BunsenLabs, ultra-léger sur base Debian
Robinwood
Message par Robinwood »
BunsenLabs Linux, à tester pour petite configuration: https://www.bunsenlabs.org/index.html" onclick="window.open(this.href);return false;
http://www.pcds.fi/downloads/iso/debian ... nlabs.html" onclick="window.open(this.href);return false;
Avec un "repository" bien foutu: https://www.bunsenlabs.org/repositories.html" onclick="window.open(this.href);return false;
BunsenLabs is a Debian Jessie desktop with custom configurations and some additions. Hence, the hardware recommendations from the Debian project apply for both 32bit and 64bit systems:
RAM (minimum) RAM (recommended) Hard Drive
256M 1G 10G
Depending on the applications and feature set you decide to use (especially if you do not run a graphical desktop), the system may run fine with less resources. An installation from the live ISOs uses approximately 2.1G of space on the hard drive.
Intel nuc8i3phn Linux mint cinnamon
Firefox Audacious
Cyrrus
Re: BunsenLabs, ultra-léger sur base Debian
Message par Cyrrus »
Hello
pour les versions i386, ça veut dire quoi "nonPAE" ? du coup je ne sais pas laquelle prendre pour essayer de raviver le vieux Fujitsu :shock:
