Résolu le 28-12-18 (RÉSOLUT)le téléchargement des informations du dépôt a échoué
jacques325i
Message par jacques325i »
bonjour a tous.
j'ai un souci avec les mise a jours, pendant la mise a jour du cache, une fenêtre s'ouvre " le téléchargement des informations du dépôt a échoué". dans détails j'obtiens ça.
E:The repository 'https://dl.winehq.org/wine-builds/ubuntu/sudo bionic Release' does not have a Release file.,
W:Updating from such a repository can't be done securely, and is therefore disabled by default.,
W:See apt-secure(8) manpage for repository creation and user configuration details.,
W:Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3,
W:Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3,
W:Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3,
W:Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3,
W:Target Translations (main/i18n/Translation-fr) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3,
W:Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3,
W:Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3,
W:Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3,
W:Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3
je ne suis pas super doués avec linux donc merci de votre compréhension.
Modifié en dernier par jacques325i le mer. 15 août 2018 13:22, modifié 3 fois.
Asus X53S 8g RAM, SSD Crucial CT250MX, NVIDIA Geforce 610M-2GB, Linux Mint 19 Cinnamon Version 3.8.8 Noyau Linux 4.15.0-30, Intel Core i5-2450M
Re: problème mise a jour
'Jour,
tout d'abord, tu devrais créer une signature en suivant ça => https://forum-francophone-linuxmint.fr/ ... f=2&t=1514" onclick="window.open(this.href);return false; , c'est plus pratique pour aider
Pour ton souci, à priori, c'est ton fichier sources.list qui pose problème. t'as des entrées multiples et donc il se mélange les pinceaux....
Attends un docteur en linux, j'ai pas sous la main la manip pour t'aider ;)
jacques325i
merci thyam, je patiente!
jacques325i
pour la signature j'espère que j'ai bon?
Re, yes ;)
jacques325i
c'est deja ça! :D
david37
Message par david37 »
Salut jacques,
Petite préconisation de présentation quand tu donnes les retours d'un terminal, il est conseillé de le coller dans le message entre les balises "code", c'est plus simple et plus facile à suivre ;)
Et si possible, espacé les lignes, parce que là ça te fait un pavé :-o qui peut en rebuter plus d'un pour pouvoir venir t'aider :?
Je t'arrange ça pour cette fois mais penses y à l'avenir ;)
EDIT: Il semble que ça soit un peu le broll dans ton fichier listant la liste des sources de dépôt de logiciels. Afin que l'on puisse voir cette liste et voir où ça coince, pourrais tu ouvrir un terminal et nous donner le retour de:
cat /etc/apt/sources.list
et de
cat /etc/apt/sources/additional.repositories.list
EDIT2: Je viens de me rendre compte que ton souci ne concerne pas l'environnement de bureau Cinnamon, donc je déplace dans "Générale" ;)
jacques325i a écrit :le téléchargement des informations du dépôt a échoué
Ca ferai un bon titre :mrgreen: ;)
jacques325i
merci, je vais essayer de faire mieux.
jacques@jacques-K53SD:~$ cat /etc/apt/sources.list
#deb cdrom:[Linux Mint 19 _Tara_ - Release amd64 20180626]/ bionic contrib main non-free
jacques@jacques-K53SD:~$ cat /etc/apt/sources/additional.repositories.list
cat: /etc/apt/sources/additional.repositories.list: Aucun fichier ou dossier de ce type
voila j'espère ne pas m'être trompé.
jacques325i
oui mais j'y ai pas pensé :?
