Abandon le 5-06-26 Supprimer une imprimante Brother
Genevrier1
Re: Supprimer une imprimante Brother
Message par Genevrier1 »
,,,,,,,…….# Printer configuration file for CUPS v2.4.7
# Written by cupsd
# DO NOT EDIT THIS FILE WHEN CUPSD IS RUNNING
NextPrinterId 102
<Printer Canon-MF4320-4350-(UFRII-LT)>
PrinterId 10
UUID urn:uuid:bb9fd10d-9be0-30fa-4764-a988802d785d
Info Canon MF4320-4350 (UFRII LT)
Location michel-HP-EliteBook-850-G3
MakeModel Canon iP4500 series - CUPS+Gutenprint v5.3.4
DeviceURI usb://Canon/MF4320-4350%20(UFRII%20LT)?serial=SJF885051022G&interface=1
State Stopped
StateMessage Unplugged or turned off
StateTime 1764531599
ConfigTime 1764403188
Reason paused
Type 36892
Accepting Yes
Shared Yes
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
ErrorPolicy retry-job
</Printer>
<DefaultPrinter Canon-TS3300-series>
PrinterId 6
UUID urn:uuid:25bebaef-162a-393d-6102-eb97ef8f16b8
AuthInfoRequired none
Info Canon TS3300 series
Location
MakeModel Canon Printer, driverless, 2.0.0
DeviceURI ipps://Canon%20TS3300%20series._ipps._tcp.local/
State Idle
StateTime 1756986159
ConfigTime 1756927898
Type 36876
Accepting Yes
Shared Yes
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
Attribute marker-colors \#00CFFF#F200FF#FFDA00,#000000
Attribute marker-levels 100,100
Attribute marker-low-levels 15,15
Attribute marker-high-levels 100,100
Attribute marker-names Color,Black
Attribute marker-types ink-cartridge,ink-cartridge
Attribute marker-change-time 1756986144
</DefaultPrinter>
<Printer Hewlett-Packard-hp-LaserJet-3020>
PrinterId 13
UUID urn:uuid:59bbcbd3-a5ba-3442-5166-da4a42c3ca1d
Info Hewlett-Packard hp LaserJet 3020
MakeModel HP LaserJet 3020 3030 Postscript (recommended)
DeviceURI hp:/usb/hp_LaserJet_3020?serial=00CNBF048758
State Idle
StateTime 1769430787
ConfigTime 1769430783
Type 8425540
Accepting Yes
Shared Yes
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
</Printer>
<Printer hp-LaserJet-3020>
PrinterId 11
UUID urn:uuid:47f0706e-6a35-3172-4737-25abe833c1d8
State Idle
StateTime 1769430656
ConfigTime 1769430656
Type 8425540
Accepting Yes
Shared Yes
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
</Printer>
<Printer hp-LaserJet-3020-Fax>
PrinterId 12
UUID urn:uuid:a6ed0256-d11c-347d-5975-19c3e0b2b01d
Info HP Fax
MakeModel HP Fax hpcups
DeviceURI hpfax:/usb/hp_LaserJet_3020?serial=00CNBF048758
State Idle
StateTime 1769430659
ConfigTime 1769430659
Type 4108
Accepting Yes
Shared Yes
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
</Printer>
Mint 22 cinamon 5.6.7
Lepoune
Message par Lepoune »
Ouèp !
Pas de Brother...
Mais tu as dit plus avant qu'elle est connectée en WiFi.
Je me dis que tu devrais aller voir dans tes connexions :
Clic gauche sur l'applet réseau / Connexion au réseau / et si elle apparaît sur la boite "Connexions réseau", faire un clic de sélection puis sur le " -" en bas à gauche de la boite...
S'il elle n'apparaît pas dans la boite, il faudrait peut-être la sélectionner avant dans l'applet pour qu'elle "monte" puis la supprimer ?
Faudra peut-être redémarrer la machine pour actualiser (et s'assurer que l'imprimante soit éteinte...).
Genevrier1
Et bien, elle n'apparaît pas dans les connexions réseau !
C'est un vrai mystère ...
Lepoune
À tenter :
http://localhost:631/printers/
Puis cliquer sur la Brother si elle apparaît
Puis choisir le menu «Administration / Supprimer l’imprimante / (se connecter : nom utilistateur ordi+MdP) / Confirmer»
Eteindre ordi + redémarrer.
Sinon, y a aussi ça :
viewtopic.php?p=261435
Genevrier1
ça relève de la magie noire !
J'ai réussi à "supprimer l'imprimante"....qui s'empresse de revenir !
Lepoune
Re-
Je pense que seule une ré-installation totale pourrais (peut-être :mrgreen: ) éradiquer le pb.
Mais si c'est juste pour "éliminer" une imprimante, je ne suis pas certain que ça vaille la peine...
Désolé de ne pas avoir pu faire mieux.
EDIT : est-ce que ton imprimante était (est) en réseau (via ta box) ?
Genevrier1
je crois que oui ...
Sinon, nous sommes bien d'accord, ça ne mérite pas une réinstallation....
Je vais "abandonner" le sujet...
Un grand merci pour l'accompagnement ...
Lepoune
Regarde dans ta box, c'est peut-être là qu'elle est présente...
Genevrier1
Comment faire pour "regarder dans ma box" ?
Genevrier1
Si je la supprime dans ma box, ça veut dire qu'aucun PC n'aura accès à cette imprimante ....?
Or je ne souhaite la supprimer que sur un PC ...t
Lepoune
Ben faut laisser comme ça alors.
Pi c'est normal que tu l'aies... :D :D :D
EDIT : juste pour info :
pour aller dans une box "Orange" :
http://192.168.1.1/
Connexion : Admin
MdP : les 8 premiers caractères de ta clef WiFi
Et pour un reset :
https://assistance.orange.fr/livebox-mo ... 685-827333#
