sources.list propre
lherbaux
sources.list propre
Message par lherbaux »
bonjour,
je suis en linux mint 21.1 mate et quand je tape :
find /etc/apt -type f -regex ".*\.\(list*\|sources\)" -exec bash -c 'echo -e "\n$1"; [[ "${1##*/}" =~ (list|sources)$ ]] && cat -n "$1"' _ '{}' \;
/etc/apt/sources.list.d/balena-etcher.list
1 # deb https://deb.etcher.io stable etcher
/etc/apt/sources.list.d/official-package-repositories.list
1 deb http://packages.linuxmint.com vanessa main upstream import backport
2
3 deb http://archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
4 deb http://archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
5 deb http://archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
6
7 deb http://security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
/etc/apt/sources.list.d/gezakovacs-ppa-focal.list
1 # deb http://ppa.launchpad.net/gezakovacs/ppa/ubuntu focal main
2 # deb-src http://ppa.launchpad.net/gezakovacs/ppa/ubuntu focal main
/etc/apt/sources.list.d/i2p-maintainers-i2p-focal.list
1 deb http://ppa.launchpad.net/i2p-maintainers/i2p/ubuntu jammy main
2 # deb-src http://ppa.launchpad.net/i2p-maintainers/i2p/ubuntu focal main
/etc/apt/sources.list.d/playonlinux.list
1 # deb http://deb.playonlinux.com/ cosmic main
1 # deb cdrom:[Linux Mint 20.3 _Una_ - Release amd64 20220104]/ focal contrib main
2
3 # This system was installed using small removable media
4 # (e.g. netinst, live or single CD). The matching "deb cdrom"
5 # entries were disabled at the end of the installation process.
6 # For information about how to configure apt package sources,
7 # see the sources.list(5) manual.
je trouve que j'ai beaucoup trop de lignes qui n'ont rien à faire. lesquels dois-je retirer ?
merci d'avance.
à bientôt.
processeur : AMD A4-4000 APU with Radeon(tm) HD Graphics × 2
mémoire : 4 go de ram
disque dur : ssd de 60 go
Version Linux Mint 20.3 Una 64-bit mate
alv37
Re: sources.list propre
Message par alv37 »
Slt, pour savoir lequel supprimer, ça sera plus à toi de le savoir par rapport au logiciel que tu utilise et ceux que tu n’utilise plus, si tu n'utilise plus certains programmes tu les supprime.
On peut voir que tu a un dépôt pour Playonlinux (qui commencent à dater) qui possède la même version qui est dans le dépot d'ubuntu donc il peut être supprimer.
Ensuite tu a un dépôt (qui date la v20.04), un pour i2p (qui à une version dispo pour la v22.04), tu peut donc soit mettre à jour le dépôt soit le supprimer si tu ne l'utilise plus.
Ensuite tu a un dépôt pour unetbootin mais tu a aussi un dépôt pour etcher, les 2 logiciels faisant pareil tu pourrais en supprimer un des 2 (voir les 2 est utiliser ventoy à la place qui fait pareil que ces 2 derniers mais avec plus de fonctions).
Et pour fini tu le dépôt CD qui à été créer lors de l'installation (en 20.3 apparemment) qui ne sert plus et tu peut donc le supprimer.
PC Principal [Dual-Boot] (Custom) : MB: MS-7823 (MSI B85M-G43) | CPU: Intel i7 4790k | RAM: 8 Go | GPU: Nvidia Geforce GTX 970
  • OS: VoidLinux | DE: Cinnamon v5.8.4 | Kernel: 6.10.3
  • OS: ArchLinux | DE: Cinnamon v6.2.7 | Kernel: 6.10.2
PC Secondaire (Custom) : OS: Linux Mint 22 | DE: Cinnamon v6.2.7 | Kernel: 6.8.0 | MB: Gigabyte GA-G31M-ES2L v2 | CPU: Intel Pentium D 915 | RAM: 4 Go | GPU: Intel 82G33/G31 Express Integrated Graphics
Ces 4 repos n'ont que des entrées en commentaires donc tu peux les virer, ça ne changera rien ;)
lherbaux
j'ai demandé un sources.list propre, pas de le supprimer
'Jour,
@lherbaux : Relis les réponses, alv37 et cyrille ne te disent pas de le supprimer, ils te disent simplement que tu peux faire du ménage et donc, t'auras un sources.list propre ;)
