Je voudrais savoir si avec replaygain il est possible de traiter les fichiers inclus dans les sous-dossiers. L'aide indique ceci :
Options:
--version show program's version number and exit
-h, --help show this help message and exit
-f, --force Recalculate Replay Gain even if the file already
contains gain information.
-d, --dry-run Don't actually modify any files.
-r REF, --reference-loudness=REF
Set the reference loudness to REF dB (default: 89 dB)
--mp3-format=MP3_FORMAT
Choose the Replay Gain data format for MP3 files. The
default setting should be compatible with most decent
software music players, so it is generally not
necessary to mess with this setting. Check the README
or man page for more information.
--help-gst Show GStreamer options.
--no-album Don't write any album gain information.
--show Don't calculate anything, simply show Replay Gain
information for the specified files. In this mode, all
other options save for '--mp3-format' are ignored, for
they would make no sense.
Y aurait-il moyen de passer par un bash ?
