message Gnome-keyring-daemon absence de réponse
Re: message Gnome-keyring-daemon absence de réponse
voilà ce que j'ai dans xsession-errors
/etc/mdm/Xsession: Beginning session setup...
localuser:alain being added to access control list
I: Script for none started at run_im.
I: Script for auto started at run_im.
I: Script for default started at run_im.
gnome-keyring-daemon: insufficient process capabilities, unsecure memory might get used
** Message: couldn't access control socket: /run/user/1000/keyring/control: Aucun fichier ou dossier de ce type
GPG_AGENT_INFO=/run/user/1000/keyring/gpg:0:1
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
[cinnamon-settings-daemon-smartcard] Failed to start: impossible de trouver un pilote de carte à puce adapté
Failed to play sound: Sound disabled
(nm-applet:1575): libnm-glib-CRITICAL **: nm_secret_agent_register: assertion 'priv->registered == FALSE' failed
Cjs-Message: JS LOG: About to start Cinnamon
St-Message: cogl npot texture sizes SUPPORTED
Cjs-Message: JS LOG: Cinnamon started at Mon Oct 30 2017 20:54:56 GMT+0100 (CET)
Cjs-Message: JS LOG: network applet: Cannot find connection for active (or connection cannot be read)
openGL version 2.1 Mesa 10 detected (GL Cogl Driver)
MetaSyncRing disabled: couldn't find required GL extensions, or the minimum safe openGL version was not met
Window manager warning: Log level 16: Symbolic icon /usr/share/cinnamon/applets/windows-quick-list@cinnamon.org/icons/windows-quick-list-symbolic.svg is not in an icon theme directory
failed to create drawable
Cjs-Message: JS LOG: Invalid network device type, is 14
Cjs-Message: JS LOG: network applet: Found connection for active
mintUpdate: aucun processus trouvé
Gerinald
Message par Gerinald »
Salux,
Bon, j'ai tout réinstallé .. au propre et directement installé toutes les mises à jours, plus passage au kernel 4.13 ...
Et de nouveau ce bête message .... mais .... :)
En fait, tant que je n'avais pas activé Thunderbird et installé Firetray ... tout les redémarrage se sont effectué sans ce foutu pop-up ...
Par contre .... une fois activé Th et installé Firetray ... le pop-up est apparu ...
Alors .... est ce une coïncidence ou pas .... il faudrait voir si je suis le seul dans ce cas ...
Une piste comme une autre ...
@Pluche
Gerinald
Mia88
Message par Mia88 »
Salut tout le monde,
Ça semble être rentré dans l'ordre sans que je n'ai rien fait d'autre que de lancer les commandes de mpat qui semblent pourtant n'avoir pas fonctionné.
sudo chmod a-x /usr/bin/gnome-keyring*
sudo  killall gnome-keyring-daemon
C'est la dernière chose que j'ai faite avant que le problème disparaisse, mais peut-être qu'une mise à jour a résolu le problème ?
zebulon a écrit :L'informagique mon ami, l'informagique...... :D
Comme tu dis :l
Carlos06
Message par Carlos06 »
Mon cas est apparu après l'install de Wine :
salut, ouvrir un terminal et faire un copier coller des commandes ci-dessous.
sudo apt-get install playonlinux
sudo apt-get install wine
sudo apt-get install winetricks
sudo apt-get install wine1.6
sudo apt-get install wine1.6-amd64
sudo apt-get install wine1.6-i386:386
:l
Linux Mint 18.2 Cinnamon 64-bit : 3.4.3
Noyau Linux : 4.8.0-53-gen Pentium 1.60GHz x 4
Disques durs : 965.2 Go
Carte graphique : Intel Device 22b1
....pour une informatique libre ! -membre de l'April
c'est une question, une solution ? du grand n'importe quoi ;)
en plus il existe les balises code pour mettre en forme :l
:l :l
Carlos06
Bonjour, bref !!!! 8-) 8-) C'est une exemple a ne pas suivre :roll:
Carlos06 a écrit : une exemple
Une exemple est à ne jamais suivre, il vaut toujours suivre un exemple :lol:
Mais on s'écarte du sujet ;)
Carlos06
Salut, mais depuis le PCP rame au delà de la complaisance :oops:
Carlos06
Bonjour, Bonjour mes Dames et Messieurs, après avoir exécuté la manip Mpat tout est revenu à la normal ; Sauf le téléchargement d'un DD externe vers le PC portable, 1 heur 25 minutes, pour comparaison (( la mème action par W$ 2 minute 30 sc )), donc, je suppute une aide céleste de votre part :B :)
bonjour, et moi je "solliciterai" plutôt, car je "suppute" que les solutions proposées ici ne vont pas, que tu ouvres un sujet ;)
