Je recherche, sans succès, une appli pour disposer sous Mint 18 d'une calculatrice en notation polonaise inverse (NPI en français mais RPN en anglais). Il en existe de nombreuses pouriOS, Android et même pour Ouidose. Quelqu'un aurait-il des lumières ?
Calculatrice RPN
Calculatrice RPN
Intel NUC i3 6100 DDR4 8Gb SSD 250 Gb
Re: Calculatrice RPN
dc sous mint
Voir http://www.ibiblio.org/pub/linux/docs/l ... 1-0319.pdf" onclick="window.open(this.href);return false;
calcoo via apt-get install calcoo ou le gestionnaire de paquet synaptic
Marrant je connaissais pas lol
man dcCode : Tout sélectionner
dc(1) General Commands Manual dc(1)
NAME
dc - an arbitrary precision calculator
SYNOPSIS
dc [-V] [--version] [-h] [--help]
[-e scriptexpression] [--expression=scriptexpression]
[-f scriptfile] [--file=scriptfile]
[file ...]
DESCRIPTION
dc is a reverse-polish desk calculator which supports unlimited preci‐
sion arithmetic. It also allows you to define and call macros. Nor‐
mally dc reads from the standard input; if any command arguments are
given to it, they are filenames, and dc reads and executes the contents
of the files before reading from standard input. All normal output is
to standard output; all error output is to standard error.
A reverse-polish calculator stores numbers on a stack. Entering a num‐
ber pushes it on the stack. Arithmetic operations pop arguments off
the stack and push the results.
kitty@kitty ~ $ dc
2
3+
p
5
3
3-
p
0
6
6*
p
36
Kernel: 5.15.0-126-generic x86_64 bits: 64 Desktop: Xfce 4.18.1
Distro: Linux Mint 21.3 Virginia
ASUSTeK model: P5KPL-AM
Single Core model: Pentium E5300 bits: 64 type, Not Easy ('.°)
NVIDIA GK208B [GeForce GT 730]
Local: total: 1.28 TiB used: 237.14 GiB (18.1%)
Samsung model: SSD 870 EVO 250GB size: 232.89 GiB
Western Digital model: WD10JPCX-24UE4T0 size: 931.51 GiB
Western Digital model: WD1600BEVS-08VAT1 size: 149.05 GiB
