PC1 : Asus AB350 Kernel: 6.8.0-139-generic arch: x86_64 bits: 64
Desktop: MATE v: 1.26.2 Distro: Linux Mint 22.1 Xia
Machine:
Double boot : Win10-linuxmint
<VirtualHost *:80>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request's Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
#ServerName www.example.com
ServerAdmin webmaster@localhost
DocumentRoot /var/www/html
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the loglevel for particular
# modules, e.g.
#LogLevel info ssl:warn
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
# For most configuration files from conf-available/, which are
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with "a2disconf".
#Include conf-available/serve-cgi-bin.conf
</VirtualHost>
Nota : Je n'ai pas besoin de peplocal.test. Je peux le supprimer s'il le faut.
Machine:
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xeu apache2.service" for details.
/etc/apache2/sites-available$ journalctl -xeu apache2.service
févr. 08 09:44:38 aet3-lemien systemd[1]: Starting apache2.service - The Apache HTTP Server...
░░ Subject: L'unité (unit) apache2.service a commencé à démarrer
░░ Defined-By: systemd
░░ Support: http://www.ubuntu.com/support
░░ L'unité (unit) apache2.service a commencé à démarrer.
févr. 08 09:44:38 aet3-lemien apachectl[1584]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name,>
févr. 08 09:44:38 aet3-lemien systemd[1]: Started apache2.service - The Apache HTTP Server.
░░ Subject: L'unité (unit) apache2.service a terminé son démarrage
░░ L'unité (unit) apache2.service a terminé son démarrage, avec le résultat done.
févr. 08 11:26:04 aet3-lemien systemd[1]: Reloading apache2.service - The Apache HTTP Server...
░░ Subject: L'unité (unit) apache2.service a commencé à recharger sa configuration
░░ L'unité (unit) apache2.service a commencé à recharger sa configuration.
févr. 08 11:26:04 aet3-lemien apachectl[6848]: apache2: Syntax error on line 225 of /etc/apache2/apache2.conf: Syntax error on line 1 o>
févr. 08 11:26:04 aet3-lemien systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
lines 1-23/139 18%...skipping...
févr. 08 09:44:38 aet3-lemien apachectl[1584]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
févr. 08 11:26:04 aet3-lemien apachectl[6848]: apache2: Syntax error on line 225 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/sites-enabled/peplocal.fr.conf: /etc/apache2/sites-enabled/peplocal.fr.conf:1: <Virtua>
░░ An ExecReload= process belonging to unit apache2.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
févr. 08 11:26:04 aet3-lemien systemd[1]: Reload failed for apache2.service - The Apache HTTP Server.
░░ Subject: L'unité (unit) apache2.service a terminé de recharger configuration
░░ L'unité (unit) apache2.service a terminé de recharger configuration,
░░ avec le résultat failed.
févr. 08 11:26:32 aet3-lemien systemd[1]: Reloading apache2.service - The Apache HTTP Server...
févr. 08 11:26:32 aet3-lemien apachectl[6873]: apache2: Syntax error on line 225 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/sites-enabled/peplocal.fr.conf: /etc/apache2/sites-enabled/peplocal.fr.conf:1: <Virtua>
févr. 08 11:26:32 aet3-lemien systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
févr. 08 11:26:32 aet3-lemien systemd[1]: Reload failed for apache2.service - The Apache HTTP Server.
lines 1-55/139 40%
Machine:
<VirtualHost *:80>
ServerName peplocal.fr
ServerAlias www.peplocal.fr
ServerAdmin webmaster@peplocal.fr
DocumentRoot /var/www/peplocal.fr/public_html
<Directory /var/www/peplocal.fr/public_html>
Options -Indexes +FollowSymLinks
AllowOverride All
</Directory>
<Directory /var/www/html>
Options Indexes FollowSymLinks
AllowOverride All
Require all granted
</Directory>
</VirtualHost>
J'ai redémarré apache avec la modif mod_rewrite et il n'y a pas d'erreur.
Je vais continuer en reprenant ton tuto LAMP.
Encore merci.
Machine:
avec le mdp compliqué que j'avais entré l'autre jour, j'obtiens l'accès à la console mysql.
Je quitte donc la console mysql. J'essaie avec ce même mot de passe root dans phpmyadmin.
Et là, j'ai l'erreur :
mysqli::real_connect(): (HY000/1698): Access denied for user 'root'@'localhost'
Machine:
Je viens de découvrir que le mot de passe saisi dans la console mysql pouvait être accepté ou refusé si j'utilise le pavé numérique à droite.
Je dispose d'un clavier étendu avec à droite le pavé numérique.
Comme mon mdp comprend un chiffre, même dans la console mysql, si j'utilise le pavé numérique, le mdp est refusé par mysql.
Si j'utilise au contraire pour taper le chiffre en question les chiffres situés au dessus des touches alpha numériques, le mot de passe est valide et accepté.
Je vais essayer avec adminer pour vérifier si le problème demeure ou pas.
Je reviendrai demain pour vous dire si adminer règle le problème ou pas.
Machine:
Je viens d'installer adminer.
Mais c'est le même problème.
Accès refusé donc avec adminer.
Machine:
Access denied for user 'root'@'localhost' (using password: YES)
Machine:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
Machine:
Donc désinstaller apache, mysql et php ?
Autre chose à désinstaller ?
Machine:
Ok.
Mais comment purger les fichiers de conf : une commande console ?
Machine:
