je ferais des recherches demain, n'ayant pas ton matos c'est pas évident.
[RÉSOLU] soucis de résolution écran
Re: soucis de résolution écran
- Dr-Weedm@n
voili voilà voilou :
encore merci, bonne nuit...
dr-weedmn@drweedmn-System-Product-Name ~ $ sudo get-edid | parse-edid
[sudo] password for dr-weedmn:
This is read-edid version 3.0.1. Prepare for some fun.
Attempting to use i2c interface
No EDID on bus 1
No EDID on bus 2
No EDID on bus 3
No EDID on bus 4
1 potential busses found: 0
Bus 0 doesn't really have an EDID...
Couldn't find an accessible EDID on this computer.
Attempting to use the classical VBE interface
Performing real mode VBE call
Interrupt 0x10 ax=0x4f00 bx=0x0 cx=0x0
Function supported
Call successful
VBE version 300
VBE string at 0x11100 "NVIDIA"
VBE/DDC service about to be called
Report DDC capabilities
Interrupt 0x10 ax=0x4f15 bx=0x0 cx=0x0
Function supported
Call successful
Monitor and video card combination does not support DDC1 transfers
Monitor and video card combination does not support DDC2 transfers
0 seconds per 128 byte EDID block transfer
Screen is not blanked during DDC transfer
Reading next EDID block
Read EDID
Interrupt 0x10 ax=0x4f15 bx=0x1 cx=0x0
Function supported
Call failed
The EDID data should not be trusted as the VBE call failed
Error: output block unchanged
I'm sorry nothing was successful. Maybe try some other arguments
if you played with them, or send an email to Matthew Kern <pyrophobicman@gmail.com>.
Partial Read... Try again-Linux Mint 19.1 Cinnamon
-noyau linux 4.15.0-50-generic
-cinnamon 4.0.10
-laptop acer Chromebook cp5-471
-processeur Intel© Celeron© CPU 3855U @ 1.60GHz × 2
-ram 4go
-CG : Intel Corporation HD Graphics 510
-cinnamon 4.0.10
-ram 4go
tu as vraiment un souci de reconnaissance de ton écran, on va essayer de trouver une soluce mais pas simple.
voila ce que devrait donner un retour de commande.
donnes moi le retour de cette commande, --> xrandr
tu pourrais changer de noyau, quand tout fonctionne bien on ne touche pas au noyau en principe, Vu qu'il s'agit d'un problème matériel le changement de noyau pourrait régler ton problème. (j'emploie le 4.2.0-30 jusque maintenant pas de souci.)
aller dans gestionnaire de mises à jour --> vue --> noyau --> prendre le dernier 4.2.0-30 faire installer le noyau
une fois installé rebooter et bien choisir le 4.2.0 au démarrage.
- L5d
Est-ce que ton écran est celui-là ? http://www.lcd-compare.com/moniteur-SAM ... on-94V.htm
Si oui, les infos données par mpat sont un peu trop optimistes (BP maxi 140 Mhz, pas 160) et résolution maxi 1280*1024, pas 1680*1050_75 ...
par contre sa méthode de recherche de solutions est la bonne, je dirais même excellente
il est trop fort.
Si ce n'est pas cet écran, peux-tu nous donner un peu plus de précisions sur le modèle que "samtron 19" mis en page 1
Mon micro de Bureau :
- Dr-Weedm@n
il sagit bien de cet écran...je n'attendais pas plus que 1280x1024 qui serait largement mieux que 1024x768.
Petite info supplémentaire , j'ai également installé steam os et la résolution est également bloqué à 1024x768.
-cinnamon 4.0.10
-ram 4go
-cinnamon 4.0.10
-ram 4go
oui il est mal reconnu.
puis arandr dans un terminal colle ça ici.
chez moi vu qu'il s'agit d'un portable ça donne ceci. ce qui ne me plaît pas dans ton rapport edid
Surveiller et la combinaison de la carte vidéo ne prend pas en charge les transferts de DDC1
Surveiller et la combinaison de la carte vidéo ne prend pas en charge les transferts de DDC2
0 secondes par transfert de blocs de 128 octets EDID
L'écran est pas masqué pendant le transfert DDC
Lecture prochain bloc EDID
VBE / DDC services sur le point d'être appelé
Lire EDID
Exécution en mode réel VBE appel
Interrompre 0x10 ax = 0x4f15 bx = 0x1 cx = 0x0
Fonction prise en charge
Échec de l'appel
sudo apt-get install arandrchez moi vu qu'il s'agit d'un portable ça donne ceci. ce qui ne me plaît pas dans ton rapport edid
Lire EDID
Échec de l'appel
- L5d
Dr-Weedm@n, puisque tu confirmes que ton écran est la même référence que celle de mon lien, les infos intéressantes de cette description sont :
Mpat, si tu peux revoir l'un de tes posts 1 ou 2 pages avant, avec ces données là, ça fonctionnera peut-être mieux pour Dr-Weedm@nSynch. Vert. Analogique :
Mini : 56 Hz / Maxi : 75 Hz
Synch. Hor. Analogique :
Mini : 30 kHz / Maxi : 81 kHz
BP Vidéo Analogique :
140 MHz
Oui L5d, j'ai déjà préparer le fichier, il est vrai que j'ai vu grand dans les résolutions, le souci il n'est pas bien reconnu par edid, j'attend le résultat de la commande arandr pour voir comment est connecter cet écran.
Dr-Weedm@n
j'ai trouver ceci: ( peut-être a tester )
Attention, il arrive quelques fois que ddcprobe ne renvoie ni la résolution maximale (renvoie par exemple 1024x768 au lieu 1280x1024) ni les fréquences maximales du moniteur. Sur certains moniteurs (en général des LCDs), dans le menu hardware du moniteur, il doit y avoir une fonction Reset. En utilisant la fonction Reset du moniteur, vous devriez obtenir les nouvelles résolutions et les nouvelles fréquences. (testé sur des vieux moniteurs XIOD LCD 17 pouces).
Dr-Weedm@n
- Dr-Weedm@n
xrandr me donne :
je sais pas si ça peut aider mais dccprobe me donne :
il y a t-il une manip particulière pour effectuer un reset de mon écran? car dans le menu je ne trouve rien...
encore merci à tous de l'intérêt que vous portez à mon poste
dr-weedmn@drweedmn-System-Product-Name ~ $ xrandr
Screen 0: minimum 8 x 8, current 1024 x 768, maximum 16384 x 16384
VGA-0 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.0*+
1360x768 60.0 59.8
1152x864 60.0
800x600 72.2 60.3 56.2
680x384 60.0 59.8
640x480 59.9
512x384 60.0
400x300 72.2
320x240 60.1
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)je sais pas si ça peut aider mais dccprobe me donne :
dr-weedmn@drweedmn-System-Product-Name ~ $ sudo ddcprobe
vbe: VESA 3.0 detected.
oem: NVIDIA
vendor: NVIDIA Corporation
product: BIOS-P/N@N10678 Chip Rev
memory: 14336kb
mode: 640x400x256
mode: 640x480x256
mode: 800x600x16
mode: 800x600x256
mode: 1024x768x16
mode: 1024x768x256
mode: 1280x1024x16
mode: 1280x1024x256
mode: 320x200x64k
mode: 320x200x16m
mode: 640x480x64k
mode: 640x480x16m
mode: 800x600x64k
mode: 800x600x16m
mode: 1024x768x64k
mode: 1024x768x16m
mode: 1280x1024x64k
mode: 1280x1024x16m
edid:
edidfail
-cinnamon 4.0.10
-ram 4go
-cinnamon 4.0.10
-ram 4go
bon a lire tes rendus, ton écran ne veux pas plus de 1024 x 768, mais ta carte elle veux bien monter jusque 1280 x 1024 en 16 millions de couleur, et nous renseigne un edidfail ce qui dis bien que ton écran est mal détecté.
Pour ton reset j'ai trouvé ceci sur youtube c'est une vidéo en anglais mais easy de compréhension.
https://www.youtube.com/watch?v=DUHZyHjrIEs
ici tu as le manuel d'utilisation de ton moniteur on parle du reset en page 47.
http://www.manualslib.com/manual/145503 ... -943t.html
- Dr-Weedm@n
Il ne s'agit pas du même modèle dans la vidéo ainsi que le 2eme lien , mon menu est différent et ne trouve rien sur le reset.
j'ai trouvé la notice de mon écran mais rien sur le reset :
http://www.manualslib.com/manual/201750 ... tml#manual
-cinnamon 4.0.10
-ram 4go
-cinnamon 4.0.10
-ram 4go
