# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${initrdfail}" = 2 ]; then
set initrdfail=
elif [ "${initrdfail}" = 1 ]; then
set next_entry="${prev_entry}"
set prev_entry=
save_env prev_entry
if [ "${next_entry}" ]; then
set initrdfail=2
fi
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function initrdfail {
if [ -n "${have_grubenv}" ]; then if [ -n "${partuuid}" ]; then
if [ -z "${initrdfail}" ]; then
set initrdfail=1
if [ -n "${boot_once}" ]; then
set prev_entry="${default}"
save_env prev_entry
fi
fi
save_env initrdfail
fi; fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gpt
insmod ext2
set root='hd1,gpt2'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt2 --hint-efi=hd1,gpt2 --hint-baremetal=ahci1,gpt2 c02085e9-39e8-4fc9-9216-789c01a0a4c6
else
search --no-floppy --fs-uuid --set=root c02085e9-39e8-4fc9-9216-789c01a0a4c6
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=1920x1080x8
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=fr_FR
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
set timeout=30
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=25
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 25 ; then
set timeout=0
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if [ ${grub_platform} != pc ]; then
set linux_gfx_mode=keep
elif hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry 'Linux Mint 20.3 Xfce' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-c02085e9-39e8-4fc9-9216-789c01a0a4c6' {
recordfail
savedefault
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_gpt
insmod ext2
set root='hd1,gpt2'
else
fi
linux /boot/vmlinuz-5.4.0-139-generic root=UUID=c02085e9-39e8-4fc9-9216-789c01a0a4c6 ro quiet splash
initrd /boot/initrd.img-5.4.0-139-generic
submenu 'Options avancées pour Linux Mint 20.3 Xfce' $menuentry_id_option 'gnulinux-advanced-c02085e9-39e8-4fc9-9216-789c01a0a4c6' {
menuentry 'Linux Mint 20.3 Xfce, avec Linux 5.4.0-139-generic' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-139-generic-advanced-c02085e9-39e8-4fc9-9216-789c01a0a4c6' {
recordfail
savedefault
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd1,gpt2'
else
fi
echo 'Chargement de Linux 5.4.0-139-generic…'
echo 'Chargement du disque mémoire initial…'
menuentry 'Linux Mint 20.3 Xfce, avec Linux 5.4.0-137-generic' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-137-generic-advanced-c02085e9-39e8-4fc9-9216-789c01a0a4c6' {
recordfail
savedefault
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd1,gpt2'
else
fi
echo 'Chargement de Linux 5.4.0-137-generic…'
linux /boot/vmlinuz-5.4.0-137-generic root=UUID=c02085e9-39e8-4fc9-9216-789c01a0a4c6 ro quiet splash
initrd /boot/initrd.img-5.4.0-137-generic
menuentry 'Linux Mint 20.3 Xfce, avec Linux 5.4.0-73-generic' --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-73-generic-advanced-c02085e9-39e8-4fc9-9216-789c01a0a4c6' {
recordfail
savedefault
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd1,gpt2'
else
fi
echo 'Chargement de Linux 5.4.0-73-generic…'
linux /boot/vmlinuz-5.4.0-73-generic root=UUID=c02085e9-39e8-4fc9-9216-789c01a0a4c6 ro quiet splash
initrd /boot/initrd.img-5.4.0-73-generic
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/10_linux_zfs ###
### END /etc/grub.d/10_linux_zfs ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Peppermint 10 Ten (10) (sur /dev/sda1)' --class peppermint --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-fad36cd9-704b-4083-8ad6-b90e0d7cfeb8' {
savedefault
insmod part_msdos
insmod ext2
set root='hd0,msdos1'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 fad36cd9-704b-4083-8ad6-b90e0d7cfeb8
else
search --no-floppy --fs-uuid --set=root fad36cd9-704b-4083-8ad6-b90e0d7cfeb8
fi
linux /boot/vmlinuz-5.4.0-97-generic root=UUID=fad36cd9-704b-4083-8ad6-b90e0d7cfeb8 ro quiet splash $vt_handoff
initrd /boot/initrd.img-5.4.0-97-generic
submenu 'Options avancées pour Peppermint 10 Ten (10) (sur /dev/sda1)' $menuentry_id_option 'osprober-gnulinux-advanced-fad36cd9-704b-4083-8ad6-b90e0d7cfeb8' {
menuentry 'Peppermint GNU/Linux (sur /dev/sda1)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.4.0-97-generic--fad36cd9-704b-4083-8ad6-b90e0d7cfeb8' {
savedefault
insmod part_msdos
insmod ext2
else
fi
menuentry 'Peppermint GNU/Linux, avec Linux 5.4.0-97-generic (sur /dev/sda1)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.4.0-97-generic--fad36cd9-704b-4083-8ad6-b90e0d7cfeb8' {
savedefault
insmod part_msdos
insmod ext2
else
fi
menuentry 'Peppermint GNU/Linux, avec Linux 5.4.0-97-generic (recovery mode) (sur /dev/sda1)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.4.0-97-generic-root=UUID=fad36cd9-704b-4083-8ad6-b90e0d7cfeb8 ro recovery nomodeset dis_ucode_ldr-fad36cd9-704b-4083-8ad6-b90e0d7cfeb8' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.4.0-97-generic root=UUID=fad36cd9-704b-4083-8ad6-b90e0d7cfeb8 ro recovery nomodeset dis_ucode_ldr
menuentry 'Peppermint GNU/Linux, avec Linux 5.0.0-37-generic (sur /dev/sda1)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.0.0-37-generic--fad36cd9-704b-4083-8ad6-b90e0d7cfeb8' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.0.0-37-generic root=UUID=fad36cd9-704b-4083-8ad6-b90e0d7cfeb8 ro quiet splash $vt_handoff
initrd /boot/initrd.img-5.0.0-37-generic
menuentry 'Peppermint GNU/Linux, avec Linux 5.0.0-37-generic (recovery mode) (sur /dev/sda1)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.0.0-37-generic-root=UUID=fad36cd9-704b-4083-8ad6-b90e0d7cfeb8 ro recovery nomodeset dis_ucode_ldr-fad36cd9-704b-4083-8ad6-b90e0d7cfeb8' {
savedefault
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.0.0-37-generic root=UUID=fad36cd9-704b-4083-8ad6-b90e0d7cfeb8 ro recovery nomodeset dis_ucode_ldr
set timeout_style=menu
if [ "${timeout}" = 0 ]; then
set timeout=10
fi
### BEGIN /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/35_fwupd ###
### END /etc/grub.d/35_fwupd ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
