probleme linux mint 18.1
Re: probleme linux mint 18.1
hi
You go to sources software you remove the ppa atllasian
Salut Kali,
Alors, on va commencer par le commencement
Tout d'abord, décris ton matériel dans ta signature comme indiqué dans ce tuto: Aide pour une signature utile
C'est important que les gens qui veulent t'aider sachent sur quel système tu tournes. Les solutions peuvent être différentes selon les OS et/ou les versions d'OS.
Ensuite... dis moi, est-ce que t'aurais pas un peu fait ta feignasse en postant ton sujet ?
Une petite contextualisation du sujet aurait pu aider ?
(bon t'as de la chance, mpat est un crack )
A+
David
Hi Kali,
Let's start by the beginning (despite mpat's reply), it's important to follow a couple of guidelines in order to make things better for everyone.
First above, please describe your computer (hardware / software) in your sign part by reading the following tutorial: Aide pour une signature utile
For FFLM members that want to help you, it's important to know which OS you're using because answers could be different from one OS to another.
Then, ... I think you were a "little bit" lazy when you post your problem, right ?
A little decription of your problem (when it happens, what did you do just before,...) could be very helpful for getting best solution for your problem
(You're quite lucky, mpat is a "cador" )
Best,
David
A+
David
Hi Kali,
Best,
David
Great !
I'm glad that mpat's solution worked for you. So, if your issue is solved, you should tagged the psot as "solved".
For doing that, follow this procedure: voir tuto ici
Thanks for the description, but it will be better if you incorporate in your "signature" (see in your profil options).
Best,
David
Best,
David
yo mister, you are please speak in french in forum french pls for the respect language french
tank you
the professor roromint
tank you
cordialement,
Ro.
Ro.
Dit-il en anglais
Navigateur : Brave 1.18.78
Monsieur, vous êtes s'il vous plaît parlez en francais dans le forum francais pls pour le respect langue français
Le professeur roromint
cordialement,
Ro.
Ro.
Merci roro.
