problèmes avant migration vers Mint 20
jthibaut
Message par jthibaut »
Je suis sous Mint 19.3 et je souhaiterais migrer vers la version 20.
J'ai suivi le site suivant:
https://www.numetopia.fr/comment-mettre ... 20-ulyana/
Quand exécute mintupgrade check j'ai le message suivant:
Executing 'check'. This will perform the following:
    1 - Your repositories will be switched to point to Linux Mint 20 'Ulyana' and
        any 3rd party repositories will be removed. A backup of your APT sources
        will be written to /home/jacquin/Upgrade-Backup-tricia/APT.
    2 - The upgrade will be simulated so impacted packages can be evaluated.
    Your sources will be restored to Linux Mint 19.3 'Tricia' at the end of this command.
    Do you want to continue? [y/n]: y
  + Checking your Linux Mint codename...
  + Checking your Linux Mint edition...
  + Checking your Timeshift configuration...
  + Updating cache...
Atteint :1 http://security.ubuntu.com/ubuntu bionic-security InRelease
Atteint :2 http://ppa.launchpad.net/alexlarsson/flatpak/ubuntu bionic InRelease
Atteint :3 http://archive.ubuntu.com/ubuntu bionic InRelease
Atteint :4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Atteint :5 http://dl.google.com/linux/chrome/deb stable InRelease
Réception de :6 http://ppa.launchpad.net/elmer-csc-ubuntu/elmer-csc-ppa/ubuntu bionic InRelease [15,9 kB]
Atteint :7 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Ign :8 http://packages.linuxmint.com tricia InRelease
Réception de :9 https://repo.skype.com/deb stable InRelease [4 501 B]
Atteint :10 http://archive.canonical.com/ubuntu bionic InRelease
Atteint :11 https://packages.microsoft.com/repos/ms-teams stable InRelease
Atteint :12 http://ppa.launchpad.net/gregory-hainaut/pcsx2.official.ppa/ubuntu bionic InRelease
Atteint :13 http://packages.linuxmint.com tricia Release
Atteint :14 http://ppa.launchpad.net/ppsspp/stable/ubuntu bionic InRelease
Atteint :15 http://ppa.launchpad.net/yannubuntu/boot-repair/ubuntu bionic InRelease
Err :9 https://repo.skype.com/deb stable InRelease
  Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY 1F3045A5DF7587C3
Atteint :16 https://packagecloud.io/slacktechnologies/slack/debian jessie InRelease
20,4 ko réceptionnés en 2s (10,3 ko/s)
W: Une erreur s'est produite lors du contrôle de la signature. Le dépôt n'est pas mis à jour et les fichiers d'index précédents seront utilisés. Erreur de GPG : https://repo.skype.com/deb stable InRelease : Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY 1F3045A5DF7587C3
W: Impossible de récupérer https://repo.skype.com/deb/dists/stable/InRelease  Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY 1F3045A5DF7587C3
W: Le téléchargement de quelques fichiers d'index a échoué, ils ont été ignorés, ou les anciens ont été utilisés à la place.
  + Checking your APT repositories...
!!  ERROR: The following 3rd party repositories were detected. Disable them and refresh your APT cache.
    - . stable (. stable) - repo.skype.com
    - Boot-Repair (LP-PPA-yannubuntu-boot-repair) - ppa.launchpad.net
    - Flatpak (LP-PPA-alexlarsson-flatpak) - ppa.launchpad.net
    - Google (Google LLC) - dl.google.com
    - PPSSPP - stable version (LP-PPA-ppsspp-stable) - ppa.launchpad.net
    - elmer-csc-ppa (LP-PPA-elmer-csc-ubuntu-elmer-csc-ppa) - ppa.launchpad.net
    - ms-teams stable (ms-teams stable) - packages.microsoft.com
    - official ppa for pcsx2 team (LP-PPA-gregory-hainaut-pcsx2.official.ppa) - ppa.launchpad.net
    - slack (packagecloud.io/slacktechnologies/slack) - packagecloud.io
!!  Exiting.
  + Restoring your backed up APT sources...
Comment puis-je régler le problème avec skype ?
Comment puis-je régler les problèmes après le message "!! ERROR: The following 3rd party repositories were detected. Disable them and refresh your APT cache." qui apparait en rouge dans le terminal ?
En vous remerciant par avance,
Cordialement
Thibaut
PC MSI CX61-2PC / CPU Dual Core Intel i3-4100M / Linux Mint 19.3 64 bits / Tricia base: Ubuntu 18.04 bionic / Desktop: Xfce 4.14.1 / 8 Go de RAM
Disque dur SSD Crucial model: CT500MX500SSD1 size: 465.76 GiB
Partition:
ID-1: / size: 105.23 GiB used: 14.13 GiB (13.4%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 140.24 GiB used: 34.38 GiB (24.5%) fs: ext4 dev: /dev/sda3
philosophedesetoiles
Message par philosophedesetoiles »
lu,
Desactiver les PPA.
ps : avant de te lancer fait une sauvegarde avec timeshift.
"De chacun selon ses forces, à chacun selon ses besoins."
Thinkpad L570
8Go Ram 500Go HDD
MXlinux 21.3 “Wildflower”
XFCE4
Thinkpad t520
4Go Ram 250Go HDD
Mint 20-3 Mate
jthibaut
Re: problèmes avant migration vers Mint 20
J'ai maintenant le message suivant:
Atteint :1 http://archive.canonical.com/ubuntu bionic InRelease
Atteint :2 http://archive.ubuntu.com/ubuntu bionic InRelease
Atteint :3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Atteint :4 http://security.ubuntu.com/ubuntu bionic-security InRelease
Atteint :5 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Ign :6 http://packages.linuxmint.com tricia InRelease
Atteint :7 http://packages.linuxmint.com tricia Release
  + Checking your APT packages...
    - flatpak: 1.10.1-flatpak1~bionic, should be 1.0.9-0ubuntu0.2 (from bionic-updates)
    - gir1.2-flatpak-1.0: 1.10.1-flatpak1~bionic, should be 1.0.9-0ubuntu0.2 (from bionic-updates)
    - libflatpak0: 1.10.1-flatpak1~bionic, should be 1.0.9-0ubuntu0.2 (from bionic-updates)
    - libostree-1-1: 2020.8-flatpak1.5~bionic, should be 2018.8-0ubuntu0.2 (from bionic-updates)
    - pcsx2:i386: 1:1.4.0-11, should be 1.4.0+dfsg-2 (from bionic)
    - playonlinux: 4.3.4, should be 4.2.12-1 (from bionic)
    - skypeforlinux: 8.60.0.76, should be 8.59.0.77 (from tricia)
    - xdg-desktop-portal: 1.7.2-flatpak1~bionic, should be 1.0.3-0ubuntu0.2 (from bionic-updates)
    - xdg-desktop-portal-gtk: 1.7.1-flatpak1~bionic, should be 1.0.2-0ubuntu1.1 (from bionic-updates)
!!  ERROR: The packages above have incorrect versions. They can be downgraded using 'Software Sources -> Maintenance -> Downgrade Foreign Packages'.
!!  Exiting.
Partition:
concernant les depots tiers et les paquets étrangers consulte ce lien :
https://blablalinux.be/2020/07/13/comme ... plus-sure/
Thinkpad L570
8Go Ram 500Go HDD
XFCE4
Thinkpad t520
4Go Ram 250Go HDD
Mint 20-3 Mate
La résolution est dans le retour de la commande
!!  Exiting.
D'une façon générale, on déconseille sans cesse les ppa, maintenant du comprends pourquoi....
