Résolu le 28-12-18 Mint 18.3 Méga lent ... [Résolu] même si je sais pas comment MDR
Spycrow
Message par Spycrow »
Pour commencer, de la lecture mdr
System:    Host: spycrow-Aspire-7739Z Kernel: 4.13.0-26-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3) dm: lightdm Distro: Linux Mint 18.3 Sylvia
Machine:   System: Acer (portable) product: Aspire 7739Z v: V1.04
           Mobo: Acer model: HMA71_CP v: Type2 - Board Version Bios: Insyde v: V1.04 date: 10/11/2011
CPU:       Dual core Intel Pentium P6200 (-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 ssse3) bmips: 8533
           clock speeds: min/max: 933/2133 MHz 1: 1066 MHz 2: 1199 MHz
Graphics:  Card: Intel Core Processor Integrated Graphics Controller bus-ID: 00:02.0 chip-ID: 8086:0046
           Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1600x900@60.01hz
           GLX Renderer: Mesa DRI Intel Ironlake Mobile
           GLX Version: 2.1 Mesa 17.2.4 Direct Rendering: Yes
Audio:     Card Intel 5 Series/3400 Series High Definition Audio
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:3b56
           Sound: Advanced Linux Sound Architecture v: k4.13.0-26-generic
Network:   Card-1: Qualcomm Atheros AR9485 Wireless Network Adapter
           driver: ath9k bus-ID: 02:00.0 chip-ID: 168c:0032
           IF: wlp2s0 state: down mac: <filter>
           Card-2: Qualcomm Atheros AR8152 v2.0 Fast Ethernet
           driver: atl1c v: 1.0.1.1-NAPI port: 2000 bus-ID: 03:00.0 chip-ID: 1969:2062
           IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 500.1GB (5.7% used)
           ID-1: /dev/sda model: WDC_WD5000LPVX size: 500.1GB serial: WD-WX81AC309408
Partition: ID-1: / size: 451G used: 20G (5%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 8.24GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
RAID:      System: supported: N/A
           No RAID devices: /proc/mdstat, md_mod kernel module present
           Unused Devices: none
Sensors:   System Temperatures: cpu: 40.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Repos:     Active apt sources in file: /etc/apt/sources.list.d/additional-repositories.list
           deb https: //dl.winehq.org/wine-builds/ubuntu/ xenial main
           Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list
           deb http: //packages.linuxmint.com sylvia main upstream import backport #id:linuxmint_main
           deb http: //archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
           deb http: //archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
           deb http: //archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
           deb http: //security.ubuntu.com/ubuntu/ xenial-security main restricted universe multiverse
           deb http: //archive.canonical.com/ubuntu/ xenial partner
Info:      Processes: 166 Uptime: 19 min Memory: 1118.9/7647.8MB
           Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.4.0
Client: Unknown python2.7 client inxi: 2.2.35
Je ne comprends pas, j'étais en 17.1 ou .2 depuis des plombes et j'ai voulu upgrader, mal m'en à pris. Ça n'avance plus, je n'arrive même plus à regarder une vidéo YOUTUBE sans freeze en 480P, je cherche mais je ne comprends pas ...
Merci de m'aider.
Modifié en dernier par Spycrow le dim. 21 janv. 2018 16:01, modifié 1 fois.
Re: Mint 18.3 Méga lent ...
merci d'utiliser les balises code pour tout ce qui est terminal ;)
j'ai donc repris ton message ;)
Spycrow
Ok ,,,, Merci :D
peut-être le fruit d'une maj incomplète !!
essais :
sudo apt clean && sudo apt update && sudo apt install -f && sudo apt autoremove && sudo apt dist-upgrade
et redémarre ;)
Spycrow
J'avais déjà fait cela ainsi qu'un Bleachbit, mais non ...
à tout hasard , tu as essayer de changer de thème ?
pingouinormand
Message par pingouinormand »
Avec ton processeur, un environnement XFCE serait peut-être plus adapté.
Laptop : Lenovo Thinkpad T430
OS : LMDE 5
WORK : 10 PCs sous Linux Mint 20.3 XFCE (CPU AMD Phenom X3 8450 | 4Go RAM DDR2 | GPU GeForce 8400 GS | SSD Crucial BX500 240 Go)
le upgrade de 17 vers 18 n'est pas du tout recommandé, car trop de différences, donc je pense pour éviter d'avoir un Os bancal, que le mieux serait de refaire une installe propre de LM18.3
Spycrow
C'est un redo from start, pas un upgrade, je me suis mal exprimé pardon.
Le changement de thème n'a rien fait mais j'ai essayé ...
Spycrow
Je dois quand même vous expliquer qu'avant en 17.*, le pc allait bien, pas de lenteur, pas de freeze, pas de lag, un surf idéal et le visionnage des vidéos fluides ainsi qu'avec KODI ... Maintenant KODI on oublie ...
