Configurer Samba correctement
calixtus06
Message par calixtus06 »
Bonjour, je suis au boulot et j'ai 3 pc : W7, Linux Mint et Mx. Je ne parviens pas à finaliser la config du réseau et un coup de main me serait très précieux
Détail de la mx qui n'a accès à rien :
System:    Host: <filter> Kernel: 4.19.0-6-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-4.19.0-6-amd64
           root=UUID=<filter> ro quiet splash
           Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm4 dm: LightDM 1.26.0
           Distro: MX-19.2_x64 patito feo February 15  2020 base: Debian GNU/Linux 10 (buster)
Machine:   Type: Desktop Mobo: ASUSTeK model: P8H61-M LX3 PLUS R2.0 v: Rev X.0x serial: <filter>
           BIOS: American Megatrends v: 0802 date: 10/08/2012
CPU:       Topology: Dual Core model: Intel Core i3-2120 bits: 64 type: MT MCP
           arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
           L2 cache: 3072 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 26399
           Speed: 1912 MHz min/max: 1600/3300 MHz Core speeds (MHz): 1: 2058 2: 1954 3: 1858
           4: 2273
           Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
           Type: l1tf mitigation: PTE Inversion
           Type: mds mitigation: Clear CPU buffers; SMT vulnerable
           Type: meltdown mitigation: PTI
           Type: spec_store_bypass
           mitigation: Speculative Store Bypass disabled via prctl and seccomp
           Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
           STIBP: conditional, RSB filling
           Type: tsx_async_abort status: Not affected
Graphics:  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
           vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0102
           Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
           resolution: 1280x1024~60Hz
           OpenGL: renderer: Mesa DRI Intel Sandybridge Desktop v: 3.3 Mesa 18.3.6 compat-v: 3.0
           direct render: Yes
Audio:     Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: ASUSTeK
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
           Device-2: C-Media Audio Adapter type: USB driver: hid-generic,snd-usb-audio,usbhid
           bus ID: 2-1.1.2:7 chip ID: 0d8c:000c
           Sound Server: ALSA v: k4.19.0-6-amd64
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
           vendor: ASUSTeK P8 series driver: r8169 v: kernel port: e000 bus ID: 03:00.0
           chip ID: 10ec:8168
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           Device-2: Realtek RTL8191SU 802.11n WLAN Adapter type: USB driver: r8712u
           bus ID: 2-1.5:5 chip ID: 0bda:8172 serial: <filter>
           IF: wlan0 state: down mac: <filter>
Drives:    Local Storage: total: 149.05 GiB used: 30.02 GiB (20.1%)
           ID-1: /dev/sda vendor: Maxtor model: STM3160211AS size: 149.05 GiB block size:
           physical: 512 B logical: 512 B speed: <unknown> serial: <filter> rev: E scheme: MBR
Partition: ID-1: / raw size: 147.02 GiB size: 143.71 GiB (97.75%) used: 30.02 GiB (20.9%)
           fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap swappiness: 15 (default 60)
           cache pressure: 100 (default) dev: /dev/sda2
Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C
           Fan Speeds (RPM): cpu: 0
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
           1: deb http://ftp.rezopole.net/debian/ buster-updates main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/debian.list
           1: deb http://ftp.rezopole.net/debian/ buster main contrib non-free
           2: deb http://deb.debian.org/debian-security/ buster/updates main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/mx.list
           1: deb http://mxl.mirror.root.lu/mx/repo/ buster non-free main
           Active apt repos in: /etc/apt/sources.list.d/nordvpn.list
           1: deb https://repo.nordvpn.com/deb/nordvpn/debian/ stable main
           Active apt repos in: /etc/apt/sources.list.d/teamviewer.list
           1: deb http://linux.teamviewer.com/deb stable main
           No active apt repos in: /etc/apt/sources.list.d/various.list
Info:      Processes: 216 Uptime: 43m Memory: 7.49 GiB used: 1.16 GiB (15.5%) Init: SysVinit
           v: 2.93 runlevel: 5 default: 5 Compilers: gcc: 8.3.0 alt: 8 Shell: quick-system-in
           running in: quick-system-in inxi: 3.0.36
Son adresse IP est 192.168.70.40, window7 (198.168.70.18) et Linux mint ( 198.168.70.22)
Avec angryscan:
Depuis La linux mint: LM peut lire ce qu'il y a dans le W7, elle voit MX sur le réseau.
Depuis Mx: MX voit Linux mint mais n'a pas d'accès à son contenu. Depuis l'onglet réseau par contre mx ne voit pas LM.
Mx ne voit pas W7 y compris avec angryscan !
Mx a accès à notre imprimante réseau et je peux donc lancer des impression depuis ma MX.
Depuis l'onglet "réseau " de W7, ce dernier voit MX qui s'appelle désormais debian(??) mais le nom d'identifiant et le mot de passe ne fonctionne pas ( ???)
De même W7 ne voit pas linux mint
Sur MX, j'ai copié/collé le fichier/etc/samba/smb.conf que j'avais sur mint:
[global]
   workgroup = WORKGROUP
  server string = %h server (Samba, Ubuntu)
;   wins server = w.x.y.z
   dns proxy = no
;   interfaces = 127.0.0.0/8 eth0
;   bind interfaces only = yes
   log file = /var/log/samba/log.%m
   max log size = 1000
   syslog = 0
   panic action = /usr/share/samba/panic-action %d
   server role = standalone server
   passdb backend = tdbsam
   obey pam restrictions = yes
   unix password sync = yes
   passwd program = /usr/bin/passwd %u
   passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
   pam password change = yes
   map to guest = bad user
;   logon path = \\%N\profiles\%U
;   logon drive = H:
;   logon script = logon.cmd
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
; add machine script  = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
; add group script = /usr/sbin/addgroup --force-badname %g
;   include = /home/samba/etc/smb.conf.%m
;   idmap uid = 10000-20000
;   idmap gid = 10000-20000
;   template shell = /bin/bash
;   usershare max shares = 100
   usershare allow guests = yes
;[homes]
;   comment = Home Directories
;   browseable = no
;   read only = no
;   create mask = 0700
;   directory mask = 0700
;   valid users = %S
;[netlogon]
;   comment = Network Logon Service
;   path = /home/samba/netlogon
;   guest ok = yes
;   read only = yes
;[profiles]
;   comment = Users profiles
;   path = /home/samba/profiles
;   guest ok = no
;   browseable = no
;   create mask = 0600
[printers]
   comment = All Printers
   browseable = no
   path = /var/spool/samba
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
;   write list = root, @lpadmin
Comment faire pour que MX puisse lire ce qu'il y a sur W7 et Mint ?? Et comment peut on avoir accès à mon dossier Public sur ma MX depuis les 2 autres PC ??? Comment LM peut être repéré par W7 ?
Merci d'avance
Nico
ACER ASPIRE M3641,
KDE Plasma 5.6.5, Distro: Linux Mint 18 Sarah, Intel model: DG41CN, Quad core Intel Core2 Quad Q6600, speed/max: 1596/2394 MHz, NVIDIA G73 [GeForce 7600 GT],
Network Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
Drives: HDD Total Size: 160.0GB (34.1% used)
Memory: 3 go DDR2 Synchrone 667 MHz (1,5 ns)
Kernel: 4.4.0-21-generic x86_64 (64 bit),
Re: Configurer Samba correctement
