actation du wifi/bluetooth
Abel17
Message par Abel17 »
Je viens d'installer Mint 21.1 Vera sur un portable HP Pavillon.
Si l'installation s'est bien passée, il me manque le wifi et le bluetooth.
Voici le résultat de quelques commandes :
>lsusb
Bus 001 Device 002: ID 8087:8001 Intel Corp. Integrated Hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 0a5c:216d Broadcom Corp. BCM43142A0 Bluetooth 4.0
Bus 002 Device 002: ID 064e:930a Suyin Corp. HP Truevision HD
>rfkill list
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
>hciconfig -a
hci0:	Type: Primary  Bus: USB
	BD Address: D8:5D:E2:B9:3F:AA  ACL MTU: 0:0  SCO MTU: 0:0
	DOWN
	RX bytes:342 acl:0 sco:0 events:9 errors:0
	TX bytes:27 acl:0 sco:0 commands:9 errors:0
	Features: 0xff 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
	Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
	Link policy:
	Link mode: PERIPHERAL ACCEPT
>inxi -Fxz
System:
  Kernel: 6.0.0-1009-oem x86_64 bits: 64 compiler: N/A Desktop: MATE 1.26.0
    Distro: Linux Mint 21.1 Vera base: Ubuntu 22.04 jammy
Machine:
  Type: Laptop System: HP product: HP Pavilion Notebook
    v: Type1ProductConfigId serial: <superuser required>
  Mobo: HP model: 8097 v: 89.32 serial: <superuser required> UEFI: Insyde
    v: F.77 date: 12/18/2015
Battery:
  ID-1: BAT0 charge: 25.1 Wh (100.0%) condition: 25.1/25.1 Wh (100.0%)
    volts: 16.4 min: 14.8 model: Hewlett-Packard Primary status: Full
CPU:
  Info: dual core model: Intel Core i5-5200U bits: 64 type: MT MCP
    arch: Broadwell rev: 4 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 1775 high: 2201 min/max: 500/2700 cores: 1: 2200
    2: 2201 3: 500 4: 2200 bogomips: 17598
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Graphics:
  Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
    v: kernel bus-ID: 00:02.0
  Device-2: NVIDIA GM108M [GeForce 940M] vendor: Hewlett-Packard
    driver: N/A bus-ID: 0a:00.0
  Device-3: Suyin HP Truevision HD type: USB driver: uvcvideo bus-ID: 2-3:2
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
    unloaded: fbdev,vesa gpu: i915 resolution: 1600x900~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
    v: 4.6 Mesa 22.0.5 direct render: Yes
Audio:
  Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  Device-2: Intel Wildcat Point-LP High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  Sound Server-1: ALSA v: k6.0.0-1009-oem running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: N/A
    bus-ID: 08:00.0
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
    vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 09:00.0
  IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth:
  Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
    bus-ID: 2-7:3
  Report: hciconfig ID: hci0 rfk-id: 0 state: down
    bt-service: enabled,running rfk-block: hardware: no software: no
    address: <filter>
Drives:
  Local Storage: total: 931.51 GiB used: 27.9 GiB (3.0%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
Partition:
  ID-1: / size: 479.55 GiB used: 27.87 GiB (5.8%) fs: ext4 dev: /dev/sda5
  ID-2: /boot/efi size: 96 MiB used: 30.2 MiB (31.5%) fs: vfat
    dev: /dev/sda1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
  System Temperatures: cpu: 44.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 221 Uptime: 1h 13m Memory: 7.69 GiB used: 1.88 GiB (24.5%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2306 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
Pour info, le paquet backport-iwlwifi-dkms est déjà installé.
Si je ne me trompe pas le wifi et le bluetooth sont gérés par la même carte Broadcom BCM43142 qui est reconnue, il ne devrait pas falloir faire grand chose pour l'activer, mais quoi ?
Si quelqu'un a une idée, je suis preneur.
Cordialement et bon Noel à tous.
Re: actation du wifi/bluetooth
Yep
Script complet d'aide / wifi :
viewtopic.php?f=33&t=18709
bonjour
sujet n'ayant rien à faire dans "Actu et bug du forum (ouverte"
je l'ai déplacé dans la bonne cat "Assistance technique (ouverte" ;)
il faudrait également éditer le titre du premier message car le mot "actation" n'est pas , comment dire, pas ... :lol:
merci d'avance;)
Abel17
Re: activation du wifi/bluetooth
ok, merci de la remarque.
Abel
Abel17
Voici le résultat du script donné par Cyrill :
connecté à internet en RJ45
rfkill est installé. Continuons.
xclip est installé. Continuons.
Carte réseau :
 08:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM43142 802.11b/g/n [14e4:4365] (rev 01)
Prise en charge par le kernel :
	DeviceName: Broadcom BCM43142 802.11 b/g/n 1x1Wi-Fi + BT4.0 M.2 Combo Adapter
	Subsystem: Hewlett-Packard Company BCM43142 802.11b/g/n [103c:804a]
	Kernel modules: bcma
Présence firmware (ip _a) :
    inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 3c:a8:2a:c0:3c:90 brd ff:ff:ff:ff:ff:ff
    altname enp9s0
    inet 192.168.0.16/24 brd 192.168.0.255 scope global dynamic noprefixroute eno1
       valid_lft 40959sec preferred_lft 40959sec
    inet6 2a01:e0a:199:ce20:1c62:3ffb:4479:badb/64 scope global temporary dynamic
       valid_lft 86062sec preferred_lft 83588sec
    inet6 2a01:e0a:199:ce20:75b0:2cf9:70f8:51ab/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 86062sec preferred_lft 86062sec
    inet6 fe80::17bf:4f1c:a937:c1d9/64 scope link noprefixroute
Firmware manquant :
[    0.112725] DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x000000009d800000-0x000000009fffffff], contact BIOS vendor for fixes
[    0.135890] Spectre V2 : Enabling Restricted Speculation for firmware calls
[   22.542006] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
Verrouillage soft / hard :
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
IPBox :
PING 192.168.0.254 (192.168.0.254) 56(84) bytes of data.
64 bytes from 192.168.0.254: icmp_seq=1 ttl=64 time=0.736 ms
64 bytes from 192.168.0.254: icmp_seq=2 ttl=64 time=0.539 ms
64 bytes from 192.168.0.254: icmp_seq=3 ttl=64 time=0.531 ms
--- 192.168.0.254 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2041ms
rtt min/avg/max/mdev = 0.531/0.602/0.736/0.094 ms
Ping vers la box :
Kernel :
Linux codep17-HP 6.0.0-1009-oem #9-Ubuntu SMP PREEMPT_DYNAMIC Thu Dec 8 07:13:10 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Kernel(s) installé(s) :
ii  linux-image-5.15.0-56-generic              5.15.0-56.62                               amd64        Signed kernel image generic
ii  linux-image-6.0.0-1009-oem                 6.0.0-1009.9                               amd64        Signed kernel image OEM
ii  linux-image-generic                        5.15.0.56.54                               amd64        Generic Linux kernel image
Invalid MIT-MAGIC-COOKIE-1 keyError: Can't open display: :0
et maintenant le même script en débranchant la prise RJ45
ping: usage error: Adresse de destination requise
Carte réseau :
2: eno1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
    altname enp9s0
Firmware manquant :
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
IPBox :
Ping vers la box :
Kernel :
à priori, il manquerait un firmware et ça se passerait dans le bios... tout ça m'est bien étrange.
Merci d'avance.
Abel
Modifié en dernier par alain le jeu. 5 janv. 2023 16:31, modifié 1 fois.
Très en vitesse, mais à ma avis tu trouveras ton pilote dans ce paquet
 broadcom-sta-dkms
donc
sudo apt install  broadcom-sta-dkms
Et reboot
(Si secure boot dans le bios, le desactiver)
Abel17
Merci de ta réponse.
Le paquet a été installé, j'ai rebooté en vérifiant que le sécure boot n'était pas activé et je n'ai toujours pas le wifi/bluetooth.
J'ai relancé le script magique et comparé les sorties, ce sont les mêmes qu'avant l'installation...
Il doit manquer quelquechose, mais quoi ...
Abel
tu peux poster le retour de
aptitude search broadcom
Et as tu bien desactiver le Secure Bios ?
 sudo apt install  mokutil
Puis donner le retour de
 mokutil --sb-state
Abel17
Voila le résultat de : aptitude search broadcom
p broadcom-sta-common - Fichiers communs pour le pilote de carte sans fil Broadcom STA
i broadcom-sta-dkms - source dkms pour le pilote Wi-Fi STA Broadcom
v broadcom-sta-modules -
i broadcom-sta-source - Source pour le pilote de carte sans fil Broadcom STA
et le résultat de : mokutil --sb-state
SecureBoot disabled
Platform is in Setup Mode
Cordialement
Abel
