Résolu le 16-04-21 ACER Aspire 5 514-54 - PAS DE SON
mathtom
Message par mathtom »
J'ai installé Linux Mint 20.1
Je n'ai pas de son (ni de micro).
lspci | grep -i audio
Donne :
00:lf.3 Multimedia audio controller: Intel Corporation Device a0c8 (rev 20)
aplay -l
Donne :
aplay: device_list:274: aucune carte son n'a été trouvée...
Enfin,
inxi -F
System:
  Host: ACER2-Mint Kernel: 5.4.0-70-generic x86_64 bits: 64
  Desktop: MATE 1.24.0 Distro: Linux Mint 20.1 Ulyssa
Machine:
  Type: Laptop System: Acer product: Aspire A514-54 v: V1.08
  serial: <superuser/root required>
  Mobo: TGL model: Lily_TL v: V1.08 serial: <superuser/root required>
  UEFI: Insyde v: 1.08 date: 01/22/2021
Battery:
  ID-1: BAT1 charge: 10.0 Wh condition: 50.1/47.8 Wh (105%)
CPU:
  Topology: Dual Core model: 11th Gen Intel Core i3-1115G4 bits: 64
  type: MT MCP L2 cache: 6144 KiB
  Speed: 1510 MHz min/max: 400/4100 MHz Core speeds (MHz): 1: 1507 2: 1550
  3: 1522 4: 1528
Graphics:
  Device-1: Intel driver: N/A
  Display: x11 server: X.Org 1.20.9 driver: fbdev unloaded: modesetting,vesa
  resolution: 1920x1080~77Hz
  OpenGL: renderer: llvmpipe (LLVM 11.0.0 256 bits) v: 4.5 Mesa 20.2.6
Audio:
  Device-1: Intel driver: sof-audio-pci
  Sound Server: ALSA v: k5.4.0-70-generic
Network:
  Device-1: Intel driver: iwlwifi
  IF: wlp0s20f3 state: up mac: 68:3e:26:81:ad:df
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8169
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: 08:97:98:d4:82:01
Drives:
  Local Storage: total: 476.94 GiB used: 27.53 GiB (5.8%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: OM8PCP3512F-AA size: 476.94 GiB
Partition:
  ID-1: / size: 91.17 GiB used: 20.64 GiB (22.6%) fs: ext4
  dev: /dev/nvme0n1p2
  ID-2: /home size: 109.50 GiB used: 6.89 GiB (6.3%) fs: ext4
  dev: /dev/nvme0n1p3
Sensors:
  System Temperatures: cpu: 28.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 204 Uptime: 46m Memory: 7.58 GiB used: 1.32 GiB (17.4%)
  Shell: bash inxi: 3.0.38
Quelqu'un a-t-il déjà rencontré ce problème ?
Merci !
Modifié en dernier par mathtom le ven. 16 avr. 2021 16:06, modifié 1 fois.
Thomas
Acer Aspire 5 - 514.54
Mint 20.1
Noyau 5.4.0-70
mathtom
Re: ACER Aspire 5 514-54 - PAS DE SON
J'ai tenté d'installer le paquet firmware-intel-sound mais j'obtiens cette erreur :
sudo dpkg -i firmware-intel-sound_20190114-2_all.deb
[sudo] Mot de passe de thomas :
Sélection du paquet firmware-intel-sound précédemment désélectionné.
(Lecture de la base de données... 534309 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de firmware-intel-sound_20190114-2_all.deb ...
Dépaquetage de firmware-intel-sound (20190114-2) ...
dpkg: erreur de traitement de l'archive firmware-intel-sound_20190114-2_all.deb (--install) :
 tentative de remplacement de « /lib/firmware/intel/IntcSST2.bin », qui appartient aussi au paquet linux-firmware 1.187.10
dpkg-deb: erreur: coller subprocess was killed by signal (Relais brisé (pipe))
Est-ce que je peux désinstaller linux-firmware ? ou juste supprimer /lib/firmware/intel/IntcSST2.bin ?
Thomas
Mint 20.1
Noyau 5.4.0-70
Essaie cette solution : https://forums.linuxmint.com/viewtopic. ... 4&start=20
(désolé c'est en anglais, c'est sur le forum officiel... traduction approximative dans le spoiler ci-dessous)
MrEen a écrit :Je pense que j'ai peut-être une meilleure solution. Au lieu d'essayer de faire fonctionner la nouvelle m*rde sof, ce que je ne pense pas possible sur un système d'exploitation LTS pour le moment, cela devrait amener à bugger en utilisant snd-hda-intel, je crois.
Dans le terminal, entrer :
xed admin:///etc/default/grub
et modifier la ligne qui ressemble à ceci:
par :
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash snd_hda_intel.dmic_detect=0"
Enregistrer et fermer le fichier, ignorer les avertissements GTK dans le terminal, puis exécuter :
sudo update-grub
et redémarrer.
Ce truc sof est vraiment nouveau (la version originale date d'avril 2019) et c'est la «voie à suivre» pour le son sous Linux. Les gens du son Linux concentrent leurs efforts sur cela à l'exclusion de tout le reste à ce qu'il semblerait. Une partie de cela leur a été imposée avec des technologies plus récentes comme les matrices de microphones à champ lointain que la spécification HDAudio ne pouvait pas gérer, alors ils tentent de tout unifier sous un seul pilote. Je trouve encore de nombreux problèmes signalés avec les noyaux 5.5, il faudra donc un certain temps avant que les choses ne commencent à fonctionner de manière assez cohérente.
Je crois que la modification ci-dessus de grub permettra au pilote snd-hda-intel hérité de se charger correctement, donc "aplay -l" devrait afficher la sortie comme je l'ai mentionné plus tôt dans ce fil. Je suis presque sûr que le micro interne ne fonctionnera pas, mais tout le reste devrait.
Nous devrons peut-être annuler les modifications que vous avez apportées, mais je soupçonne qu'elles ne feront aucune différence à ce stade.
mathtom
Merci !
Avec ton lien et d'autres, j'ai réussi. Voici ma procédure :
J'ai trouvé ! Voici une solution qui fonctionne. Je ne suis pas sûr d'avoir tout compris, ni que toutes les étapes décrites ci-dessous sont indispensable, mais maintenant j'ai du son :
1) éditer le fichier /etc/default/grub en root et modifier la ligne :
en :
2) Ajouter à la fin du fichier /etc/modprobe.d/alsa-base.conf la ligne :
option snd_hda_intel model=basic enable=1 index=0
3) lancer la commande
alsa-info
éventuellement deux fois s'il fait une mise à jour
et repérer le numéro du bloc qui ressemble à (pour moi c'est 0) :
0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0xf7b10000 irq 44
4)
touch ~/.asoundrc
puis éditer ce fichier (pour moi avec gedit :
gedit ~/.asoundrc
Compléter avec :
pcm.!default {
    type hw
    card 0
ctl.!default {
    type hw
    card 0
en remplaçant les "0" par le numéro du bloc repéré à l'étape précédente.
5)
ls -l ~/.asoundrc
Vérifier avec
aplay -l
Voilà.
Mes sources : https://askubuntu.com/questions/1243369 ... -audio-pci et https://debian-facile.org/doc:materiel: ... eme-de-son.
Thomas
Mint 20.1
Noyau 5.4.0-70
Super si tu as trouvé ton bonheur .... merci pour le retour, ça pourra servir à d'autres utilisateurs ayant le même souci que toi 8-) ;)
