regardes d'abord dans ton home et effaces le fichier my-edid.bin.pour créer un nouveau.
sudo get-edid > my-edid.binCode : Tout sélectionner
parse-edid < my-edid.bin
[RÉSOLU] soucis de résolution écranDernier message de la page précédente :
regardes d'abord dans ton home et effaces le fichier my-edid.bin.Code : Tout sélectionner
parse-edid < my-edid.binCode : Tout sélectionner
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "samtron"
Option "DPMS"
HorizSync 30-81
VertRefresh 56-75
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Depth 1
Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480" "640x400" "640x350"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSectionCode : Tout sélectionner
dr-weedmn@drweedmn-System-Product-Name ~ $ sudo get-edid > my-edid.bin
This is read-edid version 3.0.1. Prepare for some fun.
Attempting to use i2c interface
No EDID on bus 1
No EDID on bus 2
No EDID on bus 3
No EDID on bus 4
1 potential busses found: 0
Bus 0 doesn't really have an EDID...
Couldn't find an accessible EDID on this computer.
Attempting to use the classical VBE interface
Performing real mode VBE call
Interrupt 0x10 ax=0x4f00 bx=0x0 cx=0x0
Function supported
Call successful
VBE version 300
VBE string at 0x11100 "NVIDIA"
VBE/DDC service about to be called
Report DDC capabilities
Interrupt 0x10 ax=0x4f15 bx=0x0 cx=0x0
Function supported
Call successful
Monitor and video card combination does not support DDC1 transfers
Monitor and video card combination does not support DDC2 transfers
0 seconds per 128 byte EDID block transfer
Screen is not blanked during DDC transfer
Reading next EDID block
Read EDID
Interrupt 0x10 ax=0x4f15 bx=0x1 cx=0x0
Function supported
Call failed
The EDID data should not be trusted as the VBE call failed
Error: output block unchanged
I'm sorry nothing was successful. Maybe try some other arguments
if you played with them, or send an email to Matthew Kern <pyrophobicman@gmail.com>.Code : Tout sélectionner
sudo startxCode : Tout sélectionner
Section "Device"
Identifier "NVIDIA Gforce gt730"
Driver "nvidia"
Busid "PCI:2:0:0"
Videoram 262144
Option "AddARGBVisuals" "True"
Option "AddARGBGLXVisuals" "True"
Option "UseDisplayDevice" "DFP"
Option "UseEDIDFreqs" "FALSE"
Option "ModeValidation" "NoEdidModes"
Option "NoLogo" "True"
Option "IgnoreEDIDChecksum" "CRT,DFP,TV
EndSection
Section "Monitor"
Option "DPMS"
HorizSync 30-81
VertRefresh 56-75
EndSection
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
Modeline "1816x1024@75" 218.82 1816 1848 2672 2704 1024 1043 1056 1076
EndSubSection
EndSection
