Comment utilise t'on smartmontools?
- Frederix
Comment utilise t'on smartmontools pour verifier ses storages? Je l'ai téléchargé sur la logitheque de Mint mais je n'arive pas même à le lancer ("commande non reconnue").
PC moyen-tour: i3 10100F (10th gen.) à 3.6 Ghz socket LGA 1200, UDIMM 1.2v DDR4 16Gb 2666 Mhz, 2 HD 512 Gb, carte vidéo GeForce GT730 sous Linux Mint 21.1 Vera (Cinnamon) 64 bits, kernel 5.15.0.
Portable HP 450G2: i7-4510U à 2.00GHz, RAM 8 Gb, SSD interne 512Gb.
Connexion Internet par la fibre (SFR).
- Frederix
Re: Comment utilise t'on smartmontools?
Merci. J'ai des "re-located sectors" est-ce à dire que mon disque est trop vieux, faut-il songer à le remplacer?
$ sudo /usr/sbin/smartctl -a /dev/sda
[sudo] Mot de passe de newman :
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.0-58-generic] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: SanDisk based SSDs
Device Model: SanDisk SD7SB2Q512G1001
Serial Number: 160633400475
LU WWN Device Id: 5 001b44 4a46ee69f
Firmware Version: X2230001
User Capacity: 512 110 190 592 bytes [512 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2 T13/2015-D revision 3
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Jan 24 13:56:37 2022 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 10) minutes.
SMART Attributes Data Structure revision number: 4
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0032 100 100 --- Old_age Always - 100
9 Power_On_Hours 0x0032 253 100 --- Old_age Always - 12432
12 Power_Cycle_Count 0x0032 100 100 --- Old_age Always - 2681
166 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 7
167 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 45
168 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 186
169 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 729
170 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 0
171 Program_Fail_Count 0x0032 100 100 --- Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 --- Old_age Always - 0
173 Avg_Write/Erase_Count 0x0032 100 100 --- Old_age Always - 72
174 Unexpect_Power_Loss_Ct 0x0032 100 100 --- Old_age Always - 65
178 Used_Rsvd_Blk_Cnt_Chip 0x0032 100 100 --- Old_age Always - 0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0032 100 100 --- Old_age Always - 27974
184 End-to-End_Error 0x0032 100 100 --- Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 --- Old_age Always - 0
188 Command_Timeout 0x0032 100 100 --- Old_age Always - 0
194 Temperature_Celsius 0x0022 075 045 --- Old_age Always - 25 (Min/Max 18/45)
199 UDMA_CRC_Error_Count 0x0032 100 100 --- Old_age Always - 0
212 SATA_PHY_Error 0x0032 100 100 --- Old_age Always - 0
230 Perc_Write/Erase_Count 0x0032 100 100 --- Old_age Always - 552
232 Perc_Avail_Resrvd_Space 0x0033 100 100 004 Pre-fail Always - 100
233 Media_Wearout_Indicator 0x0032 100 100 --- Old_age Always - 36539
241 Total_LBAs_Written 0x0030 253 253 --- Old_age Offline - 3051
242 Total_LBAs_Read 0x0030 253 253 --- Old_age Offline - 8091
244 Thermal_Throttle 0x0032 000 100 --- Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 12094 -
# 2 Short offline Completed without error 00% 12023 -
Selective Self-tests/Logging not supported
newman@newman-HP-ProBook-450-G2:~$
Bah c'est écrit noir sur blanc dans la doc donnée en lien
- Frederix
oui je voulais une confirmation, mon disque date, c'est un pc reconditionné dont j'ai dû changer la batterie déjà.
- Frederix
Pas de secteurs défectueux pourtant, je suis rassuré: Merci pour le lien c'est ce qu'il fallait.
Etape 1: install e2fsprogs
Etape2: disque OK
~$ sudo apt-get install e2fsprogs
e2fsprogs est déjà la version la plus récente (1.45.5-2ubuntu1).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 412 non mis à jour.
$ sudo badblocks -v /dev/sda5 > bad-blocks
Vérification des blocs 0 à 499580927
Vérification des blocs défectueux (test en mode lecture seule) :
complété
Passe complétée, 0 blocs défectueux repérés. (0/0/0 erreurs)
- Frederix
En l'occurence pour mon système l'étape 1 n'était pas nécessaire. Rétrospectivement je ne vois d'ailleurs pas le rapport entre e2fsprogs et badblocks, j'ai appliqué le tuto
peut etre simplement parce que c'est ce paquet qui fournit l'utilitaire badblock
apt-file list e2fsprogs | grep badblock
e2fsprogs: /sbin/badblocks
e2fsprogs: /usr/share/man/man8/badblocks.8.gz
- Frederix
J'y avais bien pensé mais je ne savais pas encore comment le savoir merci.
