Résolu le 12-02-23 Ordre de boot grub 2.04 dual boot LM 20.3 et LMDE 5
TéMentheOuPas
Message par TéMentheOuPas »
J'ai un soucis de paramètrage de grub 2.04 en dual boot LM 20.3 et LMDE 5.
J'aimerai pouvoir selctionner automatiquement la ligne LMDE 5 par default au lieu de LM 20.3
J'ai fait diverses commande ci dessous, sans succès.
jerome@a660:~$ grep menuentry /boot/grub/grub.cfg
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
  menuentry_id_option=""
export menuentry_id_option
menuentry 'LMDE 5 Elsie' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-7e12660b-f0d5-4c85-9d67-a687e5fdfb7d' {
submenu 'Advanced options for LMDE 5 Elsie' $menuentry_id_option 'gnulinux-advanced-7e12660b-f0d5-4c85-9d67-a687e5fdfb7d' {
	menuentry 'LMDE 5 Elsie, with Linux 5.10.0-21-amd64' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.10.0-21-amd64-advanced-7e12660b-f0d5-4c85-9d67-a687e5fdfb7d' {
	menuentry 'LMDE 5 Elsie, with Linux 5.10.0-21-amd64 (recovery mode)' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.10.0-21-amd64-recovery-7e12660b-f0d5-4c85-9d67-a687e5fdfb7d' {
	menuentry 'LMDE 5 Elsie, with Linux 5.10.0-12-amd64' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.10.0-12-amd64-advanced-7e12660b-f0d5-4c85-9d67-a687e5fdfb7d' {
	menuentry 'LMDE 5 Elsie, with Linux 5.10.0-12-amd64 (recovery mode)' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.10.0-12-amd64-recovery-7e12660b-f0d5-4c85-9d67-a687e5fdfb7d' {
menuentry 'Linux Mint 20.3 Una (20.3) (on /dev/sda5)' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-e92656de-1a8b-40c6-8406-dc97ea2f6515' {
submenu 'Advanced options for Linux Mint 20.3 Una (20.3) (on /dev/sda5)' $menuentry_id_option 'osprober-gnulinux-advanced-e92656de-1a8b-40c6-8406-dc97ea2f6515' {
	menuentry 'Linux Mint 20.3 Cinnamon (on /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.4.0-91-generic--e92656de-1a8b-40c6-8406-dc97ea2f6515' {
	menuentry 'Linux Mint 20.3 Cinnamon, avec Linux 5.4.0-91-generic (on /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.4.0-91-generic--e92656de-1a8b-40c6-8406-dc97ea2f6515' {
	menuentry 'Linux Mint 20.3 Cinnamon, avec Linux 5.4.0-91-generic (recovery mode) (on /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.4.0-91-generic-root=UUID=e92656de-1a8b-40c6-8406-dc97ea2f6515 ro recovery nomodeset dis_ucode_ldr-e92656de-1a8b-40c6-8406-dc97ea2f6515' {
jerome@a660:~$ sudo nano /etc/default/grub
[sudo] Mot de passe de jerome :
jerome@a660:~$ sudo update-grub
Found theme: /boot/grub/themes/linuxmint/theme.txt
Found linux image: /boot/vmlinuz-5.10.0-21-amd64
Found initrd image: /boot/initrd.img-5.10.0-21-amd64
Found linux image: /boot/vmlinuz-5.10.0-12-amd64
Found initrd image: /boot/initrd.img-5.10.0-12-amd64
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
Found Linux Mint 20.3 Una (20.3) on /dev/sda5
done
J'ai même remplacer Grub default =2 au lieu de 0 et autres manipulations trouve sur le forum ou internet et j'ai également installer/essayer puis desinstaller grub customizer vu que ca ne fonctionnepasnon plus
Bref divers manipulations et essais sans succès.... Certainement un truc qui manque au fichier de configuration ou autre chose.....
GRUB_DEFAULT="gnulinux-simple-7e12660b-f0d5-4c85-9d67-a687e5fdfb7d"
GRUB_TIMEOUT="4"
GRUB_DISTRIBUTOR="`lsb_release -i -s 2> /dev/null || echo Debian`"
GRUB_CMDLINE_LINUX=""
export GRUB_COLOR_NORMAL="light-gray/black"
export GRUB_COLOR_HIGHLIGHT="magenta/black"
Pouvez vous svp me dire et m'ecrire exactement les commandes ou lignes a modifier et a saisir.
Je ne suis pas expert. ;)
Amicalement,
Toshiba satellite A660 renové
8 go Ram, ssd , 256 Go SSD, carte graphique nvidia geforce 310 M, proc x86-64 i5 M450 2.4 Ghz
Dual boot LM 20.3 cinnamon 64 bits avec LMDE 5
Re: Ordre de boot grub 2.04 dual boot LM 20.3 et LMDE 5
Il faut modifier le fichier /etc/default/grub
Le chiffre a indiquer a la ligne GRUB_DEFAULT=0 est la position (dans le grub qui apparaît au démarrage) du système que tu souhaites démarrer -1
Par exemple sur cette image pour lancer Windows qui apparaît a la 7ème ligne , il faut mettre 6 a GRUB_DEFAULT=
Et finir en passant la commande
sudo update-grub
Modifié en dernier par Jennatux le sam. 11 févr. 2023 18:29, modifié 1 fois.
Clevo
Avec partition data
Une fraction de seconde
TéMentheOuPas
J'ai déjà testé et modifié avec le chiffre 2 ( vu que lmde est en 3 ligne au démarrage de l'ordinateur avec grub).
C'est autre chose mais quoi....la est la question.
Il y a un truc qui me dérange, c'est "Warning avec os......" indiqué dans la fenêtre de code....
Désolé, autre chose à proposer svp?
Amicalement
f.x0
Message par f.x0 »
Bonjour TéMentheOuPas,
tu as essayé avec cette ligne dans /etc/default/grub ???
et ensuite tu as bien fait ???
sudo update-grub
Modifié en dernier par f.x0 le sam. 11 févr. 2023 18:43, modifié 1 fois.
SOPI
TéMentheOuPas a écrit :
sam. 11 févr. 2023 17:22
Amicalement
Bon ben si ton systeme est sur la 3ème ligne ,effectivement il faut mettre 2
Mais une fois modifié le fichier /etc/default/grub il faut mettre a jour avec
sudo update-grub
Clevo
Avec partition data
TéMentheOuPas
Oui bien sûr.
Vous pouvez le voir dans la première fenêtre de code.
Ce message affichée "warning etc..." indiqué dans la fenêtre de code est sûrement une piste...
Mais je suis bloqué d'idées.
Bonne soirée
f.x0
Message par f.x0 »
Essaies ceci alors :
ajoutes la ligne sans les guillemets dans /etc/default/grub
GRUB_DEFAULT=gnulinux-simple-7e12660b-f0d5-4c85-9d67-a687e5fdfb7d
puis postes le retour de
sudo update-grub
redémarres le PC, et dis ce que ça donne...
SOPI
TéMentheOuPas a écrit :Ce message affichée "warning etc..." indiqué dans la fenêtre de code est sûrement une piste...
Chez moi aussi
sudo update-grub
[sudo] Mot de passe de luc :
Sourcing file `/etc/default/grub.d/init-select.cfg'
Found background image: 1.jpg
Found linux image: /boot/vmlinuz-5.19.0-21-generic
Found initrd image: /boot/microcode.cpio /boot/initrd.img-5.19.0-21-generic
Found memtest86+x64 image: /boot/memtest86+x64.bin
Found Ubuntu 22.10 (22.10) on /dev/sda1
Found Deepin 20.8 (20.8) on /dev/sda3
Found Ubuntu 22.04.1 LTS (22.04) on /dev/sda6
Found Ubuntu 22.10 (22.10) on /dev/sda7
Found Ubuntu 22.04.1 LTS (22.04) on /dev/sda8
done
En français
Attention : os-prober sera exécuté pour détecter d'autres partitions amorçables.
os prober est lancé par update-grub pour rechercher les autres os et chez toi il trouve
Si la solution de f.x0 ne fonctionne pas
donne le retour de
cat /etc/default/grub
Clevo
Avec partition data
TéMentheOuPas
Avec et sans guilements, ca ne fonctionne toujours pas;
Voici ci dessous le retour de la commande "cat /etc/default/grub"
jerome@a660:~$ cat /etc/default/grub
# /boot/grub/grub.cfg.
#   info -f grub -n 'Simple configuration'
GRUB_TIMEOUT="4"
#GRUB_TERMINAL="console"
#GRUB_GFXMODE="640x480"
#GRUB_DISABLE_LINUX_UUID="true"
#GRUB_DISABLE_RECOVERY="true"
#GRUB_INIT_TUNE="480 440 1"
#GRUB_THEME="/boot/grub/themes/linuxmint/theme.txt"
Et de la commande "grep menuentry /boot/grub/grub.cfg" pour vous aidez peut etre
code apre sudo update-grub
done
jerome@a660:~$
Au demarrage de l'ordinateur et de grub, j'ai l'etoile asterix mis sur linux cinnamon 20.3 par default sur la premiere ligne.
J'aimerai avoir la troisième ligne selectionner automatiquement ( LMDE 5 ). L'essai est sans succes également avec GRUB_DEFAULT=2
C'est compliqué :x
Bonne soirée
Amicalement
Tu as installé LM 20.3 après LMDE ou l'inverse ?...
Parce que là tu modifies apparemment le grub de Lmde puisse que LM 20.3 apparaît dans les os vu par os-prober donc ce n'est pas le bon grub
As tu deja modifié un des 2 grub auparavant ?
Clevo
Avec partition data
