Re Imprimante HP
Carlos06
Re Imprimante HP
Message par Carlos06 »
Slt
Un bug / ou normal ?
Dans Priter Control, j'ai fais Refresh et depuis plus d'une heure, la petite barre tourne, et je ne sais pas quoi faire ?
La copie du terminal, pour votre aide.
HP Linux Imaging and Printing System (ver. 3.16.3)
Self Diagnse Utility and Healing Utility ver. 1.0
Copyright (c) 2001-15 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Checking for Deprecated items....
error: This distro (i.e linuxmint  18.1) is either deprecated or not yet supported.
The diagnosis is limited on unsupported platforms. Do you want to continue?(y=yes*, n=no):
Checking for HPLIP updates....
error: Failed to locate hp-upgrade utility
Checking for Dependencies....
warning: linuxmint-18.1 version is not supported. Using linuxmint-17.3 versions dependencies to verify and install...
| SYSTEM INFO |
 Kernel: 4.4.0-53-generic #74-Ubuntu SMP Fri Dec 2 15:59:10 UTC 2016 GNU/Linux
 Host: charly-MS-7728-Invalid-entry-length-16-Fixed-up-to-11
 Proc: 4.4.0-53-generic #74-Ubuntu SMP Fri Dec 2 15:59:10 UTC 2016 GNU/Linux
 Distribution: linuxmint 18.1
 Bitness: 64 bit
| HPLIP CONFIGURATION |
HPLIP-Version: HPLIP 3.16.3
HPLIP-Home: /usr/share/hplip
warning: HPLIP-Installation: Auto installation is not supported for linuxmint distro  18.1 version
Current contents of '/etc/hp/hplip.conf' file:
# hplip.conf.  Generated from hplip.conf.in by configure.
[hplip]
version=3.16.3
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip
html=/usr/share/doc/hplip-doc
icon=no
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv
bin=/usr/bin
apparmor=/etc/apparmor.d
# Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=yes
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.16.3
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
policy-kit=yes
lite-build=no
udev_sysfs_rules=no
hpcups-only-build=no
hpijs-only-build=no
apparmor_build=no
Current contents of '/var/lib/hp/hplip.state' file:
Plugins are not installed. Could not access file: No such file or directory
Current contents of '~/.hplip/hplip.conf' file:
[last_used]
device_uri = "hp:/net/ENVY_7640_series?zc=HPFC3FDBCB511C"
printer_name =
working_dir = .
[settings]
systray_visible = 0
systray_messages = 0
[commands]
scan = /usr/bin/simple-scan %SANE_URI%
[refresh]
rate = 30
enable = false
type = 1
[polling]
enable = false
interval = 5
device_list =
[fax]
voice_phone =
email_address =
[upgrade]
notify_upgrade = false
last_upgraded_time = 1490778448
pending_upgrade_time = 0
[installation]
date_time = 03/30/17 15:13:50
version = 3.16.3
 <Package-name>        <Package-Desc>      <Required/Optional> <Min-Version> <Installed-Version> <Status>   <Comment>
|  External Dependencies |
 avahi-utils          avahi-utils                                                  OPTIONAL        -               0.6.32          OK         -
 error: cups          CUPS - Common Unix Printing System                           REQUIRED        1.1             -               INCOMPAT   'CUPS may not be installed or not running'
 scanimage            scanimage - Shell scanning program                           OPTIONAL        1.0             1.0.25          OK         -
 gs                   GhostScript - PostScript and PDF language interpreter and previewer REQUIRED        7.05            9.18            OK         -
 network              network -wget                                                OPTIONAL        -               1.17.1          OK         -
 error: dbus          DBus - Message bus system                                    REQUIRED        -               1.10.6          MISSING    'DBUS may not be installed or not running'
 error: xsane         xsane - Graphical scanner frontend for SANE                  OPTIONAL        0.9             -               MISSING    'xsane needs to be installed'
 policykit            PolicyKit - Administrative policy framework                  OPTIONAL        -               0.105           OK         -
|  General Dependencies |
 sane                 SANE - Scanning library                                      REQUIRED        -               -               OK         -
 error: libnetsnmp-devel libnetsnmp-devel - SNMP networking library development files REQUIRED        5.0.9           -               MISSING    'libnetsnmp-devel needs to be installed'
 python3-pyqt4-dbus   PyQt 4 DBus - DBus Support for PyQt4                         OPTIONAL        4.0             4.11.4          OK         -
 python3-dbus         Python DBus - Python bindings for DBus                       REQUIRED        0.80.0          1.2.0           OK         -
 error: cups-devel    CUPS devel- Common Unix Printing System development files    REQUIRED        -               -               MISSING    'cups-devel needs to be installed'
 python3X             Python 2.2 or greater - Python programming language          REQUIRED        2.2             3.5.2           OK         -
 error: libcrypto     libcrypto - OpenSSL cryptographic library                    REQUIRED        -               1.0.2           MISSING    'libcrypto needs to be installed'
 python3-pyqt4        PyQt 4- Qt interface for Python (for Qt version 4.x)         REQUIRED        4.0             4.11.4          OK         -
 python3-reportlab    Reportlab - PDF library for Python                           OPTIONAL        2.0             3.3.0           OK         -
 error: python3-notify2 Python libnotify - Python bindings for the libnotify Desktop notifications OPTIONAL        -               -               MISSING    'python3-notify2 needs to be installed'
 error: sane-devel    SANE - Scanning library development files                    REQUIRED        -               -               MISSING    'sane-devel needs to be installed'
 error: python3-devel Python devel - Python development files                      REQUIRED        2.2             3.5.2           MISSING    'python3-devel needs to be installed'
 python3-xml          Python XML libraries                                         REQUIRED        -               2.1.0           OK         -
 python3-pil          PIL - Python Imaging Library (required for commandline scanning with hp-scan) OPTIONAL        -               1.1.7           OK         -
 error: libjpeg       libjpeg - JPEG library                                       REQUIRED        -               -               MISSING    'libjpeg needs to be installed'
 libpthread           libpthread - POSIX threads library                           REQUIRED        -               b'2.23'         OK         -
 error: libusb        libusb - USB library                                         REQUIRED        -               1.0             MISSING    'libusb needs to be installed'
 error: cups-image    CUPS image - CUPS image development files                    REQUIRED        -               -               MISSING    'cups-image needs to be installed'
|  COMPILEDEP |
 error: libtool       libtool - Library building support services                  REQUIRED        -               -               MISSING    'libtool needs to be installed'
 make                 make - GNU make utility to maintain groups of programs       REQUIRED        3.0             4.1             OK         -
 error: gcc           gcc - GNU Project C and C++ Compiler                         REQUIRED        -               5.4.0           MISSING    'gcc needs to be installed'
|  Python Extentions |
 hpmudext             IO-Extension                                                 REQUIRED        -               3.16.3          OK         -
 cupsext              CUPS-Extension                                               REQUIRED        -               3.16.3          OK         -
|  Scan Configuration |
 scanext              Scan-SANE-Extension                                          REQUIRED        -               3.16.3          OK         -
'/etc/sane.d/dll.d/hpaio' not found.
 hpaio                HPLIP-SANE-Backend                                           REQUIRED        -               3.16.3          OK         'hpaio found in /etc/sane.d/dll.conf'
|  Other Dependencies |
| DISCOVERED SCANNER DEVICES |
device `hpaio:/usb/ENVY_7640_series?serial=TH61L3S0Z4063T' is a Hewlett-Packard ENVY_7640_series all-in-one
device `hpaio:/net/ENVY_7640_series?zc=HPFC3FDBCB511C' is a Hewlett-Packard ENVY_7640_series all-in-one
device `hpaio:/net/envy_7640_series?ip=192.168.1.71&queue=false' is a Hewlett-Packard envy_7640_series all-in-one
| DISCOVERED USB DEVICES |
  Device URI                        Model
  hp:/usb/ENVY_7640_series?serial=  HP ENVY 7640 series
  TH61L3S0Z4063T
| INSTALLED CUPS PRINTER QUEUES |
ENVY-7640-series-Fax-4
Type: Fax
Device URI: hpfax:/usb/ENVY_7640_series?serial=TH61L3S0Z4063T
PPD: /etc/cups/ppd/ENVY-7640-series-Fax-4.ppd
warning: Failed to read /etc/cups/ppd/ENVY-7640-series-Fax-4.ppd ppd file
PPD Description:
Printer status: printer ENVY-7640-series-Fax-4 is idle.  enabled since jeu. 23 mars 2017 20:38:17 CET
Communication status: Good
HP-ENVY-7640-series
Type: Printer
Device URI: hp:/net/ENVY_7640_series?zc=HPFC3FDBCB511C
PPD: /etc/cups/ppd/HP-ENVY-7640-series.ppd
warning: Failed to read /etc/cups/ppd/HP-ENVY-7640-series.ppd ppd file
PPD Description:
Printer status: printer HP-ENVY-7640-series is idle.  enabled since dim. 26 mars 2017 14:36:15 CEST
MIB search path: /home/charly/.snmp/mibs:/usr/share/snmp/mibs:/usr/share/snmp/mibs/iana:/usr/share/snmp/mibs/ietf:/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp
Cannot find module (SNMPv2-MIB): At line 1 in (none)
Cannot find module (IF-MIB): At line 1 in (none)
Cannot find module (IP-MIB): At line 1 in (none)
Cannot find module (TCP-MIB): At line 1 in (none)
Cannot find module (UDP-MIB): At line 1 in (none)
Cannot find module (HOST-RESOURCES-MIB): At line 1 in (none)
Cannot find module (NOTIFICATION-LOG-MIB): At line 1 in (none)
Cannot find module (DISMAN-EVENT-MIB): At line 1 in (none)
Cannot find module (DISMAN-SCHEDULE-MIB): At line 1 in (none)
Cannot find module (HOST-RESOURCES-TYPES): At line 1 in (none)
Cannot find module (MTA-MIB): At line 1 in (none)
Cannot find module (NETWORK-SERVICES-MIB): At line 1 in (none)
Cannot find module (SNMPv2-TC): At line 15 in /usr/share/snmp/mibs/UCD-DISKIO-MIB.txt
Cannot find module (SNMPv2-SMI): At line 34 in /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Cannot find module (SNMPv2-TC): At line 37 in /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Did not find 'enterprises' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
Did not find 'TruthValue' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
Unlinked OID in UCD-SNMP-MIB: ucdavis ::= { enterprises 2021 }
Undefined identifier: enterprises near line 39 of /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/UCD-DISKIO-MIB.txt)
Did not find 'ucdExperimental' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/UCD-DISKIO-MIB.txt)
Unlinked OID in UCD-DISKIO-MIB: ucdDiskIOMIB ::= { ucdExperimental 15 }
Undefined identifier: ucdExperimental near line 19 of /usr/share/snmp/mibs/UCD-DISKIO-MIB.txt
Cannot find module (SNMPv2-TC): At line 10 in /usr/share/snmp/mibs/UCD-DLMOD-MIB.txt
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/UCD-DLMOD-MIB.txt)
Did not find 'ucdExperimental' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/UCD-DLMOD-MIB.txt)
Unlinked OID in UCD-DLMOD-MIB: ucdDlmodMIB ::= { ucdExperimental 14 }
Undefined identifier: ucdExperimental near line 13 of /usr/share/snmp/mibs/UCD-DLMOD-MIB.txt
Cannot find module (SNMPv2-TC): At line 15 in /usr/share/snmp/mibs/LM-SENSORS-MIB.txt
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/LM-SENSORS-MIB.txt)
Did not find 'ucdExperimental' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/LM-SENSORS-MIB.txt)
Unlinked OID in LM-SENSORS-MIB: lmSensors ::= { ucdExperimental 16 }
Undefined identifier: ucdExperimental near line 32 of /usr/share/snmp/mibs/LM-SENSORS-MIB.txt
Did not find 'ucdavis' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/UCD-DEMO-MIB.txt)
Unlinked OID in UCD-DEMO-MIB: ucdDemoMIB ::= { ucdavis 14 }
Undefined identifier: ucdavis near line 7 of /usr/share/snmp/mibs/UCD-DEMO-MIB.txt
Cannot find module (SNMP-TARGET-MIB): At line 1 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 9 in /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Cannot find module (SNMPv2-SMI): At line 8 in /usr/share/snmp/mibs/NET-SNMP-MIB.txt
Did not find 'enterprises' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-MIB.txt)
Unlinked OID in NET-SNMP-MIB: netSnmp ::= { enterprises 8072 }
Undefined identifier: enterprises near line 10 of /usr/share/snmp/mibs/NET-SNMP-MIB.txt
Cannot find module (SNMPv2-TC): At line 21 in /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'netSnmpObjects' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'netSnmpModuleIDs' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'netSnmpNotifications' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'netSnmpGroups' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'TruthValue' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Unlinked OID in NET-SNMP-AGENT-MIB: nsAgentNotifyGroup ::= { netSnmpGroups 9 }
Undefined identifier: netSnmpGroups near line 545 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsTransactionGroup ::= { netSnmpGroups 8 }
Undefined identifier: netSnmpGroups near line 536 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsConfigGroups ::= { netSnmpGroups 7 }
Undefined identifier: netSnmpGroups near line 515 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsCacheGroup ::= { netSnmpGroups 4 }
Undefined identifier: netSnmpGroups near line 505 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsModuleGroup ::= { netSnmpGroups 2 }
Undefined identifier: netSnmpGroups near line 495 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: netSnmpAgentMIB ::= { netSnmpModuleIDs 2 }
Undefined identifier: netSnmpModuleIDs near line 24 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsTransactions ::= { netSnmpObjects 8 }
Undefined identifier: netSnmpObjects near line 55 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsConfiguration ::= { netSnmpObjects 7 }
Undefined identifier: netSnmpObjects near line 54 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsErrorHistory ::= { netSnmpObjects 6 }
Undefined identifier: netSnmpObjects near line 53 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsCache ::= { netSnmpObjects 5 }
Undefined identifier: netSnmpObjects near line 52 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsDLMod ::= { netSnmpObjects 4 }
Undefined identifier: netSnmpObjects near line 51 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsExtensions ::= { netSnmpObjects 3 }
Undefined identifier: netSnmpObjects near line 50 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsMibRegistry ::= { netSnmpObjects 2 }
Undefined identifier: netSnmpObjects near line 49 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsVersion ::= { netSnmpObjects 1 }
Undefined identifier: netSnmpObjects near line 48 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsNotifyRestart ::= { netSnmpNotifications 3 }
Undefined identifier: netSnmpNotifications near line 482 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsNotifyShutdown ::= { netSnmpNotifications 2 }
Undefined identifier: netSnmpNotifications near line 476 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsNotifyStart ::= { netSnmpNotifications 1 }
Undefined identifier: netSnmpNotifications near line 470 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Cannot find module (SNMP-MPD-MIB): At line 1 in (none)
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 1 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 1 in (none)
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 1 in (none)
Cannot find module (SNMP-COMMUNITY-MIB): At line 1 in (none)
Cannot find module (IPV6-ICMP-MIB): At line 1 in (none)
Cannot find module (IPV6-MIB): At line 1 in (none)
Cannot find module (IPV6-TCP-MIB): At line 1 in (none)
Cannot find module (IPV6-UDP-MIB): At line 1 in (none)
Cannot find module (IP-FORWARD-MIB): At line 1 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 10 in /usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt
Cannot find module (SNMP-FRAMEWORK-MIB): At line 10 in /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
Cannot find module (SNMPv2-TC): At line 12 in /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
Cannot find module (INET-ADDRESS-MIB): At line 13 in /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Did not find 'netSnmp' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Did not find 'StorageType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Did not find 'InetAddressType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Did not find 'InetAddress' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Unlinked OID in NET-SNMP-EXAMPLES-MIB: netSnmpExamples ::= { netSnmp 2 }
Undefined identifier: netSnmp near line 16 of /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt)
Did not find 'netSnmpExamples' in module NET-SNMP-EXAMPLES-MIB (/usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt)
Unlinked OID in NET-SNMP-PASS-MIB: netSnmpPassExamples ::= { netSnmpExamples 255 }
Undefined identifier: netSnmpExamples near line 14 of /usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt
Cannot find module (SNMPv2-TC): At line 16 in /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
Did not find 'nsExtensions' in module NET-SNMP-AGENT-MIB (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
Did not find 'StorageType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
Unlinked OID in NET-SNMP-EXTEND-MIB: nsExtendGroups ::= { nsExtensions 3 }
Undefined identifier: nsExtensions near line 39 of /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
Unlinked OID in NET-SNMP-EXTEND-MIB: nsExtendObjects ::= { nsExtensions 2 }
Undefined identifier: nsExtensions near line 38 of /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
Unlinked OID in NET-SNMP-EXTEND-MIB: netSnmpExtendMIB ::= { nsExtensions 1 }
Undefined identifier: nsExtensions near line 19 of /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
Cannot find module (SNMP-NOTIFICATION-MIB): At line 1 in (none)
Cannot find module (SNMPv2-TM): At line 1 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 9 in /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 16 in /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
Cannot find module (SNMPv2-TC): At line 25 in /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'netSnmpObjects' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'netSnmpGroups' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'vacmGroupName' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'vacmAccessContextPrefix' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'vacmAccessSecurityModel' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'vacmAccessSecurityLevel' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'StorageType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Unlinked OID in NET-SNMP-VACM-MIB: netSnmpVacmMIB ::= { netSnmpObjects 9 }
Undefined identifier: netSnmpObjects near line 28 of /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
Cannot adopt OID in UCD-SNMP-MIB: logMatchRegExCompilation ::= { logMatchEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchErrorFlag ::= { logMatchEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchCycle ::= { logMatchEntry 11 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchCount ::= { logMatchEntry 10 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchCounter ::= { logMatchEntry 9 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchCurrentCount ::= { logMatchEntry 8 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchCurrentCounter ::= { logMatchEntry 7 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchGlobalCount ::= { logMatchEntry 6 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchGlobalCounter ::= { logMatchEntry 5 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchRegEx ::= { logMatchEntry 4 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchFilename ::= { logMatchEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchName ::= { logMatchEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchIndex ::= { logMatchEntry 1 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmAccessEntry ::= { nsVacmAccessTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: extErrFixCmd ::= { extEntry 103 }
Cannot adopt OID in UCD-SNMP-MIB: extErrFix ::= { extEntry 102 }
Cannot adopt OID in UCD-SNMP-MIB: extOutput ::= { extEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: extResult ::= { extEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: extCommand ::= { extEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: extNames ::= { extEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: extIndex ::= { extEntry 1 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoPublic ::= { ucdDemoMIBObjects 1 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodTable ::= { ucdDlmodMIB 2 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodNextIndex ::= { ucdDlmodMIB 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExamples ::= { netSnmp 2 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpConformance ::= { netSnmp 5 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpNotificationPrefix ::= { netSnmp 4 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpExperimental ::= { netSnmp 9999 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpEnumerations ::= { netSnmp 3 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpObjects ::= { netSnmp 1 }
Cannot adopt OID in UCD-SNMP-MIB: versionDoDebugging ::= { version 20 }
Cannot adopt OID in UCD-SNMP-MIB: versionSavePersistentData ::= { version 13 }
Cannot adopt OID in UCD-SNMP-MIB: versionRestartAgent ::= { version 12 }
Cannot adopt OID in UCD-SNMP-MIB: versionUpdateConfig ::= { version 11 }
Cannot adopt OID in UCD-SNMP-MIB: versionClearCache ::= { version 10 }
Cannot adopt OID in UCD-SNMP-MIB: versionConfigureOptions ::= { version 6 }
Cannot adopt OID in UCD-SNMP-MIB: versionIdent ::= { version 5 }
Cannot adopt OID in UCD-SNMP-MIB: versionCDate ::= { version 4 }
Cannot adopt OID in UCD-SNMP-MIB: versionDate ::= { version 3 }
Cannot adopt OID in UCD-SNMP-MIB: versionTag ::= { version 2 }
Cannot adopt OID in UCD-SNMP-MIB: versionIndex ::= { version 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleHeartbeatNotification ::= { netSnmpExampleNotificationPrefix 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheStatus ::= { nsCacheEntry 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheTimeout ::= { nsCacheEntry 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCachedOID ::= { nsCacheEntry 1 }
Cannot adopt OID in UCD-SNMP-MIB: unknown ::= { ucdSnmpAgent 255 }
Cannot adopt OID in UCD-SNMP-MIB: dragonfly ::= { ucdSnmpAgent 17 }
Cannot adopt OID in UCD-SNMP-MIB: macosx ::= { ucdSnmpAgent 16 }
Cannot adopt OID in UCD-SNMP-MIB: aix ::= { ucdSnmpAgent 15 }
Cannot adopt OID in UCD-SNMP-MIB: hpux11 ::= { ucdSnmpAgent 14 }
Cannot adopt OID in UCD-SNMP-MIB: win32 ::= { ucdSnmpAgent 13 }
Cannot adopt OID in UCD-SNMP-MIB: openbsd ::= { ucdSnmpAgent 12 }
Cannot adopt OID in UCD-SNMP-MIB: bsdi ::= { ucdSnmpAgent 11 }
Cannot adopt OID in UCD-SNMP-MIB: linux ::= { ucdSnmpAgent 10 }
Cannot adopt OID in UCD-SNMP-MIB: irix ::= { ucdSnmpAgent 9 }
Cannot adopt OID in UCD-SNMP-MIB: freebsd ::= { ucdSnmpAgent 8 }
Cannot adopt OID in UCD-SNMP-MIB: netbsd1 ::= { ucdSnmpAgent 7 }
Cannot adopt OID in UCD-SNMP-MIB: hpux10 ::= { ucdSnmpAgent 6 }
Cannot adopt OID in UCD-SNMP-MIB: ultrix ::= { ucdSnmpAgent 5 }
Cannot adopt OID in UCD-SNMP-MIB: osf ::= { ucdSnmpAgent 4 }
Cannot adopt OID in UCD-SNMP-MIB: solaris ::= { ucdSnmpAgent 3 }
Cannot adopt OID in UCD-SNMP-MIB: sunos4 ::= { ucdSnmpAgent 2 }
Cannot adopt OID in UCD-SNMP-MIB: hpux9 ::= { ucdSnmpAgent 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutputGroup ::= { nsExtendGroups 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendConfigGroup ::= { nsExtendGroups 1 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOEntry ::= { diskIOTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionEntry ::= { nsTransactionTable 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpGroups ::= { netSnmpConformance 2 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpCompliances ::= { netSnmpConformance 1 }
Cannot adopt OID in UCD-SNMP-MIB: mrModuleName ::= { mrEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: mrIndex ::= { mrEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugTokenEntry ::= { nsDebugTokenTable 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendStatus ::= { nsExtendConfigEntry 21 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendStorage ::= { nsExtendConfigEntry 20 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendRunType ::= { nsExtendConfigEntry 7 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendExecType ::= { nsExtendConfigEntry 6 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendCacheTime ::= { nsExtendConfigEntry 5 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendInput ::= { nsExtendConfigEntry 4 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendArgs ::= { nsExtendConfigEntry 3 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendCommand ::= { nsExtendConfigEntry 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendToken ::= { nsExtendConfigEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleTable ::= { nsMibRegistry 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpPlaypen ::= { netSnmpExperimental 9999 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpIETFWGEntry ::= { netSnmpIETFWGTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: prErrFixCmd ::= { prEntry 103 }
Cannot adopt OID in UCD-SNMP-MIB: prErrFix ::= { prEntry 102 }
Cannot adopt OID in UCD-SNMP-MIB: prErrMessage ::= { prEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: prErrorFlag ::= { prEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: prCount ::= { prEntry 5 }
Cannot adopt OID in UCD-SNMP-MIB: prMax ::= { prEntry 4 }
Cannot adopt OID in UCD-SNMP-MIB: prMin ::= { prEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: prNames ::= { prEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: prIndex ::= { prEntry 1 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodEntry ::= { dlmodTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: memSwapErrorMsg ::= { memory 101 }
Cannot adopt OID in UCD-SNMP-MIB: memSwapError ::= { memory 100 }
Cannot adopt OID in UCD-SNMP-MIB: memUsedRealTXT ::= { memory 17 }
Cannot adopt OID in UCD-SNMP-MIB: memUsedSwapTXT ::= { memory 16 }
Cannot adopt OID in UCD-SNMP-MIB: memCached ::= { memory 15 }
Cannot adopt OID in UCD-SNMP-MIB: memBuffer ::= { memory 14 }
Cannot adopt OID in UCD-SNMP-MIB: memShared ::= { memory 13 }
Cannot adopt OID in UCD-SNMP-MIB: memMinimumSwap ::= { memory 12 }
Cannot adopt OID in UCD-SNMP-MIB: memTotalFree ::= { memory 11 }
Cannot adopt OID in UCD-SNMP-MIB: memAvailRealTXT ::= { memory 10 }
Cannot adopt OID in UCD-SNMP-MIB: memTotalRealTXT ::= { memory 9 }
Cannot adopt OID in UCD-SNMP-MIB: memAvailSwapTXT ::= { memory 8 }
Cannot adopt OID in UCD-SNMP-MIB: memTotalSwapTXT ::= { memory 7 }
Cannot adopt OID in UCD-SNMP-MIB: memAvailReal ::= { memory 6 }
Cannot adopt OID in UCD-SNMP-MIB: memTotalReal ::= { memory 5 }
Cannot adopt OID in UCD-SNMP-MIB: memAvailSwap ::= { memory 4 }
Cannot adopt OID in UCD-SNMP-MIB: memTotalSwap ::= { memory 3 }
Cannot adopt OID in UCD-SNMP-MIB: memErrorName ::= { memory 2 }
Cannot adopt OID in UCD-SNMP-MIB: memIndex ::= { memory 1 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoMIBObjects ::= { ucdDemoMIB 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleTimeout ::= { nsModuleEntry 6 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleModes ::= { nsModuleEntry 5 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleName ::= { nsModuleEntry 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsmRegistrationPriority ::= { nsModuleEntry 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsmRegistrationPoint ::= { nsModuleEntry 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsmContextName ::= { nsModuleEntry 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsEntry ::= { lmMiscSensorsTable 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpNotificationObjects ::= { netSnmpNotificationPrefix 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpNotifications ::= { netSnmpNotificationPrefix 0 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassTable ::= { netSnmpPassExamples 2 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassOIDValue ::= { netSnmpPassExamples 99 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassGauge ::= { netSnmpPassExamples 6 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassCounter ::= { netSnmpPassExamples 5 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassIpAddress ::= { netSnmpPassExamples 4 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassTimeTicks ::= { netSnmpPassExamples 3 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassString ::= { netSnmpPassExamples 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpDomains ::= { netSnmpEnumerations 3 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpAgentOIDs ::= { netSnmpEnumerations 2 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpModuleIDs ::= { netSnmpEnumerations 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsEntry ::= { lmFanSensorsTable 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsEntry ::= { lmTempSensorsTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleGroup ::= { netSnmpGroups 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheGroup ::= { netSnmpGroups 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsConfigGroups ::= { netSnmpGroups 7 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionGroup ::= { netSnmpGroups 8 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsAgentNotifyGroup ::= { netSnmpGroups 9 }
Cannot adopt OID in UCD-SNMP-MIB: fileEntry ::= { fileTable 1 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmStatus ::= { nsVacmAccessEntry 5 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmStorageType ::= { nsVacmAccessEntry 4 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmViewName ::= { nsVacmAccessEntry 3 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmContextMatch ::= { nsVacmAccessEntry 2 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmAuthType ::= { nsVacmAccessEntry 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: netSnmpExtendMIB ::= { nsExtensions 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendObjects ::= { nsExtensions 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendGroups ::= { nsExtensions 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmVoltSensorsEntry ::= { lmVoltSensorsTable 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmp ::= { enterprises 8072 }
Cannot adopt OID in UCD-SNMP-MIB: ucdavis ::= { enterprises 2021 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIONWrittenX ::= { diskIOEntry 13 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIONReadX ::= { diskIOEntry 12 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOLA15 ::= { diskIOEntry 11 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOLA5 ::= { diskIOEntry 10 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOLA1 ::= { diskIOEntry 9 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOWrites ::= { diskIOEntry 6 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOReads ::= { diskIOEntry 5 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIONWritten ::= { diskIOEntry 4 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIONRead ::= { diskIOEntry 3 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIODevice ::= { diskIOEntry 2 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOIndex ::= { diskIOEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionMode ::= { nsTransactionEntry 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionID ::= { nsTransactionEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugTokenStatus ::= { nsDebugTokenEntry 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugTokenPrefix ::= { nsDebugTokenEntry 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: nsIETFWGChair2 ::= { netSnmpIETFWGEntry 3 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: nsIETFWGChair1 ::= { netSnmpIETFWGEntry 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: nsIETFWGName ::= { netSnmpIETFWGEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLoggingTable ::= { nsConfigLogging 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostsEntry ::= { netSnmpHostsTable 1 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodStatus ::= { dlmodEntry 5 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodError ::= { dlmodEntry 4 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodPath ::= { dlmodEntry 3 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodName ::= { dlmodEntry 2 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodIndex ::= { dlmodEntry 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsValue ::= { lmMiscSensorsEntry 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsDevice ::= { lmMiscSensorsEntry 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsIndex ::= { lmMiscSensorsEntry 1 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassEntry ::= { netSnmpPassTable 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmSensors ::= { ucdExperimental 16 }
Cannot adopt OID in UCD-DLMOD-MIB: ucdDlmodMIB ::= { ucdExperimental 14 }
Cannot adopt OID in UCD-DISKIO-MIB: ucdDiskIOMIB ::= { ucdExperimental 15 }
Cannot adopt OID in UCD-SNMP-MIB: dskEntry ::= { dskTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: netSnmpAgentMIB ::= { netSnmpModuleIDs 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsValue ::= { lmFanSensorsEntry 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsDevice ::= { lmFanSensorsEntry 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsIndex ::= { lmFanSensorsEntry 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsValue ::= { lmTempSensorsEntry 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsDevice ::= { lmTempSensorsEntry 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsIndex ::= { lmTempSensorsEntry 1 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchTable ::= { logMatch 2 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchMaxEntries ::= { logMatch 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLoggingEntry ::= { nsLoggingTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: fileErrorMsg ::= { fileEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: fileErrorFlag ::= { fileEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: fileMax ::= { fileEntry 4 }
Cannot adopt OID in UCD-SNMP-MIB: fileSize ::= { fileEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: fileName ::= { fileEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: fileIndex ::= { fileEntry 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput2Table ::= { nsExtendObjects 4 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput1Table ::= { nsExtendObjects 3 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendConfigTable ::= { nsExtendObjects 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendNumEntries ::= { nsExtendObjects 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput1Entry ::= { nsExtendOutput1Table 1 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuNumCpus ::= { systemStats 67 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawGuestNice ::= { systemStats 66 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawGuest ::= { systemStats 65 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawSteal ::= { systemStats 64 }
Cannot adopt OID in UCD-SNMP-MIB: ssRawSwapOut ::= { systemStats 63 }
Cannot adopt OID in UCD-SNMP-MIB: ssRawSwapIn ::= { systemStats 62 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawSoftIRQ ::= { systemStats 61 }
Cannot adopt OID in UCD-SNMP-MIB: ssRawContexts ::= { systemStats 60 }
Cannot adopt OID in UCD-SNMP-MIB: ssRawInterrupts ::= { systemStats 59 }
Cannot adopt OID in UCD-SNMP-MIB: ssIORawReceived ::= { systemStats 58 }
Cannot adopt OID in UCD-SNMP-MIB: ssIORawSent ::= { systemStats 57 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawInterrupt ::= { systemStats 56 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawKernel ::= { systemStats 55 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawWait ::= { systemStats 54 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawIdle ::= { systemStats 53 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawSystem ::= { systemStats 52 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawNice ::= { systemStats 51 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawUser ::= { systemStats 50 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuIdle ::= { systemStats 11 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuSystem ::= { systemStats 10 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuUser ::= { systemStats 9 }
Cannot adopt OID in UCD-SNMP-MIB: ssSysContext ::= { systemStats 8 }
Cannot adopt OID in UCD-SNMP-MIB: ssSysInterrupts ::= { systemStats 7 }
Cannot adopt OID in UCD-SNMP-MIB: ssIOReceive ::= { systemStats 6 }
Cannot adopt OID in UCD-SNMP-MIB: ssIOSent ::= { systemStats 5 }
Cannot adopt OID in UCD-SNMP-MIB: ssSwapOut ::= { systemStats 4 }
Cannot adopt OID in UCD-SNMP-MIB: ssSwapIn ::= { systemStats 3 }
Cannot adopt OID in UCD-SNMP-MIB: ssErrorName ::= { systemStats 2 }
Cannot adopt OID in UCD-SNMP-MIB: ssIndex ::= { systemStats 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput2Entry ::= { nsExtendOutput2Table 1 }
Cannot adopt OID in UCD-SNMP-MIB: laEntry ::= { laTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheTable ::= { nsCache 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheEnabled ::= { nsCache 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheDefaultTimeout ::= { nsCache 1 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchEntry ::= { logMatchTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: extEntry ::= { extTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsConfigLogging ::= { nsConfiguration 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsConfigDebug ::= { nsConfiguration 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleString ::= { netSnmpExampleScalars 3 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleSleeper ::= { netSnmpExampleScalars 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleInteger ::= { netSnmpExampleScalars 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmVoltSensorsValue ::= { lmVoltSensorsEntry 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmVoltSensorsDevice ::= { lmVoltSensorsEntry 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmVoltSensorsIndex ::= { lmVoltSensorsEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheEntry ::= { nsCacheTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugTokenTable ::= { nsConfigDebug 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugDumpPdu ::= { nsConfigDebug 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugOutputAll ::= { nsConfigDebug 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugEnabled ::= { nsConfigDebug 1 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoPassphrase ::= { ucdDemoPublic 4 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoUserList ::= { ucdDemoPublic 3 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoPublicString ::= { ucdDemoPublic 2 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoResetKeys ::= { ucdDemoPublic 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleHeartbeatName ::= { netSnmpExampleNotificationObjects 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleHeartbeatRate ::= { netSnmpExampleNotificationObjects 1 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassExamples ::= { netSnmpExamples 255 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleNotifications ::= { netSnmpExamples 3 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleTables ::= { netSnmpExamples 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleScalars ::= { netSnmpExamples 1 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmAccessTable ::= { netSnmpVacmMIB 1 }
Cannot adopt OID in UCD-SNMP-MIB: ucdShutdown ::= { ucdTraps 2 }
Cannot adopt OID in UCD-SNMP-MIB: ucdStart ::= { ucdTraps 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsTable ::= { lmSensors 5 }
Cannot adopt OID in LM-SENSORS-MIB: lmVoltSensorsTable ::= { lmSensors 4 }
Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsTable ::= { lmSensors 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsTable ::= { lmSensors 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmSensorsMIB ::= { lmSensors 1 }
Cannot adopt OID in UCD-SNMP-MIB: mrEntry ::= { mrTable 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendConfigEntry ::= { nsExtendConfigTable 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostRowStatus ::= { netSnmpHostsEntry 5 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostStorage ::= { netSnmpHostsEntry 4 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostAddress ::= { netSnmpHostsEntry 3 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostAddressType ::= { netSnmpHostsEntry 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostName ::= { netSnmpHostsEntry 1 }
Cannot adopt OID in UCD-SNMP-MIB: prEntry ::= { prTable 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleNotification ::= { netSnmpExampleNotifications 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleNotificationObjects ::= { netSnmpExampleNotifications 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleNotificationPrefix ::= { netSnmpExampleNotifications 0 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostsTable ::= { netSnmpExampleTables 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpIETFWGTable ::= { netSnmpExampleTables 1 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassOID ::= { netSnmpPassEntry 3 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassInteger ::= { netSnmpPassEntry 2 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassIndex ::= { netSnmpPassEntry 1 }
Cannot adopt OID in NET-SNMP-VACM-MIB: netSnmpVacmMIB ::= { netSnmpObjects 9 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsVersion ::= { netSnmpObjects 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsMibRegistry ::= { netSnmpObjects 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsExtensions ::= { netSnmpObjects 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDLMod ::= { netSnmpObjects 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCache ::= { netSnmpObjects 5 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsErrorHistory ::= { netSnmpObjects 6 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsConfiguration ::= { netSnmpObjects 7 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactions ::= { netSnmpObjects 8 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoMIB ::= { ucdavis 14 }
Cannot adopt OID in UCD-SNMP-MIB: logMatch ::= { ucdavis 16 }
Cannot adopt OID in UCD-SNMP-MIB: fileTable ::= { ucdavis 15 }
Cannot adopt OID in UCD-SNMP-MIB: ucdTraps ::= { ucdavis 251 }
Cannot adopt OID in UCD-SNMP-MIB: systemStats ::= { ucdavis 11 }
Cannot adopt OID in UCD-SNMP-MIB: mrTable ::= { ucdavis 102 }
Cannot adopt OID in UCD-SNMP-MIB: snmperrs ::= { ucdavis 101 }
Cannot adopt OID in UCD-SNMP-MIB: version ::= { ucdavis 100 }
Cannot adopt OID in UCD-SNMP-MIB: laTable ::= { ucdavis 10 }
Cannot adopt OID in UCD-SNMP-MIB: dskTable ::= { ucdavis 9 }
Cannot adopt OID in UCD-SNMP-MIB: memory ::= { ucdavis 4 }
Cannot adopt OID in UCD-SNMP-MIB: extTable ::= { ucdavis 8 }
Cannot adopt OID in UCD-SNMP-MIB: prTable ::= { ucdavis 2 }
Cannot adopt OID in UCD-SNMP-MIB: ucdSnmpAgent ::= { ucdavis 250 }
Cannot adopt OID in UCD-SNMP-MIB: ucdExperimental ::= { ucdavis 13 }
Cannot adopt OID in UCD-SNMP-MIB: ucdInternal ::= { ucdavis 12 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleEntry ::= { nsModuleTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: dskErrorMsg ::= { dskEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: dskErrorFlag ::= { dskEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: dskUsedHigh ::= { dskEntry 16 }
Cannot adopt OID in UCD-SNMP-MIB: dskUsedLow ::= { dskEntry 15 }
Cannot adopt OID in UCD-SNMP-MIB: dskAvailHigh ::= { dskEntry 14 }
Cannot adopt OID in UCD-SNMP-MIB: dskAvailLow ::= { dskEntry 13 }
Cannot adopt OID in UCD-SNMP-MIB: dskTotalHigh ::= { dskEntry 12 }
Cannot adopt OID in UCD-SNMP-MIB: dskTotalLow ::= { dskEntry 11 }
Cannot adopt OID in UCD-SNMP-MIB: dskPercentNode ::= { dskEntry 10 }
Cannot adopt OID in UCD-SNMP-MIB: dskPercent ::= { dskEntry 9 }
Cannot adopt OID in UCD-SNMP-MIB: dskUsed ::= { dskEntry 8 }
Cannot adopt OID in UCD-SNMP-MIB: dskAvail ::= { dskEntry 7 }
Cannot adopt OID in UCD-SNMP-MIB: dskTotal ::= { dskEntry 6 }
Cannot adopt OID in UCD-SNMP-MIB: dskMinPercent ::= { dskEntry 5 }
Cannot adopt OID in UCD-SNMP-MIB: dskMinimum ::= { dskEntry 4 }
Cannot adopt OID in UCD-SNMP-MIB: dskDevice ::= { dskEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: dskPath ::= { dskEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: dskIndex ::= { dskEntry 1 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOTable ::= { ucdDiskIOMIB 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLoggingGroup ::= { nsConfigGroups 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugGroup ::= { nsConfigGroups 1 }
Cannot adopt OID in UCD-SNMP-MIB: snmperrErrMessage ::= { snmperrs 101 }
Cannot adopt OID in UCD-SNMP-MIB: snmperrErrorFlag ::= { snmperrs 100 }
Cannot adopt OID in UCD-SNMP-MIB: snmperrNames ::= { snmperrs 2 }
Cannot adopt OID in UCD-SNMP-MIB: snmperrIndex ::= { snmperrs 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionTable ::= { nsTransactions 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogStatus ::= { nsLoggingEntry 5 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogMaxLevel ::= { nsLoggingEntry 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogType ::= { nsLoggingEntry 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogToken ::= { nsLoggingEntry 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogLevel ::= { nsLoggingEntry 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendResult ::= { nsExtendOutput1Entry 4 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutNumLines ::= { nsExtendOutput1Entry 3 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutputFull ::= { nsExtendOutput1Entry 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput1Line ::= { nsExtendOutput1Entry 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutLine ::= { nsExtendOutput2Entry 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendLineIndex ::= { nsExtendOutput2Entry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsNotifyStart ::= { netSnmpNotifications 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsNotifyShutdown ::= { netSnmpNotifications 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsNotifyRestart ::= { netSnmpNotifications 3 }
Cannot adopt OID in UCD-SNMP-MIB: laErrMessage ::= { laEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: laErrorFlag ::= { laEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: laLoadFloat ::= { laEntry 6 }
Cannot adopt OID in UCD-SNMP-MIB: laLoadInt ::= { laEntry 5 }
Cannot adopt OID in UCD-SNMP-MIB: laConfig ::= { laEntry 4 }
Cannot adopt OID in UCD-SNMP-MIB: laLoad ::= { laEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: laNames ::= { laEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: laIndex ::= { laEntry 1 }
error: Communication status: Failed
| PERMISSION |
USB             None                           Required        -        -        OK       Node:'/dev/bus/usb/001/003' Perm:'  root  lp rw- rw- rw- rw- r--'
Missing Required Dependencies
error: 'libcups2' package is missing or 'cups' service is not running.
error: 'libdbus-1-dev' package is missing/incompatible
error: 'libsnmp-dev' package is missing/incompatible
error: 'snmp-mibs-downloader' package is missing/incompatible
error: 'libcups2-dev' package is missing or 'cups' service is not running.
error: 'cups-bsd' package is missing or 'cups' service is not running.
error: 'cups-client' package is missing or 'cups' service is not running.
error: 'openssl' package is missing/incompatible
error: 'libsane-dev' package is missing/incompatible
error: 'python3-dev' package is missing/incompatible
error: 'libjpeg8-dev' package is missing/incompatible
error: 'libusb-1.0.0-dev' package is missing/incompatible
error: 'libcupsimage2-dev' package is missing or 'cups' service is not running.
error: 'libtool' package is missing/incompatible
error: 'build-essential' package is missing/incompatible
Missing Optional Dependencies
error: 'xsane' package is missing/incompatible
error: 'python3-notify2' package is missing/incompatible
ENTER SUDO PASSWORD
Please enter the sudoer (charly)'s password:
Do you want to update repository and Install missing/incompatible packages. (a=install all*, c=custom_install, s=skip):
Updating repository
Installing Missing/Incompatible packages
cmd =libtool
error: Failed to install 'libtool' package, please install manually.
cmd =libjpeg8-dev
error: Failed to install 'libjpeg8-dev' package, please install manually.
cmd =libdbus-1-dev
error: Failed to install 'libdbus-1-dev' package, please install manually.
cmd =libsane-dev
error: Failed to install 'libsane-dev' package, please install manually.
cmd =libcupsimage2-dev
error: Failed to install 'libcupsimage2-dev' package, please install manually.
cmd =libsnmp-dev
error: Failed to install 'libsnmp-dev' package, please install manually.
cmd =python3-dev
error: Failed to install 'python3-dev' package, please install manually.
cmd =openssl
Tout ce qui est error , est en rouge.
Linux Mint 18.2 Cinnamon 64-bit : 3.4.3
Noyau Linux : 4.8.0-53-gen Pentium 1.60GHz x 4
Disques durs : 965.2 Go
Carte graphique : Intel Device 22b1
....pour une informatique libre ! -membre de l'April
Robinwood
Re: Re Imprimante HP
Message par Robinwood »
Ta présentation de sujet est un bug :mrgreen: .
Utilises les balises code.
Intel nuc8i3phn Xero Linux
linux mint 21 xfce
j'ai mis les balises
pour l'utilisation des balises "code" merci de lire ce tuto ça évite la longueur interminable d'un post ce qui rebute la plupart des intervenants
salut tu dois installer hplip ici c'est pour Lmint18
suis les démarches ci-dessous dans l'ordre. possible qu'il te dise par moment la même version existe dans le paquets pas grave tu installes quand même.
les fichiers deb. avec Gdebi comme ceci
http://security.ubuntu.com/ubuntu/pool/ ... _amd64.deb" onclick="window.open(this.href);return false;
http://security.ubuntu.com/ubuntu/pool/ ... -1_all.deb" onclick="window.open(this.href);return false;
http://mirrors.kernel.org/ubuntu/pool/u ... _amd64.deb" onclick="window.open(this.href);return false;
ici tu ouvres un terminal
sudo apt-get update
sudo apt-get install python3-pyqt4
ici avec Gdebi
ici en terminal
hp-setup
Carlos06
Salut, j'ai fais exactement ce que tu m'as indiqué, tous c'est bien passé.
Mais je n'ai toujours pas l'utilisation du scanner en rafale ; Et n'est plus le scanner page par page ? :cry:
je ne connais pas ton scanner mais tu appelle quoi scanner en rafale, quel log emploie tu pour scanner
Carlos06
C'est une imprimante HP ENVY 7640 Multi.
Il y a un chargeur de +/- de pages pour les documents a scanner, comme sur la photo où il y a le i.
J'avais trouvé un logiciel pour linux mint, qui géré tous, mais comme je suis CON ( et le mot est faible ) je n'ai pas sauvegardé la page, le seul Bmole, il était en run, et j'ai foutu le bordel.
?tu confond pas copie et scan, je viens d'aller voir ton truc pour scanner c'est un plateau. donc feuille à feuille. et l'emplacement i c'est le bac a feuille ou enveloppe et a photocopie
pour scanner ce logiciel est plus complet que simple scan.
sudo apt-get install xsane
Carlos06
Merci, je le tante et te tien au courant.
Vers 13 / 14 heures.
Carlos06
Je ne trouve pas xsane, mais j'ai trouvé HPLIP Toolbox, après quelques manipes, j'ai pu utiliser le multi scanne ; Mais il n'est pas en automatique et dans HPLIP Statuts Service ?
