Bien sûr comme pour tous les servicesCode : Tout sélectionner
sudo systemctl restart NOM-DU-SERVICE.serviceCode : Tout sélectionner
sudo systemctl restart bluetooth.serviceDernier message de la page précédente :
sudo systemctl restart bluetooth.serviceCode : Tout sélectionner
sudo dmesg | grep -i bluetooth; sudo dmesg | grep -i firmware;Code : Tout sélectionner
uname -aCode : Tout sélectionner
mumu@MyXps:~$ sudo dmesg | grep -i bluetooth; sudo dmesg | grep -i firmware;
[sudo] Mot de passe de mumu :
[ 5.310518] Bluetooth: Core ver 2.22
[ 5.310543] Bluetooth: HCI device and connection manager initialized
[ 5.310547] Bluetooth: HCI socket layer initialized
[ 5.310549] Bluetooth: L2CAP socket layer initialized
[ 5.310552] Bluetooth: SCO socket layer initialized
[ 5.647558] Bluetooth: hci0: BCM: chip id 63
[ 5.648553] Bluetooth: hci0: BCM: features 0x07
[ 5.665561] Bluetooth: hci0: BCM20702A
[ 5.666555] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[ 5.667002] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0a5c-216f.hcd failed with error -2
[ 5.667006] Bluetooth: hci0: BCM: Patch brcm/BCM20702A1-0a5c-216f.hcd not found
[ 7.207282] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.207284] Bluetooth: BNEP filters: protocol multicast
[ 7.207288] Bluetooth: BNEP socket layer initialized
[ 9.629518] Bluetooth: RFCOMM TTY layer initialized
[ 9.629527] Bluetooth: RFCOMM socket layer initialized
[ 9.629534] Bluetooth: RFCOMM ver 1.11
[ 7803.512559] Bluetooth: hci0: BCM: chip id 63
[ 7803.513528] Bluetooth: hci0: BCM: features 0x07
[ 7803.529565] Bluetooth: hci0: MyXps
[ 7803.530500] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[ 7803.530521] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0a5c-216f.hcd failed with error -2
[ 7803.530523] Bluetooth: hci0: BCM: Patch brcm/BCM20702A1-0a5c-216f.hcd not found
[ 0.000000] [Firmware Bug]: TPM Final Events table missing or invalid
[ 0.124628] Spectre V2 : Enabling Restricted Speculation for firmware calls
mumu@MyXps:~$ uname -a
Linux MyXps 5.4.0-81-generic #91-Ubuntu SMP Thu Jul 15 19:09:17 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
wget https://github.com/winterheart/broadcom-bt-firmware/blob/master/brcm/BCM20702A1-0a5c-216f.hcd
sudo cp BCM20702A1-0a5c-216f.hcd /lib/firmware/brcmCode : Tout sélectionner
[ 5.182017] Bluetooth: Core ver 2.22
[ 5.182047] Bluetooth: HCI device and connection manager initialized
[ 5.182050] Bluetooth: HCI socket layer initialized
[ 5.182053] Bluetooth: L2CAP socket layer initialized
[ 5.182057] Bluetooth: SCO socket layer initialized
[ 5.478377] Bluetooth: hci0: BCM: chip id 63
[ 5.479377] Bluetooth: hci0: BCM: features 0x07
[ 5.495381] Bluetooth: hci0: MyXps
[ 5.496375] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[ 5.496901] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0a5c-216f.hcd failed with error -2
[ 5.496905] Bluetooth: hci0: BCM: Patch brcm/BCM20702A1-0a5c-216f.hcd not found
[ 6.739031] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.739033] Bluetooth: BNEP filters: protocol multicast
[ 6.739037] Bluetooth: BNEP socket layer initialized
[ 9.048610] Bluetooth: RFCOMM TTY layer initialized
[ 9.048616] Bluetooth: RFCOMM socket layer initialized
[ 9.048623] Bluetooth: RFCOMM ver 1.11
[ 2907.278283] Bluetooth: hci0: BCM: chip id 63
[ 2907.279293] Bluetooth: hci0: BCM: features 0x07
[ 2907.295308] Bluetooth: hci0: BCM20702A
[ 2907.296299] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[ 2907.296336] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0a5c-216f.hcd failed with error -2
[ 2907.296338] Bluetooth: hci0: BCM: Patch brcm/BCM20702A1-0a5c-216f.hcd not found
[ 0.113947] Spectre V2 : Enabling Restricted Speculation for firmware calls
ls -l /lib/firmware/brcm/Code : Tout sélectionner
mumu@MyXps:~$ ls -l /lib/firmware/brcm/
total 16760
-rw-r--r-- 1 root root 54734 août 2 17:41 BCM-0bb4-0306.hcd
-rw-r--r-- 1 root root 269595 août 2 17:41 bcm4329-fullmac-4.bin
-rw-r--r-- 1 root root 96224 août 2 17:41 bcm43xx-0.fw
-rw-r--r-- 1 root root 180 août 2 17:41 bcm43xx_hdr-0.fw
-rw-r--r-- 1 root root 29618 oct. 11 2020 BCM.hcd
-rw-r--r-- 1 root root 397312 août 2 17:41 brcmfmac43143.bin
-rw-r--r-- 1 root root 385067 août 2 17:41 brcmfmac43143-sdio.bin
-rw-r--r-- 1 root root 348160 août 2 17:41 brcmfmac43236b.bin
-rw-r--r-- 1 root root 455745 août 2 17:41 brcmfmac43241b0-sdio.bin
-rw-r--r-- 1 root root 403855 août 2 17:41 brcmfmac43241b4-sdio.bin
-rw-r--r-- 1 root root 408682 août 2 17:41 brcmfmac43241b5-sdio.bin
-rw-r--r-- 1 root root 479232 août 2 17:41 brcmfmac43242a.bin
-rw-r--r-- 1 root root 253748 août 2 17:41 brcmfmac4329-sdio.bin
-rw-r--r-- 1 root root 222126 août 2 17:41 brcmfmac4330-sdio.bin
-rw-r--r-- 1 root root 1509 août 2 17:41 brcmfmac4330-sdio.Prowise-PT301.txt
-rw-r--r-- 1 root root 400864 août 2 17:41 brcmfmac43340-sdio.bin
-rw-r--r-- 1 root root 1693 août 2 17:41 brcmfmac43340-sdio.meegopad-t08.txt
-rw-r--r-- 1 root root 1724 août 2 17:41 brcmfmac43340-sdio.pov-tab-p1006w-data.txt
-rw-r--r-- 1 root root 451566 août 2 17:41 brcmfmac4334-sdio.bin
-rw-r--r-- 1 root root 569291 août 2 17:41 brcmfmac4335-sdio.bin
-rw-r--r-- 1 root root 202107 août 2 17:41 brcmfmac43362-sdio.bin
-rw-r--r-- 1 root root 803 août 2 17:41 brcmfmac43362-sdio.cubietech,cubietruck.txt
lrwxrwxrwx 1 root root 43 août 2 17:41 brcmfmac43362-sdio.lemaker,bananapro.txt -> brcmfmac43362-sdio.cubietech,cubietruck.txt
-rw-r--r-- 1 root root 562183 août 2 17:41 brcmfmac4339-sdio.bin
-rw-r--r-- 1 root root 382455 août 2 17:41 brcmfmac43430a0-sdio.bin
-rw-r--r-- 1 root root 951 août 2 17:41 brcmfmac43430a0-sdio.jumper-ezpad-mini3.txt
-rw-r--r-- 1 root root 989 août 2 17:41 'brcmfmac43430a0-sdio.ONDA-V80 PLUS.txt'
-rw-r--r-- 1 root root 875 août 2 17:41 brcmfmac43430-sdio.AP6212.txt
-rw-r--r-- 1 root root 388739 août 2 17:41 brcmfmac43430-sdio.bin
-rw-r--r-- 1 root root 928 août 2 17:41 brcmfmac43430-sdio.Hampoo-D2D3_Vi8A1.txt
-rw-r--r-- 1 root root 831 août 2 17:41 brcmfmac43430-sdio.MUR1DX.txt
-rw-r--r-- 1 root root 874 août 2 17:41 brcmfmac43430-sdio.raspberrypi,3-model-b.txt
-rw-r--r-- 1 root root 488193 août 2 17:41 brcmfmac43455-sdio.bin
-rw-r--r-- 1 root root 2510 août 2 17:41 'brcmfmac43455-sdio.MINIX-NEO Z83-4.txt'
-rw-r--r-- 1 root root 1864 août 2 17:41 brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt
-rw-r--r-- 1 root root 1863 août 2 17:41 brcmfmac43455-sdio.raspberrypi,4-model-b.txt
-rw-r--r-- 1 root root 623304 août 2 17:41 brcmfmac4350c2-pcie.bin
-rw-r--r-- 1 root root 626140 août 2 17:41 brcmfmac4350-pcie.bin
-rw-r--r-- 1 root root 605388 août 2 17:41 brcmfmac4354-sdio.bin
-rw-r--r-- 1 root root 557056 août 2 17:41 brcmfmac43569.bin
-rw-r--r-- 1 root root 648770 août 2 17:41 brcmfmac4356-pcie.bin
-rw-r--r-- 1 root root 2515 août 2 17:41 brcmfmac4356-pcie.gpd-win-pocket.txt
-rw-r--r-- 1 root root 526383 août 2 17:41 brcmfmac4356-sdio.bin
-rw-r--r-- 1 root root 550333 août 2 17:41 brcmfmac43570-pcie.bin
-rw-r--r-- 1 root root 633817 août 2 17:41 brcmfmac4358-pcie.bin
-rw-r--r-- 1 root root 595472 août 2 17:41 brcmfmac43602-pcie.ap.bin
-rw-r--r-- 1 root root 635449 août 2 17:41 brcmfmac43602-pcie.bin
-rw-r--r-- 1 root root 1105361 août 2 17:41 brcmfmac4366b-pcie.bin
-rw-r--r-- 1 root root 1120971 août 2 17:41 brcmfmac4366c-pcie.bin
-rw-r--r-- 1 root root 623448 août 2 17:41 brcmfmac4371-pcie.bin
-rw-r--r-- 1 root root 479232 août 2 17:41 brcmfmac4373.bin
-rw-r--r-- 1 root root 457994 août 2 17:41 brcmfmac4373-sdio.binCode : Tout sélectionner
wget https://github.com/winterheart/broadcom-bt-firmware/blob/master/brcm/BCM20702A1-0a5c-216f.hcd[
ls -l /lib/firmware/brcm | grep BCM20702A1
