Problème Riseup VPN
carld2010
Problème Riseup VPN
Message par carld2010 »
Bonjour à tous!
Jusqu'à ce matin, Riseup VPN fonctionnait très bien sur mon Linux Mint Cinnamon 20.2.
Sans avoir rien fait de particulier, il a cessé de fonctionner. Le VPN s'ouvre, il y a l'icône sur le tableau de bord, mais reste grise (non connecté).
J'ai plusieurs erreurs lorsque je le lance avec une console, quelqu'un pourrait m'aider :? ?
Merci !
carl@carl:~$ /snap/bin/riseup-vpn.launcher
qrc:/qml/main.qml:41:9: QML QQuickItem: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
qrc:/qml/main.qml:108:9: QML QQuickItem: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
qrc:/qml/main.qml:177:9: QML BridgesItem: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
qml: Platform: linux
qml: DEBUG: Pre-seeded providers:
qml: {
    "default": "riseup",
    "providers": [
            "apiURL": "https://api.black.riseup.net/",
            "applicationName": "RiseupVPN",
            "askForDonations": "true",
            "auth": "anon",
            "authEmptyPass": "false",
            "binaryName": "riseup-vpn",
            "caCertString": "-----BEGIN CERTIFICATE-----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\n0BuC1b7uW/bBn/xKm319wXVDvBgZgcktMolak39V7DVO\n-----END CERTIFICATE-----",
            "donateURL": "https://riseup.net/vpn/donate",
            "geolocationAPI": "https://api.black.riseup.net:9001/json",
            "helpURL": "https://riseup.net/support",
            "name": "Riseup",
            "providerURL": "riseup.net",
            "timeStamp": "2021-06-22 18:28:43",
            "tosURL": "https://riseup.net/tos"
qml: systray init completed
qml: show systray
2021/11/20 15:42:07 Client expects anon auth
2021/11/20 15:42:07 firewall stop
2021/11/20 15:42:08 Fetching gateways...
2021/11/20 15:42:08 Got sorted gateways: [gaei.riseup.net yal.riseup.net starling.riseup.net limpkin.riseup.net crane.riseup.net garza.riseup.net hornero.riseup.net mockingjay.riseup.net redshank.riseup.net shag.riseup.net hoatzin.riseup.net pie.riseup.net mouette.riseup.net zarapito.riseup.net hirondelle.riseup.net fournier.riseup.net]
2021/11/20 15:42:32 Fetching certificate to /tmp/leap-938791973/openvpn.pem
2021/11/20 15:42:34 Get vpn cert has failed with status: 500 Internal Server Error
2021/11/20 15:42:34 From here, api.black.riseup.net resolves to:
2021/11/20 15:42:34 198.252.153.107
2021/11/20 15:42:37 Successfully did certificate bypass
2021/11/20 15:42:37 Got sorted gateways: [yal.riseup.net gaei.riseup.net starling.riseup.net crane.riseup.net limpkin.riseup.net garza.riseup.net shag.riseup.net redshank.riseup.net hornero.riseup.net mockingjay.riseup.net hirondelle.riseup.net pie.riseup.net zarapito.riseup.net fournier.riseup.net mouette.riseup.net hoatzin.riseup.net]
2021/11/20 15:42:37 Got sorted gateways: [yal.riseup.net gaei.riseup.net starling.riseup.net limpkin.riseup.net crane.riseup.net garza.riseup.net hornero.riseup.net mockingjay.riseup.net shag.riseup.net redshank.riseup.net fournier.riseup.net mouette.riseup.net pie.riseup.net zarapito.riseup.net hoatzin.riseup.net hirondelle.riseup.net]
2021/11/20 15:42:37 firewall start
2021/11/20 15:42:37 openvpn start:  [--auth SHA1 --cipher AES-128-CBC --keepalive 10 30 --tls-cipher DHE-RSA-AES128-SHA --tun-ipv6 --remote 199.58.83.10 443 tcp4 --remote 199.58.83.12 443 tcp4 --remote 185.220.103.12 443 tcp4 --verb 3 --management-client --management 127.0.0.1 6061 --ca /tmp/leap-938791973/cacert.pem --cert /tmp/leap-938791973/openvpn.pem --key /tmp/leap-938791973/openvpn.pem --persist-tun]
2021/11/20 15:42:37 New connection into the management
2021/11/20 15:42:37 Event: INFO: OpenVPN Management Interface Version 1 -- type 'help' for more info
2021/11/20 15:42:37 Event: FATAL: Cannot load certificate file /tmp/leap-938791973/openvpn.pem
2021/11/20 15:42:37 Event: FATAL: Error reading from OpenVPN
2021/11/20 15:42:37 Error while running bitmask-root:
2021/11/20 15:42:37 args:  [/snap/bin/riseup-vpn.bitmask-root openvpn start /snap/bin/riseup-vpn.openvpn --auth SHA1 --cipher AES-128-CBC --keepalive 10 30 --tls-cipher DHE-RSA-AES128-SHA --tun-ipv6 --remote 199.58.83.10 443 tcp4 --remote 199.58.83.12 443 tcp4 --remote 185.220.103.12 443 tcp4 --verb 3 --management-client --management 127.0.0.1 6061 --ca /tmp/leap-938791973/cacert.pem --cert /tmp/leap-938791973/openvpn.pem --key /tmp/leap-938791973/openvpn.pem --persist-tun]
2021/11/20 15:42:37 output:  Sat Nov 20 15:42:37 2021 Note: option tun-ipv6 is ignored because modern operating systems do not need special IPv6 tun handling anymore.
Sat Nov 20 15:42:37 2021 WARNING: Using --management on a TCP port WITHOUT passwords is STRONGLY discouraged and considered insecure
Sat Nov 20 15:42:37 2021 OpenVPN 2.4.7 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Apr 27 2021
Sat Nov 20 15:42:37 2021 library versions: OpenSSL 1.1.1f  31 Mar 2020, LZO 2.10
Sat Nov 20 15:42:37 2021 MANAGEMENT: Connected to management server at [AF_INET]127.0.0.1:6061
Sat Nov 20 15:42:37 2021 WARNING: you are using user/group/chroot/setcon without persist-tun -- this may cause restarts to fail
Sat Nov 20 15:42:37 2021 Deprecated TLS cipher name 'DHE-RSA-AES128-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-128-CBC-SHA'
Sat Nov 20 15:42:37 2021 OpenSSL: error:0909006C:PEM routines:get_name:no start line
Sat Nov 20 15:42:37 2021 OpenSSL: error:140AD009:SSL routines:SSL_CTX_use_certificate_file:PEM lib
Sat Nov 20 15:42:37 2021 MANAGEMENT: Client disconnected
Sat Nov 20 15:42:37 2021 Cannot load certificate file /tmp/leap-938791973/openvpn.pem
Sat Nov 20 15:42:37 2021 Exiting due to fatal error
2021/11/20 15:42:37 An error ocurred running openvpn: exit status 1
OS: Linux Mint 20.2 toujours à jour
CPU: AMD FX-8350
GPU: GeForce GTX 1060
RAM: 16 Go
SSD: 240 Go (partition système)
DD: 1 To
Re: Problème Riseup VPN
Sujet archivé (en lecture seule), plus de 2 mois
Si besoin de rouvrir, faire un MP à un membre de l'équipe ;)
