vu le résultat de ton dmesg, c'est pas ton disque dur qu'il faut vérifier mais plutôt ton support DVD ou clé.xunil2003 a écrit : ↑mar. 21 mai 2019 22:31Re,
J'ai constaté quand je suis sur lm en live via le dvd bootable, dmesg marque des fail
Extrait dmesgCode : Tout sélectionner
[ 735.557033] sd 5:0:0:0: [sdc] Attached SCSI removable disk [ 736.992805] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 744.769866] FAT-fs (sdb1): Directory bread(block 3122144) failed [ 744.769870] FAT-fs (sdb1): Directory bread(block 3122145) failed [ 744.769871] FAT-fs (sdb1): Directory bread(block 3122146) failed [ 744.769873] FAT-fs (sdb1): Directory bread(block 3122147) failed [ 744.769874] FAT-fs (sdb1): Directory bread(block 3122148) failed [ 744.769875] FAT-fs (sdb1): Directory bread(block 3122149) failed [ 744.769877] FAT-fs (sdb1): Directory bread(block 3122150) failed [ 744.769878] FAT-fs (sdb1): Directory bread(block 3122151) failed [ 744.769879] FAT-fs (sdb1): Directory bread(block 3122152) failed [ 744.769880] FAT-fs (sdb1): Directory bread(block 3122153) failed [ 751.816640] fat__get_entry: 22 callbacks suppressed [ 751.816646] FAT-fs (sdb1): Directory bread(block 3122144) failed [ 751.816650] FAT-fs (sdb1): Directory bread(block 3122145) failed [ 751.816653] FAT-fs (sdb1): Directory bread(block 3122146) failed [ 751.816656] FAT-fs (sdb1): Directory bread(block 3122147) failed [ 751.816659] FAT-fs (sdb1): Directory bread(block 3122148) failed [ 751.816661] FAT-fs (sdb1): Directory bread(block 3122149) failed [ 751.816664] FAT-fs (sdb1): Directory bread(block 3122150) failed [ 751.816667] FAT-fs (sdb1): Directory bread(block 3122151) failed [ 751.816670] FAT-fs (sdb1): Directory bread(block 3122152) failed [ 751.816672] FAT-fs (sdb1): Directory bread(block 3122153) failed [ 765.263869] fat__get_entry: 22 callbacks suppressed [ 765.263875] FAT-fs (sdb1): Directory bread(block 3122144) failed [ 765.263879] FAT-fs (sdb1): Directory bread(block 3122145) failed [ 765.263882] FAT-fs (sdb1): Directory bread(block 3122146) failed [ 765.263885] FAT-fs (sdb1): Directory bread(block 3122147) failed [ 765.263888] FAT-fs (sdb1): Directory bread(block 3122148) failed [ 765.263891] FAT-fs (sdb1): Directory bread(block 3122149) failed [ 765.263893] FAT-fs (sdb1): Directory bread(block 3122150) failed [ 765.263896] FAT-fs (sdb1): Directory bread(block 3122151) failed [ 765.263899] FAT-fs (sdb1): Directory bread(block 3122152) failed [ 765.263902] FAT-fs (sdb1): Directory bread(block 3122153) failed [ 774.592909] FAT-fs (sdb1): unable to read boot sector to mark fs as dirty
Ou as tu téléchargé tes isos ? Sur le site officiel ?
