info:
sda5: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sda3: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Linux Mint 19
Boot files: /etc/fstab
sda4: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files: /grub/grub.cfg /grub/i386-pc/core.img
Disk /dev/sda: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 64 255,995,774 255,995,711 7 NTFS / exFAT / HPFS
/dev/sda2 * 255,995,902 259,901,439 3,905,538 5 Extended
/dev/sda5 255,995,904 259,901,439 3,905,536 82 Linux swap / Solaris
/dev/sda3 259,901,440 318,494,719 58,593,280 83 Linux
/dev/sda4 318,494,720 761,853,951 443,359,232 83 Linux
Device UUID TYPE LABEL
/dev/sda1 FAEA2FF6EA2FADB7 ntfs
/dev/sda3 714c7d0e-1885-4e9b-931c-696c9a8523e6 ext4
/dev/sda4 c31ea9e3-580a-4ac0-9216-5570a8ce9ca4 ext4
/dev/sda5 42bdd4f6-cc20-42a7-88eb-c14fd2cf65aa swap
total 0
lrwxrwxrwx 1 root root 9 Nov 15 18:18 ata-Samsung_SSD_860_EVO_500GB_S4CNNG0M203610L -> ../../sda
lrwxrwxrwx 1 root root 10 Nov 15 18:18 ata-Samsung_SSD_860_EVO_500GB_S4CNNG0M203610L-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Nov 15 18:18 ata-Samsung_SSD_860_EVO_500GB_S4CNNG0M203610L-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Nov 15 18:18 ata-Samsung_SSD_860_EVO_500GB_S4CNNG0M203610L-part3 -> ../../sda3
lrwxrwxrwx 1 root root 10 Nov 15 18:18 ata-Samsung_SSD_860_EVO_500GB_S4CNNG0M203610L-part4 -> ../../sda4
lrwxrwxrwx 1 root root 10 Nov 15 18:18 ata-Samsung_SSD_860_EVO_500GB_S4CNNG0M203610L-part5 -> ../../sda5
lrwxrwxrwx 1 root root 9 Nov 15 18:18 wwn-0x5002538e701d4297 -> ../../sda
lrwxrwxrwx 1 root root 10 Nov 15 18:18 wwn-0x5002538e701d4297-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Nov 15 18:18 wwn-0x5002538e701d4297-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Nov 15 18:18 wwn-0x5002538e701d4297-part3 -> ../../sda3
lrwxrwxrwx 1 root root 10 Nov 15 18:18 wwn-0x5002538e701d4297-part4 -> ../../sda4
lrwxrwxrwx 1 root root 10 Nov 15 18:18 wwn-0x5002538e701d4297-part5 -> ../../sda5
Device Mount_Point Type Options
/dev/fuse /home/bachibouzouk/.cache/doc fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
/dev/sda3 / ext4 (rw,relatime,errors=remount-ro,data=ordered)
/dev/sda4 /boot ext4 (rw,relatime,data=ordered)
/dev/sda4 /home ext4 (rw,relatime,data=ordered)
========================== sda1/grldr embedded menu: ===========================
=============================== sda3/etc/fstab: ================================
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda3 during installation
UUID=714c7d0e-1885-4e9b-931c-696c9a8523e6 / ext4 errors=remount-ro 0 1
# /home was on /dev/sda4 during installation
UUID=c31ea9e3-580a-4ac0-9216-5570a8ce9ca4 /home ext4 defaults 0 2
# swap was on /dev/sda5 during installation
UUID=42bdd4f6-cc20-42a7-88eb-c14fd2cf65aa none swap sw 0 0
UUID=c31ea9e3-580a-4ac0-9216-5570a8ce9ca4 /boot ext4 defaults 0 2
=================== sda3: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
124.102512360 = 133.254057984 vmlinuz 2
124.102512360 = 133.254057984 vmlinuz.old 2
126.450748444 = 135.775457280 initrd.img 5
126.450748444 = 135.775457280 initrd.img.old 5
============================= sda4/grub/grub.cfg: ==============================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos3'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos3 --hint-efi=hd0,msdos3 --hint-baremetal=ahci0,msdos3 714c7d0e-1885-4e9b-931c-696c9a8523e6
else
search --no-floppy --fs-uuid --set=root 714c7d0e-1885-4e9b-931c-696c9a8523e6
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=fr_FR
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
set timeout=10
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=10
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 10 ; then
set timeout=10
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=1
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-714c7d0e-1885-4e9b-931c-696c9a8523e6' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_msdos
insmod ext2
set root='hd0,msdos4'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos4 --hint-efi=hd0,msdos4 --hint-baremetal=ahci0,msdos4 c31ea9e3-580a-4ac0-9216-5570a8ce9ca4
else
search --no-floppy --fs-uuid --set=root c31ea9e3-580a-4ac0-9216-5570a8ce9ca4
fi
linux /vmlinuz-4.15.0-70-generic root=UUID=714c7d0e-1885-4e9b-931c-696c9a8523e6 ro quiet splash $vt_handoff
initrd /initrd.img-4.15.0-70-generic
submenu 'Advanced options for Ubuntu' $menuentry_id_option 'gnulinux-advanced-714c7d0e-1885-4e9b-931c-696c9a8523e6' {
menuentry 'Ubuntu, with Linux 4.15.0-70-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.15.0-70-generic-advanced-714c7d0e-1885-4e9b-931c-696c9a8523e6' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 4.15.0-70-generic ...'
echo 'Loading initial ramdisk ...'
menuentry 'Ubuntu, with Linux 4.15.0-70-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.15.0-70-generic-recovery-714c7d0e-1885-4e9b-931c-696c9a8523e6' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /vmlinuz-4.15.0-70-generic root=UUID=714c7d0e-1885-4e9b-931c-696c9a8523e6 ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=================== sda4: Location of files loaded by Grub: ====================
151.870121002 = 163.069300736 grub/grub.cfg 1
242.051815033 = 259.901157376 grub/i386-pc/core.img 1
152.041965485 = 163.253817344 vmlinuz-4.15.0-70-generic 2
154.390201569 = 165.775216640 initrd.img-4.15.0-70-generic 5
======================== Unknown MBRs/Boot Sectors/etc: ========================
Unknown BootLoader on sda2
hexdump: /dev/sda2: No such device or address
File descriptor 9 (/proc/21165/mountinfo) leaked on lvs invocation. Parent PID 30175: bash
File descriptor 63 (pipe:[67102]) leaked on lvs invocation. Parent PID 30175: bash
ADDITIONAL INFORMATION :
=================== log of boot-repair 20191115_1817 ===================
boot-repair version : 4ppa66
boot-sav version : 4ppa66
boot-sav-extra version :
glade2script version : 3.2.3~ppa4
/usr/share/boot-sav/gui-scan.sh: ligne 20: os-prober : commande introuvable
boot-repair is executed in installed-session (Linux Mint 19 Tara, tara, LinuxMint, x86_64)
CPU op-mode(s): 32-bit, 64-bit
BOOT_IMAGE=/vmlinuz-4.15.0-70-generic root=UUID=714c7d0e-1885-4e9b-931c-696c9a8523e6 ro quiet splash vt.handoff=1
/dev/sda3:L'OS actuellement utilisé - Linux Mint 19 Tara CurrentSession:linux
=================== blkid:
/dev/sda1: UUID="FAEA2FF6EA2FADB7" TYPE="ntfs" PARTUUID="0f154e29-01"
/dev/sda3: UUID="714c7d0e-1885-4e9b-931c-696c9a8523e6" TYPE="ext4" PARTUUID="0f154e29-03"
/dev/sda4: UUID="c31ea9e3-580a-4ac0-9216-5570a8ce9ca4" TYPE="ext4" PARTUUID="0f154e29-04"
/dev/sda5: UUID="42bdd4f6-cc20-42a7-88eb-c14fd2cf65aa" TYPE="swap" PARTUUID="0f154e29-05"
1 disks with OS, 1 OS : 1 Linux, 0 MacOS, 0 Windows, 0 unknown type OS.
Windows not detected by os-prober on sda1.
=================== /etc/grub.d/ :
drwxr-xr-x 3 root root 4096 nov. 15 00:45 grub.d
drwxr-xr-x 5 root root 4096 nov. 15 00:08 grub.d.bak
total 80
-rwxr-xr-x 1 root root 10046 mars 18 2019 00_header
-rwxr-xr-x 1 root root 6258 mars 18 2019 05_debian_theme
-rwxr-xr-x 1 root root 12693 mars 18 2019 10_linux
-rwxr-xr-x 1 root root 11298 mars 18 2019 20_linux_xen
-rwxr-xr-x 1 root root 12059 mars 18 2019 30_os-prober
-rwxr-xr-x 1 root root 1418 mars 18 2019 30_uefi-firmware
-rwxr-xr-x 1 root root 214 mars 18 2019 40_custom
-rwxr-xr-x 1 root root 216 mars 18 2019 41_custom
drwxr-xr-x 4 root root 4096 nov. 15 00:26 backup
-rw-r--r-- 1 root root 483 mars 18 2019 README
=================== /etc/default/grub :
# /boot/grub/grub.cfg.
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT="0"
GRUB_TIMEOUT_STYLE="hidden"
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR="`lsb_release -i -s 2> /dev/null || echo Debian`"
GRUB_CMDLINE_LINUX=""
#GRUB_TERMINAL="console"
#GRUB_GFXMODE="640x480"
#GRUB_DISABLE_LINUX_UUID="true"
#GRUB_DISABLE_RECOVERY="true"
#GRUB_INIT_TUNE="480 440 1"
/boot detected in the fstab of sda3: UUID=c31ea9e3-580a-4ac0-9216-5570a8ce9ca4 (sda4)
This installed-session is not in EFI-mode.
EFI in dmesg.
[ 0.000000] ACPI: UEFI 0x00000000BAFDF000 00003E (v01 LENOVO TP-G5 00002560 PTL 00000002)
[ 0.000000] ACPI: UEFI 0x00000000BAFDE000 000042 (v01 PTL COMBUF 00000001 PTL 00000001)
[ 0.000000] ACPI: UEFI 0x00000000BAFDA000 0002A6 (v01 LENOVO TP-G5 00002560 PTL 00000002)
SecureBoot disabled.
sda3 : sda, not-sepboot, grubenv-ok grub2, grub-pc , update-grub, 64, with-boot, is-os, not--efi--part, fstab-has-goodBOOT, fstab-without-efi, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, apt-get, grub-install, with--usr, fstab-without-usr, not-sep-usr, standard, farbios, notbiosboot, .
sda1 : sda, not-sepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, is-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, bootmgr, is-winboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, farbios, notbiosboot, /media/bachibouzouk/FAEA2FF6EA2FADB7.
sda4 : sda, is-sepboot, grubenv-ok nogrub, no-docgrub, no-update-grub, 32, no-boot, no-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, farbios, notbiosboot, /boot.
sda : not-GPT, BIOSboot-not-needed, has-no-EFIpart, not-usb, not-mmc, has-os, 64 sectors * 512 bytes
BYT;
/dev/sda:500GB:scsi:512:512:msdos:ATA Samsung SSD 860:;
1:32.8kB:131GB:131GB:ntfs::;
2:131GB:133GB:2000MB:::boot;
5:131GB:133GB:2000MB:linux-swap(v1)::;
3:133GB:163GB:30.0GB:ext4::;
4:163GB:390GB:227GB:ext4::;
=================== lsblk:
KNAME TYPE FSTYPE SIZE LABEL
sda disk 465,8G
sda1 part ntfs 122,1G
sda3 part ext4 28G
sda4 part ext4 211,4G
sda5 part swap 1,9G
KNAME ROTA RO RM STATE MOUNTPOINT
sda 0 0 0 running
sda1 0 0 0 /media/bachibouzouk/FAEA2FF6EA2FADB7
sda3 0 0 0 /
sda4 0 0 0 /home
sda5 0 0 0 [SWAP]
=================== mount:
udev on /dev type devtmpfs (rw,nosuid,relatime,size=5896728k,nr_inodes=1474182,mode=755)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=1185952k,mode=755)
/dev/sda3 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=44,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=20536)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
configfs on /sys/kernel/config type configfs (rw,relatime)
/dev/sda4 on /boot type ext4 (rw,relatime,data=ordered)
/dev/sda4 on /home type ext4 (rw,relatime,data=ordered)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=1185952k,mode=700,uid=1000,gid=1000)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
/dev/sda1 on /media/bachibouzouk/FAEA2FF6EA2FADB7 type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
/dev/fuse on /home/bachibouzouk/.cache/doc type fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
gvfsd-fuse on /home/bachibouzouk/.gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
=================== ls:
/sys/block/sda (filtered): alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range hidden holders inflight integrity power queue range removable ro sda1 sda2 sda3 sda4 sda5 size slaves stat subsystem trace uevent
/dev (filtered): autofs block bsg btrfs-control bus char console core cpu cpu_dma_latency cuse disk dri drm_dp_aux0 drm_dp_aux1 drm_dp_aux2 ecryptfs fb0 fd full fuse fw0 hpet hugepages hwrng i2c-0 i2c-1 i2c-10 i2c-11 i2c-12 i2c-13 i2c-14 i2c-15 i2c-16 i2c-17 i2c-18 i2c-19 i2c-2 i2c-20 i2c-3 i2c-4 i2c-5 i2c-6 i2c-7 i2c-8 i2c-9 initctl input kmsg lightnvm log mapper mcelog media0 mei0 mem memory_bandwidth mqueue net network_latency network_throughput null port ppp psaux ptmx ptp0 pts random rfkill rtc rtc0 sda sda1 sda2 sda3 sda4 sda5 sg0 shm snapshot snd stderr stdin stdout tpm0 uhid uinput urandom userio v4l vboxusb vfio vga_arbiter vhci vhost-net vhost-vsock video0 zero
ls /dev/mapper: control
=================== hexdump -n512 -C /dev/sda1
00000000 eb 52 90 4e 54 46 53 20 20 20 20 00 02 08 00 00 |.R.NTFS .....|
00000010 00 00 00 00 00 f8 00 00 3f 00 ff 00 40 00 00 00 |........?...@...|
00000020 00 00 00 00 80 00 80 00 3e 2f 42 0f 00 00 00 00 |........>/B.....|
00000030 00 00 0c 00 00 00 00 00 02 00 00 00 00 00 00 00 |................|
00000040 f6 00 00 00 01 00 00 00 b7 ad 2f ea f6 2f ea fa |........../../..|
00000050 00 00 00 00 fa 33 c0 8e d0 bc 00 7c fb 68 c0 07 |.....3.....|.h..|
00000060 1f 1e 68 66 00 cb 88 16 0e 00 66 81 3e 03 00 4e |..hf......f.>..N|
00000070 54 46 53 75 15 b4 41 bb aa 55 cd 13 72 0c 81 fb |TFSu..A..U..r...|
00000080 55 aa 75 06 f7 c1 01 00 75 03 e9 dd 00 1e 83 ec |U.u.....u.......|
00000090 18 68 1a 00 b4 48 8a 16 0e 00 8b f4 16 1f cd 13 |.h...H..........|
000000a0 9f 83 c4 18 9e 58 1f 72 e1 3b 06 0b 00 75 db a3 |.....X.r.;...u..|
000000b0 0f 00 c1 2e 0f 00 04 1e 5a 33 db b9 00 20 2b c8 |........Z3... +.|
000000c0 66 ff 06 11 00 03 16 0f 00 8e c2 ff 06 16 00 e8 |f...............|
000000d0 4b 00 2b c8 77 ef b8 00 bb cd 1a 66 23 c0 75 2d |K.+.w......f#.u-|
000000e0 66 81 fb 54 43 50 41 75 24 81 f9 02 01 72 1e 16 |f..TCPAu$....r..|
000000f0 68 07 bb 16 68 70 0e 16 68 09 00 66 53 66 53 66 |h...hp..h..fSfSf|
00000100 55 16 16 16 68 b8 01 66 61 0e 07 cd 1a 33 c0 bf |U...h..fa....3..|
00000110 28 10 b9 d8 0f fc f3 aa e9 5f 01 90 90 66 60 1e |(........_...f`.|
00000120 06 66 a1 11 00 66 03 06 1c 00 1e 66 68 00 00 00 |.f...f.....fh...|
00000130 00 66 50 06 53 68 01 00 68 10 00 b4 42 8a 16 0e |.fP.Sh..h...B...|
00000140 00 16 1f 8b f4 cd 13 66 59 5b 5a 66 59 66 59 1f |.......fY[ZfYfY.|
00000150 0f 82 16 00 66 ff 06 11 00 03 16 0f 00 8e c2 ff |....f...........|
00000160 0e 16 00 75 bc 07 1f 66 61 c3 a0 f8 01 e8 09 00 |...u...fa.......|
00000170 a0 fb 01 e8 03 00 f4 eb fd b4 01 8b f0 ac 3c 00 |..............<.|
00000180 74 09 b4 0e bb 07 00 cd 10 eb f2 c3 0d 0a 41 20 |t.............A |
00000190 64 69 73 6b 20 72 65 61 64 20 65 72 72 6f 72 20 |disk read error |
000001a0 6f 63 63 75 72 72 65 64 00 0d 0a 42 4f 4f 54 4d |occurred...BOOTM|
000001b0 47 52 20 69 73 20 6d 69 73 73 69 6e 67 00 0d 0a |GR is missing...|
000001c0 42 4f 4f 54 4d 47 52 20 69 73 20 63 6f 6d 70 72 |BOOTMGR is compr|
000001d0 65 73 73 65 64 00 0d 0a 50 72 65 73 73 20 43 74 |essed...Press Ct|
000001e0 72 6c 2b 41 6c 74 2b 44 65 6c 20 74 6f 20 72 65 |rl+Alt+Del to re|
000001f0 73 74 61 72 74 0d 0a 00 8c a9 be d6 00 00 55 aa |start.........U.|
00000200
=================== df -Th:
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 5.7G 0 5.7G 0% /dev
tmpfs tmpfs 1.2G 1.5M 1.2G 1% /run
/dev/sda3 ext4 28G 12G 15G 46% /
tmpfs tmpfs 5.7G 93M 5.6G 2% /dev/shm
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs tmpfs 5.7G 0 5.7G 0% /sys/fs/cgroup
/dev/sda4 ext4 208G 132G 66G 67% /boot
tmpfs tmpfs 1.2G 28K 1.2G 1% /run/user/1000
/dev/sda1 fuseblk 123G 48G 75G 39% /media/bachibouzouk/FAEA2FF6EA2FADB7
=================== fdisk -l:
Disklabel type: dos
Disk identifier: 0x0f154e29
Device Boot Start End Sectors Size Id Type
/dev/sda1 64 255995774 255995711 122.1G 7 HPFS/NTFS/exFAT
/dev/sda2 * 255995902 259901439 3905538 1.9G 5 Extended
/dev/sda3 259901440 318494719 58593280 28G 83 Linux
/dev/sda4 318494720 761853951 443359232 211.4G 83 Linux
/dev/sda5 255995904 259901439 3905536 1.9G 82 Linux swap / Solaris
Partition table entries are not in disk order.
=================== Recommended repair
The default repair of the Boot-Repair utility will reinstall the grub2 of sda3 into the MBR of sda, using the following options: sda4/boot,
Additional repair will be performed: unhide-bootmenu-10s
*******lspci -nnk | grep -iA3 vga
00:02.0 VGA compatible controller [0300]: Intel Corporation 3rd Gen Core processor Graphics Controller [8086:0166] (rev 09)
Subsystem: Lenovo 3rd Gen Core processor Graphics Controller [17aa:21f5]
Kernel driver in use: i915
Kernel modules: i915
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GK107GLM [Quadro K1000M] [10de:0ffc] (rev a1)
Subsystem: Lenovo GK107GLM [Quadro K1000M] [17aa:21f5]
Kernel driver in use: nouveau
Kernel modules: nvidiafb, nouveau
grub-install --version
grub-install (GRUB) 2.02-2ubuntu8.13,grub-install (GRUB) 2.
Reinstall the GRUB of sda3 into the MBR of sda
Installing for i386-pc platform.
Installation finished. No error reported.
grub-install /dev/sda: exit code of grub-install /dev/sda:0
update-grub
Found linux image: /boot/vmlinuz-4.15.0-70-generic
Found initrd image: /boot/initrd.img-4.15.0-70-generic
Unhide GRUB boot menu in sda3/boot/grub/grub.cfg
Le démarrage de l'ordinateur a été correctement réparé.
Vous pouvez maintenant redémarrer votre ordinateur.
Les fichiers de démarrage de [L'OS actuellement utilisé - Linux Mint 19 Tara] sont loin du début du disque. Votre BIOS pourrait ne pas les détecter. Vous voudrez peut-être re-essayer après avoir créé une partition /boot (EXT4, >200MB, en début de disque). Cela peut être réalisé via des outils tels que gParted. Puis sélectionnez cette partition via l'option [Partition /boot séparée :] de [Réparateur de démarrage]. (http://doc.ubuntu-fr.org/tutoriel/partition_boot)
N'hésitez pas si vous avez des suggestions!
Merci d'avance
(J'ajoute quand même que j'ai déja passé plusieurs heures sur l'internet mondial avant ce message à la recherche de solutions, sans résultat... Les docs de grub/LinuxMint/ubuntu, ne m'ont pas vraiment aidés non plus, mon faible niveau d'informatique ne me permettant pas de réellement déterminer mon problème. Et copier/coller des lignes auquelles je ne capte rien, ce ne me plait pas trop...)
