Résolu le 25-04-23 Démarrage très long: (A start job is running for ...... (... - 1min 30s)
Dundee33
Message par Dundee33 »
Bonsoir.
Depuis que j'ai installer d'autres distributions à côté de Mint, j'ai ce problème: 'A start job is running for ...... (... - 1min 30s)' qui est rester sans solution sur ce post: viewtopic.php?p=182911#p182911
La photo prise sur le démarrage:
Voici ce que retourne la commande: systemd-analyze blame dont la question a était poser sur l'autre sujet:
remy@remy-TUF-GAMING-FX504GD-FX80GD:~$ systemd-analyze blame
30.625s postfix@-.service
20.677s udisks2.service
17.950s networkd-dispatcher.service
16.980s ModemManager.service
13.603s NetworkManager-wait-online.service
12.486s accounts-daemon.service
10.962s systemd-udev-settle.service
10.134s lightdm.service
 8.782s ubuntu-system-adjustments.service
 8.196s dev-sdb1.device
 7.268s polkit.service
 6.951s cups.service
 6.840s avahi-daemon.service
 6.837s bluetooth.service
 6.758s NetworkManager.service
 6.196s thermald.service
 6.194s systemd-logind.service
 6.191s wpa_supplicant.service
 5.367s systemd-journal-flush.service
 4.785s gpu-manager.service
 4.779s lighttpd.service
 4.146s rsyslog.service
 4.040s secureboot-db.service
 3.603s ntp.service
 2.823s e2scrub_reap.service
 2.696s systemd-modules-load.service
 2.635s dump1090-mutability.service
 2.506s upower.service
 2.357s grub-common.service
 2.076s systemd-random-seed.service
 2.044s systemd-tmpfiles-setup-dev.service
 2.025s lm-sensors.service
 1.840s nvidia-persistenced.service
 1.793s colord.service
 1.792s apparmor.service
 1.747s systemd-udevd.service
 1.698s systemd-sysusers.service
 1.425s grub-initrd-fallback.service
 1.356s systemd-fsck@dev-disk-by\x2duuid-6496\x2d933B.service
 1.319s clamav-daemon.service
 1.298s systemd-sysctl.service
 1.208s user@1000.service
 1.133s keyboard-setup.service
 1.051s mythtv-backend.service
  907ms systemd-backlight@backlight:intel_backlight.service
  901ms systemd-udev-trigger.service
  822ms ifupdown-pre.service
  814ms systemd-resolved.service
  693ms alsa-restore.service
  669ms networking.service
  602ms systemd-tmpfiles-setup.service
  577ms zfs-load-module.service
  526ms systemd-rfkill.service
  516ms setvtrgb.service
  497ms kerneloops.service
  480ms systemd-journald.service
  397ms packagekit.service
  336ms sys-kernel-tracing.mount
  335ms sys-kernel-debug.mount
  334ms dev-mqueue.mount
  332ms dev-hugepages.mount
  324ms lvm2-monitor.service
  324ms kmod-static-nodes.service
  323ms modprobe@drm.service
  322ms modprobe@configfs.service
  320ms modprobe@fuse.service
  234ms boot-efi.mount
  222ms systemd-remount-fs.service
  214ms dns-clean.service
  182ms systemd-user-sessions.service
  177ms modprobe@chromeos_pstore.service
  170ms systemd-update-utmp.service
  162ms zfs-volume-wait.service
  158ms console-setup.service
  158ms zfs-mount.service
  150ms plymouth-read-write.service
  146ms ufw.service
  140ms systemd-tmpfiles-clean.service
   92ms rtkit-daemon.service
   85ms blueman-mechanism.service
   81ms finalrd.service
   31ms user-runtime-dir@1000.service
    8ms modprobe@efi_pstore.service
    7ms modprobe@pstore_blk.service
    7ms modprobe@pstore_zone.service
    6ms modprobe@ramoops.service
    5ms sys-fs-fuse-connections.mount
    5ms openvpn.service
    5ms zfs-share.service
    5ms sys-kernel-config.mount
    3ms systemd-update-utmp-runlevel.service
    2ms plymouth-quit-wait.service
    1ms postfix.service
   33us blk-availability.service
lines 72-94/94 (END)
Merci d’avance pour votre aide.
Cordialement Rémy
Modifié en dernier par Dundee33 le mar. 25 avr. 2023 16:01, modifié 3 fois.
PC portable 'ASUS TUF Gaming F17' Processeur Intel® Core™ i7-12700H - mémoire RAM DDR5 à 4800MHz de 16 Go - carte graphique NVIDIA® GeForce RTX™ 3070 - avec Linux Mint 22 Cinnamon 64b en multi-boots sur un SSD M2 2 To.
Re: Depuis peu le démarrage est très long: (A start job is running for ...... (... - 1min 30s)
Bonjour Rémy.
Ça fait penser à la recherche d'une partition qu'il ne trouve pas.
Donne nous les retours de:
sudo blkid
et de:
cat /etc/fstab
tescan
Message par tescan »
dans le bios le "first boot device" ne pointerait pas sur autre chose que "hd"?
Dundee33
tescan a écrit : jeu. 20 avr. 2023 08:02 Bonjour,
Si comme indiqué dans la partie signature, je suis booter sur le disque dur externe qui est en USB. Ce disque est partager en trois partitions avant installation de Mint. Mint étant sur la première partition. Cette ligne est apparu du moment où j'ai installer d'autres distributions sur les autres partitions. ;) Par-contre la version de Grub qui c'est installer est celui de Lubuntu.
Merci de votre aide.
Cordialement Rémy
Dundee33
Bonsoir, ou Bonjour.
A quoi correspond cette ligne sur le démarrage ?
Pas de solution pour réduire ce conteur au minimum ? :?
Bonjour Dundee
Dundee33 a écrit : sam. 22 avr. 2023 04:16 A quoi correspond cette ligne sur le démarrage ?
J'ai répondu a cette question: viewtopic.php?p=221876#p221876
Mais tu ne semble pas avoir vu.
Pour le savoir il faut les retours que je t'ai demandé.
Dundee33
alain a écrit : sam. 22 avr. 2023 05:02 Bonjour Dundee
Ah zut. Mes excuses. Effectivement, je n'avais pas vue. :oops:
remy@remy-TUF-GAMING-FX504GD-FX80GD:~$ sudo blkid
[sudo] Mot de passe de remy :
/dev/nvme0n1p3: LABEL="OS" BLOCK_SIZE="512" UUID="3EE4986FE4982AE3" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="93697ef8-db06-47e0-9cac-f29c510ac5a0"
/dev/nvme0n1p1: LABEL_FATBOOT="SYSTEM" LABEL="SYSTEM" UUID="6496-933B" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="e28abbcd-67ce-4502-9625-fbf5b62b8ed9"
/dev/nvme0n1p4: LABEL="RECOVERY" BLOCK_SIZE="512" UUID="FE3EC35F3EC30F97" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="524ababc-40a6-4bf3-915d-a92b1bb453c4"
/dev/sdb4: UUID="e923cad4-b3d4-41a8-ac7e-5f87293c5f5e" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="Linux3" PARTUUID="54bd0e9d-9c2d-4f5d-b80f-b37845d2d69a"
/dev/sdb2: UUID="46769f93-0946-4327-a0bf-503426b54ed7" TYPE="swap" PARTLABEL="linux-swap" PARTUUID="ac38caa8-d6fa-436c-83b5-0f4f24626c02"
/dev/sdb3: UUID="221fe696-2809-475a-b451-299b4b9cb435" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="Linux2" PARTUUID="5b61c010-6632-4095-8933-2d70ff77ae4a"
/dev/sdb1: UUID="73d082f2-942f-44d4-8cb1-f4abc174a9c9" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="Linux1" PARTUUID="c20d5f69-94d3-42f8-88ec-c2e263cbe7a2"
/dev/sda1: LABEL="DATA" BLOCK_SIZE="512" UUID="2E544AA7544A719F" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="c505e170-c629-4a3b-a68a-a92b37731bf0"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="a42642a9-22f6-487f-8431-a53c7b0bfc5e"
/dev/sdb5: PARTLABEL="bios_grub" PARTUUID="27b2f154-5523-489f-9001-e678117a7a55"
remy@remy-TUF-GAMING-FX504GD-FX80GD:~$ cat /etc/fstab
# / was on /dev/sda1 during installation
UUID=73d082f2-942f-44d4-8cb1-f4abc174a9c9 /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/nvme0n1p1 during installation
UUID=6496-933B  /boot/efi       vfat    umask=0077      0       1
# swap was on /dev/sda2 during installation
UUID=215a06ce-398a-4629-8314-db3256776e8f none            swap    sw              0       0
Cordialement Rémy
Bonjour Remy.
C'est la partition swap qui a changé, il ne trouve plus celle d'avant qui n'existe plus. D'où le temps long...
Dans ton fstab, change l'UUID du swap par celle ci : 46769f93-0946-4327-a0bf-503426b54ed7
Dundee33
alain a écrit : sam. 22 avr. 2023 16:40 Bonjour Remy.
Bonsoir Alain.
Ok compris. Ça c'est quand j'ai installer les deux autres distributions à côté. D'ailleurs au démarrage c'est Grub de Lubuntu qui est à la place de celui de Mint. J'ai voulu remettre celui de Mint, mais je n'y arrive pas.
alain a écrit : sam. 22 avr. 2023 16:40 Dans ton fstab, change l'UUID du swap par celle ci : 46769f93-0946-4327-a0bf-503426b54ed7
Oui, bien-sur... :? Sauf que je ne sais pas du tout comment faire. :oops: J'ai tester autre chose. J'ai reformater en swap, puis cliquer sur Activer.
Je redémarre le PC et ....... Zut ! Toujours pareil.
Je retourne dans mon gestionnaire de partitions pour voir que le swap ne se réactive pas automatiquement. Pourtant il est là. :|
Merci de votre aide. ;)
Cordialement Rémy
Aye! du coup je ne sais pas si tu as formater la partition swap que je t'indiquais de mettre dans ton fstab.
Sinon la méthode est simple pour modifier le fstab il faut l'éditer avec les droits d'administrateur (c'est un fichier system):
sudo nano /etc/fstab
la je te propose nano parce que c'est celui que j'utilise, mais tu peux le faire avec l'éditeur que tu veux.
Tu repère la ligne :
(avec nano on utilise les flèches pour naviguer dans le fichier)
Et tu changes 215a06ce-398a-4629-8314-db3256776e8f par 46769f93-0946-4327-a0bf-503426b54ed7
Si c'est toujours l'UUID du swap après tes manipes :?
Si c'est plus ça un nouveau:
sudo blkid
Te donnera la nouvelle-nouvelle UUID du swap (dans la ligne : TYPE="swap" PARTLABEL="linux-swap").
Avant de sortir de nano, après avoir fait le changement, Tu fais crtl+o et entrer pour enregistrer tes modifications. Puis crtl+x pour fermer nano (mais cela est écris en bas de la fenêtre nano)
