Résolu le 26-04-19 [résolu]Error! Bad return status for module build on kernel: 3.16.0-4-amd64 (x86_64)
Re: Error! Bad return status for module build on kernel: 3.16.0-4-amd64 (x86_64)
oui, j'ai bien « /boot/grub/grub.cfg »
diff /etc/grub.d/00_header. /etc/grub.d/00_header.old
19a20,21
> transform="s,x,x,"
21,22c23,25
< exec_prefix="/usr"
< datarootdir="/usr/share"
> exec_prefix="${prefix}"
> datarootdir="${prefix}/share"
> locale_dir=`echo ${GRUB_PREFIX}/locale | sed ${transform}`
24,28d26
< grubdir="`echo "/boot/grub" | sed 's,//*,/,g'`"
< quick_boot="0"
< export TEXTDOMAIN=grub
< export TEXTDOMAINDIR="${datarootdir}/locale"
41c39
< if [ "x${GRUB_GFXMODE}" = "x" ] ; then GRUB_GFXMODE=auto ; fi
> if [ "x${GRUB_GFXMODE}" = "x" ] ; then GRUB_GFXMODE=640x480 ; fi
49d46
<   set have_grubenv=true
57,61d53
< elif [ "\${next_entry}" ] ; then
<    set default="\${next_entry}"
<    set next_entry=
<    save_env next_entry
<    set boot_once=true
68,75c60
< if [ "\${next_entry}" ] ; then
<    set next_entry=
< else
<    set default="${GRUB_DEFAULT}"
< fi
Les fichiers arrivent...
79,87d63
< if [ x"\${feature_menuentry_id}" = xy ]; then
<   menuentry_id_option="--id"
< else
<   menuentry_id_option=""
< fi
< export menuentry_id_option
102d77
< EOF
104,126d78
< if [ "$quick_boot" = 1 ]; then
<     cat <<EOF
< function recordfail {
<   set recordfail=1
< EOF
<     FS="$(grub-probe --target=fs "${grubdir}")"
<     case "$FS" in
<       btrfs | cpiofs | newc | odc | romfs | squash4 | tarfs | zfs)
<       cat <<EOF
<   # GRUB lacks write support for $FS, so recordfail support is disabled.
< EOF
<       cat <<EOF
<   if [ -n "\${have_grubenv}" ]; then if [ -z "\${boot_once}" ]; then save_env recordfail; fi; fi
< EOF
<     esac
<     cat <<EOF
< EOF
< fi
< cat <<EOF
134,147c86,91
< # If all_video.mod isn't available load all modules available
< # with versions prior to introduction of all_video.mod
< cat <<EOF
<   if [ x\$feature_all_video_module = xy ]; then
<     insmod all_video
<   else
<     insmod efi_gop
<     insmod efi_uga
<     insmod ieee1275_fb
<     insmod vbe
<     insmod vga
<     insmod video_bochs
<     insmod video_cirrus
<   fi
>     # Insert all available backends; GRUB will use the most appropriate.
>     have_video=0;
>     for backend in $(cat "${GRUB_PREFIX}/video.lst"); do
>       have_video=1;
>       cat <<EOF
>   insmod ${backend}
148a93,96
>     done
>     if [ x$have_video = x0 ]; then
>       echo "true"
>     fi
166a115,118
>     if ! test -e "${GRUB_PREFIX}/serial.mod" ; then
>       echo "Serial terminal not available on this platform." >&2 ; exit 1
>     fi
168c120
<       grub_warn "$(gettext "Requested serial terminal but GRUB_SERIAL_COMMAND is unspecified. Default parameters will be used.")"
>       grub_warn "Requested serial terminal but GRUB_SERIAL_COMMAND is unspecified. Default parameters will be used."
175,212c127,128
<     if [ -n "$GRUB_FONT" ] ; then
<        # Make the font accessible
<        prepare_grub_to_access_device `${grub_probe} --target=device "${GRUB_FONT}"`
<     cat << EOF
< if loadfont `make_system_path_relative_to_its_root "${GRUB_FONT}"` ; then
< EOF
<     else
<       for dir in "${pkgdatadir}" "`echo '/boot/grub' | sed "s,//*,/,g"`" /usr/share/grub ; do
<           for basename in unicode unifont ascii; do
<               path="${dir}/${basename}.pf2"
<               if is_path_readable_by_grub "${path}" > /dev/null ; then
<                   font_path="${path}"
<               else
<                   continue
<               fi
<               break 2
<           done
<       done
<       if [ -n "${font_path}" ] ; then
<     cat << EOF
< if [ x\$feature_default_font_path = xy ] ; then
<    font=unicode
< else
< EOF
<               prepare_grub_to_access_device `${grub_probe} --target=device "${font_path}"`
<     cat << EOF
<     font="`make_system_path_relative_to_its_root "${font_path}"`"
< fi
< if loadfont \$font ; then
< EOF
<           else
<     cat << EOF
< if loadfont unicode ; then
< EOF
<           fi
<       fi
>     prepare_grub_to_access_device `${grub_probe} --target=device "${GRUB_FONT_PATH}"`
215c131,132
<   set gfxmode=${GRUB_GFXMODE}
> if loadfont `make_system_path_relative_to_its_root "${GRUB_FONT_PATH}"` ; then
> set gfxmode=1024x768
221c138,139
< if [ "x${LANG}" != "xC" ] &&  [ "x${LANG}" != "x" ]; then
> if [ "x${LANG}" != "xC" ] && [ -d "${locale_dir}" ] ; then
>     prepare_grub_to_access_device $(${grub_probe} --target=device ${locale_dir}) | sed -e "s/^/  /"
223c141
<   set locale_dir=\$prefix/locale
>   set locale_dir=(\$root)$(make_system_path_relative_to_its_root ${locale_dir})
259,260c177
<       gettext_printf "Found theme: %s\n" "$GRUB_THEME" >&2
>       echo "Found theme: $GRUB_THEME" >&2
291d207
< export theme
295c211
<       gettext_printf "Found background: %s\n" "$GRUB_BACKGROUND" >&2
>       echo "Found background: $GRUB_BACKGROUND" >&2
300c216
<           *)             gettext "Unsupported image format" >&2; echo >&2; exit 1 ;;
>           *)             echo "Unsupported image format" >&2; exit 1 ;;
312,326c228
<     cat << EOF
< if [ "\${recordfail}" = 1 ] ; then
<   set timeout=${GRUB_RECORDFAIL_TIMEOUT:--1}
< else
< EOF
<     if [ "x${3}" != "x" ] ; then
<       timeout="${2}"
<       style="${3}"
<     elif [ "x${1}" != "x" ] && \
<        ([ "$quick_boot" = 1 ] || [ "x${1}" != "x0" ]) ; then
<       # Handle the deprecated GRUB_HIDDEN_TIMEOUT scheme.
<       timeout="${1}"
<       if [ "x${2}" != "x0" ] ; then
<           grub_warn "$(gettext "Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.")"
<       fi
>     if [ "x${1}" != "x" ] ; then
328d229
<           style="hidden"
331d231
<           style="countdown"
334,344d233
<     else
<       # No hidden timeout, so treat as GRUB_TIMEOUT_STYLE=menu
<       timeout="${2}"
<       style="menu"
<     fi
<     cat << EOF
<   if [ x\$feature_timeout_style = xy ] ; then
<     set timeout_style=${style}
<     set timeout=${timeout}
< EOF
<     if [ "x${style}" = "xmenu" ] ; then
346,349c235,237
<   # Fallback normal timeout code in case the timeout_style feature is
<   # unavailable.
<   else
> if sleep$verbose --interruptible ${1} ; then
>   set timeout=${2}
> fi
353,356c241
<   # Fallback hidden-timeout code in case the timeout_style feature is
<   # unavailable.
<   elif sleep${verbose} --interruptible ${timeout} ; then
<     set timeout=0
> set timeout=${2}
359,362d243
<     cat << EOF
<   fi
< fi
< EOF
369c250
< make_timeout "${GRUB_HIDDEN_TIMEOUT_BUTTON}" "${GRUB_TIMEOUT_BUTTON}" "${GRUB_TIMEOUT_STYLE_BUTTON}"
371c252
< make_timeout "${GRUB_HIDDEN_TIMEOUT}" "${GRUB_TIMEOUT}" "${GRUB_TIMEOUT_STYLE}"
374c255
Voila:
00_header=
#! /bin/sh
set -e
# grub-mkconfig helper script.
# Copyright (C) 2006,2007,2008,2009,2010  Free Software Foundation, Inc.
# GRUB is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# GRUB is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with GRUB.  If not, see <http://www.gnu.org/licenses/>.
prefix="/usr"
exec_prefix="/usr"
grub_lang=`echo $LANG | cut -d . -f 1`
quick_boot="0"
. "${datarootdir}/grub/grub-mkconfig_lib"
# Do this as early as possible, since other commands might depend on it.
# (e.g. the `loadfont' command might need lvm or raid modules)
for i in ${GRUB_PRELOAD_MODULES} ; do
  echo "insmod $i"
done
if [ "x${GRUB_DEFAULT}" = "x" ] ; then GRUB_DEFAULT=0 ; fi
if [ "x${GRUB_DEFAULT}" = "xsaved" ] ; then GRUB_DEFAULT='${saved_entry}' ; fi
if [ "x${GRUB_TIMEOUT}" = "x" ] ; then GRUB_TIMEOUT=5 ; fi
if [ "x${GRUB_DEFAULT_BUTTON}" = "x" ] ; then GRUB_DEFAULT_BUTTON="$GRUB_DEFAULT" ; fi
if [ "x${GRUB_DEFAULT_BUTTON}" = "xsaved" ] ; then GRUB_DEFAULT_BUTTON='${saved_entry}' ; fi
if [ "x${GRUB_TIMEOUT_BUTTON}" = "x" ] ; then GRUB_TIMEOUT_BUTTON="$GRUB_TIMEOUT" ; fi
cat << EOF
if [ -s \$prefix/grubenv ]; then
  load_env
fi
EOF
if [ "x$GRUB_BUTTON_CMOS_ADDRESS" != "x" ]; then
    cat <<EOF
if cmostest $GRUB_BUTTON_CMOS_ADDRESS ; then
   set default="${GRUB_DEFAULT_BUTTON}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
fi
EOF
else
    cat <<EOF
   set next_entry=
   save_env next_entry
   set boot_once=true
else
fi
EOF
fi
cat <<EOF
else
fi
if [ "\${prev_saved_entry}" ]; then
  set saved_entry="\${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
    saved_entry="\${chosen}"
  fi
EOF
    cat <<EOF
  set recordfail=1
EOF
    case "$FS" in
	cat <<EOF
EOF
	cat <<EOF
EOF
    esac
    cat <<EOF
EOF
fi
cat <<EOF
function load_video {
EOF
if [ -n "${GRUB_VIDEO_BACKEND}" ]; then
    cat <<EOF
  insmod ${GRUB_VIDEO_BACKEND}
EOF
else
cat <<EOF
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
EOF
fi
cat <<EOF
EOF
serial=0;
gfxterm=0;
for x in ${GRUB_TERMINAL_INPUT} ${GRUB_TERMINAL_OUTPUT}; do
    if [ xserial = "x$x" ]; then
	serial=1;
    fi
    if [ xgfxterm = "x$x" ]; then
	gfxterm=1;
    fi
done
if [ "x$serial" = x1 ]; then
    if [ "x${GRUB_SERIAL_COMMAND}" = "x" ] ; then
	GRUB_SERIAL_COMMAND=serial
    fi
    echo "${GRUB_SERIAL_COMMAND}"
fi
if [ "x$gfxterm" = x1 ]; then
    cat << EOF
EOF
    else
		    font_path="${path}"
		else
		    continue
		fi
		break 2
	    done
	done
    cat << EOF
   font=unicode
else
EOF
    cat << EOF
fi
EOF
	    else
    cat << EOF
EOF
	    fi
	fi
    cat << EOF
  load_video
  insmod gfxterm
EOF
# Gettext variables and module
  cat << EOF
  set lang=${grub_lang}
  insmod gettext
EOF
fi
cat <<EOF
fi
EOF
fi
case x${GRUB_TERMINAL_INPUT} in
  x)
    # Just use the native terminal
  x*)
    cat << EOF
terminal_input ${GRUB_TERMINAL_INPUT}
EOF
esac
case x${GRUB_TERMINAL_OUTPUT} in
  x)
  x*)
    cat << EOF
terminal_output ${GRUB_TERMINAL_OUTPUT}
EOF
esac
    if [ "x$GRUB_THEME" != x ] && [ -f "$GRUB_THEME" ] \
	&& is_path_readable_by_grub "$GRUB_THEME"; then
	prepare_grub_to_access_device `${grub_probe} --target=device "$GRUB_THEME"`
	cat << EOF
insmod gfxmenu
EOF
	themedir="`dirname "$GRUB_THEME"`"
	for x in "$themedir"/*.pf2 "$themedir"/f/*.pf2; do
	    if [ -f "$x" ]; then
		cat << EOF
loadfont (\$root)`make_system_path_relative_to_its_root $x`
EOF
	    fi
	done
	if [ x"`echo "$themedir"/*.jpg`" != x"$themedir/*.jpg" ] || [ x"`echo "$themedir"/*.jpeg`" != x"$themedir/*.jpeg" ]; then
	    cat << EOF
insmod jpeg
EOF
	fi
	if [ x"`echo "$themedir"/*.png`" != x"$themedir/*.png" ]; then
	    cat << EOF
insmod png
EOF
	fi
	if [ x"`echo "$themedir"/*.tga`" != x"$themedir/*.tga" ]; then
	    cat << EOF
insmod tga
EOF
	fi
	cat << EOF
set theme=(\$root)`make_system_path_relative_to_its_root $GRUB_THEME`
export theme
EOF
    elif [ "x$GRUB_BACKGROUND" != x ] && [ -f "$GRUB_BACKGROUND" ] \
	    && is_path_readable_by_grub "$GRUB_BACKGROUND"; then
	case "$GRUB_BACKGROUND" in
	    *.png)         reader=png ;;
	    *.tga)         reader=tga ;;
	    *.jpg|*.jpeg)  reader=jpeg ;;
	esac
	prepare_grub_to_access_device `${grub_probe} --target=device "$GRUB_BACKGROUND"`
	cat << EOF
insmod $reader
background_image -m stretch `make_system_path_relative_to_its_root "$GRUB_BACKGROUND"`
EOF
    fi
fi
make_timeout ()
    cat << EOF
else
EOF
	timeout="${2}"
	style="${3}"
	timeout="${1}"
	fi
	if [ "x${GRUB_HIDDEN_TIMEOUT_QUIET}" = "xtrue" ] ; then
	    style="hidden"
	    verbose=
	else
	    style="countdown"
	    verbose=" --verbose"
	fi
    else
	timeout="${2}"
	style="menu"
    fi
    cat << EOF
EOF
	cat << EOF
  # unavailable.
  else
EOF
    else
	cat << EOF
  # unavailable.
    set timeout=0
EOF
    fi
    cat << EOF
  fi
fi
EOF
    cat <<EOF
EOF
echo else
echo fi
else
fi
if [ "x$GRUB_BUTTON_CMOS_ADDRESS" != "x" ] && [ "x$GRUB_BUTTON_CMOS_CLEAN" = "xyes" ]; then
    cat <<EOF
cmosclean $GRUB_BUTTON_CMOS_ADDRESS
EOF
fi
# Play an initial tune
if [ "x${GRUB_INIT_TUNE}" != "x" ] ; then
  echo "play ${GRUB_INIT_TUNE}"
fi
if [ "x${GRUB_BADRAM}" != "x" ] ; then
  echo "badram ${GRUB_BADRAM}"
fi
le 00-header.old=
#! /bin/sh
set -e
transform="s,x,x,"
prefix="/usr"
  echo "insmod $i"
done
cat << EOF
  load_env
fi
EOF
    cat <<EOF
else
fi
EOF
else
    cat <<EOF
EOF
fi
cat <<EOF
  set boot_once=true
fi
  fi
EOF
    cat <<EOF
EOF
else
    have_video=0;
	have_video=1;
	cat <<EOF
  insmod ${backend}
EOF
    done
	echo "true"
    fi
fi
cat <<EOF
EOF
serial=0;
gfxterm=0;
	serial=1;
    fi
	gfxterm=1;
    fi
done
    fi
    fi
fi
    cat << EOF
  load_video
  insmod gfxterm
EOF
  cat << EOF
  insmod gettext
EOF
fi
cat <<EOF
fi
EOF
fi
  x)
  x*)
    cat << EOF
EOF
esac
  x)
  x*)
    cat << EOF
EOF
esac
	cat << EOF
insmod gfxmenu
EOF
		cat << EOF
EOF
	    fi
	done
	    cat << EOF
insmod jpeg
EOF
	fi
	    cat << EOF
insmod png
EOF
	fi
	    cat << EOF
insmod tga
EOF
	fi
	cat << EOF
EOF
	esac
	cat << EOF
insmod $reader
EOF
    fi
fi
make_timeout ()
	    verbose=
	else
	fi
	cat << EOF
  set timeout=${2}
fi
EOF
    else
	cat << EOF
set timeout=${2}
EOF
    fi
    cat <<EOF
EOF
echo else
echo fi
else
fi
    cat <<EOF
EOF
fi
fi
fi
WarLocG
Message par WarLocG »
Ok, a la lecture du diff j'ai confirmation que c'est ton vieux 00_header.old qui fout le boxon.
Il contient des variables qui n'existent plus car ont été remplacée, et du coup valent vide, c'est le cas du GRUB_PREFIX (avec le fameux video.lst) et du GRUB_FONT_PATH (ayant été remplacé par GRUB_FONT).
En virant, ton 00_header.old du dossier /etc/grub.d/ tu pourras également virer video.lst à la racine qui était requis par 00_header.old.
Modifié en dernier par WarLocG le mar. 21 mars 2017 01:23, modifié 1 fois.
WarLocG a écrit : J'ai vu ou ca plante, on peut pas le louper :) Ca ne va pas au dela de /etc/grub.d/00_header et tu as même un 00_header.old. Pourrais-tu faire diff sur tes deux fichiers /etc/grub.d/00_header et 00_header.old pour qu'on apercois les changements et également nous coller ces fichiers 00_header pour voir si il y a quelque chose de chelou la dedans ?
C'est d'ailleurs dans le .old qu'il plante.
Alors comme patch temporaire (j'aimerais quand savoir ce qu'il y a dans ton 00_header.old pour planter ton update-grub), tu pourrais deja tester en isolant ce fichier 00_header.old (le déplacer ailleurs, par exemple sur ton Bureau.) Vérifier si update-grub passe et pendant ce temps la je vais chercher mes scalpels :D
00_header.old déplacé, puis update-grub...Et ça fonctionne :D
Found background image: /usr/share/images/desktop-base/desktop-grub.png
Image Linux trouvée : /boot/vmlinuz-3.16.0-4-amd64
Image mémoire initiale trouvée : /boot/initrd.img-3.16.0-4-amd64
Image Linux trouvée : /boot/vmlinuz-3.16.0-0.bpo.4-amd64
Image mémoire initiale trouvée : /boot/initrd.img-3.16.0-0.bpo.4-amd64
Image Linux trouvée : /boot/vmlinuz-3.2.0-4-amd64
Image mémoire initiale trouvée : /boot/initrd.img-3.2.0-4-amd64
Found memtest86+ image: /boot/memtest86+.bin
Found memtest86+ multiboot image: /boot/memtest86+_multiboot.bin
fait
As tu un explication pour ce fichier .old, de pourquoi il était pris en compte?
WarLocG
Hourra :D
Parce qu'il se trouve dans /etc/grub.d/ et qu'il doit y avoir un script en amont qui lit tous les fichiers présent dans ce dossier.
Finalement, plus qu'a éditer le sujet et le mettre en résolu :)
Modifié en dernier par WarLocG le mar. 21 mars 2017 01:28, modifié 1 fois.
oui, ça d'accord. mais sa présence ici, elle est due a quoi? suite a la suppression du dual ubuntu?
video.lst : viré...
Merci beaucoup WarLocG ;)
Modifié en dernier par alain le mar. 21 mars 2017 01:30, modifié 1 fois.
WarLocG
Probablement. Tu avais un système ubuntu dont tu as changé les source.lst et dist-upgrade depuis ?
WarLocG a écrit :Probablement. Tu avais un système ubuntu dont tu as changé les source.lst et dist-upgrade depuis ?
Oui j'ai fait c'est sur, mais y a bien longtemps... ça serait donc ça :o
Je reboote et te dis quoi...
Nickel ! ;) Un immense merci WarLocG.
Je ne pensais pas la sauver celle la... :D
Je pense que je peux mettre en résolu? qu'en penses tu?
WarLocG
oui la c'est résolu, a moins que tu repartes mettre un 00_trolol avec du script chelou dans /etc/grub.d/ pour faire durer le plaisir :lol:
lol :lol: Non fini les 00_trolol avec du script chelou dans /etc/grub.d/. :lol:
Au prochain dual que je vire je saurai ou regarder si ça tousse :D
(c'est pourtant pas la première fois que j'en vire un, j'avais pas eu ce trololo les fois précédentes...)
Donc Résolu grâce à WarLocG et remerciements à Mpat et Tyrry pour leurs aides en irc et ici ;)
