Minidlna ne fonctionne pas, n’apparaît pas
60olivier
Message par 60olivier »
J'ai installé Minidlna (venant de la logithèque) mais impossible de le faire fonctionné sur ce pc, j'ai fait la même procédure sur mon portable et ça fonctionne du 1er coup.
J'ai cherché à droite à gauche mais je n'ai pas trouvé de solution.
j'ai bien sure desinstallé avec un purge et réinstallé mais c'est pareil.
Si quelqu'un a une idée, je ne suis pas expert en linux
merci d'avance.
Mon fichier minidlna.conf:
# This is the configuration file for the MiniDLNA daemon, a DLNA/UPnP-AV media
# server.
# Unless otherwise noted, the commented out options show their default value.
# On Debian, you can also refer to the minidlna.conf(5) man page for
# documentation about this file.
# Specify the user name or uid to run as (root by default).
# On Debian system command line option (from /etc/default/minidlna) overrides this.
#user=minidlna
# Path to the directory you want scanned for media files.
# This option can be specified more than once if you want multiple directories
# scanned.
# If you want to restrict a media_dir to a specific content type, you can
# prepend the directory name with a letter representing the type (A, P or V),
# followed by a comma, as so:
#   * "A" for audio    (eg. media_dir=A,/var/lib/minidlna/music)
#   * "P" for pictures (eg. media_dir=P,/var/lib/minidlna/pictures)
#   * "V" for video    (eg. media_dir=V,/var/lib/minidlna/videos)
#   * "PV" for pictures and video (eg. media_dir=PV,/var/lib/minidlna/digital_camera)
media_dir=/home/olivier/Vidéos
# Set this to merge all media_dir base contents into the root container
# (The default is no.)
#merge_media_dirs=no
# Path to the directory that should hold the database and album art cache.
db_dir=/var/cache/minidlna
# Path to the directory that should hold the log file.
#log_dir=/var/log
# Type and minimum level of importance of messages to be logged.
# The types are "artwork", "database", "general", "http", "inotify",
# "metadata", "scanner", "ssdp" and "tivo".
# The levels are "off", "fatal", "error", "warn", "info" or "debug".
# "off" turns of logging entirely, "fatal" is the highest level of importance
# and "debug" the lowest.
# The types are comma-separated, followed by an equal sign ("="), followed by a
# level that applies to the preceding types. This can be repeated, separating
# each of these constructs with a comma.
# The default is to log all types of messages at the "warn" level.
#log_level=general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=warn
# Use a different container as the root of the directory tree presented to
# clients. The possible values are:
#   * "." - standard container
#   * "B" - "Browse Directory"
#   * "M" - "Music"
#   * "P" - "Pictures"
#   * "V" - "Video"
#   * Or, you can specify the ObjectID of your desired root container
#     (eg. 1$F for Music/Playlists)
# If you specify "B" and the client device is audio-only then "Music/Folders"
# will be used as root.
#root_container=.
# Network interface(s) to bind to (e.g. eth0), comma delimited.
# This option can be specified more than once.
#network_interface=
# Port number for HTTP traffic (descriptions, SOAP, media transfer).
# This option is mandatory (or it must be specified on the command-line using
# "-p").
port=8209
# URL presented to clients (e.g. http://example.com:80).
#presentation_url=/
# Name that the DLNA server presents to clients.
# Defaults to "hostname: username".
#friendly_name=
# Serial number the server reports to clients.
# Defaults to the MAC address of nework interface.
#serial=
# Model name the server reports to clients.
#model_name=Windows Media Connect compatible (MiniDLNA)
# Model number the server reports to clients.
# Defaults to the version number of minidlna.
#model_number=
# Automatic discovery of new files in the media_dir directory.
inotify=yes
# List of file names to look for when searching for album art.
# Names should be delimited with a forward slash ("/").
album_art_names=Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg
album_art_names=AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg
album_art_names=Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
# Strictly adhere to DLNA standards.
# This allows server-side downscaling of very large JPEG images, which may
# decrease JPEG serving performance on (at least) Sony DLNA products.
#strict_dlna=no
# Support for streaming .jpg and .mp3 files to a TiVo supporting HMO.
#enable_tivo=no
# Which method to use for registering in TiVo: 'bonjour' (default) or
# legacy 'beacon'
#tivo_discovery=bonjour
# SSDP notify interval, in seconds.
#notify_interval=895
# Path to the MiniSSDPd socket, for MiniSSDPd support.
#minissdpdsocket=/run/minissdpd.sock
# Always set SortCriteria to this value, regardless of the SortCriteria
# passed by the client
# e.g. force_sort_criteria=+upnp:class,+upnp:originalTrackNumber,+dc:title
#force_sort_criteria=
# maximum number of simultaneous connections
# note: many clients open several simultaneous connections while streaming
#max_connections=50
# set this to yes to allow symlinks that point outside user-defined media_dirs.
#wide_links=no
Linux Mint 20.2, Intel Core i5-7400, Radeon RX 460, 8Go Ram
serged
Re: Minidlna ne fonctionne pas, n’apparaît pas
Message par serged »
T'as lu la doc ?
Chez moi, il marche comme sur des roulettes sur 2 machines différentes. Avec une Livebox.
60olivier
oui j'ai bien lu la doc et fait ce qui est demandé mais pareil, je ne comprend pas.
le service est bien démarré, je ne compte plus combien de fois je l'ai redémarré.
J'ai changer user et group dans etc/defaut...
ajouté la règle au pare feu
je vois pas, peux être un autre programme qui rentre en conflit?
