Mon pc tournant sous Linux mint 20 affiche initramfs à chaque démarrage.
La commande
fsck -y /dev/sda2
Voici un peu ce que je vis depuis une semaine. Aide-moi !
fsck -y /dev/sda2
sudo dmesg | egrep 'fail|error'
df -h
ctrl + alt + F1
df -h
[ 138.552329] ata1.00: failed command: READ FPDMA QUEUED
res 41/40:00:f0:08:10/00:00:1c:00:00/40 Emask 0x409 (media error) <F>
[ 138.552619] ata1.00: error: { UNC }
[ 138.580445] sd 0:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error - auto reallocate failed
[ 138.580459] blk_update_request: I/O error, dev sda, sector 470812912 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 628.612176] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
df -h
udev 1,7G 0 1,7G 0% /dev
tmpfs 338M 1,6M 336M 1% /run
/dev/sda2 457G 317G 118G 73% /
tmpfs 1,7G 0 1,7G 0% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 1,7G 0 1,7G 0% /sys/fs/cgroup
/dev/sda1 511M 7,9M 504M 2% /boot/efi
tmpfs 338M 60K 338M 1% /run/user/1002
