Tout neuf de hier
Tournicoti tournicota
Allez du conky encore du conky en version 1.10
root@pc-domino:/home/hermes# cat /etc/conky/conky.conf
-- vim: ts=4 sw=4 noet ai cindent syntax=lua
Conky, a system monitor, based on torsmo
Any original torsmo code is licensed under the BSD license
All code written since the fork of torsmo is licensed under the GPL
Please see COPYING for details
Copyright (c) 2004, Hannu Saransaari and Lauri Hakkarainen
Copyright (c) 2005-2012 Brenden Matthews, Philip Kovacs, et. al. (see AUTHORS)
All rights reserved.
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
conky.config = {
alignment = 'top_left',
background = false,
border_width = 1,
cpu_avg_samples = 2,
default_color = 'white',
default_outline_color = 'white',
default_shade_color = 'white',
draw_borders = false,
draw_graph_borders = true,
draw_outline = false,
draw_shades = false,
use_xft = true,
font = 'DejaVu Sans Mono:size=12',
gap_x = 5,
gap_y = 60,
minimum_height = 5,
minimum_width = 5,
net_avg_samples = 2,
no_buffers = true,
out_to_console = false,
out_to_stderr = false,
extra_newline = false,
own_window = true,
own_window_class = 'Conky',
own_window_type = 'desktop',
stippled_borders = 0,
update_interval = 1.0,
uppercase = false,
use_spacer = 'none',
show_graph_scale = false,
show_graph_range = false
conky.text = [[
${scroll 16 $nodename - $sysname $kernel on $machine | }
$hr
${color grey}Uptime:$color $uptime
${color grey}Frequency (in MHz):$color $freq
${color grey}Frequency (in GHz):$color $freq_g
${color grey}RAM Usage:$color $mem/$memmax - $memperc% ${membar 4}
${color grey}Swap Usage:$color $swap/$swapmax - $swapperc% ${swapbar 4}
${color grey}CPU Usage:$color $cpu% ${cpubar 4}
${color grey}Processes:$color $processes ${color grey}Running:$color $running_processes
$hr
${color grey}File systems:
/ $color${fs_used /}/${fs_size /} ${fs_bar 6 /}
${color grey}Networking:
Up:$color ${upspeed eth0} ${color grey} - Down:$color ${downspeed eth0}
$hr
${color grey}Name PID CPU% MEM%
${color lightgrey} ${top name 1} ${top pid 1} ${top cpu 1} ${top mem 1}
${color lightgrey} ${top name 2} ${top pid 2} ${top cpu 2} ${top mem 2}
${color lightgrey} ${top name 3} ${top pid 3} ${top cpu 3} ${top mem 3}
${color lightgrey} ${top name 4} ${top pid 4} ${top cpu 4} ${top mem 4}
root@pc-domino:/home/hermes# cp /etc/conky/conky.conf /home/$USER/.conkyrc
cp: impossible de créer le fichier standard '/home/root/.conkyrc': Aucun fichier ou dossier de ce type
root@pc-domino:/home/hermes# conky ~/.conkyrc &
[1] 1955
root@pc-domino:/home/hermes# No protocol specified
conky: can't open display: :0
conky -v
conky 1.10.6 compiled Fri Dec 9 09:25:23 UTC 2016 for Linux 3.16.0-4-amd64 x86_64
Compiled in features:
System config file: /etc/conky/conky.conf
Package library path: /usr/lib/conky
General:
* math
* hddtemp
* portmon
* IPv6
* Curl
* RSS
* Weather (METAR)
* Weather (XOAP)
* wireless
* support for IBM/Lenovo notebooks
* nvidia
* eve-online
* builtin default configuration
* old configuration syntax
* Imlib2
* apcupsd
* iostats
* ncurses
* Internationalization support
* PulseAudio
Lua bindings:
* Cairo
* Imlib2
* RSVG
X11:
* Xdamage extension
* Xinerama extension (virtual display)
* XDBE (double buffer extension)
* Xft
* ARGB visual
* Own window
Music detection:
* Audacious
* MPD
* MOC
* XMMS2
Default values:
* Netdevice: eth0
* Local configfile: $HOME/.conkyrc
* Localedir: /usr/share/locale
* Maximum netdevices: 64
* Maximum text size: 16384
* Size text buffer: 256
[1]+ Termine 1 conky ~/.conkyrc
conky -c ~/conkyhermesCode : Tout sélectionner
conky.config = {
background = true,
use_xft = true,
font = 'Liberation Sans:size=17',
xftalpha = 1,
update_interval = 0.2, -- 1.0 pour un raffraichissement par seconde
total_run_times = 0,
own_window = true,
own_window_transparent = true,
--own_window_color 000000
own_window_argb_visual = true,
--own_window_argb_value = 250,
own_window_type = 'normal',
own_window_hints = 'undecorated,below,skip_taskbar,skip_pager',
double_buffer = true,
minimum_width = 400, minimum_height = 470,
maximum_width = 400,
text_buffer_size = 2048,
draw_graph_borders = false,
alignment = 'top_right',
gap_x = 20,
gap_y = 30,
no_buffers = true,
uppercase = false,
override_utf8_locale = true,
imlib_cache_flush_interval = 60,
imlib_cache_size = 10000,
-- Taille des pointillés
stippled_borders = 5,
-- Couleurs
default_color = '#ffffff',--ffd579
default_shade_color = '#333333',
default_outline_color = 'black',
conky.text = [[
${scroll 16 Bonjour Hermes Comment ça va ? Loutch }
