Lors de ma dernière installation, j'ai remis au gout du jour des logiciels qui me tiennent à coeur, dont « nitroshare». Il sert à partager des fichiers entre pc et surtout avec le mac de ma femme. Très facule et pratique que je conseille à beaucoup.
Mais voilà que j'obtiens après une nouvelle installation cela :
yvance@yvance ~ $ nitroshare
qt5ct: using qt5ct plugin
(process:17420): Gtk-CRITICAL **: 17:51:41.840: IA__gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
(process:17420): GLib-GObject-WARNING **: 17:51:41.840: invalid (NULL) pointer instance
(process:17420): GLib-GObject-CRITICAL **: 17:51:41.840: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(process:17420): GLib-GObject-WARNING **: 17:51:41.841: invalid (NULL) pointer instance
(process:17420): GLib-GObject-CRITICAL **: 17:51:41.841: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(process:17420): Gtk-CRITICAL **: 17:51:41.842: IA__gtk_settings_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
(process:17420): GLib-GObject-CRITICAL **: 17:51:41.842: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(process:17420): GLib-GObject-WARNING **: 17:51:41.842: invalid (NULL) pointer instance
(process:17420): GLib-GObject-CRITICAL **: 17:51:41.842: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(process:17420): GLib-GObject-CRITICAL **: 17:51:41.843: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(process:17420): GLib-GObject-WARNING **: 17:51:41.843: invalid (NULL) pointer instance
(process:17420): GLib-GObject-CRITICAL **: 17:51:41.843: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(process:17420): Gtk-CRITICAL **: 17:51:41.843: IA__gtk_settings_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
inotify_add_watch("/home/yvance/.config/qt5ct") failed: "No such file or directory"
(process:17420): Gtk-WARNING **: 17:51:41.844: Screen for GtkWindow not set; you must always set
a screen for a GtkWindow before using the window
(process:17420): Gdk-CRITICAL **: 17:51:41.844: IA__gdk_screen_get_display: assertion 'GDK_IS_SCREEN (screen)' failed
(process:17420): Gdk-CRITICAL **: 17:51:41.844: IA__gdk_keymap_get_for_display: assertion 'GDK_IS_DISPLAY (display)' failed
(process:17420): GLib-GObject-WARNING **: 17:51:41.844: invalid (NULL) pointer instance
(process:17420): GLib-GObject-CRITICAL **: 17:51:41.844: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(process:17420): GLib-GObject-WARNING **: 17:51:41.945: invalid (NULL) pointer instance
(process:17420): GLib-GObject-CRITICAL **: 17:51:41.945: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(process:17420): Gdk-CRITICAL **: 17:51:41.945: IA__gdk_screen_get_root_window: assertion 'GDK_IS_SCREEN (screen)' failed
(process:17420): Gdk-CRITICAL **: 17:51:41.945: IA__gdk_screen_get_display: assertion 'GDK_IS_SCREEN (screen)' failed
(process:17420): Gdk-CRITICAL **: 17:51:41.945: IA__gdk_x11_display_get_xdisplay: assertion 'GDK_IS_DISPLAY (display)' failed
(process:17420): Gdk-CRITICAL **: 17:51:41.945: IA__gdk_screen_get_number: assertion 'GDK_IS_SCREEN (screen)' failed
Erreur de segmentation (core dumped)
