bonus du matin, pour installer tous les trucs kf5, j'ai utilisé cette commande(méthode de bourrin comme prévenu
dpkg -l | grep kf5 | awk '{print $2}' | xargs -n1 sudo aptitude installDernier message de la page précédente :
bonus du matin, pour installer tous les trucs kf5, j'ai utilisé cette commandeCode : Tout sélectionner
dpkg -l | grep kf5 | awk '{print $2}' | xargs -n1 sudo aptitude installCode : Tout sélectionner
joffrey@joffrey-bureau:~/KmyMoneyGit/build/bin$ ./kmymoney
Model for "ST" loaded with 4 items in 0 ms
WebConnect: Try to connect to WebConnect server
WebConnect: Connect to server failed
WebConnect: Starting server failed. Try to remove stale socket.
WebConnect: Running in server mode
System icon theme as reported by QT: "oxygen-mix-1.4"
App icon theme as configured in KMyMoney: "system"
Obeying the system-wide icon theme, currently set to: "oxygen-mix-1.4"
Icon theme "oxygen-mix-1.4" not found.
Model for "T" loaded with 1 items in 0 ms
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/gncimporter.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/kcm_csvimporter.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/qifexporter.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/onlinejoboutboxview.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/budgetview.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/csvimporter.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/konlinetasks_sepa.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/kcm_qif.so" Validity false
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/qifimporter.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/kcm_checkprinting.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/kcm_forecastview.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/csvexporter.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/checkprinting.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/reconciliationreport.so" Validity true
Located plugin "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/forecastview.so" Validity true
Loading "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/budgetview.so"
Plugins: budgetview loaded
Loading "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/checkprinting.so"
Plugins: checkprinting loaded
Template successfully opened from "/usr/share/checkprinting/check_template.html"
Loading "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/csvexporter.so"
Plugins: csvexporter loaded
Loading "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/csvimporter.so"
Plugins: csvimporter loaded
Loading "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/forecastview.so"
Plugins: forecastview loaded
Loading "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/gncimporter.so"
Plugins: gncimporter loaded
Loading "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/onlinejoboutboxview.so"
Plugins: onlinejoboutboxview loaded
Loading "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/qifexporter.so"
Plugins: qifexporter loaded
Loading "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/qifimporter.so"
Plugins: qifimporter loaded
Loading "/usr/lib/x86_64-linux-gnu/qt5/plugins/kmymoney/reconciliationreport.so"
Plugins: reconciliation report loaded
Erreur de segmentation (core dumped)
Determining if the include file windows.h exists failed with the following output:
Change Dir: /home/joffrey/KmyMoneyGit/build/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/make cmTC_ff6d3/fast && /usr/bin/make -f CMakeFiles/cmTC_ff6d3.dir/build.make CMakeFiles/cmTC_ff6d3.dir/build
make[1] : on entre dans le répertoire « /home/joffrey/KmyMoneyGit/build/CMakeFiles/CMakeTmp »
Building CXX object CMakeFiles/cmTC_ff6d3.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -D_BSD_SOURCE -D_XOPEN_SOURCE=500 -std=c++14 -o CMakeFiles/cmTC_ff6d3.dir/CheckIncludeFile.cxx.o -c /home/joffrey/KmyMoneyGit/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
/home/joffrey/KmyMoneyGit/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx:1:10: fatal error: windows.h: Aucun fichier ou dossier de ce type
1 | #include <windows.h>
compilation terminated.
make[1]: *** [CMakeFiles/cmTC_ff6d3.dir/build.make:66 : CMakeFiles/cmTC_ff6d3.dir/CheckIncludeFile.cxx.o] Erreur 1
make[1] : on quitte le répertoire « /home/joffrey/KmyMoneyGit/build/CMakeFiles/CMakeTmp »
make: *** [Makefile:121 : cmTC_ff6d3/fast] Erreur 2
Determining if the include file lmcons.h exists failed with the following output:
Run Build Command(s):/usr/bin/make cmTC_d5f58/fast && /usr/bin/make -f CMakeFiles/cmTC_d5f58.dir/build.make CMakeFiles/cmTC_d5f58.dir/build
Building CXX object CMakeFiles/cmTC_d5f58.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -D_BSD_SOURCE -D_XOPEN_SOURCE=500 -std=c++14 -o CMakeFiles/cmTC_d5f58.dir/CheckIncludeFile.cxx.o -c /home/joffrey/KmyMoneyGit/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
/home/joffrey/KmyMoneyGit/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx:1:10: fatal error: lmcons.h: Aucun fichier ou dossier de ce type
1 | #include <lmcons.h>
make[1]: *** [CMakeFiles/cmTC_d5f58.dir/build.make:66 : CMakeFiles/cmTC_d5f58.dir/CheckIncludeFile.cxx.o] Erreur 1
make: *** [Makefile:121 : cmTC_d5f58/fast] Erreur 2
Determining if the include file process.h exists failed with the following output:
Run Build Command(s):/usr/bin/make cmTC_a4149/fast && /usr/bin/make -f CMakeFiles/cmTC_a4149.dir/build.make CMakeFiles/cmTC_a4149.dir/build
Building CXX object CMakeFiles/cmTC_a4149.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -D_BSD_SOURCE -D_XOPEN_SOURCE=500 -std=c++14 -o CMakeFiles/cmTC_a4149.dir/CheckIncludeFile.cxx.o -c /home/joffrey/KmyMoneyGit/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
/home/joffrey/KmyMoneyGit/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx:1:10: fatal error: process.h: Aucun fichier ou dossier de ce type
1 | #include <process.h>
make[1]: *** [CMakeFiles/cmTC_a4149.dir/build.make:66 : CMakeFiles/cmTC_a4149.dir/CheckIncludeFile.cxx.o] Erreur 1
make: *** [Makefile:121 : cmTC_a4149/fast] Erreur 2
