Je ne parviens pas à démarrer clementine sur ma nouvelle LM20 mate. Voilà le message d'erreur obtenu en console:
~$ clementine
__logging_message__09:56:12.896 DEBUG unknown using qt5ct plugin
__logging_message__09:56:12.966 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:12.966 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:12.976 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:12.976 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:12.976 WARN unknown QSqlQuery::prepare: database not open
09:56:12.976 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:12.976 ERROR Database:596 faulty query: ""
09:56:12.976 ERROR Database:597 bound values: QMap()
__logging_message__09:56:12.981 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:12.981 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:12.981 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752910906448' is still in use, all queries will cease to work.
__logging_message__09:56:12.981 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752910906448', old connection removed.
__logging_message__09:56:12.982 WARN unknown QSqlQuery::prepare: database not open
09:56:12.982 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:12.982 ERROR Database:596 faulty query: ""
09:56:12.982 ERROR Database:597 bound values: QMap()
__logging_message__09:56:12.982 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:12.982 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:12.982 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752910906448' is still in use, all queries will cease to work.
__logging_message__09:56:12.982 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752910906448', old connection removed.
__logging_message__09:56:12.991 DEBUG unknown D-Bus system tray: no
__logging_message__09:56:13.122 DEBUG unknown D-Bus global menu: no
__logging_message__09:56:13.149 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.149 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.149 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752907258912' is still in use, all queries will cease to work.
__logging_message__09:56:13.149 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752907258912', old connection removed.
__logging_message__09:56:13.236 WARN unknown QSqlQuery::prepare: database not open
09:56:13.236 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.236 ERROR Database:596 faulty query: ""
09:56:13.236 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.236 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.236 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.236 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752907258912' is still in use, all queries will cease to work.
__logging_message__09:56:13.236 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752907258912', old connection removed.
__logging_message__09:56:13.237 WARN unknown QSqlQuery::prepare: database not open
09:56:13.237 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.237 ERROR Database:596 faulty query: ""
09:56:13.237 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.243 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.244 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.244 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752907258912' is still in use, all queries will cease to work.
__logging_message__09:56:13.244 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752907258912', old connection removed.
__logging_message__09:56:13.244 WARN unknown QSqlQuery::prepare: database not open
09:56:13.244 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.244 ERROR Database:596 faulty query: ""
09:56:13.244 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.263 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.263 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.263 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752910906448' is still in use, all queries will cease to work.
__logging_message__09:56:13.263 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752910906448', old connection removed.
__logging_message__09:56:13.263 WARN unknown QSqlQuery::prepare: database not open
09:56:13.263 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.263 ERROR Database:596 faulty query: ""
09:56:13.263 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.270 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.270 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.270 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752910906448' is still in use, all queries will cease to work.
__logging_message__09:56:13.270 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752910906448', old connection removed.
__logging_message__09:56:13.270 WARN unknown QSqlQuery::prepare: database not open
09:56:13.270 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.271 ERROR Database:596 faulty query: ""
09:56:13.271 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.295 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.295 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.295 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752910906448' is still in use, all queries will cease to work.
__logging_message__09:56:13.295 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752910906448', old connection removed.
__logging_message__09:56:13.296 WARN unknown QSqlQuery::prepare: database not open
09:56:13.296 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.296 ERROR Database:596 faulty query: ""
09:56:13.296 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.300 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.300 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.300 WARN unknown QSqlQuery::prepare: database not open
09:56:13.300 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.300 ERROR Database:596 faulty query: ""
09:56:13.301 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.314 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.314 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.314 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752907258912' is still in use, all queries will cease to work.
__logging_message__09:56:13.314 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752907258912', old connection removed.
__logging_message__09:56:13.315 WARN unknown QSqlQuery::exec: database not open
09:56:13.315 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.315 ERROR Database:596 faulty query: ""
09:56:13.315 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.321 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.321 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.321 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752910906448' is still in use, all queries will cease to work.
__logging_message__09:56:13.322 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752910906448', old connection removed.
__logging_message__09:56:13.322 WARN unknown QSqlQuery::prepare: database not open
09:56:13.322 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.322 ERROR Database:596 faulty query: ""
09:56:13.322 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.328 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.328 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.329 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752910906448' is still in use, all queries will cease to work.
__logging_message__09:56:13.329 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752910906448', old connection removed.
__logging_message__09:56:13.329 WARN unknown QSqlQuery::prepare: database not open
09:56:13.329 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.329 ERROR Database:596 faulty query: ""
09:56:13.329 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.333 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.333 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.333 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752910906448' is still in use, all queries will cease to work.
__logging_message__09:56:13.333 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752910906448', old connection removed.
__logging_message__09:56:13.333 WARN unknown QSqlQuery::prepare: database not open
09:56:13.333 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.333 ERROR Database:596 faulty query: ""
09:56:13.333 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.338 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.338 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.338 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752910906448' is still in use, all queries will cease to work.
__logging_message__09:56:13.338 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752910906448', old connection removed.
__logging_message__09:56:13.338 WARN unknown QSqlQuery::prepare: database not open
09:56:13.338 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.338 ERROR Database:596 faulty query: ""
09:56:13.338 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.339 WARN unknown libpng warning: iCCP: known incorrect sRGB profile
__logging_message__09:56:13.343 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.343 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.343 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752910906448' is still in use, all queries will cease to work.
__logging_message__09:56:13.343 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752910906448', old connection removed.
__logging_message__09:56:13.343 WARN unknown QSqlQuery::prepare: database not open
09:56:13.343 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.343 ERROR Database:596 faulty query: ""
09:56:13.343 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.344 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.344 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.344 WARN unknown QSqlQuery::prepare: database not open
09:56:13.344 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.344 ERROR Database:596 faulty query: ""
09:56:13.344 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.349 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.349 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.349 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752907258912' is still in use, all queries will cease to work.
__logging_message__09:56:13.349 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752907258912', old connection removed.
__logging_message__09:56:13.350 WARN unknown QSqlQuery::prepare: database not open
09:56:13.350 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.350 ERROR Database:596 faulty query: ""
09:56:13.350 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.392 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.392 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.392 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752920770528' is still in use, all queries will cease to work.
__logging_message__09:56:13.392 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752920770528', old connection removed.
__logging_message__09:56:13.392 WARN unknown QSqlQuery::prepare: database not open
09:56:13.392 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.392 ERROR Database:596 faulty query: ""
09:56:13.393 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.393 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.393 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.393 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752920770528' is still in use, all queries will cease to work.
__logging_message__09:56:13.393 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752920770528', old connection removed.
__logging_message__09:56:13.393 WARN unknown QSqlQuery::prepare: database not open
09:56:13.393 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.393 ERROR Database:596 faulty query: ""
__logging_message__09:56:13.433 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.433 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.433 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752907258912' is still in use, all queries will cease to work.
__logging_message__09:56:13.433 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752907258912', old connection removed.
__logging_message__09:56:13.434 WARN unknown QSqlQuery::prepare: database not open
09:56:13.434 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.434 ERROR Database:596 faulty query: ""
09:56:13.434 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.434 WARN unknown QSqlDatabase: QSQLITE driver not loaded
__logging_message__09:56:13.434 WARN unknown QSqlDatabase: available drivers:
__logging_message__09:56:13.434 WARN unknown QSqlDatabasePrivate::removeDatabase: connection '1_thread_94752907258912' is still in use, all queries will cease to work.
__logging_message__09:56:13.434 WARN unknown QSqlDatabasePrivate::addDatabase: duplicate connection name '1_thread_94752907258912', old connection removed.
__logging_message__09:56:13.435 WARN unknown QSqlQuery::prepare: database not open
09:56:13.436 ERROR Database:595 db error: QSqlError("", "Driver not loaded", "Driver not loaded")
09:56:13.436 ERROR Database:596 faulty query: ""
09:56:13.436 ERROR Database:597 bound values: QMap()
__logging_message__09:56:13.436 ERROR unknown Couldn't create playlist
Abandon (core dumped)
Merci à vous
phcook
