System: Kernel: 5.4.0-94-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 5.2.7
wm: muffin dm: LightDM Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Machine: Type: Laptop System: LENOVO product: 20HJS00500 v: ThinkPad P51 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20HJS00500 v: 0B98417 WIN serial: <filter> UEFI: LENOVO
v: N1UET82W (1.56 ) date: 08/12/2021
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Illuminated Keyboard K800
serial: <filter> charge: 100% (should be ignored) status: Discharging
CPU: Topology: Quad Core model: Intel Core i7-7820HQ bits: 64 type: MT MCP arch: Kaby Lake
rev: 9 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 46398
Speed: 3689 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 3613 2: 3581 3: 3539
4: 3848 5: 3613 6: 3624 7: 3595 8: 3596
Graphics: Device-1: Intel HD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:591b
Device-2: NVIDIA GM206GLM [Quadro M2200 Mobile] vendor: Lenovo driver: nvidia v: 470.86
bus ID: 01:00.0 chip ID: 10de:1436
Display: x11 server: X.Org 1.20.13 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1920x1200~60Hz
OpenGL: renderer: Quadro M2200/PCIe/SSE2 v: 4.6.0 NVIDIA 470.86 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a171
Device-2: NVIDIA GM206 High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0fba
Sound Server: ALSA v: k5.4.0-94-generic
Network: Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: 3.2.6-k port: efa0
bus ID: 00:1f.6 chip ID: 8086:15e3
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: d000
bus ID: 04:00.0 chip ID: 8086:24fd
IF: wlp4s0 state: up mac: <filter>
Drives: Local Storage: total: 238.47 GiB used: 230.96 GiB (96.8%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P2SSD8 size: 931.51 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter>
ID-2: /dev/nvme1n1 vendor: Toshiba model: N/A size: 238.47 GiB speed: 31.6 Gb/s
Partition: ID-1: / size: 97.93 GiB used: 71.85 GiB (73.4%) fs: ext4 dev: /dev/nvme1n1p4
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 chip ID: 1d6b:0002
Device-1: 1-1:2 info: Super Top microSD card reader (SY-T18) type: Mass Storage
driver: usb-storage rev: 2.0 chip ID: 14cd:1212
Device-2: 1-5:3 info: MosArt 2.4G Keyboard Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid rev: 1.1 chip ID: 062a:5918
Device-3: 1-6:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
driver: logitech-djreceiver,usbhid rev: 2.0 chip ID: 046d:c52b
Device-4: 1-8:5 info: Chicony Integrated Camera type: Video driver: uvcvideo rev: 2.0
chip ID: 04f2:b5ab
Device-5: 1-14:6 info: Intel type: Bluetooth driver: btusb rev: 2.0 chip ID: 8087:0a2b
Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 40.0 C mobo: 39.0 C gpu: nvidia temp: 40 C
Fan Speeds (RPM): cpu: 2304
Repos: No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/google-chrome.list
1: deb [arch=amd64] https: //dl.google.com/linux/chrome/deb/ stable main
Active apt repos in: /etc/apt/sources.list.d/lutris-team-lutris-focal.list
1: deb http: //ppa.launchpad.net/lutris-team/lutris/ubuntu focal main
1: deb http: //packages.linuxmint.com una main upstream import backport #id:linuxmint_main
2: deb http: //archive.ubuntu.com/ubuntu focal main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
6: deb http: //archive.canonical.com/ubuntu/ focal partner
Info: Processes: 284 Uptime: 28m Memory: 15.48 GiB used: 3.48 GiB (22.5%) Init: systemd
v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 8/9 Client: Unknown python3.8 client
inxi: 3.0.38
Fusion 360 installé avec lutris.
La fonction insérer "Macmaster" débute bien avec le choix de l'objet dans le panneau qui s'affiche puis blocage .
la souris bouge , je peux faire apparaitre différentes fenètres à l'écran , que je peux déplacer, mais le panneau "MACMASTER" reste sur le dessus et aucune action efficace .
je suis obliger de provoquer un arrêt par un appui long sur le bouton marche arrêt .
J'ai vérifié que cette sonction "insérez MACMASTAIR" fonctionne bien sur fusion 360 sous windows.
Cordialement,
GLR
