La deuxième commande ( pour le disque " / " ) :Code : Tout sélectionner
mint@mint:~$ sudo smartctl -a /dev/sda6
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.0-74-generic] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Toshiba 2.5" HDD MK..65GSX
Device Model: TOSHIBA MK6465GSXN
Serial Number: Y0UJS0LOS
LU WWN Device Id: 5 000039 2e5f0a0d2
Firmware Version: GH101M
User Capacity: 640 135 028 736 bytes [640 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5400 rpm
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Sep 4 09:33:24 2021 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 120) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 200) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 1975
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 6904
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 9
7 Seek_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 086 086 000 Old_age Always - 5601
10 Spin_Retry_Count 0x0033 237 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 6884
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 21
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 65562
193 Load_Cycle_Count 0x0032 088 088 000 Old_age Always - 123985
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 30 (Min/Max 14/48)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 8
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 5
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 5
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 117
222 Loaded_Hours 0x0032 089 089 000 Old_age Always - 4590
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 335
240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
SMART Error Log Version: 1
ATA Error Count: 529 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 529 occurred at disk power-on lifetime: 5601 hours (233 days + 9 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 41 62 2a a1 8e 6d Error: UNC at LBA = 0x0d8ea12a = 227451178
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 08 60 28 a1 8e 40 00 01:05:47.037 READ FPDMA QUEUED
ef 10 03 00 00 00 a0 00 01:05:47.037 SET FEATURES [Enable SATA feature]
ef 10 02 00 00 00 a0 00 01:05:47.037 SET FEATURES [Enable SATA feature]
27 00 00 00 00 00 e0 00 01:05:47.036 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 a0 00 01:05:47.035 IDENTIFY DEVICE
Error 528 occurred at disk power-on lifetime: 5601 hours (233 days + 9 hours)
40 41 5a 2a a1 8e 6d Error: UNC at LBA = 0x0d8ea12a = 227451178
60 08 58 28 a1 8e 40 00 01:05:42.612 READ FPDMA QUEUED
60 08 50 20 a1 8e 40 00 01:05:42.612 READ FPDMA QUEUED
60 08 48 18 a1 8e 40 00 01:05:42.612 READ FPDMA QUEUED
60 08 40 10 a1 8e 40 00 01:05:42.611 READ FPDMA QUEUED
60 08 38 08 a1 8e 40 00 01:05:42.611 READ FPDMA QUEUED
Error 527 occurred at disk power-on lifetime: 5601 hours (233 days + 9 hours)
40 41 b2 a3 a0 8e 6d Error: UNC at LBA = 0x0d8ea0a3 = 227451043
60 08 b0 a0 a0 8e 40 00 01:04:57.170 READ FPDMA QUEUED
61 08 90 98 a0 8e 40 00 01:04:57.170 WRITE FPDMA QUEUED
ef 10 03 00 00 00 a0 00 01:04:57.170 SET FEATURES [Enable SATA feature]
ef 10 02 00 00 00 a0 00 01:04:57.170 SET FEATURES [Enable SATA feature]
27 00 00 00 00 00 e0 00 01:04:57.170 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 526 occurred at disk power-on lifetime: 5601 hours (233 days + 9 hours)
40 41 ba a3 a0 8e 6d Error: UNC at LBA = 0x0d8ea0a3 = 227451043
60 08 b8 a0 a0 8e 40 00 01:04:47.399 READ FPDMA QUEUED
60 08 b0 70 a0 4a 40 00 01:04:37.672 READ FPDMA QUEUED
60 08 a8 00 a0 4a 40 00 01:04:37.657 READ FPDMA QUEUED
60 08 a0 00 a0 0a 40 00 01:04:37.642 READ FPDMA QUEUED
60 08 98 08 a0 ca 40 00 01:04:37.642 READ FPDMA QUEUED
Error 525 occurred at disk power-on lifetime: 5601 hours (233 days + 9 hours)
40 41 7a 9f a0 8e 6d Error: UNC at LBA = 0x0d8ea09f = 227451039
60 08 78 98 a0 8e 40 00 01:04:07.326 READ FPDMA QUEUED
ef 10 03 00 00 00 a0 00 01:04:07.325 SET FEATURES [Enable SATA feature]
ef 10 02 00 00 00 a0 00 01:04:07.325 SET FEATURES [Enable SATA feature]
27 00 00 00 00 00 e0 00 01:04:07.325 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 a0 00 01:04:07.324 IDENTIFY DEVICE
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
mint@mint:~$
