mintupgrade
Yvon58
mintupgrade
Message par Yvon58 »
Bonjour à tous.
Actuellement sur mint 19.3 Tricia je souhaite upgrader sur Mint 20 puis mint 21. J'ai installé mintupgrade mais ca ne fonctionne pas.
Voci le résultat de "mintupgrade check:
yvon@HP-All-in-One-Mint:~$ mintupgrade check
    Executing 'check'. This will perform the following:
    1 - Your repositories will be switched to point to Linux Mint 20 'Ulyana' and
        any 3rd party repositories will be removed. A backup of your APT sources
        will be written to /home/yvon/Upgrade-Backup-tricia/APT.
    2 - The upgrade will be simulated so impacted packages can be evaluated.
    Your sources will be restored to Linux Mint 19.3 'Tricia' at the end of this command.
   Do you want to continue? [y/n]: y
  + Checking your Linux Mint codename...
  + Checking your Linux Mint edition...
  + Checking your Timeshift configuration...
  + Updating cache...
[sudo] Mot de passe de yvon :
Réception de :1 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB]
Atteint :2 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
Ign :3 http://packages.linuxmint.com tricia InRelease
Atteint :4 http://archive.ubuntu.com/ubuntu bionic InRelease
Atteint :5 http://archive.canonical.com/ubuntu bionic InRelease
Réception de :6 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88,7 kB]
Atteint :7 http://packages.linuxmint.com tricia Release
Réception de :9 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [83,3 kB]
261 ko réceptionnés en 2s (122 ko/s)
  + Checking your APT repositories...
!!  ERROR: The following 3rd party repositories were detected. Disable them and refresh your APT cache.
    - Proprietary GPU Drivers (LP-PPA-graphics-drivers) - ppa.launchpad.net
!!  Exiting.
  + Restoring your backed up APT sources...
Je suis dépassé...
PS/ comment copier la fenetre du terminal ?
Merci à Tous.
Modifié en dernier par cyrille le mar. 6 déc. 2022 13:20, modifié 1 fois.
Raison : Ajout des balises CODE
HP desktop intel Core I3 8Go ram 64 bits Windows 10
Bientôt Linux Mint Cinnamon
Re: mintupgrade
Avant d'upgrader vers la nouvelle version il faut que tu nettoies tes sources.list des ppa que tu as mis
Donne nous le retour de
find /etc/apt -type f -name '*.list' -exec bash -c 'echo -e "\n$1"; nl -ba "$1"' _ '{}' \;
qu'on te dise quel fichier supprimer
Re: mintupgrade
Ensuite sauter de la 19 à la 20 puis 21
Pourquoi ne pas repartir directement depuis une installation propre de la 21 ?
tioker
Re: mintupgrade
Message par tioker »
Yvon,
Pour plus de lisibilité, merci de mettre ton code entre deux balises ... code. Vois comme c'est beau...
+ Updating cache...
!! Exiting.
Sinon je pense que le message à retenir est bien celui qui te dit que tu as des dépôts tiers qui empêchent la migration. Lire ce post qui l'explique.
Et je pense que tu as une piste comme montré dans cette copie de fenêtre.
Yvon58
Re: mintupgrade
cyrille a écrit :
mar. 6 déc. 2022 13:14
yvon@HP-All-in-One-Mint:~$ find /etc/apt -type f -name '*.list' -exec bash -c 'echo -e "\n$1"; nl -ba "$1"' _ '{}' \;
/etc/apt/sources.list.d/official-package-repositories.list
     1	deb http://packages.linuxmint.com tricia main upstream import backport
     2
     3	deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
     4	deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
     5	deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
     6
     7	deb http://security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
     8	deb http://archive.canonical.com/ubuntu/ bionic partner
/etc/apt/sources.list.d/graphics-drivers-ppa-bionic.list
     1	deb http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic main
     2	# deb-src http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic main
     1	#deb cdrom:[Linux Mint 19.3 _Tricia_ - Release amd64 20191213]/ bionic contrib main non-free
[Code]
Modifié en dernier par Yvon58 le mar. 6 déc. 2022 14:47, modifié 2 fois.
Re: mintupgrade
sudo rm  /etc/apt/sources.list.d/graphics-drivers-ppa-bionic.list
Et relance l'upgrade ;)
