newman@newman-HP-ProBook-450-G2:~/Nord-Manager$ ./install.sh
[sudo] Mot de passe de newman :
gir1.2-appindicator3-0.1 est déjà la version la plus récente (12.10.1+20.04.20200408.1-0ubuntu1).
Installation completed, please read the readme file to know more
newman@newman-HP-ProBook-450-G2:~/Nord-Manager$ ./app/nordmanager.py
== Please check your internet connection and try again.
timing:3
./app/nordmanager.py:63: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: https://wiki.gnome.org/PyGObject/InitializerDeprecations
self.item_browse = Gtk.MenuItem("Browse...")
./app/nordmanager.py:64: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: https://wiki.gnome.org/PyGObject/InitializerDeprecations
self.item_1 = Gtk.MenuItem(data["it1n"])
./app/nordmanager.py:65: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: https://wiki.gnome.org/PyGObject/InitializerDeprecations
self.item_2 = Gtk.MenuItem(data["it2n"])
./app/nordmanager.py:66: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: https://wiki.gnome.org/PyGObject/InitializerDeprecations
self.item_3 = Gtk.MenuItem(data["it3n"])
./app/nordmanager.py:67: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: https://wiki.gnome.org/PyGObject/InitializerDeprecations
self.item_4 = Gtk.MenuItem(data["it4n"])
./app/nordmanager.py:68: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: https://wiki.gnome.org/PyGObject/InitializerDeprecations
self.item_5 = Gtk.MenuItem(data["it5n"])
./app/nordmanager.py:69: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: https://wiki.gnome.org/PyGObject/InitializerDeprecations
self.item_6 = Gtk.MenuItem(data["it6n"])
./app/nordmanager.py:72: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: https://wiki.gnome.org/PyGObject/InitializerDeprecations
item_stop = Gtk.ImageMenuItem('Close VPN connection')
./app/nordmanager.py:73: DeprecationWarning: Gtk.ImageMenuItem.set_image is deprecated
item_stop.set_image(Gtk.Image.new_from_icon_name("network-offline", Gtk.IconSize(5)))
./app/nordmanager.py:76: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: https://wiki.gnome.org/PyGObject/InitializerDeprecations
item_settings = gtk.ImageMenuItem('Settings')
./app/nordmanager.py:80: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: https://wiki.gnome.org/PyGObject/InitializerDeprecations
item_quit = Gtk.ImageMenuItem('Quit')
timer !!
['\n', '-\n', ' \n', 'Please check your internet connection and try again.\n']
green_word : connected
disconnected
transmission-gtk: aucun processus trouvé
timer !!
disconnected
timer !!
disconnected
timer !!
disconnected
etc. etc. (ça boucle).
Par contre j’ai bien l’icone de nord-Manager dans la « barre des tâches » et un clic-droit ouvre le menu… mais si je kill la boucle ci-dessus l’icone disparaît.
Je crois que c’est le même problème de connection qu’avant cette GUI.
J’ai reçu la réponse du support technique de NordVPN mais c’est inexploitable je pense puisqu’ils me demandent d’être connecté sous le VPN avant d’aller sur leur test (lien ci-dessous) alors que mon probleme est justement de me connecter via vpn !
https://dnsleaktest.com/
Merci de ton attention. Je crois malheureusement que tant que j'aurais un partage de connection au lieu d'une box, le problème subsiste.
