[ 1.168290] usb usb1: Product: EHCI Host Controller
[ 1.168291] usb usb1: Manufacturer: Linux 4.13.0-43-generic ehci_hcd
[ 1.168292] usb usb1: SerialNumber: 0000:00:12.0
[ 1.168429] hub 1-0:1.0: USB hub found
[ 1.168435] hub 1-0:1.0: 2 ports detected
[ 1.168544] ehci-platform: EHCI generic platform driver
[ 1.168566] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.168568] ohci-pci: OHCI PCI platform driver
[ 1.168580] ohci-platform: OHCI generic platform driver
[ 1.168587] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.168744] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.168748] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 1.168955] xhci_hcd 0000:00:10.0: hcc params 0x014040c3 hci version 0x100 quirks 0x00000410
[ 1.169099] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.169100] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.169102] usb usb2: Product: xHCI Host Controller
[ 1.169103] usb usb2: Manufacturer: Linux 4.13.0-43-generic xhci-hcd
[ 1.169104] usb usb2: SerialNumber: 0000:00:10.0
[ 1.169191] hub 2-0:1.0: USB hub found
[ 1.169200] hub 2-0:1.0: 4 ports detected
[ 1.169551] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.169554] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 3
[ 1.175855] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.175872] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.175874] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.175875] usb usb3: Product: xHCI Host Controller
[ 1.175876] usb usb3: Manufacturer: Linux 4.13.0-43-generic xhci-hcd
[ 1.175877] usb usb3: SerialNumber: 0000:00:10.0
[ 1.175954] hub 3-0:1.0: USB hub found
[ 1.175962] hub 3-0:1.0: 4 ports detected
[ 1.176272] i8042: PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.200104] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.200107] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.200219] mousedev: PS/2 mouse device common for all mice
[ 1.200374] rtc_cmos 00:01: RTC can wake from S4
[ 1.200464] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.200490] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[ 1.200494] i2c /dev entries driver
[ 1.200546] device-mapper: uevent: version 1.0.3
[ 1.200611] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[ 1.200636] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.200987] NET: Registered protocol family 10
[ 1.204733] Segment Routing with IPv6
[ 1.204758] NET: Registered protocol family 17
[ 1.204772] Key type dns_resolver registered
[ 1.204955] RAS: Correctable Errors collector initialized.
[ 1.205033] microcode: CPU0: patch_level=0x06006704
[ 1.205038] microcode: CPU1: patch_level=0x06006704
[ 1.205068] microcode: Microcode Update Driver: v2.2.
[ 1.205080] sched_clock: Marking stable (1205064325, 0)->(1352023850, -146959525)
[ 1.205238] registered taskstats version 1
[ 1.205247] Loading compiled-in X.509 certificates
[ 1.207573] Loaded X.509 cert 'Build time autogenerated kernel key: a287497b044864e8c1d63effe2112eb278f4c334'
[ 1.207600] zswap: loaded using pool lzo/zbud
[ 1.210797] Key type big_key registered
[ 1.210801] Key type trusted registered
[ 1.211063] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 1.212435] Key type encrypted registered
[ 1.212439] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.212441] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[ 1.212473] evm: HMAC attrs: 0x1
[ 1.212924] Magic number: 6:107:0
[ 1.213005] memory memory48: hash matches
[ 1.213048] rtc_cmos 00:01: setting system clock to 2018-06-02 00:02:57 UTC (1527897777)
[ 1.213183] acpi_cpufreq: overriding BIOS provided _PSD data
[ 1.213242] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.213243] EDD information not available.
[ 1.213278] PM: Hibernation image not present or could not be loaded.
[ 1.272325] ACPI: Battery Slot [BAT1] (battery present)
[ 1.274650] Freeing unused kernel memory: 2368K
[ 1.274653] Write protecting the kernel read-only data: 18432k
[ 1.275405] Freeing unused kernel memory: 2024K
[ 1.275576] Freeing unused kernel memory: 84K
[ 1.277288] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.336998] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 1.337885] acpi device:00: registered as cooling_device2
[ 1.337930] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[ 1.350086] wmi_bus wmi_bus-PNP0C14:00: WQBJ data block query control method not found
[ 1.355777] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.355789] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 1.369106] r8169 0000:02:00.0 eth0: RTL8168h/8111h at 0xffffa55f00cbd000, b4:b6:86:46:a9:c7, XID 14100800 IRQ 33
[ 1.369108] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 1.370961] ahci 0000:00:11.0: version 3.0
[ 1.371173] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 1.371176] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp fbs pio slum part
[ 1.380503] scsi host0: ahci
[ 1.382924] scsi host1: ahci
[ 1.382992] ata1: SATA max UDMA/133 abar m1024@0xf046c000 port 0xf046c100 irq 19
[ 1.382994] ata2: SATA max UDMA/133 abar m1024@0xf046c000 port 0xf046c180 irq 19
[ 1.391473] r8169 0000:02:00.0 enp2s0: renamed from eth0
[ 1.420849] [drm] amdgpu kernel modesetting enabled.
[ 1.422926] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.425756] Found CRAT image with size=744
[ 1.425758] Parsing CRAT table with 1 nodes
[ 1.425759] Found CU entry in CRAT table with proximity_domain=0 caps=0
[ 1.425760] CU CPU: cores=2 id_base=16
[ 1.425761] Found CU entry in CRAT table with proximity_domain=0 caps=0
[ 1.425762] CU GPU: simds=40 id_base=-2147483648
[ 1.425762] Found memory entry in CRAT table with proximity_domain=0
[ 1.425763] Found cache entry in CRAT table with processor_id=16
[ 1.425764] Found cache entry in CRAT table with processor_id=16
[ 1.425764] Found cache entry in CRAT table with processor_id=17
[ 1.425765] Found TLB entry in CRAT table (not processing)
[ 1.425766] Found TLB entry in CRAT table (not processing)
[ 1.425767] Creating topology SYSFS entries
[ 1.425780] Finished initializing topology ret=0
[ 1.425792] kfd kfd: Initialized module
[ 1.426361] checking generic (e0000000 420000) vs hw (e0000000 10000000)
[ 1.426362] fb: switching to amdgpudrmfb from VESA VGA
[ 1.426394] Console: switching to colour dummy device 80x25
[ 1.426768] [drm] initializing kernel modesetting (STONEY 0x1002:0x98E4 0x103C:0x8330 0xDA).
[ 1.426782] [drm] register mmio base: 0xF0400000
[ 1.426783] [drm] register mmio size: 262144
[ 1.426993] [drm] UVD is enabled in physical mode
[ 1.426994] [drm] VCE enabled in VM mode
[ 1.439251] [drm] BIOS signature incorrect 0 0
[ 1.440348] ATOM BIOS: 113-C91400-007
[ 1.440358] [drm] GPU post is not needed
[ 1.440610] [drm] vm size is 64 GB, block size is 13-bit
[ 1.440617] amdgpu 0000:00:01.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
[ 1.440619] amdgpu 0000:00:01.0: GTT: 3072M 0x0000000020000000 - 0x00000000DFFFFFFF
[ 1.440625] [drm] Detected VRAM RAM=512M, BAR=512M
[ 1.440625] [drm] RAM width 64bits UNKNOWN
[ 1.440686] [TTM] Zone kernel: Available graphics memory: 3841946 kiB
[ 1.440687] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 1.440688] [TTM] Initializing pool allocator
[ 1.440692] [TTM] Initializing DMA pool allocator
[ 1.440720] [drm] amdgpu: 512M of VRAM memory ready
[ 1.440721] [drm] amdgpu: 3072M of GTT memory ready.
[ 1.440729] [drm] GART: num cpu pages 786432, num gpu pages 786432
[ 1.441892] [drm] PCIE GART of 3072M enabled (table at 0x0000000000040000).
[ 1.441911] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.441911] [drm] Driver supports precise vblank timestamp query.
[ 1.441958] amdgpu 0000:00:01.0: amdgpu: using MSI.
[ 1.441974] [drm] amdgpu: irq initialized.
[ 1.441989] amdgpu: [powerplay] amdgpu: powerplay sw initialized
[ 1.442993] [drm] amdgpu atom DIG backlight initialized
[ 1.442995] [drm] AMDGPU Display Connectors
[ 1.442995] [drm] Connector 0:
[ 1.442996] [drm] eDP-1
[ 1.442997] [drm] HPD1
[ 1.442998] [drm] DDC: 0x4868 0x4868 0x4869 0x4869 0x486a 0x486a 0x486b 0x486b
[ 1.442998] [drm] Encoders:
[ 1.442999] [drm] LCD1: INTERNAL_UNIPHY
[ 1.442999] [drm] Connector 1:
[ 1.443000] [drm] HDMI-A-1
[ 1.443000] [drm] HPD2
[ 1.443001] [drm] DDC: 0x486c 0x486c 0x486d 0x486d 0x486e 0x486e 0x486f 0x486f
[ 1.443001] [drm] Encoders:
[ 1.443002] [drm] DFP1: INTERNAL_UNIPHY
[ 1.443002] [drm] Connector 2:
[ 1.443003] [drm] DP-1
[ 1.443003] [drm] HPD3
[ 1.443004] [drm] DDC: 0x4870 0x4870 0x4871 0x4871 0x4872 0x4872 0x4873 0x4873
[ 1.443004] [drm] Encoders:
[ 1.443004] [drm] DFP2: INTERNAL_UNIPHY1
[ 1.443322] amdgpu 0000:00:01.0: fence driver on ring 0 use gpu addr 0x0000000020000010, cpu addr 0xffff9468aaf0e010
[ 1.443365] amdgpu 0000:00:01.0: fence driver on ring 1 use gpu addr 0x0000000020000020, cpu addr 0xffff9468aaf0e020
[ 1.443394] amdgpu 0000:00:01.0: fence driver on ring 2 use gpu addr 0x0000000020000030, cpu addr 0xffff9468aaf0e030
[ 1.443422] amdgpu 0000:00:01.0: fence driver on ring 3 use gpu addr 0x0000000020000040, cpu addr 0xffff9468aaf0e040
[ 1.443452] amdgpu 0000:00:01.0: fence driver on ring 4 use gpu addr 0x0000000020000050, cpu addr 0xffff9468aaf0e050
[ 1.443479] amdgpu 0000:00:01.0: fence driver on ring 5 use gpu addr 0x0000000020000060, cpu addr 0xffff9468aaf0e060
[ 1.443506] amdgpu 0000:00:01.0: fence driver on ring 6 use gpu addr 0x0000000020000070, cpu addr 0xffff9468aaf0e070
[ 1.443536] amdgpu 0000:00:01.0: fence driver on ring 7 use gpu addr 0x0000000020000080, cpu addr 0xffff9468aaf0e080
[ 1.443565] amdgpu 0000:00:01.0: fence driver on ring 8 use gpu addr 0x0000000020000090, cpu addr 0xffff9468aaf0e090
[ 1.443583] amdgpu 0000:00:01.0: fence driver on ring 9 use gpu addr 0x00000000200000a4, cpu addr 0xffff9468aaf0e0a4
[ 1.443687] amdgpu 0000:00:01.0: fence driver on ring 10 use gpu addr 0x00000000200000b4, cpu addr 0xffff9468aaf0e0b4
[ 1.443819] [drm] Found UVD firmware Version: 1.38 Family ID: 15
[ 1.444080] amdgpu 0000:00:01.0: fence driver on ring 11 use gpu addr 0x0000000000695860, cpu addr 0xffffa55f01442860
[ 1.444187] [drm] Found VCE firmware Version: 52.0 Binary ID: 3
[ 1.444270] amdgpu 0000:00:01.0: fence driver on ring 12 use gpu addr 0x00000000200000d4, cpu addr 0xffff9468aaf0e0d4
[ 1.444302] amdgpu 0000:00:01.0: fence driver on ring 13 use gpu addr 0x00000000200000e4, cpu addr 0xffff9468aaf0e0e4
[ 1.473571] [drm] ring test on 0 succeeded in 9 usecs
[ 1.473884] [drm] ring test on 9 succeeded in 7 usecs
[ 1.473892] [drm] ring test on 1 succeeded in 3 usecs
[ 1.473928] [drm] ring test on 2 succeeded in 20 usecs
[ 1.473948] [drm] ring test on 3 succeeded in 10 usecs
[ 1.473968] [drm] ring test on 4 succeeded in 10 usecs
[ 1.473988] [drm] ring test on 5 succeeded in 10 usecs
[ 1.474008] [drm] ring test on 6 succeeded in 10 usecs
[ 1.474028] [drm] ring test on 7 succeeded in 10 usecs
[ 1.474047] [drm] ring test on 8 succeeded in 10 usecs
[ 1.474068] [drm] ring test on 10 succeeded in 3 usecs
[ 1.859986] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.864231] ata2.00: ATAPI: hp DVDRW DA8AESH, XH6M, max UDMA/133
[ 1.865821] ata2.00: configured for UDMA/133
[ 2.124775] psmouse serio1: synaptics: queried max coordinates: x [..5648], y [..4826]
[ 2.154520] psmouse serio1: synaptics: queried min coordinates: x [1292..], y [1026..]
[ 2.154524] psmouse serio1: synaptics: Your touchpad (PNP: SYN3254 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[ 2.212660] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.16, id: 0x1e2b1, caps: 0xf00323/0x840300/0x2e800/0x400000, board id: 3320, fw id: 2659795
[ 2.219961] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.250269] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input6
[ 2.260479] ata1.00: ATA-10: TOSHIBA MQ04ABF100, JU001C, max UDMA/100
[ 2.260481] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.261534] ata1.00: configured for UDMA/100
[ 2.261667] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MQ04ABF1 1C PQ: 0 ANSI: 5
[ 2.466438] usb 2-1: new high-speed USB device number 2 using xhci_hcd
[ 2.466448] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 2.466472] tsc: Refined TSC clocksource calibration: 2994.377 MHz
[ 2.466476] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b2985b93fc, max_idle_ns: 440795324766 ns
[ 2.492340] [drm] ring test on 11 succeeded in 1 usecs
[ 2.492350] [drm] UVD initialized successfully.
[ 2.592460] [drm] ring test on 12 succeeded in 4 usecs
[ 2.592468] [drm] ring test on 13 succeeded in 2 usecs
[ 2.592469] [drm] VCE initialized successfully.
[ 2.592787] [drm] ib test on ring 0 succeeded
[ 2.592885] [drm] ib test on ring 1 succeeded
[ 2.592913] [drm] ib test on ring 2 succeeded
[ 2.592934] [drm] ib test on ring 3 succeeded
[ 2.592962] [drm] ib test on ring 4 succeeded
[ 2.592985] [drm] ib test on ring 5 succeeded
[ 2.593012] [drm] ib test on ring 6 succeeded
[ 2.593034] [drm] ib test on ring 7 succeeded
[ 2.593064] [drm] ib test on ring 8 succeeded
[ 2.620419] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 2.620421] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.620432] sd 0:0:0:0: [sda] Write Protect is off
[ 2.620434] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.620449] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.620683] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.630204] scsi 1:0:0:0: CD-ROM hp DVDRW DA8AESH XH6M PQ: 0 ANSI: 5
[ 2.669100] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8
[ 2.669636] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.674095] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 2.674098] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.674252] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.674310] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.680328] usb 1-1: New USB device found, idVendor=0438, idProduct=7900
[ 2.680330] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.680872] hub 1-1:1.0: USB hub found
[ 2.681048] hub 1-1:1.0: 4 ports detected
[ 2.699520] usb 2-1: New USB device found, idVendor=04f2, idProduct=b5d5
[ 2.699522] usb 2-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.699524] usb 2-1: Product: HP TrueVision HD Camera
[ 2.699525] usb 2-1: Manufacturer: Chicony Electronics Co.,Ltd.
[ 2.699526] usb 2-1: SerialNumber: 0001
[ 2.968167] usb 1-1.3: new full-speed USB device number 3 using ehci-pci
[ 3.078654] usb 1-1.3: New USB device found, idVendor=2a94, idProduct=5009
[ 3.078656] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.078657] usb 1-1.3: Product: Multi-Touch by G2TSP
[ 3.078658] usb 1-1.3: Manufacturer: G2Touch
[ 3.081778] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.086315] usbcore: registered new interface driver usbhid
[ 3.086317] usbhid: USB HID core driver
[ 3.087915] hid-generic 0003:2A94:5009.0002: hiddev0,hidraw0: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:12.0-1.3/input1
[ 3.100190] [drm] ib test on ring 9 succeeded
[ 3.100222] [drm] ib test on ring 10 succeeded
[ 3.100975] [drm] ib test on ring 11 succeeded
[ 3.101187] [drm] ib test on ring 12 succeeded
[ 3.103252] amdgpu: [powerplay] min_core_set_clock not set
[ 3.103600] amdgpu: [powerplay] min_core_set_clock not set
[ 3.175952] usb 1-1.4: new full-speed USB device number 4 using ehci-pci
[ 3.285874] usb 1-1.4: New USB device found, idVendor=8087, idProduct=0aa7
[ 3.285877] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.726373] clocksource: Switched to clocksource tsc
[ 3.765345] [drm] fb mappable at 0x1FF89F000
[ 3.765347] [drm] vram apper at 0x1FF000000
[ 3.765348] [drm] size 4325376
[ 3.765349] [drm] fb depth is 24
[ 3.765349] [drm] pitch is 5632
[ 3.824120] fbcon: amdgpudrmfb (fb0) is primary device
[ 3.824376] Console: switching to colour frame buffer device 170x48
[ 3.824396] amdgpu 0000:00:01.0: fb0: amdgpudrmfb frame buffer device
[ 4.356111] amdgpu: [powerplay] min_core_set_clock not set
[ 4.970344] [drm] Initialized amdgpu 3.18.0 20150101 for 0000:00:01.0 on minor 0
[ 5.594464] amdgpu: [powerplay] min_core_set_clock not set
[ 5.597793] amdgpu: [powerplay] min_core_set_clock not set
[ 6.229067] amdgpu: [powerplay] min_core_set_clock not set
[ 6.230371] amdgpu: [powerplay] min_core_set_clock not set
[ 6.271943] raid6: sse2x1 gen() 5465 MB/s
[ 6.319939] raid6: sse2x1 xor() 4909 MB/s
[ 6.367942] raid6: sse2x2 gen() 9059 MB/s
[ 6.415936] raid6: sse2x2 xor() 6971 MB/s
[ 6.463935] raid6: sse2x4 gen() 11196 MB/s
[ 6.511937] raid6: sse2x4 xor() 5045 MB/s
[ 6.559935] raid6: avx2x1 gen() 10701 MB/s
[ 6.607937] raid6: avx2x1 xor() 6979 MB/s
[ 6.655938] raid6: avx2x2 gen() 12705 MB/s
[ 6.703937] raid6: avx2x2 xor() 7777 MB/s
[ 6.751937] raid6: avx2x4 gen() 14306 MB/s
[ 6.799936] raid6: avx2x4 xor() 6145 MB/s
[ 6.799937] raid6: using algorithm avx2x4 gen() 14306 MB/s
[ 6.799937] raid6: .... xor() 6145 MB/s, rmw enabled
[ 6.799938] raid6: using avx2x2 recovery algorithm
[ 6.801766] xor: automatically using best checksumming function avx
[ 6.817368] Btrfs loaded, crc32c=crc32c-intel
[ 7.054440] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 7.820718] random: crng init done
[ 8.754210] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 8.772265] systemd[1]: Detected architecture x86-64.
[ 8.772755] systemd[1]: Set hostname to <jarvis>.
[ 11.162923] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.163070] systemd[1]: Listening on Journal Audit Socket.
[ 11.163130] systemd[1]: Started Trigger resolvconf update for networkd DNS.
[ 11.163270] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.163307] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 11.163344] systemd[1]: Listening on Syslog Socket.
[ 11.163370] systemd[1]: Listening on LVM2 poll daemon socket.
[ 11.768314] lp: driver loaded but no devices found
[ 11.834182] ppdev: user-space parallel port driver
[ 13.180162] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
[ 13.220137] systemd-journald[331]: Received request to flush runtime journal from PID 1
[ 13.749487] tpm_crb MSFT0101:00: can't request region for resource [mem 0xdfb7a000-0xdfb7dfff]
[ 13.749496] tpm_crb: probe of MSFT0101:00 failed with error -16
[ 13.765240] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 13.826213] cmi: probe of SMB0001:00 failed with error -5
[ 13.856672] input: HP Wireless hotkeys as /devices/virtual/input/input7
[ 14.068610] Intel(R) Wireless WiFi driver for Linux
[ 14.068612] Copyright(c) 2003- 2015 Intel Corporation
[ 14.192152] iwlwifi 0000:03:00.0: loaded firmware version 29.1044073957.0 op_mode iwlmvm
[ 14.354654] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
[ 14.373008] iwlwifi 0000:03:00.0: base HW address: 7c:76:35:01:b9:31
[ 14.456780] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 14.457085] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 14.457102] thermal thermal_zone2: failed to read out thermal zone (-5)
[ 14.601961] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 14.601964] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 14.766628] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
[ 14.936337] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input9
[ 14.940047] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC3227: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 14.940049] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 14.940051] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 14.940052] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 14.940053] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 14.940055] snd_hda_codec_realtek hdaudioC1D0: Mic=0x19
[ 14.940056] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 14.954834] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:09.2/sound/card1/input10
[ 14.954887] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:09.2/sound/card1/input11
[ 15.406516] AVX2 version of gcm_enc/dec engaged.
[ 15.406519] AES CTR mode by8 optimization enabled
[ 15.546264] media: Linux media interface: v0.10
[ 15.546555] input: HP WMI hotkeys as /devices/virtual/input/input8
[ 15.752141] Linux video capture interface: v2.00
[ 15.971536] Bluetooth: Core ver 2.22
[ 15.971553] NET: Registered protocol family 31
[ 15.971554] Bluetooth: HCI device and connection manager initialized
[ 15.971557] Bluetooth: HCI socket layer initialized
[ 15.971561] Bluetooth: L2CAP socket layer initialized
[ 15.971567] Bluetooth: SCO socket layer initialized
[ 15.972560] input: G2Touch Multi-Touch by G2TSP as /devices/pci0000:00/0000:00:12.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:2A94:5009.0001/input/input12
[ 15.973429] hid-multitouch 0003:2A94:5009.0001: input,hidraw1: USB HID v1.11 Device [G2Touch Multi-Touch by G2TSP] on usb-0000:00:12.0-1.3/input0
[ 16.060919] usbcore: registered new interface driver btusb
[ 16.070939] Bluetooth: hci0: read Intel version: 370810225019140f00
[ 16.220857] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq
[ 16.263708] uvcvideo: Found UVC 1.00 device HP TrueVision HD Camera (04f2:b5d5)
[ 16.266902] uvcvideo 2-1:1.0: Entity type for entity Extension 4 was not initialized!
[ 16.266905] uvcvideo 2-1:1.0: Entity type for entity Processing 2 was not initialized!
[ 16.266906] uvcvideo 2-1:1.0: Entity type for entity Camera 1 was not initialized!
[ 16.266978] input: HP TrueVision HD Camera: HP Tru as /devices/pci0000:00/0000:00:10.0/usb2/2-1/2-1:1.0/input/input13
[ 16.267042] usbcore: registered new interface driver uvcvideo
[ 16.267043] USB Video Class driver (1.1.1)
[ 16.306385] kvm: disabled by bios
[ 16.344914] kvm: disabled by bios
[ 16.442117] MCE: In-kernel MCE decoding enabled.
[ 16.475910] Bluetooth: hci0: Intel Bluetooth firmware patch completed and activated
[ 16.697573] Adding 7885820k swap on /dev/sda8. Priority:-1 extents:1 across:7885820k FS
[ 16.757449] iwlwifi 0000:03:00.0 wlo1: renamed from wlan0
[ 17.799603] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
[ 20.251448] audit: type=1400 audit(1527897796.538:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=798 comm="apparmor_parser"
[ 20.252065] audit: type=1400 audit(1527897796.539:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=798 comm="apparmor_parser"
[ 20.252413] audit: type=1400 audit(1527897796.539:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=798 comm="apparmor_parser"
[ 20.252811] audit: type=1400 audit(1527897796.539:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=798 comm="apparmor_parser"
[ 20.290379] audit: type=1400 audit(1527897796.577:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=799 comm="apparmor_parser"
[ 20.291077] audit: type=1400 audit(1527897796.578:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=799 comm="apparmor_parser"
[ 20.363438] audit: type=1400 audit(1527897796.650:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=803 comm="apparmor_parser"
[ 20.411555] audit: type=1400 audit(1527897796.698:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=807 comm="apparmor_parser"
[ 20.555558] audit: type=1400 audit(1527897796.842:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ntpd" pid=809 comm="apparmor_parser"
[ 20.607680] audit: type=1400 audit(1527897796.894:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=805 comm="apparmor_parser"
[ 21.042413] new mount options do not match the existing superblock, will be ignored
[ 21.839183] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.839185] Bluetooth: BNEP filters: protocol multicast
[ 21.839189] Bluetooth: BNEP socket layer initialized
[ 22.752131] amdgpu: [powerplay] pp_dpm_get_temperature was not implemented.
[ 22.752143] amdgpu: [powerplay] pp_dpm_get_temperature was not implemented.
[ 26.339351] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 26.405283] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 26.414193] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 26.531205] r8169 0000:02:00.0 enp2s0: link down
[ 26.531300] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 26.835779] amdgpu: [powerplay] min_core_set_clock not set
[ 26.875901] amdgpu: [powerplay] min_core_set_clock not set
[ 26.886211] amdgpu: [powerplay] min_core_set_clock not set
[ 27.823573] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 28.605533] amdgpu: [powerplay] min_core_set_clock not set
[ 29.606950] amdgpu: [powerplay] min_core_set_clock not set
[ 39.696005] amdgpu: [powerplay] min_core_set_clock not set
[ 61.798644] wlo1: authenticate with c4:12:f5:75:94:74
[ 61.801874] wlo1: send auth to c4:12:f5:75:94:74 (try 1/3)
[ 61.804132] wlo1: authenticated
[ 61.804791] wlo1: associate with c4:12:f5:75:94:74 (try 1/3)
[ 61.809208] wlo1: RX AssocResp from c4:12:f5:75:94:74 (capab=0x431 status=0 aid=8)
[ 61.812334] wlo1: associated
[ 61.812385] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 67.978905] Bluetooth: RFCOMM TTY layer initialized
[ 67.978915] Bluetooth: RFCOMM socket layer initialized
[ 67.978925] Bluetooth: RFCOMM ver 1.11
camylle@jarvis ~ $ ^C
camylle@jarvis ~ $
